LZC-C0GW00-0230
LZC-C0GW00-0230
    AMSOSRAM(艾迈斯半导体)
    Module
    LED EMITTER WHT 2CH STAR MCPCB
LZC-C0GW00-0230 数据手册
Gallery White LED Emitter LZC-00GW00 Key Features  12-die Gallery White (CRI 98) LED  3 SDCM color bins for CCT - 3000K  Superior Color Rendering: CRI (Ra) 98; R9 98 and R15 98  Up to 42 Watt power dissipation on compact 9.0mm x 9.0mm footprint  Industry lowest thermal resistance per package size (0.7°C/W)  Engineered ceramic package with integrated glass lens  JEDEC Level 1 for Moisture Sensitivity Level  Lead (Pb) free and RoHS compliant  Reflow solderable (up to 6 cycles)  Emitter available with several MCPCB options  Full suite of TIR secondary optics family available Typical Applications  Gallery lighting  Museum lighting  High-end retail lighting  Medical surgery lighting Description The LZC-00GW00 Gallery White features warm white light with an exceptional color rendering index (CRI) of 98, as well as impressive individual R values (R1-16) in industry’s smallest footprint. It enables accurate color representation and enhances the contrast of retail merchandise, artwork and skin tones, which cannot be obtained with standard warm white LED emitters. The emitter, based on LED Engin’s LuxiGen technology platform, may be driven up to 42W of power in a compact 9.0mmx9.0mm footprint. It has the industry lowest thermal resistance per package size, which allows users to drive the emitter with higher current, while keeping the junction temperature low to ensure long operating life. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Part number options Base part number Part number Description LZC-00GW00-xxxx LZC Gallery White emitter LZC-70GW00-xxxx LZC Gallery White emitter on 1 channel 1x12 Star MCPCB LZC-C0GW00-xxxx LZC Gallery White emitter on 2 channel 2x6 Star MCPCB Bin kit option codes GW, Gallery White (CRI 98) Kit number suffix Min flux Bin Color Bin Ranges Description 0030 X 3-step MacAdams ellipse full distribution flux; 3000K ANSI CCT COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 2 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Gallery White CCT Bins 3-step MacAdam ellipse color bins plotted on excerpt from the CIE 1931 (2°) x-y Chromaticity Diagram. Coordinates are listed below in the table. Gallery White 3-Step MacAdam Ellipse CCT Bin Coordinates Nominal ANSI CCT 3000 Center Point (cx, cy) (0.4366, 0.4042) Major Axis a 0.00967 COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. Minor Axis b 0.00399 Ellipse Rotation Angle (⁰) 56.6 LZC-00GW00 (2.4 – 11/09/2018) 3 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Luminous Flux Bins Table 1: Bin Code Minimum Luminous Flux (ΦV) @ IF = 700mA [1,2] (lm) Maximum Luminous Flux (ΦV) @ IF = 700mA [1,2] (lm) X 1,085 1,357 Y 1,357 1,696 Notes for Table 1: 1. Luminous flux performance guaranteed within published operating conditions. LED Engin maintains a tolerance of ± 10% on flux measurements. 2. Luminous Flux typical value is for all 12 LED dice operating concurrently at rated current. Forward Voltage Bin Table 2: Bin Code Minimum Forward Voltage (VF) @ IF = 700mA [1,2] (V) Maximum Forward Voltage (VF) @ IF = 700mA [1,2] (V) 0 36.0 43.2 Notes for Table 2: 1. LED Engin maintains a tolerance of ± 0.48V for forward voltage measurements. 2. Forward Voltage is binned with 12 LED dice connected in series. The actual LED is configured with two strings of 6 dice in series. Color Rendering Index Bin Table 3: Bin Code Minimum Color Rendering Index @ IF = 700mA 0 95.0 COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 4 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Absolute Maximum Ratings Table 4: Parameter Symbol Value Unit IF IF IFP VR Tstg TJ Tsol 1200 1000 1500 See Note 3 -40 ~ +150 150 260 6 mA mA mA V °C °C °C [1] DC Forward Current at Tjmax=130C DC Forward Current at Tjmax=150C [1] Peak Pulsed Forward Current [2] Reverse Voltage Storage Temperature Junction Temperature Soldering Temperature [4] Allowable Reflow Cycles > 8,000 V HBM Class 3B JESD22-A114-D ESD Sensitivity [5] Notes for Table 3: 1. Maximum DC forward current (per die) is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 10 for current derating. 2: Pulse forward current conditions: Pulse Width ≤ 10msec and Duty cycle ≤ 10%. 3. LEDs are not designed to be reverse biased. 4. Solder conditions per JEDEC 020D. See Reflow Soldering Profile Figure 5. 5. LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZ4-00GW00 in an electrostatic protected area (EPA). An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1. Optical Characteristics @ TC = 25°C Table 5: Parameter Symbol Typical Unit ΦV ΦV 1400 1800 66 3000 98 110 lm lm lm/W K [1] Luminous Flux (@ IF = 700mA) Luminous Flux (@ IF = 1000mA) [1] Luminous Efficacy (@ IF = 350mA) Correlated Color Temperature Color Rendering Index (CRI) [2] Viewing Angle [2] CCT Ra 2Θ1/2 Degrees Notes for Table 4: 1. Luminous flux typical value is for all 12 LED dice operating concurrently at rated current. 2. Typical CRI (Ra) and individual R1 through R16 values listed in Table 6 3. Viewing Angle is the off-axis angle from emitter centerline where the luminous intensity is ½ of the peak value. Typical CRI (Ra) and individual R values Table 6: Ra 98 R1 98 R2 99 R3 97 R4 98 R5 98 R6 98 R7 98 R8 98 COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. R9 98 R10 99 R11 96 R12 86 R13 98 R14 97 R15 98 R16 96 LZC-00GW00 (2.4 – 11/09/2018) 5 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Electrical Characteristics @ TC = 25°C Table 7: Parameter Symbol Typical Unit Forward Voltage (@ IF = 700mA) Forward Voltage (@ IF = 1000mA) [1] VF VF 38.8 40.0 V V Temperature Coefficient of Forward Voltage [1] ΔVF/ΔTJ -24.0 mV/°C Thermal Resistance (Junction to Case) RΘJ-C 0.7 °C/W [1] Notes for Table 6: 1. Forward Voltage is binned with 12 LED dice connected in series. The actual LED is configured with two strings of 6 dice in series. IPC/JEDEC Moisture Sensitivity Level Table 8 - IPC/JEDEC J-STD-20.1 MSL Classification: Soak Requirements Floor Life Standard Accelerated Level Time Conditions Time (hrs) Conditions Time (hrs) Conditions 1 unlimited ≤ 30°C/ 85% RH 168 +5/-0 85°C/ 85% RH n/a n/a Notes for Table 7: 1. The standard soak time includes a default value of 24 hours for semiconductor manufacturer’s exposure time (MET) between bake and bag and includes the maximum time allowed out of the bag at the distributor’s facility. Average Lumen Maintenance Projections Lumen maintenance generally describes the ability of a lamp to retain its output over time. The useful lifetime for solid state lighting devices (Power LEDs) is also defined as Lumen Maintenance, with the percentage of the original light output remaining at a defined time period. Based on long-term WHTOL testing, LED Engin projects that the LZC Series will deliver, on average, 70% Lumen Maintenance at 70,000 hours of operation at a forward current of 700 mA per die. This projection is based on constant current operation with junction temperature maintained at or below 110°C. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 6 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Mechanical Dimensions (mm) Pin Out Pad Channel Function 2 1 Anode 3 1 Anode 5 2 Anode 6 2 Anode 14 2 Cathode 15 2 Cathode 17 1 Cathode 18 1 Cathode Figure 1: Package outline drawing. Notes for Figure 1: 1. LZC-00GW00 is compatible with MCPCB designed for LZC-00WW00, LZC-00NW00, and LZC-00CW00 when emitter is rotated 180 degree with respect to the LZC-00xW00 position on the MCPCB. 2. Index mark, Tc indicates case temperature measurement point. 3. Unless otherwise noted, the tolerance = ± 0.20 mm. 4. Thermal contact pad is electrically neutral. Recommended Solder Pad Layout (mm) Figure 2a: Recommended solder pad layout for anode, cathode, and thermal pad. Note for Figure 2a: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 7 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Recommended 8mil Stencil Apertures Layout (mm) Figure 2b: Recommended solder mask opening for anode, cathode, and thermal pad. Note for Figure 2b: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. Reflow Soldering Profile Figure 3: Reflow soldering profile for lead free soldering. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 8 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Typical Radiation Pattern Figure 4: Typical representative spatial radiation pattern. Typical Relative Spectral Power Distribution 1 0.9 Relative Spectral Power 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 350 400 450 500 550 600 650 700 750 800 Wavelength (nm) Figure 5: Typical relative spectral power vs. wavelength @ TC = 25°C. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 9 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Typical Relative Light Output over Forward Current 160% 140% Relatiive Light Output 120% 100% 80% 60% 40% 20% 0% 0 200 400 600 800 1000 1200 IF - Forward Current (mA) Figure 6: Typical relative light output vs. forward current @ TC = 25°C. Notes for Figure 6: 1. Luminous Flux typical value is for all 12 LED dice operating concurrently at rated current. Typical Relative Light Output over Temperature Relatiive Light Output (%) 110 100 90 80 70 60 0 10 20 30 40 50 60 70 80 90 100 Case Temperature (°C) Figure 7: Typical relative light output vs. case temperature. Notes for Figure 7: 1. Luminous Flux typical value is for all 12 LED dice operating concurrently at rated current. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 10 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Typical Chromaticity Coordinate Shift over Forward Current 0.0400 Delta_Cx 0.0300 Delta_Cy Delta Cx, Delta Cy 0.0200 0.0100 0.0000 -0.0100 -0.0200 -0.0300 -0.0400 0 200 400 600 800 1000 1200 IF - Forward Current (mA) Figure 8: Typical chromaticity coordinate shift vs. forward current Typical Chromaticity Coordinate Shift over Temperature 0.0400 0.0300 Delta_Cx Delta Cx, Delta Cy 0.0200 Delta_Cy 0.0100 0.0000 -0.0100 -0.0200 -0.0300 -0.0400 0 10 20 30 40 50 60 70 80 90 100 Case Temperature (°C) Figure 9: Typical chromaticity coordinate shift vs. Case temperature COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 11 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Typical Forward Current Characteristics 1200 IF - Forward Current (mA) 1000 800 600 400 200 0 31.0 33.0 35.0 37.0 39.0 41.0 43.0 VF - Forward Voltage (V) Figure 10: Typical forward current vs. forward voltage @ TC = at 25°C. Note for Figure 10: 1. Forward Voltage assumes 12 LED dice connected in series. The actual LED is configured with two strings of 6 dice in series. Current De-rating IF - Maximum Current (mA) 1200 1000 800 700 (Rated) 600 400 RΘJ-A = 2.0°C/W RΘJ-A = 3.0°C/W RΘJ-A = 4.0°C/W 200 0 0 25 50 75 100 125 150 Maximum Ambient Temperature (°C) Figure 11: Maximum forward current vs. ambient temperature based on TJ(MAX) = 150°C. Notes for Figure 11: 1. Maximum current assumes that all LED dice are operating concurrently at the same current. 2. RΘJ-C [Junction to Case Thermal Resistance] for the LZC-00xx00 is typically 0.7°C/W. 3. RΘJ-A [Junction to Ambient Thermal Resistance] = RΘJ-C + RΘC-A [Case to Ambient Thermal Resistance]. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 12 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Emitter Tape and Reel Specifications (mm) Figure 12: Emitter carrier tape specifications (mm). Figure 13: Emitter Reel specifications (mm). COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 13 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin LZC MCPCB Family Emitter + MCPCB Typical Vf Typical If Thermal Resistance (V) (mA) (oC/W) Part number Type of MCPCB Diameter (mm) LZC-7xxxxx 1-channel 28.3 0.7 + 0.6 = 1.3 38.8 700 LZC-Cxxxxx 2-channel 28.3 0.7 + 0.6 = 1.3 19.4 2 x 700 COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 14 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin LZC-7xxxxx 1-Channel MCPCB Mechanical Dimensions (mm) Tc Notes: • Unless otherwise noted, the tolerance = ± 0.2 mm. • Slots in MCPCB are for M3 or #4-40 mounting screws. • LED Engin recommends plastic washers to electrically insulate screws from solder pads and electrical traces. • Electrical connection pads on MCPCB are labeled “+” for Anode and “-” for Cathode. • LED Engin recommends using thermal interface material when attaching the MCPCB to a heatsink. • The thermal resistance of the MCPCB is: RΘC-B 0.6°C/W Components used MCPCB: ESD chips: HT04503 BZX585-C51 (Bergquist) (NPX, for 12 LED dies in series) Pad layout Ch. 1 MCPCB Pad + - String/die Function 1/BCEFGHJ KLMPQ Anode + Cathode - COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 15 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin LZC-Cxxxxx 2 channel, Star MCPCB (2x6) Dimensions (mm) Tc Notes: • Unless otherwise noted, the tolerance = ± 0.2 mm. • Slots in MCPCB are for M3 or #4-40 mounting screws. • LED Engin recommends plastic washers to electrically insulate screws from solder pads and electrical traces. • Electrical connection pads on MCPCB are labeled “+” for Anode and “-” for Cathode. • LED Engin recommends thermal interface material when attaching the MCPCB to a heatsink. • The thermal resistance of the MCPCB is: RΘC-B 0.6°C/W Components used MCPCB: ESD chips: HT04503 BZT52C36LP (Bergquist) (NPX, for 6 LED dies in series) Pad layout Ch. 1 2 MCPCB Pad 1+ 12+ 2- String/die 1/JKLMPQ 2/BCEFGH Function Anode + Cathode Anode + Cathode - COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 16 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Application Guidelines MCPCB Assembly Recommendations A good thermal design requires an efficient heat transfer from the MCPCB to the heat sink. In order to minimize air gaps in between the MCPCB and the heat sink, it is common practice to use thermal interface materials such as thermal pastes, thermal pads, phase change materials and thermal epoxies. Each material has its pros and cons depending on the design. Thermal interface materials are most efficient when the mating surfaces of the MCPCB and the heat sink are flat and smooth. Rough and uneven surfaces may cause gaps with higher thermal resistances, increasing the overall thermal resistance of this interface. It is critical that the thermal resistance of the interface is low, allowing for an efficient heat transfer to the heat sink and keeping MCPCB temperatures low. When optimizing the thermal performance, attention must also be paid to the amount of stress that is applied on the MCPCB. Too much stress can cause the ceramic emitter to crack. To relax some of the stress, it is advisable to use plastic washers between the screw head and the MCPCB and to follow the torque range listed below. For applications where the heat sink temperature can be above 50oC, it is recommended to use high temperature and rigid plastic washers, such as polycarbonate or glass-filled nylon. LED Engin recommends the use of the following thermal interface materials: 1. Bergquist’s Gap Pad 5000S35, 0.020in thick  Part Number: Gap Pad® 5000S35 0.020in/0.508mm  Thickness: 0.020in/0.508mm  Thermal conductivity: 5 W/m-K  Continuous use max temperature: 200°C  Using M3 Screw (or #4 screw), with polycarbonate or glass-filled nylon washer (#4) the recommended torque range is: 20 to 25 oz-in (1.25 to 1.56 lbf-in or 0.14 to 0.18 N-m) 2. 3M’s Acrylic Interface Pad 5590H  Part number: 5590H @ 0.5mm  Thickness: 0.020in/0.508mm  Thermal conductivity: 3 W/m-K  Continuous use max temperature: 100°C  Using M3 Screw (or #4 screw), with polycarbonate or glass-filled nylon washer (#4) the recommended torque range is: 20 to 25 oz-in (1.25 to 1.56 lbf-in or 0.14 to 0.18 N-m) Mechanical Mounting Considerations The mounting of MCPCB assembly is a critical process step. Excessive mechanical stress build up in the MCPCB can cause the MCPCB to warp which can lead to emitter substrate cracking and subsequent cracking of the LED dies LED Engin recommends the following steps to avoid mechanical stress build up in the MCPCB: o Inspect MCPCB and heat sink for flatness and smoothness. o Select appropriate torque for mounting screws. Screw torque depends on the MCPCB mounting method (thermal interface materials, screws, and washer). o Always use three M3 or #4-40 screws with #4 washers. o When fastening the three screws, it is recommended to tighten the screws in multiple small steps. This method avoids building stress by tilting the MCPCB when one screw is tightened in a single step. o Always use plastic washers in combinations with the three screws. This avoids high point contact stress on the screw head to MCPCB interface, in case the screw is not seated perpendicular. o In designs with non-tapped holes using self-tapping screws, it is common practice to follow a method of three turns tapping a hole clockwise, followed by half a turn anti-clockwise, until the appropriate torque is reached. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 17 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Wire Soldering   To ease soldering wire to MCPCB process, it is advised to preheat the MCPCB on a hot plate of 125-150oC. Subsequently, apply the solder and additional heat from the solder iron will initiate a good solder reflow. It is recommended to use a solder iron of more than 60W. It is advised to use lead-free, no-clean solder. For example: SN-96.5 AG-3.0 CU 0.5 #58/275 from Kester (pn: 24-7068-7601) COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 18 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin About LED Engin LED Engin, an OSRAM business based in California’s Silicon Valley, develops, manufactures, and sells advanced LED emitters, optics and light engines to create uncompromised lighting experiences for a wide range of entertainment, architectural, general lighting and specialty applications. LuxiGenTM multi-die emitter and secondary lens combinations reliably deliver industry-leading flux density, upwards of 5000 quality lumens to a target, in a wide spectrum of colors including whites, tunable whites, multi-color and UV LEDs in a unique patented compact ceramic package. Our LuxiTuneTM series of tunable white lighting modules leverage our LuxiGen emitters and lenses to deliver quality, control, freedom and high density tunable white light solutions for a broad range of new recessed and downlighting applications. The small size, yet remarkably powerful beam output and superior insource color mixing, allows for a previously unobtainable freedom of design wherever high-flux density, directional light is required. LED Engin is committed to providing products that conserve natural resources and reduce greenhouse emissions; and reserves the right to make changes to improve performance without notice. For more information, please contact LEDE-Sales@osram.com or +1 408 922-7200. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-00GW00 (2.4 – 11/09/2018) 19 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin
LZC-C0GW00-0230 价格&库存
很抱歉,暂时无法提供与“LZC-C0GW00-0230”相匹配的价格&库存,您可以联系我们找货
