LZP-D0CW0R-0000
LZP-D0CW0R-0000
    AMSOSRAM(艾迈斯半导体)
    LED EMITTER WHT 227LM 5CH MCPCB
LZP-D0CW0R-0000 数据手册
LZP-Series Highest Lumen Density Cool White Emitter LZP-00CW0R Key Features  Highest luminous flux / area single LED emitter o 5700lm Cool White o 40mm² light emitting area  Up to 90 Watt power dissipation on compact 12.0mm x 12.0mm footprint  Industry lowest thermal resistance per package size (0.6°C/W)  Industry leading lumen maintenance  Color Point Stability 7x improvement over Energy Star requirements  Surface mount ceramic package with integrated glass lens  JEDEC Level 1 for Moisture Sensitivity Level  Lead (Pb) free and RoHS compliant  Reflow solderable (up to 6 cycles)  Copper core MCPCB option with emitter thermal slug directly soldered to the copper core  Full suite of TIR secondary optics family available Typical Applications  High Bay and Low Bay  General lighting  Stage and Studio lighting  Architectural lighting  Street lighting Description The LZP-00CW0R Cool White LED emitter can dissipate up to 90W of power in an extremely small package. With a small 12.0mm x 12.0mm footprint, this package provides unmatched luminous flux density. The high quality materials used in the package are chosen to optimize light output and minimize stresses which results in superior reliability and lumen maintenance. The robust product design thrives in outdoor applications with high ambient temperatures and high humidity. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Part number options Base part number Part number Description LZP-00CW0R-xxxx LZP Cool White emitter LZP-D0CW0R-xxxx LZP Cool White emitter on 5 channel 4x6+1 Star MCPCB Bin kit option codes CW, Cool White (5000K – 6500K) Kit number suffix Min flux Bin Chromaticity bins Description 0055 J2 2U, 2Y, 3U, 2A, 2D, 3A, 2B, 2C, 3B, 2V, 2X, 3V full distribution flux; 5500K bin 0065 J2 1U, 1A, 1B, 1V, 1Y, 1D, 1C, 1X, 2U, 2A, 2B, 2V full distribution flux; 6500K bin COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 2 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Cool White Chromaticity Groups 0.40 0.38 3X 3V 3C 2X 0.36 3B 2V 2C CIEy 1X 2B 0.34 1V 1D 1A 3Y 2D 3U 2A 1B Planckian Locus 3A 1C 0.32 3D 2Y 2U 1Y 1U 0.30 0.28 0.28 0.30 0.32 0.34 0.36 0.38 CIEx Standard Chromaticity Groups plotted on excerpt from the CIE 1931 (2°) x-y Chromaticity Diagram. Coordinates are listed below in the table. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 3 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Cool White Bin Coordinates Bin code 1U 1Y 2U 2Y 3U 3Y CIEx 0.3068 0.3144 0.3161 0.3093 0.3068 0.3144 0.3221 0.3231 0.3161 0.3144 0.3222 0.329 0.329 0.3231 0.3222 0.329 0.3366 0.3361 0.329 0.329 0.3366 0.344 0.3429 0.3361 0.3366 0.344 0.3515 0.3495 0.3429 0.344 CIEy 0.3113 0.3186 0.3059 0.2993 0.3113 0.3186 0.3261 0.312 0.3059 0.3186 0.3243 0.33 0.318 0.312 0.3243 0.33 0.3369 0.3245 0.318 0.33 0.3369 0.3428 0.3299 0.3245 0.3369 0.3428 0.3487 0.3339 0.3299 0.3428 Bin code 1A 1D 2A 2D 3A 3D CIEx 0.3048 0.313 0.3144 0.3068 0.3048 0.313 0.3213 0.3221 0.3144 0.313 0.3215 0.329 0.329 0.3222 0.3215 0.329 0.3371 0.3366 0.329 0.329 0.3371 0.3451 0.344 0.3366 0.3371 0.3451 0.3533 0.3515 0.344 0.3451 CIEy 0.3207 0.329 0.3186 0.3113 0.3207 0.329 0.3373 0.3261 0.3186 0.329 0.335 0.3417 0.33 0.3243 0.335 0.3417 0.349 0.3369 0.33 0.3417 0.349 0.3554 0.3427 0.3369 0.349 0.3554 0.362 0.3487 0.3427 0.3554 Bin code 1B 1C 2B 2C 3B 3C COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. CIEx 0.3028 0.3115 0.313 0.3048 0.3028 0.3115 0.3205 0.3213 0.313 0.3115 0.3207 0.329 0.329 0.3215 0.3207 0.329 0.3376 0.3371 0.329 0.329 0.3376 0.3463 0.3451 0.3371 0.3376 0.3463 0.3551 0.3533 0.3451 0.3463 CIEy 0.3304 0.3391 0.329 0.3207 0.3304 0.3391 0.3481 0.3373 0.329 0.3391 0.3462 0.3538 0.3417 0.335 0.3462 0.3538 0.3616 0.349 0.3417 0.3538 0.3616 0.3687 0.3554 0.349 0.3616 0.3687 0.376 0.362 0.3554 0.3687 Bin code 1V 1X 2V 2X 3V 3X CIEx 0.3005 0.3099 0.3115 0.3028 0.3005 0.3099 0.3196 0.3205 0.3115 0.3099 0.3196 0.329 0.329 0.3207 0.3196 0.329 0.3381 0.3376 0.329 0.329 0.3381 0.348 0.3463 0.3376 0.3381 0.348 0.3571 0.3551 0.3463 0.348 CIEy 0.3415 0.3509 0.3391 0.3304 0.3415 0.3509 0.3602 0.3481 0.3391 0.3509 0.3602 0.369 0.3538 0.3462 0.3602 0.369 0.3762 0.3616 0.3538 0.369 0.3762 0.384 0.3687 0.3616 0.3762 0.384 0.3907 0.376 0.3687 0.384 LZP-00CW0R (1.4 - 11/09/18) 4 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Luminous Flux Bins Table 1: Bin Code J2 K2 L2 Minimum Luminous Flux (ΦV) @ IF = 700mA /Channel [1,2] (lm) 3,800 4,200 4,600 Maximum Luminous Flux (ΦV) @ IF = 700mA /Channel [1,2] (lm) 4,200 4,600 5,100 Notes: 1. Luminous flux performance guaranteed within published operating conditions. LED Engin maintains a tolerance of ± 10% on flux measurements. 2. Luminous Flux typical value is for all 24 LED dies operating at rated current. The LED is configured with 4 Channels of 6 dies in series. Forward Voltage Bin Table 2: Bin Code 0 Minimum Forward Voltage (VF) @ IF = 700mA /Channel [1] (V) 18.0[2,3] Maximum Forward Voltage (VF) @ IF = 700mA /Channel [1] (V) 21.6[2,3] Notes: 1. LED Engin maintains a tolerance of ± 0.24V for forward voltage measurements. 2. All 4 white Channels have matched Vf for parallel operation 3. Forward Voltage is binned with 6 LED dies connected in series. The LED is configured with 4 Channels of 6 dies in series each. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 5 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Absolute Maximum Ratings Table 3: Parameter Symbol Value Unit DC Forward Current at Tjmax=135°C [1] DC Forward Current at Tjmax=150°C [1] Peak Pulsed Forward Current [2] Reverse Voltage Storage Temperature Junction Temperature Soldering Temperature [4] Allowable Reflow Cycles IF IF IFP VR Tstg TJ Tsol 1200 1000 1500 /Channel See Note 3 -40 ~ +150 150 260 6 mA mA mA V °C °C °C > 8,000 V HBM Class 3B JESD22-A114-D ESD Sensitivity [5] Notes: 1. Maximum DC forward current (per die) is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 10 for current de-rating. 2: Pulse forward current conditions: Pulse Width ≤ 10msec and Duty cycle ≤ 10%. 3. LEDs are not designed to be reverse biased. 4. Solder conditions per JEDEC 020D. See Reflow Soldering Profile Figure 5. 5. LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZP-00CW0R in an electrostatic protected area (EPA). An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1. Optical Characteristics @ TC = 25°C Table 4: Parameter Symbol Typical Unit ΦV ΦV 4400 5700 105 5500 75 110 lm lm lm/W K [1] Luminous Flux (@ IF = 700mA) Luminous Flux (@ IF = 1000mA) [1] Luminous Efficacy (@ IF = 350mA) Correlated Color Temperature Color Rendering Index (CRI) Viewing Angle [2] CCT Ra 2Θ1/2 Degrees Notes: 1. Luminous flux typical value is for all 24 LED dies operating at rated current. 2. Viewing Angle is the off-axis angle from emitter centerline where the luminous intensity is ½ of the peak value. Electrical Characteristics @ TC = 25°C Table 5: Parameter Symbol Typical Unit Forward Voltage (@ IF = 700mA) Forward Voltage (@ IF = 1000mA) [1] VF VF 18.9 /Channel 19.5 /Channel V V Temperature Coefficient of Forward Voltage [1] ΔVF/ΔTJ -16.8 mV/°C Thermal Resistance (Junction to Case) RΘJ-C 0.6 °C/W [1] Notes: 1. Forward Voltage is measured for a single string of 6 dies connected in series. The LED is configured with 4 Channels of 6 dies in series each. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 6 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin IPC/JEDEC Moisture Sensitivity Level Table 6 - IPC/JEDEC J-STD-20D.1 MSL Classification: Soak Requirements Floor Life Standard Accelerated Level Time Conditions Time (hrs) Conditions Time (hrs) Conditions 1 unlimited ≤ 30°C/ 85% RH 168 +5/-0 85°C/ 85% RH n/a n/a Notes: 1. The standard soak time includes a default value of 24 hours for semiconductor manufacturer’s exposure time (MET) between bake and bag and includes the maximum time allowed out of the bag at the distributor’s facility. Average Lumen Maintenance Projections Lumen maintenance generally describes the ability of a lamp to retain its output over time. The useful lifetime for solid state lighting devices (Power LEDs) is also defined as Lumen Maintenance, with the percentage of the original light output remaining at a defined time period. L70 defines the amount of operating hours at which the light output has reached 70% of its original output. Figure 1: De-rating curve for operation of all dies at 700mA Notes: 1. Ts is a thermal reference point on the emitter case COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 7 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Mechanical Dimensions (mm) Pin Out Ch. Pad Die Color Function 18 E CW Cathode D CW C CW na na na 1 B CW A CW na 24 F CW Anode 17 J CW I CW Cathode na H CW na G CW na L CW na 3 K CW Anode 15 O CW N CW Cathode na 2 S CW na R CW na Q CW na 5 P CW Anode 14 T CW Y CW Cathode na 3 Figure 2: Package outline drawing. X CW na W CW na V CW na 8 U CW 2 M - Anode na 23 M - na 4 Notes: 1. LZP-00xW0R pin out polarity is reversed; therefore it is not compatible with MCPCB designed for LZP00xW00 products, except for LZP-00SW00 and LZP-00GW00. 2. Index mark, Ts indicates case temperature measurement point. 3. Unless otherwise noted, the tolerance = ± 0.20 mm. 4. Thermal slug is electrically isolated 5 Recommended Solder Pad Layout (mm) +18 -24 -3 +17 +15 -5 -8 +14 +2 -23 Figure 2a: Recommended solder pad layout for anode, cathode, and thermal pad Notes: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. 2. LED Engin recommends the use of copper core MCPCB’s which allow for the emitter thermal slug to be soldered directly to the copper core (so called pedestal design). Such MCPCB technologies eliminate the high thermal resistance dielectric layer that standard MCPCB technologies use in between the emitter thermal slug and the metal core of the MCPCB, thus lowering the overall system thermal resistance. 3. LED Engin recommends x-ray sample monitoring for solder voids underneath the emitter thermal slug. The total area covered by solder voids should be less than 20% of the total emitter thermal slug area. Excessive solder voids will increase the emitter to MCPCB thermal resistance and may lead to higher failure rates due to thermal over stress. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 8 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Recommended Solder Mask Layout (mm) Figure 2b: Recommended solder mask opening for anode, cathode, and thermal pad Note for Figure 2b: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. Recommended 8 mil Stencil Apertures Layout (mm) Figure 2c: Recommended 8mil stencil apertures for anode, cathode, and thermal pad Note for Figure 2c: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 9 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Reflow Soldering Profile Figure 4: Reflow soldering profile for lead free soldering. Typical Radiation Pattern Figure 5: Typical representative spatial radiation pattern. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 10 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Typical Relative Spectral Power Distribution 1 Relative Spectral Power 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 350 400 450 500 550 600 650 700 750 800 Wavelength (nm) Figure 6: Typical relative spectral power vs. wavelength @ TC = 25°C. Typical Forward Current Characteristics 1400 IF - Forward Current (mA) 1200 1000 800 600 400 200 0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 VF - Forward Voltage (V) Figure 7: Typical forward current vs. forward voltage @ TC = at 25°C. Note: 1. Forward Voltage is measured for a single string of 6 dies connected in series. The LED is configured with 4 Channels of 6 dies in series each. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 11 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Typical Relative Light Output over Forward Current 160% 140% Relatiive Light Output 120% 100% 80% 60% 40% 20% 0% 0 200 400 600 800 1000 1200 IF - Forward Current (mA) Figure 8: Typical relative light output vs. forward current @ TC = 25°C. Notes: 1. Luminous Flux typical value is for all 24 LED dies operating concurrently at rated current per Channel. Typical Relative Light Output over Temperature Relatiive Light Output (%) 110 100 90 80 70 60 0 10 20 30 40 50 60 70 80 90 100 Case Temperature (°C) Figure 9: Typical relative light output vs. case temperature. Notes: 1. Luminous Flux typical value is for all 24 LED dies operating concurrently at rated current per Channel. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 12 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Current De-rating IF - Maximum Current (mA) 1200 1000 800 700 (Rated) 600 400 R=Θ = 2.0°C/W 1.0˚ C/W J-A= RΘJ-A R=Θ = 1.5˚ C/W J-A RΘJ-A = 3.0°C/W R=Θ = 2.0˚ C/W J-A= 4.0°C/W RΘJ-A 200 0 0 25 50 75 100 125 150 Maximum Ambient Temperature (°C) Figure 10: Maximum forward current vs. ambient temperature based on TJ(MAX) = 150°C. Notes: 1. Maximum current assumes that all LED dies are operating at rated current. 2. RΘJ-C [Junction to Case Thermal Resistance] for the LZP-series is typically 0.6°C/W. 3. RΘJ-A [Junction to Ambient Thermal Resistance] = RΘJ-C + RΘC-A [Case to Ambient Thermal Resistance]. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 13 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin LZP MCPCB Family Part number Type of MCPCB Diameter (mm) LZP-DxxxxR 5-channel (4x6+1 strings) 28.3 COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. Emitter + MCPCB Typical Vf Typical If Thermal Resistance (V) (mA) (oC/W) 0.6 + 0.1 = 0.7 18.9 4 x 700 LZP-00CW0R (1.4 - 11/09/18) 14 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin LZP-DxxxxR 5-channel, Standard Star MCPCB (4x6+1) Mechanical Dimensions (mm) Notes:  Unless otherwise noted, the tolerance = ± 0.20 mm.  Slots in MCPCB are for M3 or #4 mounting screws.  LED Engin recommends using plastic washers to electrically insulate screws from solder pads and electrical traces.  LED Engin recommends using thermal interface material when attaching the MCPCB to a heat sink.  LED Engin uses a copper core MCPCB with pedestal design, allowing direct solder connect between the MCPCB copper core and the emitter thermal slug. The thermal resistance of this copper core MCPCB is: RΘC-B 0.1°C/W Components used MCPCB: ESD chips: SuperMCPCB BZT52C36LP (Bridge Semiconductor, copper core with pedestal design) (NXP, for 6 LED dies in series) Pad layout Ch. 1 2 3 4 5 MCPCB Pad 1 10 2 9 3 8 4 7 5 6 String/die 1/EDCBAF 2/JIHGLK 3/ONSRQP 4/TYXWVU 5/M Function Anode + Cathode Anode + Cathode Anode + Cathode Anode + Cathode N/A N/A COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 15 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Application Guidelines MCPCB Assembly Recommendations A good thermal design requires an efficient heat transfer from the MCPCB to the heat sink. In order to minimize air gaps in between the MCPCB and the heat sink, it is common practice to use thermal interface materials such as thermal pastes, thermal pads, phase change materials and thermal epoxies. Each material has its pros and cons depending on the design. Thermal interface materials are most efficient when the mating surfaces of the MCPCB and the heat sink are flat and smooth. Rough and uneven surfaces may cause gaps with higher thermal resistances, increasing the overall thermal resistance of this interface. It is critical that the thermal resistance of the interface is low, allowing for an efficient heat transfer to the heat sink and keeping MCPCB temperatures low. When optimizing the thermal performance, attention must also be paid to the amount of stress that is applied on the MCPCB. Too much stress can cause the ceramic emitter to crack. To relax some of the stress, it is advisable to use plastic washers between the screw head and the MCPCB and to follow the torque range listed below. For applications where the heat sink temperature can be above 50oC, it is recommended to use high temperature and rigid plastic washers, such as polycarbonate or glass-filled nylon. LED Engin recommends the use of the following thermal interface materials: 1. Bergquist’s Gap Pad 5000S35, 0.020in thick  Part Number: Gap Pad® 5000S35 0.020in/0.508mm  Thickness: 0.020in/0.508mm  Thermal conductivity: 5 W/m-K  Continuous use max temperature: 200°C  Using M3 Screw (or #4 screw), with polycarbonate or glass-filled nylon washer (#4) the recommended torque range is: 20 to 25 oz-in (1.25 to 1.56 lbf-in or 0.14 to 0.18 N-m) 2. 3M’s Acrylic Interface Pad 5590H  Part number: 5590H @ 0.5mm  Thickness: 0.020in/0.508mm  Thermal conductivity: 3 W/m-K  Continuous use max temperature: 100°C  Using M3 Screw (or #4 screw), with polycarbonate or glass-filled nylon washer (#4) the recommended torque range is: 20 to 25 oz-in (1.25 to 1.56 lbf-in or 0.14 to 0.18 N-m) Mechanical Mounting Considerations The mounting of MCPCB assembly is a critical process step. Excessive mechanical stress build up in the MCPCB can cause the MCPCB to warp which can lead to emitter substrate cracking and subsequent cracking of the LED dies LED Engin recommends the following steps to avoid mechanical stress build up in the MCPCB: o Inspect MCPCB and heat sink for flatness and smoothness. o Select appropriate torque for mounting screws. Screw torque depends on the MCPCB mounting method (thermal interface materials, screws, and washer). o Always use three M3 or #4-40 screws with #4 washers. o When fastening the three screws, it is recommended to tighten the screws in multiple small steps. This method avoids building stress by tilting the MCPCB when one screw is tightened in a single step. o Always use plastic washers in combinations with the three screws. This avoids high point contact stress on the screw head to MCPCB interface, in case the screw is not seated perpendicular. o In designs with non-tapped holes using self-tapping screws, it is common practice to follow a method of three turns tapping a hole clockwise, followed by half a turn anti-clockwise, until the appropriate torque is reached. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 16 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin Wire Soldering   To ease soldering wire to MCPCB process, it is advised to preheat the MCPCB on a hot plate of 125-150oC. Subsequently, apply the solder and additional heat from the solder iron will initiate a good solder reflow. It is recommended to use a solder iron of more than 60W. It is advised to use lead-free, no-clean solder. For example: SN-96.5 AG-3.0 CU 0.5 #58/275 from Kester (pn: 24-7068-7601) COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 17 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin About LED Engin LED Engin, an OSRAM business based in California’s Silicon Valley, develops, manufactures, and sells advanced LED emitters, optics and light engines to create uncompromised lighting experiences for a wide range of entertainment, architectural, general lighting and specialty applications. LuxiGenTM multi-die emitter and secondary lens combinations reliably deliver industry-leading flux density, upwards of 5000 quality lumens to a target, in a wide spectrum of colors including whites, tunable whites, multi-color and UV LEDs in a unique patented compact ceramic package. Our LuxiTuneTM series of tunable white lighting modules leverage our LuxiGen emitters and lenses to deliver quality, control, freedom and high density tunable white light solutions for a broad range of new recessed and downlighting applications. The small size, yet remarkably powerful beam output and superior insource color mixing, allows for a previously unobtainable freedom of design wherever high-flux density, directional light is required. LED Engin is committed to providing products that conserve natural resources and reduce greenhouse emissions; and reserves the right to make changes to improve performance without notice. For more information, please contact LEDE-Sales@osram.com or +1 408 922-7200. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZP-00CW0R (1.4 - 11/09/18) 18 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin
LZP-D0CW0R-0000 价格&库存
很抱歉,暂时无法提供与“LZP-D0CW0R-0000”相匹配的价格&库存,您可以联系我们找货
