BXPX-27G0400-B-0300
BXPX-27G0400-B-0300
    BRIDGELUX(普瑞)
    LED-3P_5X5MM_SM
    LED SM4 300LM WM WHT 2725K 2X2
BXPX-27G0400-B-0300 数据手册
Bridgelux Micro SM4 Product Data Sheet DS27 – PRELIMINARY, Expires 03/31/12 Introduction The Bridgelux Micro SM4 delivers high performance, compact and cost-effective solid-state lighting solutions to serve general and specialty lighting applications. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of low wattage conventional light sources. The Bridgelux Micro SM4 series has been designed to enable a cost-effective design for LED retrofit bulbs, halogen spotlights, consumer luminaires and other general lighting applications. The Bridgelux Micro SM4 provides a high performance alternative to conventional solid state solutions, delivering between 400 and 500 lumens in warm and cool white color temperatures. These compact high flux density light sources enable both diffuse and directional lamp replacements for a wide range of applications. Lighting system designs incorporating these products deliver performance comparable to that of a 20-40 Watt incandescent, 20-35 Watt halogen and low wattage compact fluorescent lamps and luminaires and feature increased system level efficacy and service life. Typical applications include replacement lamps, task lighting, under cabinet, accent, pendant, sconces, porch, pathway, landscape, portable, and consumer luminaires. Features Benefits  Compact high flux density light source  Enhanced optical control  Low thermal resistance and electrically neutral thermal path  Increased design flexibility and operating temperature range  Energy Star / ANSI compliant binning with 3-step and 4-step binning options  Consistent white light   Available in 6V and 12V versions Enables driver design flexibility and low voltage lighting products  More energy efficient than incandescent, halogen and fluorescent lamps  Lower operating costs  Increased safety  Easy to use with daylight and motion detectors to enable increased energy savings  Low voltage DC operation  Instant light with unlimited dimming  5-year warranty  Reduced maintenance costs  RoHS compliant and Pb free  Environmentally friendly, no disposal issue 101 P ortol a A v enue, Li v erm ore , C A 94551 • T el : (925 ) 583 -84 0 0 • Fa x: (92 5) 58 3 -8 401 • ww w. b ri dgel u x. c om Table of Contents Page Product Nomenclature .................................................................................................................................. 3 Average Lumen Maintenance Characteristics .............................................................................................. 3 Environmental Compliance ........................................................................................................................... 3 UL Recognition .............................................................................................................................................. 4 Minor Product Change Policy........................................................................................................................ 4 Cautionary Statements.................................................................................................................................. 4 Quick Selection Guide ................................................................................................................................... 5 Flux Characteristics ....................................................................................................................................... 6 Optical Characteristics .................................................................................................................................. 7 Electrical Characteristics ............................................................................................................................... 8 Absolute Minimum and Maximum Ratings .................................................................................................... 9 Mechanical Dimensions .............................................................................................................................. 10 Recommended Solder Pad Dimensions ..................................................................................................... 11 Reflow Solder Specifications....................................................................................................................... 12 Typical Radiation Pattern ............................................................................................................................ 13 Wavelength Characteristics at Rated Test Current, Tj=25°C ..................................................................... 13 Typical Relative Luminous Flux vs. Current, Tj=25°C ................................................................................ 14 Typical Light Output Characteristics vs. Temperature ................................................................................ 15 Typical Chromaticity Characteristics vs. Temperature ............................................................................... 16 Typical Forward Current Characteristics ..................................................................................................... 17 Color Binning Information............................................................................................................................ 18 Packaging Drawings ................................................................................................................................... 21 Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 2 of 22 Product Nomenclature The part number designation for the Bridgelux Micro SM4 is explained as follows: BXPX – AB C DEFG – H – JJKK Where: BXPX – Designates product family AB – Designates the nominal ANSI color temperature; 27 = 2700K; 30 = 3000K, etc. C - Designates minimum CRI; C = 70, E = 80, G = 90 DEFG - Designates Nominal Flux; 0400 = 400lm, 0520 = 520lm, etc. H – Designates configuration; A = 350mA; B = 700mA JJ – Designates CCT Bin options 00 = Full ANSI 03 = 3 SDCM 04 = 4 SDCM KK – Reserved. Default = 00 Average Lumen Maintenance Characteristics Bridgelux projects that its Micro SM4 family of products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation with solder pad temperature maintained at or below 70°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Bridgelux LEDs are compliant to the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux will not intentionally add the following restricted materials to LED products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 3 of 22 UL Recognition Bridgelux secures UL Recognition for all the LED products. Bridgelux uses UL Recognized materials with suitable flammability ratings to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 Driver to facilitate the UL listing process. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Contact with the resin area should be avoided. Applying stress to the resin area can result in damage to the product. CAUTION: EYE SAFETY Eye safety classification for the use of the Bridgelux Micro SM4 product series is in accordance with IEC – EN62471 Photobiological Safety of Lamps and Lamp Systems specification. These products are classified as Risk Group 1 (Low Risk) when operated at or below the rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED during operation. Allow the LED to cool for a sufficient period of time before handling. The LED may reach elevated temperatures such that it can burn skin when touched. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED. Please consult Bridgelux Application Note AN21 for additional information. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 4 of 22 Quick Selection Guide Table 1: Selection Guide for Bridgelux Micro SM4 Base Part Number CCT CRI (Nominal) (min) Typical Pulsed Flux Tj 25ºC Test Current Efficacy Vf Power (mA) (Typ) (V) (Typ) (W) (Typ at Tj 25ºC) (lm/W) (lm) BXPX-27E0400-A-0000 2700 80 370 350 13.0 4.6 80 BXPX-27E0400-B-0000 2700 80 370 700 6.5 4.6 80 BXPX-27G0400-A-0000 2700 90 330 350 13.0 4.6 72 BXPX-27G0400-B-0000 2700 90 330 700 6.5 4.6 72 BXPX-30E0400-A-0000 3000 80 400 350 13.0 4.6 87 BXPX-30E0400-B-0000 3000 80 400 700 6.5 4.6 87 BXPX-30G0400-A-0000 3000 90 360 350 13.0 4.6 78 BXPX-30G0400-B-0000 3000 90 360 700 6.5 4.6 78 BXPX-56C0520-A-0000 5600 70 520 350 13.0 4.6 113 BXPX-56C0520-B-0000 5600 70 520 700 6.5 4.6 113 Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 5 of 22 Flux Characteristics Table 2: Flux Characteristics Color ANSI CCT Base Part Number (K) 2700 Warm White 3000 Cool White 5600 CRI (3) (min) (lm) Minimum Pulsed Flux Tj = 25ºC (lm) (lm) Typical DC Flux TJ = 85ºC (1) Typical Pulsed Flux Tj = 25ºC Test Current (2) (mA) BXPX-27E0400-A-0000 80 320 TBD 370 350 BXPX-27E0400-B-0000 80 320 TBD 370 700 BXPX-27G0400-A-0000 90 285 TBD 330 350 BXPX-27G0400-B-0000 90 285 TBD 330 700 BXPX-30E0400-A-0000 80 345 TBD 400 350 BXPX-30E0400-B-0000 80 345 TBD 400 700 BXPX-30G0400-A-0000 90 310 TBD 360 350 BXPX-30G0400-B-0000 90 310 TBD 360 700 BXPX-56C0520-A-0000 70 450 TBD 520 350 BXPX-56C0520-B-0000 70 450 TBD 520 700 Notes for Table 2: 1. Bridgelux maintains a ± 7% tolerance of flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Typical R9 value for 90 CRI product options is 50. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 6 of 22 Optical Characteristics Table 3: Optical Characteristics Color ANSI CCT Color Temperature (CCT) Base Part Number (K) [1], [2], [3] CRI (min) Typical Viewing Angle (Degrees) Min Typ Max BXPX-27E0400-A-0000 2580 K 2725 K 2870 K 80 165 BXPX-27E0400-B-0000 2580 K 2725 K 2870 K 80 165 BXPX-27G0400-A-0000 2580 K 2725 K 2870 K 90 165 BXPX-27G0400-B-0000 2580 K 2725 K 2870 K 90 165 BXPX-30E0400-A-0000 2870 K 3045 K 3220 K 80 165 BXPX-30E0400-B-0000 2870 K 3045 K 3220 K 80 165 BXPX-30G0400-A-0000 2870 K 3045 K 3220 K 90 165 BXPX-30G0400-B-0000 2870 K 3045 K 3220 K 90 165 BXPX-56C0520-A-0000 5310 K 5665 K 6020 K 70 165 BXPX-56C0520-B-0000 5310 K 5665 K 6020 K 70 165 2θ 1/2 [4] 2700 Warm White 3000 Cool White 5600 Notes for Table 3: 1. 2. 3. 4. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Refer to Flux Characteristic Table for test current data. Product is binned for color in x y coordinates. Viewing angle is the off axis angle from the centerline where Iv is ½ of the peak value. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 7 of 22 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Vf [2] (V) Color Test Current Base Part Number [1] Min Typ Max (mA) Typical Coefficient of Forward Voltage (mV/ºC) ∆Vf/∆Tj Typical Thermal Resistance Junction to Solder Point (ºC/W) Rθj-s Warm White Cool White BXPX-27E0400-A-0000 11.7 13.0 14.3 350 -4 to -12 1.5 BXPX-27E0400-B-0000 5.9 6.5 7.1 700 -2 to -6 1.5 BXPX-27G0400-A-0000 11.7 13.0 14.3 350 -4 to -12 1.5 BXPX-27G0400-B-0000 5.9 6.5 7.1 700 -2 to -6 1.5 BXPX-30E0400-A-0000 11.7 13.0 14.3 350 -4 to -12 1.5 BXPX-30E0400-B-0000 5.9 6.5 7.1 700 -2 to -6 1.5 BXPX-30G0400-A-0000 11.7 13.0 14.3 350 -4 to -12 1.5 BXPX-30G0400-B-0000 5.9 6.5 7.1 700 -2 to -6 1.5 BXPX-56C0520-A-0000 11.7 13.0 14.3 350 -4 to -12 1.5 BXPX-56C0520-B-0000 5.9 6.5 7.1 700 -2 to -6 1.5 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 8 of 22 Absolute Minimum and Maximum Ratings Table 5: Maximum Current and Reverse Voltage Ratings Color Warm White Cool White Maximum DC Forward Current Base Part Number Maximum Peak Pulsed Current [1] Maximum Reverse Voltage [2] (mA) (mA) (Vr) BXPX-27E0400-A-0000 BXPX-27E0400-B-0000 500 1000 700 1400 -20 V -10 V BXPX-27G0400-A-0000 BXPX-27G0400-B-0000 BXPX-30E0400-A-0000 BXPX-30E0400-B-0000 BXPX-30G0400-A-0000 BXPX-30G0400-B-0000 500 1000 500 1000 500 1000 700 1400 700 1400 700 1400 -20 V -10 V -20 V -10 V -20 V -10 V BXPX-56C0520-A-0000 BXPX-56C0520-B-0000 500 1000 700 1400 -20 V -10 V Notes for Table 5: 1. Bridgelux recommends a maximum duty cycle of 10% when operating LEDs at the maximum peak pulsed current specified. 2. Light emitting diodes are not designed to be driven in reverse voltage. Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature Storage Temperature Operating Solder Point Temperature ESD Classification 130°C -40°C to +135°C 105°C at rated test current, 85°C at maximum drive current Class 2 (HBM per JESD22-A114-F) Reflow Solderable Moisture Sensitivity Rating Floor Life JEDEC-J-STD-20C MSL1 Unlimited ≤ 30°C / 85% RH Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 9 of 22 Mechanical Dimensions Figure 1: Mechanical Dimensions for Bridgelux Micro SM4 ANODE Notes for Figure 1: 1. 2. 3. 4. 5. Drawings are not to scale. Drawing dimensions are in millimeters. Unless otherwise specified, tolerances are ± 0.20mm. Refer to product Application Notes AN21 for product handling and assembly recommendations. The optical center of the LED is defined by the mechanical center of the product. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 10 of 22 Recommended Solder Pad Dimensions Figure 2: Recommended Solder Pad Dimensions Notes for Figure 2: 1. 2. 3. 4. Drawings are not to scale. Drawing dimensions are in millimeters. Unless otherwise specified, tolerances are ± 0.20mm. Refer to product Application Notes AN21 for product handling and assembly recommendations. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 11 of 22 Reflow Solder Specifications The Bridgelux Micro SM4 products are compatible with JEDEC J-STD-020C, following the profile and parameters listed below. Figure 3: Reflow Solder Profile Table 7: Reflow Solder Parameters Profile Feature Specification Using Lead Free Solder Average Ramp-Up Rate (Tsmax to Tp) 3°C / second max Preheat Temperature Min (Tsmin) 150°C Preheat Temperature Max (Tsmax) 200°C Preheat Time (Tsmin to Tsmax) 60-180 seconds Temperature (TL) 217°C Time Maintained Above Temperature (T L ) 60-150 seconds Peak/Classification Temperature (TP) 260°C Time Within 5°C of Actual Peak Temperature (tp) 20-40 seconds Ramp Down Rate 6°C / second max Time 25°C to Peak Temperature 8 minutes max Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 12 of 22 Typical Radiation Pattern Figure 4: Typical Far Field Radiation Pattern 100% 90% 80% Relative Intensity 70% 60% 50% 40% 30% 20% 10% 0% -100 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 Degrees Wavelength Characteristics at Rated Test Current, Tj=25°C Figure 5: Typical Warm White and Cool White Color Spectrum 1.2 Relative Intensity 1.0 0.8 Cool White Warm White 0.6 0.4 0.2 0.0 400 450 500 550 600 650 Wavelength Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) 700 750 800 Page 13 of 22 Typical Relative Luminous Flux vs. Current, Tj=25°C Figure 6: Typical Light Flux vs. Current 350mA Devices (BXPX-xxxxxxx-A series products) 2.0 Normalized Luminous Flux 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 0 100 200 300 400 500 600 700 Current (mA) Figure 7: Typical Flux vs. Current 700mA Devices (BXPX-xxxxxxx-B series products) 2.0 Normalized Luminous Flux 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 0 200 400 600 800 1000 1200 1400 Current (mA) Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 14 of 22 Typical Light Output Characteristics vs. Temperature Figure 8: Typical Flux vs. Junction Temperature 1.2 Normalized Luminous Flux 1.0 0.8 Cool White Warm White 0.6 Warm White 0.4 Cool White 0.2 0.0 -10 0 10 20 30 40 50 60 70 80 90 100 110 Junction Temperature, °C Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 15 of 22 Typical Chromaticity Characteristics vs. Temperature Figure 9: Typical ccx Shift vs. Junction Temperature 0.02 Warm White 0.01 0.00 Δx -0.01 -0.02 Cool White -0.03 Warm White -0.04 Cool White -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 90 100 110 Junction Temperature, °C Figure 10: Typical ccy Shift vs. Junction Temperature 0.02 0.01 0.00 -0.01 Δy Warm White -0.02 Cool White -0.03 -0.04 Warm White -0.05 Cool White -0.06 -10 0 10 20 30 40 50 60 70 80 90 100 110 Junction Temperature, °C Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 16 of 22 Typical Forward Current Characteristics Figure 11: Forward Voltage vs. Current 350mA Devices (BXPX-xxxxxxx-A series products) MIN Vf Tc=25°C MIN Vf Tc=70°C TYP Vf Tc=25°C MAX Vf Tc=25°C Figure 12: Forward Voltage vs. Current 700mA Devices (BXPX-xxxxxxx-B series products) MIN Vf Tc=25°C MIN Vf Tc=70°C Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) TYP Vf Tc=25°C MAX Vf Tc=25°C Page 17 of 22 Color Binning Information Figure 13: Graph of 2700K Warm White Test Bins in xy Color Space Figure 14: Graph of 3000K Warm White Test Bins in xy Color Space Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 18 of 22 Color Binning Information (continued) Figure 15: Graph of 5600K Cool White Test Bins in xy Color Space Table 8: ANSI C78.377 Bounding Coordinates Center point Top Right Top Left Bottom Left Bottom Right 2700 K x y 0.4578 0.4101 0.4813 0.4319 0.4562 0.4260 0.4373 0.3893 0.4593 0.3944 3000 K x y 0.4338 0.4030 0.4562 0.4260 0.4299 0.4165 0.4147 0.3814 0.4373 0.3893 5600 K x y 0.3287 0.3417 0.3376 0.3616 0.3207 0.3462 0.3222 0.3243 0.3366 0.3369 Table 9: 4 SDCM Bounding Coordinates Center point Top Right Top Left Bottom Left Bottom Right 2700 K x y 0.4578 0.4101 0.4696 0.4210 0.4570 0.4181 0.4476 0.3997 0.4586 0.4023 3000 K x y 0.4338 0.4030 0.4450 0.4145 0.4319 0.4098 0.4243 0.3922 0.4356 0.3962 Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) 5600 K x y 0.3287 0.3417 0.3332 0.3517 0.3247 0.3440 0.3255 0.3330 0.3327 0.3393 Page 19 of 22 Color Binning Information (continued) Table 10: 3 SDCM Bounding Coordinates Center point Top Right Top Left Bottom Left Bottom Right 2700 K x y 0.4578 0.4101 0.4656 0.4174 0.4573 0.4154 0.4510 0.4032 0.4583 0.4049 Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) 3000 K x y 0.4338 0.4030 0.4413 0.4107 0.4325 0.4075 0.4274 0.3958 0.4350 0.3984 Page 20 of 22 Packaging Drawings Figure 16: Tape and Reel Dimensions Notes for Figure 16: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.20mm. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 21 of 22 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solidstate lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 500 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2012 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux Micro SM4 Preliminary Product Data Sheet DS27 (01/26/12) Page 22 of 22
BXPX-27G0400-B-0300 价格&库存
很抱歉,暂时无法提供与“BXPX-27G0400-B-0300”相匹配的价格&库存,您可以联系我们找货
