NT-53F0-0428
NT-53F0-0428
    LIGHTINGSCIENCE
    LIGHT ENGINE TITAN RED/GRN/BLUE
NT-53F0-0428 数据手册
June 5, 2013 Customer Name Customer Address City State Zip Dear Customer, In order to focus on our core products, Lighting Science Group Corporation (LSGC) has made the decision to discontinue our Lamina line. The Lamina product numbers are listed on the attached and discontinued effective immediately. We will be clearing our inventory of this product line and will make every effort to fill open orders as quickly as possible. We thank you for your business over the years and look forward to working with you on other lighting projects through our standard Lighting Science Group product portfolio. If you have questions regarding the discontinuation of Lamina or open orders, please contact us by email at orders@lsgc.com or call our toll free number 877-999-5742. Best regards, Kevin Beber Vice President, Sales Operations Lighting Science Group Corporation 1 LSGC Lamina Products Discontinued Effective June 5, 2013 Inventory Available for the following items: Item number NT2-42D1-0529 NT-41A0-0482 NT-41E0-0483 NT-42B1-0484 NT-42C1-0485 NT-42D0-0426 NT-42D1-0425 NT-42D3-0458 NT-43F0-0424 NT-44D1-0534 NT-45D0-0447 NT-45D1-0446 NT-49A0-0520 NT-49S0-0490 NT-49S2-0495 NT-50WH-0427 NT-51A0-0468 NT-51E0-0481 NT-52B1-0469 NT-52C1-0470 NT-52D0-0429 NT-52D1-0430 NT-53F0-0428 NT-54D0-0487 NT-54D1-0486 NT-54D2-0509 Item name Assembly Light Engine Atlas II Warm White Light Engine Atlas Red Light Engine Atlas Amber Light Engine Atlas Blue Light Engine Atlas Green Light Engine Atlas 4700K Daylight White (LC) Light Engine Atlas 3050K Warm White (LC) Light Engine Atlas 7000K Cool White Assembly Light Engine Atlas RGB Light Engine Atlas II Warm White Light Engine Atlas 4700K Daylight White w/60° built-in optic Light Engine Atlas 3050K Warm White w/60° built-in optic Light Engine Altas MR16 SoL Red Light Engine Atlas MR16 SoL daylight white Light Engine Atlas MR16 SoL warm white Wire Harness NT-5000 Product Line Light Engine Titan Red Light Engine Titan Amber 584-594 nm 18 die Light Engine Titan Blue Light Engine Titan Green Assembly Light Engine Titan Daylight White 4700K Assembly Light Engine Titan Warm White Light Engine Titan RGB Light Engine Titan Turbo Daylight White 4700K Light Engine Titan Turbo Warm White 3050K Light Engine Titan Turbo TruColor 3050K OP-4FM1-0442 OP-4FW1-0441 OP-4LN1-0457 OP-4LN2-0492 OP-5LM3-0455 OP-5LM3-0536 OP-5LN1-0451 OP-5LN1-0499 Optic secondary NT-4000 Fraen medium angle 30° Optic secondary NT-4000 Fraen wide angle 45° Optic Secondary narrow beam optic RGB NT-4000 Optic Secondary narrow beam optic White NT-4000 30° Optic NT-5000 Packaged Assembly with installation instructions 30° Compact Optic Titan Pkgd. Asm. with installation instructions Titan White 10° Optic Packed Assembly with installation instructions Titan 10° RGB Narrow Mixing Optic Packed assembly with instructions 2 Item Number OP-5LN2-0445 OP-5LW4-0456 Item Name 20° Optic NT-5000 Packaged Assembly with installation instructions 45° Optic NT-5000 Packaged Assembly with installation instructions EZ-4000-0357 EZ-42B1-0589 EZ-42D0-0433 EZ-42D1-0556 EZ-43F0-0431 EZ-46WH-0354 Application PCB with connector BL-4000/NT-4000 series Assembly Light Source with NT-42B1-0484 Assembly Light Source 4700 K NT- Daylight White Assembly Light Source with NT-44D1-0534 Atlas II Assembly Light Source NT-RGB Wire Harness EZ Connect for BL-4000 (6 wire) HS-4075-0345 HS-4100-0345 HS-4150-0345 HS-5100-0346 HS-5200-0493 HS-5410-0537 HS-5430-0537 HS-543R-0537 Heatsink BL-2000/BL-4000/NT-4000 black anodized 0.75" thk Heatsink BL-2000/BL-4000/NT-4000 black anodized 1.0" thk Heatsink BL-2000/BL-4000/NT-4000 black anodized 1.50" thk Heatsink BL-3000 black anodized 1.0" thk Heatsink Titan 3.94 dia x 2.36 Thick Black Titan Turbo Heatsink Black 5.91 diameter 1.18 thick no cb Titan Turbo Heatsink Black 5.91 diameter 2.95 thick no cb Titan Turbo Heatsink Black 5.91 diameter 2.95 thick 1.89 cb 800-0488 800-0491 800-0494 800-0508 800-0523 800-0528 800-0545 800-0610 800-0612 800-0613 800-0614 Light Engine Mod NT-53FX Special blue & green wavelength Assembly Light Engine SoL D1 (TruColor) Assembly Light Engine Mod NT-4 8000K Cool White Light Engine Mod NT-53F0 RGB Lambertion Beam Assembly Light Engine RL-16E0-XXXX Amber Assembly Light Engine Mod NT-43 RGB 7 die 2R3G2B Assembly Light engine Mod NT-42D0 with low profile glass lens Light Engine Atlas special Blue 6 die (SPA) Light Engine Titan Special RGB 6 die each color Unencapsulated Atlas Light Engine Atlas special 3000K Warm White 6 die 3 No Inventory Available for the following items: Item number 800-0497 800-0500 800-0557 Item name Assembly Light Engine Mod NT-4 RGB spec blue & green die Assembly Light Engine Mod NT-4 RGB lambertion beam Optic OP-5LN1-0499 non-assembled OP-4FM1-0442 OP-4FW1-0441 OP-4LN1-0457 OP-4LN2-0492 OP-5LM3-0455 OP-5LM3-0536 OP-5LN1-0451 OP-5LN1-0499 OP-5LN2-0445 OP-5LW4-0456 Optic secondary NT-4000 Fraen medium angle 30° Optic secondary NT-4000 Fraen wide angle 45° Optic Secondary narrow beam optic RGB NT-4000 Optic Secondary narrow beam optic White NT-4000 30° Optic NT-5000 Packaged Assembly with installation instructions 30° Compact Optic Titan Pkgd. Asm. with installation instructions Titan White 10° Optic Packed Assembly with installation instructions Titan 10° RGB Narrow Mixing Optic Packed assembly with instructions 20° Optic NT-5000 Packaged Assembly with installation instructions 45° Optic NT-5000 Packaged Assembly with installation instructions 4
NT-53F0-0428 价格&库存
很抱歉,暂时无法提供与“NT-53F0-0428”相匹配的价格&库存,您可以联系我们找货
