CLM3C-RKW-CUAVAAA3
CLM3C-RKW-CUAVAAA3
    WOLFSPEED
    SMD2
    LED RED DIFFUSED 2SMD
CLM3C-RKW-CUAVAAA3 数据手册
PRODUCT FAMILY DATA SHEET CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED PRODUCT DESCRIPTION FEATURES APPLICATIONS SMD LEDs is packaged in the industry • Size (mm): 2.7 X 2.0 • Channel Letter standard package. These LEDs have high reliability performance and are • Architectural Lighting • Color and Typical Dominant designed to work under a wide range of Wavelength: environmental conditions. Red (624nm) Amber (591nm) This high reliability feature makes them ideally suited to be used under illumination application conditions. • Luminous Intensity (mcd) CLM3C-RKW:(560-1400) CLM3C-AKW:(355-900) Its wide viewing angle makes these LEDs ideally suited for channel letter, or • Lead - Free general backlighting and illumina-tion • RoHS Compliant applications. The flat top emitting surface makes it easy for these LEDs to mate with light pipes. Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 1 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit Red/Amber Forward Current IF 50 mA IFP 200 mA Reverse Voltage VR 5 V Power Dissipation PD 130 mW Operation Temperature Topr -40 ~ +100 °C Storage Temperature Tstg -40 ~ +100 °C Junction Temperature TJ 110 °C Junction/Ambient RTHJA 450 °C/W Junction/Solder Point RTHJS 300 °C/W Electrostatic Discharge Classification (MIL-STD-883E) ESD Peak Forward Current Note1 Class 2 Note: 1. Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) Characteristics Color Symbol Condition Unit Forward Voltage RKW/AKW VF IF = 20 mA V Reverse Current RKW/AKW IR VR = 5 V μA RKW λD IF = 20 mA nm 618 624 630 AKW λD IF = 20 mA nm 584 591 596 RKW IV IF = 20 mA mcd 450 710 AKW IV IF = 20 mA mcd 355 700 Dominant Wavelength Luminous Intensity * Minimum Typical Maximum 2.1 2.6 10 Continuous reverse voltage can cause LED damage. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 2 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED INTENSITY BIN LIMIT Red(20 mA) - CLM3C-RKW * Amber (20 mA) - CLM3C-AKW Bin Code Min.(mcd) Max.(mcd) Bin Code Min.(mcd) Max.(mcd) Ua 450 560 Tb 355 450 Ub 560 710 Ua 450 560 Va 710 900 Ub 560 710 Vb 900 1120 Va 710 900 Tolerance of measurement of luminous intensity is ±10% COLOR BIN LIMIT Red (20 mA) - CLM3C-RKW * Amber (20 mA) - CLM3C-AKW Bin Code Min.(nm) Max.(nm) Bin Code Min.(nm) Max.(nm) RA 618 630 A2 584 587 A3 587 590 A4 590 593 A5 593 596 Tolerance of measurement of dominant wavelength is ±1 nm © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 3 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED ORDER CODE TABLE Color Kit Number Red Red Color Kit Number Luminous Intensity (mcd) Dominant Wavelength Min. Max. Color Bin Min. (nm) Color Bin Max. (nm) CLM3C-RKW-CUaVbAA3 450 1120 RA 618 RA 630 CLM3C-RKW-CUbVaAA3 560 900 RA 618 RA 630 Luminous Intensity (mcd) Dominant Wavelength Min. Max. Color Bin Min. (nm) Color Bin Max. (nm) Amber CLM3C-AKW-CTbVa253 355 900 A2 584 A5 596 Amber CLM3C-AKW-CUbVa353 560 900 A3 587 A5 596 Notes: • The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable. • Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 4 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED GRAPHS The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. (RELATIVE LUMINOUS INTENSITY) IF (mA) 100.0 5.0 80.0 4.0 Red 60.0 3.0 Red Amber 40.0 2.0 Amber 20.0 1.0 0.0 1.8 VF(V) 2.0 2.2 2.6 2.4 2.8 -60 -50 -40 -30 -20 0.0 40 20 60 80 IF(mA) 100 FIG.2 RELATIVE LUMINOUS INTENSITY VS. FORWARD CURRENT FIG.1 FORWARD CURRENT VS. FORWARD VOLTAGE. Vr(V) 0.0 -10 0 (RELATIVE LUMINOUS INTENSITY) 100% -10 80% -20 60% -30 40% -40 20% Amber -50 Ir(uA) FIG.3 RED&AMBER REVERSE CURRENT VS. REVERSE VOLTAGE. 0% 300 400 500 Red 600 700 WL(nm) 800 FIG.4 RELATIVE LUMINOUS INTENSITY VS. WAVELENGTH. (RELATIVE LUMINOUS INTENSITY) IF(mA) 1.0 100 80 60 Rth j-s=300 C/W 0.5 40 Rth j-a=450 C/W 20 0 0 20 40 60 80 Ta( C) 100 FIG.5 RED&AMBER MAXIMUM FORWARD DC CURRENT VS AMBIENT TEMPERATURE (Tjmax=110 C) 0 -90 Angle -60 -30 0 30 60 90 FIG.6 FAR FIELD PATTERN © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 5 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED MECHANICAL DIMENSIONS All dimensions are in mm. NOTES RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 6 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED KIT NUMBER SYSTEM Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 7 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED REFLOW SOLDERING • The CLM3C-RKW/AKW is rated as a MSL 5a product. Document No.: COTCO-05-0057 Rev. NO. : 13 • The recommended floor life out of bag is 24hrs. • The temperature profile is as below. Temperature Melting-point Pre-heat Soak Reflow Cooling Time Use all SMD besides LP6-NPP1-01-N1 Use only with=CLM3C-RKW/AKW Solder Sn63-Pb37 Solder = Lead-free Average ramp-up rate = 4ºC/s max. Average ramp-up rate = 4ºC/s max Preheat temperature = 100ºC ~150ºC Preheat temperature = 150ºC ~200ºC Preheat time Preheat = 100stemperature max. = 150ºC ~200ºC Preheat time = 100s max. Ramp-down rate =Preheat 6ºC/stime max. = 120s max Ramp-down rate = 6ºC/s max. Ramp-down = 6ºC/s max Peak temperature = 230ºCrate max. Peak temperature = 250ºC max. Solder Average ramp-up rate = 4ºC/s max Time within temperature = 235ºC max 5ºCPeak of actual Peak Temperature = 10s max. Time within 5ºC of actual Peak Temperature = 10s max Duration above 183ºC is 80s max. Duration above 217ºC is 45s pick up max SMD [13] Document No.: CREE-05-0 Rev. NO. : 16 Time within 5ºC of actual Peak Temperature = 10s max. Duration above 217ºC is 80s max. products during the process of SMT production . If handling is necessary, it should ta Only use LP6-NPP1-01-N1 careful to pick Theis following two solidification. methods areUsers necessary : • The packaging sizes of these SMD products are up verythese smallproducts. and the resin still soft after are required to handle Solder = Lowtouch Lead-free with care. Never the resin surface of SMD products. • To Average avoid damaging product’s ramp-upthe rate = 3ºC/ssurface max. and interior device, it is recommended to choose a special nozzle to pick up the SMD products the process of SMT production. If handling is necessary, take special care when picking up these products. The Preheatduring temperature = 130ºC ~170ºC following method is necessary: Preheat time = 120s max. Fig. 1a: For Small Top SMD Fig. 1b: For Mini side 0.8mm SMD • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. Ramp-down rate = 6ºC/s max. Peak temperature = 213ºC max. Time within 3ºC of actual Peak Temperature = 25s max. Duration above 200ºC is 40s max. Recommended solder pad design for heat dissipation (2-pin SMD LED):  7.0 series , it is recommended to use rubber material Nozzle to pick up SMD produ For Small Top SMD figure size for reference : 2.6 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 a.) Circular Nozzle: inner diameter: Ø1.8mm+/-0.05mm, outer diameter: Ø2.3mm+/-0.05mm. 8 CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED PACKAGING • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. • Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. • The boxes are not water resistant, and they must be kept away from water and moisture. • The reel pack is applied in SMD LED. • Max 3000 pcs per reel. CARRIER TAPE PACKAGE MARKING 4.0 3.3 2.25 T APE FEED DIRECTION 8.0 1.75 4.0 3.5 1.5 COVER TAPE REEL(178x8mm) Label HUMIDITY INDICATOR HUMICHECK H UMIDITY IN DICA TOR DAN GE RO US DO N O T EAT DESICCANT Av oid etal Contact w ww .v itapac.com V102 Label POLYETHYLENE BAG Label A CARTON (240x220x35mm) © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1156 REV 9 9
CLM3C-RKW-CUAVAAA3 价格&库存
很抱歉,暂时无法提供与“CLM3C-RKW-CUAVAAA3”相匹配的价格&库存,您可以联系我们找货
