C503B-ACS-CY0Z0252-030
    WOLFSPEED
    插件
    LED AMBER CLEAR 5MM ROUND T/H
C503B-ACS-CY0Z0252-030 数据手册
PRODUCT FAMILY DATA SHEET C503B-Axx-015: 5-mm Round Amber LEDs PRODUCT DESCRIPTION FEATURES APPLICATIONS Round LEDs offer superior light output • Size (mm): 5 • Electronic Signs & Signals (ESS) for excellent readability in sunlight and • Motorway Signs dependable performance. They provide • Color and Typical Dominant • Variable Message Sign (VMS) extremely stable light output over long Wavelength: • Advertising Signs periods of time. Amber (591nm) • Petrol Signs • Amusement These lamps are made with an advanced optical-grade epoxy offering superior hightemperature and high-moisture-resistance • Luminous Intensity (mcd) C503B-AAS/AAN-015: (12000-32900) • Roadway Signs performance in outdoor signal and sign • Viewing angles: applications. C503B-AAS/AAN-015 15 degree minimum • Lead - Free • RoHS Compliant Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 1 C503B-Axx-015: 5-MM ROUND AMBER LEDS ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit IF 50 Note1 mA IFP 200 mA Reverse Voltage VR 5 V Power Dissipation PD 130 mW Operation Temperature Topr -40 ~ +100 °C Storage Temperature Tstg -40 ~ +100 °C Lead Soldering Temperature Tsol Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Electrostatic Discharge Classification (MIL-STD-883E) ESD Class 2 Forward Current Peak Forward Current Note2 Note: 1. For long term performance the drive currents between 10mA and 30mA are recommended. Please contact Cree LED sales representative for more information on recommended drive conditions. 2. Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) * Characteristics Symbol Condition Unit Minimum Typical Forward Voltage VF IF = 20 mA V Reverse Current IR VR = 5 V μA Dominant Wavelength λD IF = 20 mA nm 584 591 Luminous Intensity IV IF = 20 mA mcd 12000 15000 50% Power Angle 2θ½ IF = 20 mA deg 15 2.1 Maximum 2.6 100 596 Continuous reverse voltage can cause LED damage. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 2 C503B-Axx-015: 5-MM ROUND AMBER LEDS INTENSITY BIN LIMIT Amber 15° min(20 mA) - C503B-AAS/AAN-015 * Bin Code Min.(mcd) Max.(mcd) A0 12000 16800 B0 16800 23500 C0 23500 32900 Tolerance of measurement of luminous intensity is ±15% COLOR BIN LIMIT Amber (20 mA) - C503B-Axx * Bin Code Min.(nm) Max.(nm) A2 584 587 A3 587 590 A4 590 593 A5 593 596 Tolerance of measurement of dominant wavelength is ±1 nm. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 3 C503B-Axx-015: 5-MM ROUND AMBER LEDS ORDER CODE TABLE Color Amber Viewing Angle 15° Luminous Intensity (mcd) Order Code Dominant Wavelength Package Standoff 596 Bulk Yes 593 Bulk Yes A5 596 Bulk No A4 593 Bulk No 584 A5 596 Ammo Yes 587 A4 593 Ammo Yes A2 584 A5 596 Ammo No A3 587 A4 593 Ammo No Min. Max. Color Bin Min.(nm) Color Bin Max.(nm) C503B-AAS-CA0C0251-015 12000 32900 A2 584 A5 C503B-AAS-CA0C0341-015 12000 32900 A3 587 A4 C503B-AAN-CA0C0251-015 12000 32900 A2 584 C503B-AAN-CA0C0341-015 12000 32900 A3 587 C503B-AAS-CA0C0252-015 12000 32900 A2 C503B-AAS-CA0C0342-015 12000 32900 A3 C503B-AAN-CA0C0252-015 12000 32900 C503B-AAN-CA0C0342-015 12000 32900 Notes: • The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable. • Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 4 C503B-Axx-015: 5-MM ROUND AMBER LEDS GRAPHS The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. (RELATIVE LUMINOUS INTENSITY) IF (mA) 100.0 5.0 80.0 4.0 60.0 3.0 40.0 2.0 20.0 1.0 0.0 1.8 VF(V) 2.0 2.2 2.4 2.6 0.0 0.0 2.8 -60 -50 -40 -30 -20 40 60 80 IF(mA) 100 FIG.2 RELATIVE LUMINOUS INTENSITY VS. FORWARD CURRENT FIG.1 FORWARD CURRENT VS. FORWARD VOLTAGE. Vr(V) 20 (RELATIVE LUMINOUS INTENSITY) -10 0 100% -10 80% -20 60% -30 40% -40 20% 0% 300 -50 Ir(uA) FIG.3 REVERSE CURRENT VS. REVERSE VOLTAGE. IF(mA) 100 500 400 600 700 WL(nm) 800 FIG.4 RELATIVE LUMINOUS INTENSITY VS. WAVELENGTH. 50% Power Angle : 15 C503B-AAS/AAN-015 (RELATIVE LUMINOUS INTENSITY) 0 1.0 80 60 0.5 40 20 Ta( C) 40 20 60 80 100 0 FIG.5 MAXIMUM FORWARD DC CURRENT VS AMBIENT TEMPERATURE (Tjmax=110 C) 0 0 -90 -60 -30 0 30 60 Angle 90 FIG.6 FAR FIELD PATTERN © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 5 C503B-Axx-015: 5-MM ROUND AMBER LEDS MECHANICAL DIMENSIONS All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max. C503B-AAS-015: C503B-AAN-015: NOTES RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 6 C503B-Axx-015: 5-MM ROUND AMBER LEDS KIT NUMBER SYSTEM Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 7 C503B-Axx-015: 5-MM ROUND AMBER LEDS SOLDERING GUIDELINES The LED soldering specification is shown below(suitable for both leaded solder & lead-free solder): Manual Soldering Soldering iron 35 W max Temperature 300 ºC max Soldering time Position Solder Dipping Preheat 110 ºC max Preheat time 60 seconds max Solder-bath temperature 260 ºC Max 3 seconds max Dipping time 5 seconds max Not less than 3 mm from the base of the package. Position Not less than 3 mm from the base of the package. • Manual soldering onto the PCB is not recommended because soldering time is uncontrollable. • The recommended wave soldering is as below: 300 laminar wave Temperature ºC 250 200 150 100 50 30 0 Fluxing Preheat 10 20 30 40 50 60 70 Times (sec) 80 90 100 110 120 • Do not apply any stress to the LED package, particularly when heated. • Only bottom preheat is suggested & should not preheat on top in order to reduce thermal stress experienced by the LEDs. • The LEDs must not be re used once they have been extracted from PCB. • After soldering the LEDs, the package should be protected from mechanical shock or vibration until the LEDs have reached 40 ºC or below. • Precautions must be taken as mechanical stress on the LEDs may be caused by PCB warpage or from the clinching and cutting of the LED leads. • When it is necessary to clam the LEDs during soldering, it is important to ensure no mechanical stress is exerted on the LEDs. • Cut the LED lead at normal room temperature. Lead cutting at high temperature may cause failure of the LEDs. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 8 C503B-Axx-015: 5-MM ROUND AMBER LEDS PACKAGING • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. • Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. • The boxes are not water resistant, and they must be kept away from water and moisture. • Max 500 pcs per bulk and Max 2500 pcs per ammo. Bulk Pack Packaging Type: Ammo Pack Packaging Type: xxx xxx R COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT JOWAXXXXX -XX-XXX QTY RANK PCS Iv X ( ) Vf XX ( ) Hue XX ( ) AXXXXXXXXXXX Label (anti-electrostatic bag) 20 bags/carton © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1213 REV 4 9
物料型号:C503B-Axx-015
器件简介: - 这些LED灯珠采用先进的光学级环氧树脂封装,具有优越的高温和高湿环境适应性,提供出色的户外信号和标志的可读性。 - 尺寸为5毫米,颜色为琥珀色,典型主波长为591纳米。
引脚分配:文档中未明确提供引脚分配信息,但通常5毫米LED灯珠有2个引脚,一个为正极,一个为负极。
参数特性: - 正向电流:推荐长期工作电流在10mA至30mA之间。 - 峰值正向电流:不超过200mA。 - 反向电压:不超过5V。 - 功率耗散:不超过130mW。 - 工作温度范围:-40°C至+100°C。 - 存储温度范围:-40°C至+100°C。 - 引脚焊接温度:最高260°C,持续时间不超过3秒。
功能详解: - 这些LED适用于户外信号、道路标志、电子标志和信号、高速公路标志、可变信息标志、广告标志、汽油站标志和娱乐场所。 - 具有无铅且符合RoHS标准的环保特性。
应用信息: - 适用于需要在日光下具有极好可读性和长期稳定光输出的应用。
封装信息: - 提供多种不同的亮度和色温选项,以满足不同的应用需求。 - 包装类型包括散装、弹药包装、卷带包装等。
C503B-ACS-CY0Z0252-030 价格&库存
很抱歉,暂时无法提供与“C503B-ACS-CY0Z0252-030”相匹配的价格&库存,您可以联系我们找货
