TM
LTH5MM12V Series
5mm (T-1 3/4) Through Hole LED
Built in Resistor for 12VDC
LTH5MM12VFR4600 - Blue Water-Clear T-1 3/4 (5 mm) LED
HIGH
BRIGHTNESS
LED
LED
COLOR
OPTIONS
VIEWING
ANGLE
16° / 20°
12 Volt
LED
Applications
• Automotive
• Boats
• Indoor and Outdoor Indication
• Railway
• Industrial
• Electronic Devices
• Appliances and Consumer Equipments
• Residential and Landscape Lighting
• Storage Servers
• Infrastructure
Key Features
• Made with InGaN (Blue)
• RoHS and REACH Compliant
• Through-hole technology
• High-Brightness LED
• Integrated resistor for 12VDC operation
• Available in 5 colors (red, green, white,
• With Flange
blue and yellow)
• Water-Clear Lens
• Viewing Angle: 16º (red, green, yellow)
• LED Bulb Size: 5mm (T-1 3/4), also
and 20º (blue, white)
available in 3mm (T-1)
your first call for illuminated components
• Moisture Sensitive Level (MSL): 2
www.vcclite.com
1
1.800.522.5546
03/17 Rev 2
Ordering Data
The LTH5MM12V Series is available in a range of standard features and options.
To specify your LED, simply choose one option from each column.
Series
L
Mounting
Type
Size
5MM
TH
Voltage
12V
Flange
Shape Package Color Output Color LED
4
R
F
Round Top
LED
Through-Hole
Part Numbers
LTH5MM12VFR4100
LTH5MM12VFR4400
LTH5MM12VFR4500
LTH5MM12VFR4600
LTH5MM12VFR4700
Red
100
White
400
Green
500
Blue
600
Yellow
700
12V
3MM*
3mm
5MM
5mm
With Flange
Water-Clear
4
*For 3mm option, please consult
LTH3MM12V Series’ datasheet
Color
Red
White
Green
Blue
Yellow
Product Dimensions
Ø
5.9
0.23
5.0
Ø 0.20
1.0 MAX
0.04
8.7
0.34
1.0
0.04
0.7 MAX
0.03
24.0
0.94 MIN
0.5
0.02
ANODE
2.5
0.10
[1.14 + 0.38]
0.045 + 0.015
Notes:
1. All dimensions are in [millimeters] inches.
2. Tolerance is ± [0.25] 0.01 unless otherwise noted.
3. The specifications, characteristics and technical data described in the datasheet are subject to
change without prior notice.
www.vcclite.com
2
1.800.522.5546
03/17 Rev 2
Product Dimensions
(Ta=25°C)
ABSOLUTE MAXIMUM RATINGS
Parameter
Symbol
Ratings
Unit
IFP
100
mA
IF(REC)
mA
Power Dissipation
PD
85
mW
R e v e r s e Vo l t a g e
VR
5
V
Electrostatic Discharge
ESD
200
V
Operating Temperature Range
TOPR
-40~+85
°C
Storage Temperature Range
TSTG
-40~+100
°C
Lead Soldering Temperature Range
1.6mm (1/16 inch) from body
TSOL
260°C for 5 seconds
Peak Forward Current (duty 1/10 @ 1KHz)
Recommended Operating Current
OPTICAL-ELECTRICAL CHARACTERISTICS
Parameter
(Ta=25°C)
Symbol
Test Condition
Min
Typ
Max
Unit
Luminous Intensity
IV
1500
2000
3000
mcd
Peak Emission Wavelength
λP
470
nm
Dominant Wavelength
λD
465
467
470
nm
IF=12mA
F o r w ar d Volt age
VF
11
12
13
V
S p e c t r a l L in e H a lf - W id t h
Δλ
45
nm
2ϴ½
deg
10
µA
Viewing Angle
Reverse Current
IR
VR=5V
www.vcclite.com
3
1.800.522.5546
03/17 Rev 2
Product Specifications
2
10
12
14
25
10
5
16
25
Ambient Temperature = 25°C
1.2
1.0
0.8
0.6
0.4
0.2
Forward Current (mA)
Luminous Intensity vs. Forward Current
Blue
GaN
1.0
Blue
InGaN
Blue Green
InGaN
50
75
100
Ambient Temperature (°C)
Forward Current Derating Curve
Relative Luminous Intensity
Forward Voltage(V)
Forward Current vs. Forward Voltage
30
Relative Radiant Intensity
35
Forward Current If(mA)
Typical Electrical-Optical Characteristic Curves
2.0
1.0
0.1
15 30 45 60 75 90
Luminous Intensity vs. Ambient Temperature
Green Yellow
Orange Super Red Bright Red
Gap GaAsp/GaP GaAsp/GaP GaAIAs
Gap
0.5
450
500
550
600
650
700
750
Wavelength λ (nm)
Relative Intensity vs. Wavelength
www.vcclite.com
4
1.800.522.5546
03/17 Rev 2
Application Notes
1. Storage
The Storage Temperature and RH are: 5°C ~ 30°C, RH 60% or less.
We suggest our customers use our products within a year.
If the moisture absorbent material (silica gel) has faded away or the LEDs exceeded the storage
time, bake treat more than 24 hours at 60°C ±5°C.
2. Electrostatic Discharge (ESD)
Static electricity or surge voltage will damage the LEDs.
Recommendations: Use a conductive wrist band or anti-electrostatic glove when handling
these LEDs. All devices, equipment and machinery must be properly grounded.
Work tables, storage racks, etc. should be properly grounded. In the event of a manual working
in process, make sure the devices are well protected from ESD at any time.
3. Recommended Soldering Condition
Soldering heat (DIP)
Soldering heat 260°C Max.
_ 5°C Within 5 Sec.
245 +
100°C Max
Preheat
60 Sec. Max
Temperature at tip of soldering iron: 350°C Max
Soldering time: 3 sec ±1 sec (once only)
www.vcclite.com
5
1.800.522.5546
03/17 Rev 2
Application Notes
4. Reflow Profile
Temp
_ 5°C Within 5 Sec.
245 +
to rise + 5°C/sec
120~150°C
cooling - 5°C/sec
Preheat
60~120 Sec
Time
Compliances and Approvals
www.vcclite.com
6
1.800.522.5546
03/17 Rev 2
很抱歉,暂时无法提供与“LTH5MM12VFR4600”相匹配的价格&库存,您可以联系我们找货
