GWKAJRB2.EM-TPTR-57H4
    AMSOSRAM(艾迈斯半导体)
    LED5700KWHITECHIPONBOARD
GWKAJRB2.EM-TPTR-57H4 数据手册
2013-05-16 SOLERIQ® E 30 Datasheet Version 1.0 GW KAJRB2.EM The SOLERIQ® E products were specifically designed for applications requiring large flux packages out of a compact area. For the replacement of traditional CFL light sources in downlights the following typical LED efficacies can be achieved at 4000 K: 2x18 W 111 lm/W 2x26 W 101 lm/W Die SOLERIQ® E Produkte wurden speziell für Anwendungen entwickelt, die große Lumenpakete aus einer kompakten Fläche benötigen. Für den Ersatz von traditionellen CFL-Lichtquellen in Downlights lassen sich bei 4000 K folgende typische LED Effizienzen erzielen: 2x18 W 111 lm/W 2x26 W 101 lm/W Features: • • • • • • Besondere Merkmale: Package: Chip-on-Board Viewing angle at 50 % IV: 120° Color: 2700 K - 6500 K ( white ) CRI: min. 80 ( typ. 85 ) Luminous Flux: typ. 3000 lm @ 4000 K Luminous efficacy: typ. 114 lm/W @ 4000 K • • • • • • Applications Anwendungen • Downlights • Indoor General Lighting 2013-05-16 Gehäusetyp: Chip-on-Board Abstrahlwinkel bei 50 % IV: 120° Farbe: 2700 K - 6500 K ( weiß ) CRI: min. 80 ( typ. 85 ) Lichtstrom: typ. 3000 lm @ 4000 K Lichtausbeute: typ. 114 lm/W @ 4000 K • Downlights • Innen-Allgemeinbeleuchtung 1 Version 1.0 GW KAJRB2.EM Ordering Information Bestellinformation Type: Color Temperature Luminous Flux Ordering Code Typ: Farbtemperatur Lichtstrom Bestellnummer 1) page 18 1) Seite 18 IF = 600 mA [K] ΦV [lm] GW KAJRB2.EM-STTQ-27H4 2700 2400 ... 3300 Q65111A2515 GW KAJRB2.EM-SUTQ-30H4 3000 2590 ... 3300 Q65111A2516 GW KAJRB2.EM-TPTR-40H4 4000 2800 ... 3590 Q65111A2517 GW KAJRB2.EM-TPTR-50H4 5000 2800 ... 3590 Q65111A2518 GW KAJRB2.EM-TPTR-57H4 5700 2800 ... 3590 Q65111A2519 GW KAJRB2.EM-TPTR-65H4 6500 2800 ... 3590 Q65111A2520 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page ). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW KAJRB2.EM-TPTR-40H4 means that only one group TP, TPTR, TQ, TR will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. GW KAJRB2.EM-TPTR-40H4 means that the device will be shipped within the specified limits. In order to ensure availability, single color chromaticity groups groups will not be orderable (see page ). Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite ). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW KAJRB2.EM-TPTR-40H4 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen TP, TPTR, TQ, TR enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht bestellt werden. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. GW KAJRB2.EM-TPTR-40H4 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite ). GW KAJRB2.EM-TPTR-40H4 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten, können einzelne Farbortgruppen nicht bestellt werden. 2013-05-16 2 Version 1.0 GW KAJRB2.EM Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -30 ... 85 °C Storage temperature range Lagertemperatur Tstg -40 ... 100 °C Junction temperature Sperrschichttemperatur Tj 125 °C Forward current Durchlassstrom (TS = 25 °C) IF 1080 mA Surge current Stoßstrom (t
GWKAJRB2.EM-TPTR-57H4 价格&库存
很抱歉,暂时无法提供与“GWKAJRB2.EM-TPTR-57H4”相匹配的价格&库存,您可以联系我们找货
