PT-120-RA-C11-MPF
PT-120-RA-C11-MPF
    LUMINUS(朗明纳斯)
    Module
    BIG CHIP LED HB MODULE RED
PT-120-RA-C11-MPF 数据手册
SUMMARY DATA SHEET PhlatLight™ PT120 Projection Chipset Technology Overview Features Luminus Devices’ Projection Technology is an innovative solidstate light source created to replace arc lamps in projection systems. Enabled by unique use of Photonic Lattice technology, PhlatLight chipsets represent a major breakthrough in brightness that delivers all the benefits of solid state light sources in projections applications: • Matched RGB Chipset with 12mm2 emitting area designed for - Wide color gamut for vivid colors, exceeds NTSC. - Instant turn-on, no more wait time. • Photonic lattice technology for very high surface brightness • 100% surface emission for high collection efficiency and low optical losses • Wide color gamut: RED 623 nm, GREEN 525 nm, BLUE 462 nm, EP Blue 460nm typical dominant wavelength • Single emitting area per color allows for collection with sin- - High Reliability; no lamp replacement gle lens for simplified optics - Environmentally friendly technology - Mercury-free. - Electronic control of color points and light intensity on a frame by frame basis PhlatLight products benefit from numerous innovations in the domain of packaging, thermal management and optical coupling that allow designers to achieve efficient light engine designs and deliver high screen brightness. Angular Intensity Distribution- Example • 16:9 aspect ratio matched with micro-display and screen aspect ratio • Thermally efficient Type CX Common Anode package • RoHS (lead-free) compliant Applications • Specifically engineered for Rear-Projection Displays, front projectors, head-up projection displays • Optimized for Micro-Display diagonal sizes ranging from 1.2 GR EEN , B LU E 0.65” to 0.95” with 16:9 aspect ratio. R ED Optical Power (Arbitrary Unit) projection applications 1.0 • Suitable for DLP™ (e.g. xHD5, 0.65”, 0.95” 1080p), LCoS, HTPS and 3LCD microdisplays 0.8 0.6 0.4 0.2 0.0 -100 -80 -60 -40 -20 0 20 40 60 80 100 Angle (degrees) © 2010 Luminus Devices, Inc. - All Rights Reserved Updated 3/1/10 PDS-001022 Rev 07 PT120 Summary Datasheet - Revision 07 Optical and Electrical Characteristics Symbol Red Green Blue EP-Blue1 Unit Preliminary Bin Kit Emitting Area Emitting Area Dimensions MPB MPB MPB EPA 11.96 11.96 11.96 11.96 mm2 4.6x2.6 4.6x2.6 4.6x2.6 4.6x2.6 mmxmm 25 50 25 25 % Characteristics at recommended Pulsed Drive Current IF2,3 Reference Duty Cycle4 Recommended Peak Drive Current 5 typ IF 30 30 30 30 A Peak Luminous Flux6 typ Φv 1800 3500 600 750 lm Peak Radiometric Power typ Φr 10.4 7.3 12.1 16.3 W λdmin 619 516 455 450 nm λd 623 525 462 460 nm λdmax 630 535 469 468 nm Δλd 19 39 20 20 nm 1.00 0.79 0.99 0.99 Dominant Wavelength typ FWHM - Spectral bandwidth at 50% of Φv typ Color Saturation7,8 typ Chromaticity Coordinates7,8 Forward Voltage Dynamic Resistance typ x 0.697 0.171 0.144 0.154 typ y 0.303 0.702 0.040 0.024 min VFmin 2.2 3.5 3.5 3.2 V typ VF 2.6 4.9 4.9 4.0 V max VFmax 3.4 5.9 5.9 5.2 V typ Ωdyn 0.02 0.03 0.02 0.02 Ω Device Thermal Characteristics and Lifetime Thermal Coefficient of Photometric Flux typ -1.1 -0.2 ~0 ~0 % / ºC Thermal Coefficient of Radiometric Flux typ -0.7 -0.2 -0.2 -0.2 % / ºC Forward Voltage Temperature Coefficient typ -3.0 -3.0 -3.0 -3.0 mV / ºC >60,000 >60,000 >60,000 >60,000 Hours Median Lifetime9 © 2010 Luminus Devices, Inc. - All Rights Reserved Page 2 PT120 Summary Datasheet - Revision 07 Optical and Electrical Characteristics Symbol Red Green Blue EP-Blue1 Unit Preliminary Characteristics at Reference Continuous Drive Current IF (Continuous Waveform)2 Reference Drive Current typ IF 18 18 18 18 A Luminous Flux typ Φv 1010 2450 435 540 lm Radiometric Flux typ Φr 5.8 4.7 8.0 10.8 W Dominant Wavelength typ λd 624 528 464 462 nm 1.00 0.83 0.99 0.99 Color Saturation 7,8 FWHM - Spectral bandwidth at 50% of Φv Chromaticity Coordinates7,8 Forward Voltage Dynamic Resistance typ typ Δλd 18 38 21 21 typ x 0.698 0.183 0.141 0.153 typ y 0.301 0.703 0.044 0.025 min VFmin 2.0 3.1 3.1 2.8 V typ VF 2.3 4.4 4.4 3.6 V max VFmax 3.0 5.3 5.3 4.6 V typ Ωdyn 0.02 0.03 0.02 0.05 Ω nm Note 1: Note 2: EP-Blue is recommended for new designs. Please see page 9 for part ordering numbers. All ratings are based on operation with a constant heat sink temperature Ths = 40ºC. See Thermal Resistance section for Ths definition. Note 3: Parameters rated at typical duty cycle and Pulsed operation frequency f>240Hz; Note 4: Duty Cycle used to specify device ratings under Pulsed operation. PhlatLight devices can operate at duty cycles ranging from 1% to 100%. At higher duty cycles, drive current should be adjusted to maintain the junction temperature at desired levels to meet the application lifetime requirements. Note 5: Note 6: In pulsed operation, rise time from 10 to 90% of forward current should be larger than 0.5 microseconds. For Blue and EP-Blue devices, total flux from emitting area at typical dominant wavelength at recommended peak drive current conditions. In CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1 For Reference only Assuming Tj
PT-120-RA-C11-MPF 价格&库存
很抱歉,暂时无法提供与“PT-120-RA-C11-MPF”相匹配的价格&库存,您可以联系我们找货
