C503C-WAS-CBBDB231
C503C-WAS-CBBDB231
    WOLFSPEED
    插件
    LED COOL WHITE CLEAR 5MM RND T/H
C503C-WAS-CBBDB231 数据手册
PRODUCT FAMILY DATA SHEET C503C-WAS/WAN: 5-mm Round White LEDs PRODUCT DESCRIPTION FEATURES APPLICATIONS Round LEDs offer superior light output • Size (mm): 5 • Torch for excellent readability in sunlight and • Channel Letter dependable performance. They provide • Color Temperatures: extremely stable light output over long periods of time. These lamps are made with an advanced optical-grade epoxy offering superior high- • Retail Display Lighting Cool White : Min . (4600K) / Typical (9000K) • Luminous Intensity (mcd) C503C-WAS/WAN: (20150-46100) temperature and high-moisture-resistance performance in lighting and illumination • Viewing angles: applications. This product utilizes an epoxy 15°: C503C-WAS/WAN containing a UV inhibitor. It therefore provides a UV resistance and can be used • Lead - Free in outdoor applications. • RoHS Compliant Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 1 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit IF 30 mA IFP 100 mA Reverse Voltage VR 5 V Power Dissipation PD 120 mW Operation Temperature Topr -40 ~ +95 °C Storage Temperature Tstg -40 ~ +100 °C Lead Soldering Temperature Tsol Forward Current Peak Forward Current Note 1 Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: 1. Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) Characteristics Color Symbol Condition Unit Forward Voltage WAS/WAN VF IF = 20 mA V Reverse Current WAS/WAN IR VR = 5 V μA Luminous Intensity WAS/WAN IV IF = 20 mA mcd x IF = 20 mA y IF = 20 mA 2θ½ IF = 20 mA Chromaticity Coordinates WAS/WAN 50% Power Angle WAS/WAN * Minimum Typical 3.2 Maximum 4.0 100 20150 35000 0.2895 0.2905 deg 15 Continuous reverse voltage can cause LED damage. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 2 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs INTENSITY BIN LIMIT Cool White (20 mA) - C503C-WAS/WAN * Bin Code Min.(mcd) Max.(mcd) Bb 20150 23500 Ca 23500 28200 Cb 28200 32900 Da 32900 39500 Db 39500 46100 Tolerance of measurement of luminous intensity is ±15% VOLTAGE BIN LIMIT Cool White (20 mA) - C503C-WAS/WAN * Bin Code Min. (V) Max. (V) 27 2.8 3.0 28 3.0 3.2 29 3.2 3.4 2a 3.4 3.6 2b 3.6 3.8 2c 3.8 4.0 Tolerance of measurement of voltage is ±0.05V © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 3 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs COLOR BIN LIMIT Cool White (20 mA) - C503C-WAS/WAN Bin Code Sub-bin Wa Wb W1 Wc Wd We Wf W2 Wg Wh * x y Bin Code Sub-bin x y Bin Code Sub-bin x y 0.2545 0.2480 0.2830 0.3050 0.3300 0.3600 0.2633 0.2410 0.2950 0.3210 0.3455 0.3725 0.2545 0.2245 0.2998 0.3028 0.3443 0.3535 0.2450 0.2290 0.2895 0.2905 0.3300 0.3390 Wj Wt 0.2633 0.2410 0.2895 0.2905 0.3300 0.3390 0.2720 0.2340 0.2998 0.3028 0.3443 0.3535 0.2640 0.2200 0.3045 0.2865 0.3430 0.3345 0.2545 0.2245 0.2960 0.2760 0.3300 0.3180 0.2950 0.3210 0.3455 0.3725 0.3070 0.3370 0.3610 0.3850 Wk W3 Wu W5 0.2545 0.2480 0.2640 0.2670 0.2720 0.2575 0.3100 0.3150 0.3585 0.3680 0.2633 0.2410 0.2998 0.3028 0.3443 0.3535 Wm Wv 0.2633 0.2410 0.2998 0.3028 0.3443 0.3535 0.2720 0.2575 0.3100 0.3150 0.3585 0.3680 0.2800 0.2480 0.3130 0.2970 0.3560 0.3510 0.2720 0.2340 0.3045 0.2865 0.3430 0.3345 Wn 0.2640 0.2670 0.3070 0.3370 0.2735 0.2860 0.3185 0.3485 0.2808 0.2740 0.3200 0.3270 0.2720 0.2575 0.3100 0.3150 0.2720 0.2575 0.3100 0.3150 0.2808 0.2740 0.3200 0.3270 0.2880 0.2620 0.3215 0.3075 0.2800 0.2480 0.3130 0.2970 0.2735 0.2860 0.3185 0.3485 0.2830 0.3050 0.3300 0.3600 0.2895 0.2905 0.3300 0.3390 0.2808 0.2740 0.3200 0.3270 0.2808 0.2740 0.3200 0.3270 0.2895 0.2905 0.3300 0.3390 0.2960 0.2760 0.3300 0.3180 0.2880 0.2620 0.3215 0.3075 Wp Wq W4 Wr Ws Ww Tolerance of measurement of the color coordinates is ±0.01 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 4 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs 00 K CIE CHROMATICITY DIAGRAM 00 K 50 0 .3 9 0 0 00 70 K 80 00 W 0 .1 9 0 0 0 .2 3 0 0 aW b W f 3 k h d 1 W c W n W W e q W W 0 .2 7 0 0 g W W s 2 y W j W W W u w W 10 00 W m p r W W W 90 00 K W 0K 0 .3 1 0 0 0 .2 3 0 0 W t 4 0 .3 5 0 0 5 K W v W 60 W 0 .2 7 0 0 0 .3 1 0 0 0 .3 5 0 0 0 .3 9 0 0 x © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 5 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs ORDER CODE TABLE Color Cool White Viewing Angle 15° Kit Number Luminous Intensity (mcd) Color Bin Code Package Standoff 46100 W1,W2,W3,W4,W5 Bulk Yes 46100 W2,W3 Bulk Yes Min. Max. C503C-WAS-CBbDb151 20150 C503C-WAS-CBbDb231 20150 C503C-WAS-CCaDb231 23500 46100 W2,W3 Bulk Yes C503C-WAN-CBbDb151 20150 46100 W1,W2,W3,W4,W5 Bulk No C503C-WAN-CBbDb231 20150 46100 W2,W3 Bulk No C503C-WAN-CCaDb231 23500 46100 W2,W3 Bulk No C503C-WAS-CBbDb152 20150 46100 W1,W2,W3,W4,W5 Ammo Yes C503C-WAS-CBbDb232 20150 46100 W2,W3 Ammo Yes C503C-WAS-CCaDb232 23500 46100 W2,W3 Ammo Yes C503C-WAN-CBbDb152 20150 46100 W1,W2,W3,W4,W5 Ammo No C503C-WAN-CBbDb232 20150 46100 W2,W3 Ammo No C503C-WAN-CCaDb232 23500 46100 W2,W3 Ammo No Notes: • The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable. • Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 6 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs GRAPHS The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice.                                                                                                 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 7 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs MECHANICAL DIMENSIONS All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max. C503C-WAS: C503C-WAN: NOTES RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 8 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs KIT NUMBER SYSTEM Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 9 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs SOLDERING GUIDELINES The LED soldering specification is shown below(suitable for both leaded solder & lead-free solder): Manual Soldering Soldering iron 35 W max Temperature 300 ºC max Soldering time Position Solder Dipping Preheat 110 ºC max Preheat time 60 seconds max Solder-bath temperature 260 ºC Max 3 seconds max Dipping time 5 seconds max Not less than 3 mm from the base of the package. Position Not less than 3 mm from the base of the package. • Manual soldering onto the PCB is not recommended because soldering time is uncontrollable. • The recommended wave soldering is as below: 300 laminar wave Temperature ºC 250 200 150 100 50 30 0 Fluxing Preheat 10 20 30 40 50 60 70 Times (sec) 80 90 100 110 120 • Do not apply any stress to the LED package, particularly when heated. • Only bottom preheat is suggested & should not preheat on top in order to reduce thermal stress experienced by the LEDs. • The LEDs must not be re used once they have been extracted from PCB. • After soldering the LEDs, the package should be protected from mechanical shock or vibration until the LEDs have reached 40 ºC or below. • Precautions must be taken as mechanical stress on the LEDs may be caused by PCB warpage or from the clinching and cutting of the LED leads. • When it is necessary to clam the LEDs during soldering, it is important to ensure no mechanical stress is exerted on the LEDs. • Cut the LED lead at normal room temperature. Lead cutting at high temperature may cause failure of the LEDs. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 10 C503C-WAS/WAN: 5-mm ROUND WHITE LEDs PACKAGING • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. • Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. • The boxes are not water resistant, and they must be kept away from water and moisture. • Max 500 pcs per bulk and Max 2500 pcs per ammo. Bulk Pack Packaging Type: Ammo Pack Packaging Type: xxx xxx R COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT JOWAXXXXX -XX-XXX QTY RANK PCS Iv X ( ) Vf XX ( ) Hue XX ( ) AXXXXXXXXXXX Label (anti-electrostatic bag) 20 bags/carton © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1098 REV 12 11
C503C-WAS-CBBDB231 价格&库存
很抱歉,暂时无法提供与“C503C-WAS-CBBDB231”相匹配的价格&库存,您可以联系我们找货
