PT-39-G-C21-MPC
PT-39-G-C21-MPC
    LUMINUS(朗明纳斯)
    Module
    BIG CHIP LED HB MODULE GREEN
PT-39-G-C21-MPC 数据手册
PT39 Product Datasheet PT39 LEDs Features: • Matched RGB Chipset with 3.9 mm2 emitting area designed for LED projector applications Table of Contents Technology Overview. . . . . . 2 • Photonic lattice technology for very high surface brightness and uniform surface emission Understanding Big Chip Test Specifications. . . . . . . . . . . . . . 2 • Wide color gamut: RED 623 nm, Red-Amber 615nm, GREEN 526 nm, Blue 460nm typical dominant wavelength Ordering Information . . . . . . 3 • Single emitting area per color allows for collection with single lens for simplified optics Flux /Power Bin Definition. . 4 Optical & Electrical Characteristics. . . . . . . . . . . 5- 6 Blue Flux Bin Ranges by Wavelength . . . . . . . . . . . . . . . 7 • Aspect ratio optimized and compatible with micro-display diagonal sizes ranging from 0.45” to 0.55” with 4:3 aspect ratio. • Thermally efficient Common Anode copper-core PCB package • RoHS (EU-2002/95/EC Directive) and REACH compliant Parametric Graphs . . . . . . . 8-9 Thermal Resistance . . . . . . . 10 Mechanical Dimensions.11-12 Shipping Tray Outline . . . . . 13 Packing and Shipping Specifications . . . . . . . . . . . . 14 Applications History of Changes. . . . . . . . 15 • Specifically engineered for high brightness pocket-size, ultra portable front projectors, head-up projection displays and hybrid projectors • Optimized for Micro-Display diagonal sizes ranging from 0.45” to 0.55”. • Suitable for DLP™ ( 0.45” WXGA, 0.55” SVGA), LCoS and HTPS /3LCD microdisplays 1 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Technology Overview Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and system designers to achieve solutions that are high brightness and high efficiency. Photonic Lattice Technology Reliability Luminus’ photonic lattice technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. For high power operation, Luminus Big Chip LEDs are one of the most reliable light sources in the world today. Big Chip LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus Big Chip LEDs are ready for even the most demanding applications. (Please refer to Luminus’ Reliability application note for more information.) For red, green and blue LEDs, the photonic lattice structures extract more light and create radiation patterns that are more collimated than traditional LEDs. (Having higher collimation from the source increases optical collection efficiencies and simplifies optical designs.) Environmental Benefits Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 1.6º C/W, Luminus PT39 LEDs can be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All Big Chip LED products manufactured by Luminus are RoHS and REACH compliant and free of hazardous materials, including lead and mercury. Understanding Big Chip LED Test Specifications Every Luminus LED is extensively tested at full current to ensure that it meets the high quality standards expected from Luminus’ products. Testing of Big Chip LEDs Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus Big Chip LEDs perform in the field just as they are specified. Luminus surface mount LEDs are typically tested with a 20mSec input pulse and a junction temperature of 25ºC. Expected flux values in real world operation can be extrapolated based on the information contained within this product data sheet. 2 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Ordering Information Ordering Part Number 1 Color PT-39-R-C21-MPB Min Flux or Power Bin 2 2B1 PT-39-R-C21-MPC Red 2B2 PT-39-R-C21-MPD 2C PT-39-RA-C21-MPE Red Amber PT-39-RA-C21-MPF 2D 2E PT-39-G-C21-MPC Description Red LED, consisting of a 3.9 mm2 Red LED chip, thermistor and connector mounted on a copper-core PCB. Red-Amber LED, consisting of a 3.9 mm2 Red-Amber LED chip, thermistor and connector mounted on a copper-core PCB. 2C PT-39-G-C21-MPD Green PT-39-G-C21-MPE 2D 2E PT-39-G-C21-MPF 2F PT-39-B-C21-EPA 2D PT-39-B-C21-EPB Blue 2E PT-39-B-C21-EPC 2F Green LED, consisting of a 3.9 mm2 Green LED chip, thermistor and connector mounted on a copper-core PCB. Blue LED, consisting of a 3.9 mm2 Blue LED chip, thermistor and connector mounted on a copper-core PCB. Note 1: Ordering part numbers represent bin kits (group of bins that are shippable for a given ordering part number) Note 2: See Bin Kit and Flux / Power bin definitions on page 4 Ordering Part Number Nomenclature XXX Product Family PT: Metal Coreboard PCB 00 XXXX X00 Chip Area Color Package Configuration 39: 3.9 mm2 R= Red (623nm, typ) RA= Red -Amber (615nm, typ) G= Green B= Blue C21: 26.5mm x 16.0 mm (standard) C22: 26.5mm x 16.0 mm (die rotated) See Mechanical Drawing section XXX Bin Kit 1 See page 4 for bin kit definition Note 1: A Bin Kit represents a group of individual flux or power bins that are shippable for a given ordering part number. Individual flux bins are not orderable. EXAMPLES: PT-39-R-C21-MPD i s comprised of Red-Amber Flux Bins 2C, 2D, 2E, 2F, 2G. PT-39-R-C22-MPD is comprised of Red Flux Bins 2C, 2D, 2E, 2F, 2G (Die rotated package configuration). 3 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet PT39 Bin Kit1 and Flux Bin2,3 ,4 Definitions Note: Please refer to ordering part number table on page 3 for Bin Kit availability Red Flux Bins Bin 2B1 Bin 2B2 Bin 2B3 Bin 2C Bin 2D Bin 2E Bin 2F Bin 2G Bin 2H Red Bin Flux Range (lm) 455-475 475-490 490-530 530-580 580-635 635-690 690-745 745-800 800-860 þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-39-R-C21-MPB PT-39-R-C21-MPC PT-39-R-C21-MPD Red -Amber Flux Bins Bin 2D Bin 2E Bin 2F Bin 2G Bin 2H Bin 2J Bin 2K Bin 2L Bin 2M Red -Amber Bin Flux Range (lm) 580-635 635-690 690-745 745-800 800-860 860-925 925-990 990-1055 1055 -1125 þ þ þ þ þ þ þ þ þ þ PT-39-RA-C21-MPE PT-39-RA-C21-MPF Green Flux Bins Bin 2C Bin 2D Bin 2E Bin 2F Bin 2G Bin 2H Bin 2J Bin 2K Bin 2L 2M Green Bin Flux Range (lm) 1030 -1100 1100 1200 1200 -1250 1250 -1330 1330 -1450 1450 -1550 1550 -1660 1660 -1780 1780 -1900 1900 -2020 þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-39-G-C21-MPC PT-39-G-C21-MPD PT-39-G-C21-MPE PT-39-G-C21-MPF Blue Power Bins Bin 2D Bin 2E Bin 2F Bin 2G Bin 2H Bin 2J Bin 2K Bin 2L Bin 2M Blue Bin Flux Range (lm) 190-215 215-235 235-255 255-280 280-300 300-320 320-345 345-370 370-400 þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-39-B-C21-EPA PT-39-B-C21-EPB PT-39-B-C21-EPC þ Note 1: Bin Kits are defined by a group of flux or power bins. Only one flux bin will be shipped in each individual pack. A shipment will contain packs of different allowed flux bins for a particular ordering part number. Individual Flux or Power bins are not ordereable. Note 2: PT39 LEDs are tested for luminous flux at 9.8A at 25% duty cycle for Red, Red-Amber and Blue. and at 50% duty cycle for Green Devices. Devices are sorted and packed by flux bin. Not all flux bins are are currrently populated. Note 3: Luminus maintains a test measurement accuracy for LED flux and power of +/- 6%. Note 4: Blue Flux bin limits are defined at reference dominant wavelength of 462nm. See table on page 7 for Blue bin limits at other dominant wavelengths. 4 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Optical & Electrical Characteristics Symbol Red Red -Amber Green Blue Unit Emitting Area x 3.9 3.9 3.9 3.9 mm2 Emitting Area Dimensions x 2.09 x 1.87 2.09 x 1.87 2.09 x 1.87 2.09 x 1.87 mmxmm 25 25 50 25 % General Characteristics Preliminary Characteristics at Recommended Test Drive Current , If 1, 2 Reference Duty Cycle 3 Test Peak Drive Current typ IF 9.8 9.8 9.8 9.8 A Peak Luminuous Flux 1,2,5 typ Φv 575 750 1400 235 lm Peak Radiometric Flux 1,2 typ Φr 3.2 3.1 2.9 5.0 W min λdmin 619 611 516 450 nm typ λd 623 615 525 460 nm max λdmax 630 622 535 468 nm 19 19 34 20 nm 1,2,4 Dominant Wavelength FWHM- Spectral bandwidth at 50% of Φv typ typ x 0.698 0.680 0.167 0.147 typ y 0.302 0.320 0.704 0.033 min VF min 2.2 2.2 3.5 3.2 V typ VF 2.6 2.6 4.9 3.9 V max VF max 3.2 3.2 5.9 5.2 V typ 0.05 0.05 0.08 0.05 Ω Thermal Coefficient of Photometric Flux typ -1.0 tbd -0.2 ~0 % / oC Thermal Coefficient of Radiometric Flux typ -0.6 tbd -0.2 -0.2 % / oC Forward Voltage Temperature Coefficient typ -1.5 tbd -1.0 -3 mV/ oC Chromaticity Coordinates 6,7 Forward Voltage Dynamic Resistance Device Thermal Characteristics Characteristics at Reference Continuous Drive Current IF (continuous wave)1 Reference Drive Current typ IF 5.9 5.9 5.9 5.9 A Luminous Flux typ Φv 320 420 1000 175 lm Radiometric Flux typ Φr 1.8 1.7 1.9 3.3 W Dominant Wavelength typ λd 624 616 528 462 nm FWHM -Spectral bandwidth at 50% of Φv typ 18 18 36 21 nm Chromaticity Coordinates 6,7 Forward Voltage typ x 0.700 0.682 0.171 0.145 nm typ y 0.300 0.318 0.702 0.036 nm typ VF 2.3 2.3 4.4 3.4 V 5 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Optical & Electrical Characteristics Note 1: All ratings are based on testing conditions with a constant heat sink temperature Ths = 40ºC. See Thermal Resistance section for Ths definition. Note 2: Parameters rated at test duty cycle and Pulsed operation frequency f>240Hz; t DC = --T t T Note 3: Duty Cycle used to specify device ratings under Pulsed operation. Big Chip LED devices can operate at duty cycles ranging from 1% to 100%. At higher duty cycles, drive current should be adjusted to maintain the junction temperature at desired levels to meet the application lifetime requirements. Note 4: In pulsed operation, rise time from 10 to 90% of forward current should be larger than 0.5 microseconds Note 5: For Blue devices, total flux from emitting area at typical dominant wavelength. Refer to page 7 for brightness specifications at other wavelength Note 6: In CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1 Note 7: For Reference only Absolute Maximum Ratings Symbol Red Red -Amber Green Blue Unit Minimum Current (CW or Pulsed) 200 200 200 200 mA Maximum Current (CW) 9.8 9.8 9.8 9.8 A 12 12 12 12 A 110 110 170 170 o -40 / +100 -40 / +100 -40 / +100 -40 / +100 o 1 2 Maximum Current (Pulsed) (t 240Hz, duty cycle 240Hz, duty cycle < 60%). Please refer to absolute maximum rating table above for specific absolute maximum currents for the products covered in this datasheet. Product lifetime data is specified at recommended forward drive currents. Sustained operation at absolute maximum currents will result in a reduction of device lifetime compared to recommended forward drive currents. Actual device lifetimes will also depend on junction termperature (see note 2 below). Refer to lifetime derating curves for further information. Note 2: Sustained operation at or above Maximum Operating Junction Temperature (Tjmax) will result in reduced device life time. 6 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Blue Bin Flux Ranges by Dominant Wavelength 1,2 Bin 2D Bin 2E Bin 2F Bin 2G Bin2H Bin 2J Bin 2K Bin 2L DWL (nm) Min (lm) Max (lm) Min (lm) Max (lm) Min (lm) Max (lm) Min (lm) Max (lm) Min (lm) Max (lm) Min (lm) Max (lm) Min (lm) Max (lm) Min (lm) Max (lm) 450 93 105 105 115 115 125 125 137 137 147 147 156 156 169 169 181 451 101 114 114 125 125 136 136 149 149 159 159 170 170 183 183 197 452 109 123 123 135 135 146 146 161 161 172 172 184 184 198 198 212 453 117 133 133 145 145 157 157 173 173 185 185 197 197 213 213 228 439 125 142 142 155 155 168 168 185 185 198 198 211 211 227 227 244 455 133 151 151 165 165 179 179 197 197 211 211 225 225 242 242 260 456 141 160 160 175 175 190 190 208 208 223 223 238 238 257 257 275 457 150 169 169 185 185 201 201 220 220 236 236 252 252 272 272 291 458 158 178 178 195 195 212 212 232 232 249 249 265 265 286 286 307 459 166 188 188 205 205 222 222 244 244 262 262 279 279 301 301 323 460 174 197 197 215 215 233 233 256 256 274 274 293 293 316 316 338 461 182 206 206 225 225 244 244 268 268 287 287 306 306 330 330 354 462 190 215 215 235 235 255 255 280 280 300 300 320 320 345 345 370 463 198 224 224 245 245 266 266 292 292 313 313 334 334 360 360 386 464 206 233 233 255 255 277 277 304 304 326 326 347 347 374 374 402 465 214 242 242 265 265 288 288 316 316 338 338 361 361 389 389 417 466 222 252 252 275 275 298 298 328 328 351 351 375 375 404 404 433 467 230 261 261 285 285 309 309 340 340 364 364 388 388 418 418 449 468 239 270 270 295 295 320 320 352 352 377 377 402 402 433 433 465 Note 1: Flux Min, Max values are continuous as function of dominant wavelength values. For illustration purposes, flux Min and Max values are provided at discrete dominant wavelength values. Note 2: Luminus maintains a test measurement accuracy for LED flux and power of +/- 6%. 7 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet 800 700 600 500 400 300 200 100 0 1600 300 1400 250 1200 200 Фv (lm) Фv (lm) Фv (lm) Luminous Flux variation with Wavelength: Φv = f (λd) at Test Drive Current IF = 9.8 A 1000 150 800 100 600 50 400 615 620 625 λd (nm) 515 630 520 525 530 λd (nm) 535 0 456 458 460 462 464 466 468 470 λd (nm) See notes 1,2, 3 on page 9. See note 4 on page 9 regarding Red-Amber. 1800 300 1600 Red-Amber 250 1400 Red 200 1200 Фv (lm) 800 700 600 500 400 300 200 100 0 Фv (lm) Фv (lm) Luminous Flux variation with Forward Current: Φv = f(IF) 1000 150 800 100 600 2 4 6 8 IF (A) 10 50 400 12 2 4 6 8 IF (A) 10 2 12 4 6 8 10 8 IF (A) 10 IF (A) 12 See notes 1,2, 3 on page 9. Dominant Wavelength variation with Forward Current - λd = f(IF) - Typical 626 λd (nm) λd (nm) 628 624 622 620 2 4 6 8 IF (A) 10 12 540 538 536 534 532 530 528 526 524 522 λd (nm) 630 2 4 6 8 IF (A) 10 12 461 460.8 460.6 460.4 460.2 460 459.8 459.6 459.4 2 4 6 12 See notes 1,2, 3 on page 9. See note 4 on page 9 regarding Red-Amber. 8 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Forward Voltage variation with Drive current - VF = f(IF) - Typical 3 4 3.5 1.5 1 VF (V) 4 2 VF (V) VF (V) 4.5 5 2.5 3 4 6 8 10 12 IF (A) 0 2 1.5 1 0.5 1 2 3 2.5 2 0.5 0 5 6 3.5 0 2 4 6 8 10 2 4 12 6 8 10 12 IF (A) IF (A) See notes 1,2, 3 on page 9 Optical Spectrum (Typical) Relative Intensity (a.u.) 1.2 1.0 0.8 0.6 0.4 0.2 0.0 400 450 500 550 600 Wavelength (nm) Red Green 650 700 Blue See notes 1,2, 4 on page 9 Note 1: For Pulsed operation, the reference RGB duty cycles used are 25%, 50% and 25% respectively (Ths=40oC). Note 2: Yellow square indicate device operating point under reference conditions listed in the Optical and Electrical Characteristics table. Note 3: Parametric graphs for Red-Amber are TBD. These will be added as they become available. Note 4: Typical spectrum at recommended peak drive current . 9 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Thermal Resistance Typical Thermal Resistance Window Tj Die Junction Tb Window Frame Thermistor Tref Ths Copper Core-Board Thermal Interface Material Rθj-b1 1.6 ºC/W Rθb-hs2 0.2 ºC/W Rθj-hs 1,2 1.8 ºC/W Rθj-ref2 1.6 ºC/W Heat Sink Ta Note 1: Thermal resistance values are based on FEA model results correlated to measured Rθj-hs data. Ths definition = 3 mm from core-board Note 2: Thermal Resistance is based on eGraf 1205 Thermal interface. Thermistor Information The thermistor used in PT39 devices are mounted on coreboards is from Murata Manufacturing Co. The global part number is NCP15XH103J03RC. Please see http://www.murata.com/ for details on calculating thermistor temperature. For more information on use of the thermistor, please contact Luminus directly. 10 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Electrical Pinout 1 2 3 4 5 6 7 8 Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Mechanical Dimensions -Standard Die Configuration ',0(16,216,10,//,0(7(56 5(''(9,&( “    (0,77,1* $5($ 3,1  (0,77,1* $5($ %/8('(9,&( $ $  “ [  $/,*10(17+2/(6  [ “ )$67(1(5+2/(6 *5((1'(9,&( %    3,1     6(&7,21$$ )81&7,21 7+(50,6725  7+(50,6725  32:(5  32:(5  $ % & '(7$,/% ',0(16,21 1$0( '(6&5,37,21 120,1$/ ',0(16,21 $ 7232)0(7$/68%675$7(727232)*/$66   % (0,77,1*$5($727232)*/$66   & 7232)0(7$/68%675$7(72(0,77,1*$5($   72/(5$1&( ':* Notes: 1) Red, Green and Blue PT39 Big Chip LEDs are individually assembled into a common anode copper core- board with a footprint of 26.5 mm x 16 mm. 2) Dimensions above are for information only. Please refer to the latest revision of the DWG- 001703 package outline mechanical specifications. (For legacy coreboard with interconnect clip, please see DWG-001263) 3) Connector- MOLEX Part Number: 874380843 or Global Part Number: WTB16-081SF. Please refer to DWG-001703 for pin-out information 11 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT39 Product Datasheet Mechanical Dimensions –Rotated Die Configuration ',0(16,216,10,//,0(7(56 5(''(9,&( “ 3,1   (0,77,1* $5($    (0,77,1* $5($ %/8('(9,&( $ $  “ [  $/,*10(17+2/(6  *5((1'(9,&( [ “ )$67(1(5+2/(6 %    3,1     6(&7,21$$ )81&7,21 7+(50,6725  7+(50,6725  32:(5  32:(5  $ % & '(7$,/% ',0(16,21 1$0( '(6&5,37,21 120,1$/ ',0(16,21 $ 7232)0(7$/68%675$7(727232)*/$66   % (0,77,1*$5($727232)*/$66   & 7232)0(7$/68%675$7(72(0,77,1*$5($   72/(5$1&( ':* Notes: 1) Red, Green and Blue PT39 Big Chip LEDs are individually assembled into a common anode copper core- board with a footprint of 26.5 mm x 16 mm. 2) Dimensions above are for information only. Refer to the latest revision of the DWG- 001705, package outline mechanical specifications (For legacy coreboard with interconnect clip, please see DWG-001471) 3) Connector- MOLEX Part Number: 874380843 or Global Part Number: WTB16-081SF. Please refer to DWG-001705 for pin-out information 12 PDS-001338 Rev08 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT-39 Product Datasheet Shipping Tray Outline ',0(16,216,10,//,0(7(56       $ $    3,7&+ ƒ 7
PT-39-G-C21-MPC 价格&库存
很抱歉,暂时无法提供与“PT-39-G-C21-MPC”相匹配的价格&库存,您可以联系我们找货
