CLM3C-MKW-CWAXB513
CLM3C-MKW-CWAXB513
    WOLFSPEED
    SMD2
    LED WARM WHITE DIFFUSED 2SMD
CLM3C-MKW-CWAXB513 数据手册
PRODUCT FAMILY DATA SHEET CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED PRODUCT DESCRIPTION FEATURES APPLICATIONS SMD LEDs is packaged in the industry • Size (mm): 2.7 X 2.0 • Channel Letter standard package. These LEDs have high reliability performance and are • Backlight • Color Temperatures: designed to work under a wide range of environmental conditions. This high reliability feature makes Cool White : Min . (4600K) / Typical (5500K) Warm White : Min . (2500K) / Typical (3200K) them ideally suited to be used under illumination application conditions. • Luminous Intensity (mcd) Its wide viewing angle makes these CLM3C-WKW:(1400-3550) LEDs ideally suited for channel letter, or CLM3C-MKW:(1120-2800) general backlighting and illumina-tion applications. The flat top emitting surface • CRI: makes it easy for these LEDs to mate with light pipes. Typical CRI for Cool White is 72 Typical CRI for Warm White is 80 • Lead - Free • RoHS Compliant Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 1 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit IF 25 mA IFP 100 mA Reverse Voltage VR 5 V Power Dissipation PD 100 mW Operation Temperature Topr -40 ~ +100 °C Storage Temperature Tstg -40 ~ +100 °C Junction Temperature TJ 110 °C Junction/Ambient RTHJA 350 °C/W Junction/Solder Point RTHJS 300 °C/W Forward Current Peak Forward Current Note 1 Note: 1. Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) Characteristics Color Symbol Condition Unit Forward Voltage Cool/Warm VF IF = 20 mA V Reverse Current Cool/Warm IR VR = 5 V μA Cool ΦV IF = 20 mA lm Warm ΦV IF = 20 mA lm Cool IV IF = 20 mA mcd 1400 Warm IV IF = 20 mA mcd 1120 x IF = 20 mA 0.3325 Luminous Flux Luminous Intensity Cool Chromaticity Coordinates Warm * Minimum Typical Maximum 3.2 4.0 10 4200 4000 1850 1560 y IF = 20 mA 0.3411 x IF = 20 mA 0.4234 y IF = 20 mA 0.3990 Continuous reverse voltage can cause LED damage. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 2 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED INTENSITY BIN LIMIT Cool White (20 mA) - CLM3C-WKW * Bin Code Min.(mcd) Max.(mcd) Wb 1400 Xa 1800 Xb 2240 Ya 2800 Warm White (20 mA) - CLM3C-MKW Bin Code Min.(mcd) Max.(mcd) 1800 Wa 1120 1400 2240 Wb 1400 1800 2800 Xa 1800 2240 3550 Xb 2240 2800 Tolerance of measurement of luminous intensity is ±10% VOLTAGE BIN LIMIT Cool White (20 mA) - CLM3C-WKW * Warm White (20 mA) -CLM3C-MKW Bin Code Min. (V) Max. (V) Bin Code Min. (V) Max. (V) 27 2.8 3.0 27 2.8 3.0 28 3.0 3.2 28 3.0 3.2 29 3.2 3.4 29 3.2 3.4 2a 3.4 3.6 2a 3.4 3.6 2b 3.6 3.8 2b 3.6 3.8 2c 3.8 4.0 2c 3.8 4.0 Tolerance of measurement of voltage is ±0.05V © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 3 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED COLOR BIN LIMIT Cool White (20 mA) - CLM3C-WKW Bin Code Sub-bin Wa Wb W1 Wc Wd We Wf W2 Wg Wh * x y Bin Code Sub-bin x y Bin Code Sub-bin x y 0.2545 0.2480 0.2830 0.3050 0.3300 0.3600 0.2633 0.2410 0.2950 0.3210 0.3455 0.3725 0.2545 0.2245 0.2998 0.3028 0.3443 0.3535 0.2450 0.2290 0.2895 0.2905 0.3300 0.3390 Wj Wt 0.2633 0.2410 0.2895 0.2905 0.3300 0.3390 0.2720 0.2340 0.2998 0.3028 0.3443 0.3535 0.2640 0.2200 0.3045 0.2865 0.3430 0.3345 0.2545 0.2245 0.2960 0.2760 0.3300 0.3180 0.2950 0.3210 0.3455 0.3725 0.3070 0.3370 0.3610 0.3850 Wk W3 Wu W5 0.2545 0.2480 0.2640 0.2670 0.2720 0.2575 0.3100 0.3150 0.3585 0.3680 0.2633 0.2410 0.2998 0.3028 0.3443 0.3535 Wm Wv 0.2633 0.2410 0.2998 0.3028 0.3443 0.3535 0.2720 0.2575 0.3100 0.3150 0.3585 0.3680 0.2800 0.2480 0.3130 0.2970 0.3560 0.3510 0.2720 0.2340 0.3045 0.2865 0.3430 0.3345 Wn 0.2640 0.2670 0.3070 0.3370 0.2735 0.2860 0.3185 0.3485 0.2808 0.2740 0.3200 0.3270 0.2720 0.2575 0.3100 0.3150 0.2720 0.2575 0.3100 0.3150 0.2808 0.2740 0.3200 0.3270 0.2880 0.2620 0.3215 0.3075 0.2800 0.2480 0.3130 0.2970 0.2735 0.2860 0.3185 0.3485 0.2830 0.3050 0.3300 0.3600 0.2895 0.2905 0.3300 0.3390 0.2808 0.2740 0.3200 0.3270 0.2808 0.2740 0.3200 0.3270 0.2895 0.2905 0.3300 0.3390 0.2960 0.2760 0.3300 0.3180 0.2880 0.2620 0.3215 0.3075 Wp Wq W4 Wr Ws Ww Tolerance of measurement of the color coordinates is ±0.01 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 4 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED COLOR BIN LIMIT Warm White (20 mA) - CLM3C-MKW Bin Code Sub-bin Ma Mb M1 Mc Md * x y Bin Code Sub-bin x y Bin Code Sub-bin x y 0.3610 0.3900 0.4030 0.4250 0.4490 0.4530 0.3576 0.3651 0.3926 0.3915 0.4310 0.4128 0.3751 0.3783 0.4118 0.4021 0.4572 0.4203 0.3820 0.4075 0.4260 0.4390 0.4785 0.4625 Me Mj 0.3576 0.3651 0.3926 0.3915 0.4310 0.4128 0.3541 0.3401 0.3822 0.3580 0.4129 0.3726 0.3682 0.3491 0.3976 0.3653 0.4359 0.3782 0.3749 0.3781 0.4118 0.4021 0.4572 0.4203 0.4260 0.4390 0.4785 0.4625 0.4118 0.4021 0.4572 0.4203 Mf M2 Mk M3 0.3820 0.4075 0.3751 0.3783 0.3926 0.3915 0.4310 0.4128 0.4834 0.4279 0.4030 0.4250 0.4490 0.4530 0.5080 0.4720 Mg Mm 0.3751 0.3783 0.4118 0.4021 0.4572 0.4203 0.3682 0.3491 0.3976 0.3653 0.4359 0.3782 0.3822 0.3580 0.4129 0.3725 0.4588 0.3838 0.3926 0.3915 0.4310 0.4128 0.4834 0.4279 Mh Mn Tolerance of measurement of the color coordinates is ±0.01 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 5 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED CIE CHROMATICITY DIAGRAM 0.5300 0.4700 M3 M 2 Mm Mj Mg M 0K 500 W W 3 W W W 1 W W 0.2300 0.2300 a c W W g e W W p W Ma r W W t W W v Mb Mf Mn Mh Md w u Mk Mc 5 W 60 00 K 4 W 70 00 K 80 00 K W 2 0.2900 W m W j W W W W 10 00 0K 9 00 0K y 0.3500 0.1700 0.1700 Me 1 0.4100 2700K 2500K 3000K 3500K 4000K s q n k h f d b 0.2900 0.3500 0.4100 0.4700 0.5300 x © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 6 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED ORDER CODE TABLE Color Cool White Color Warm White Kit Number Luminous Intensity (mcd) Color Bin Code Min. Max. CLM3C-WKW-CWbYa153 1400 3550 W1,W2,W3,W4,W5 CLM3C-WKW-CWbYa453 1400 3550 W4,W5 CLM3C-WKW-CXaYa453 1800 3550 W4,W5 Kit Number Luminous Intensity (mcd) Color Bin Code Min. Max. CLM3C-MKW-CWaXb133 1120 2800 M1,M2,M3 CLM3C-MKW-CWaXb513 1120 2800 W5,M1 CLM3C-MKW-CWaXb233 1120 2800 M2,M3 CLM3C-MKW-CWbXb513 1400 2800 W5,M1 CLM3C-MKW-CWbXb233 1400 2800 M2,M3 Notes: • The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable. • Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 7 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED GRAPHS The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. 50.0 (RELATIVE LUMINOUS INTENSITY) IF (mA) 5.0 40.0 4.0 30.0 3.0 20.0 2.0 10.0 1.0 0.0 2.8 3.0 3.2 3.4 3.6 FIG.1 FORWARD CURRENT VS. VF(V) 3.8 -50 -40 -30 -20 20 10 30 40 50 FIG.2 RELATIVE LUMINOUS INTENSITY VS. FORWARD VOLTAGE. Vr(V) IF(mA) 0.0 0 FORWARD CURRENT -10 0 (RELATIVE LUMINOUS INTENSITY) 0 100% -10 80% -20 60% 3700K - 5000K CCT -30 40% 2600K - 3700K CCT -40 20% 5000K - 10000K CCT FIG.3 REVERSE CURRENT VS. REVERSE VOLTAGE. -50 Ir(uA) 0% 400 450 500 550 600 650 700 FIG.4 RELATIVE LUMINOUS INTENSITY VS. WAVELENGTH. WL(nm) 750 (RELATIVE LUMINOUS INTENSITY) IF(mA) 1.0 50 40 30 Rth j-s=300 C/W 0.5 20 10 Rth j-a=350 C/W Ta( C) 40 20 60 80 100 0 FIG.5 MAXIMUM FORWARD DC CURRENT VS AMBIENT TEMPERATURE (Tjmax=110 C) 0 0 -90 Angle -60 -30 FIG.6 FAR FIELD PATTERN 0 30 60 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. 90 CLD-CT1076 REV 8 8 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED MECHANICAL DIMENSIONS All dimensions are in mm. NOTES RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 9 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED KIT NUMBER SYSTEM Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 10 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED REFLOW SOLDERING • The CLM3C-WKW/MKW is rated as a MSL 5a product. Document No.: COTCO-05-0057 Rev. NO. : 13 • The recommended floor life out of bag is 24hrs. • The temperature profile is as below. Temperature Melting-point Pre-heat Soak Reflow Cooling Time Use all SMD besides LP6-NPP1-01-N1 Use only with=CLM3C-WKW/MKW Solder Sn63-Pb37 Solder = Lead-free Average ramp-up rate = 4ºC/s max. Average ramp-up rate = 4ºC/s max Preheat temperature = 100ºC ~150ºC Preheat temperature = 150ºC ~200ºC Preheat time Preheat = 100stemperature max. = 150ºC ~200ºC Preheat time = 100s max. Ramp-down rate =Preheat 6ºC/stime max. = 120s max Ramp-down rate = 6ºC/s max. Ramp-down = 6ºC/s max Peak temperature = 230ºCrate max. Peak temperature = 250ºC max. Solder Average ramp-up rate = 4ºC/s max Time within temperature = 250ºC max 5ºCPeak of actual Peak Temperature = 10s max. Time within 5ºC of actual Peak Temperature = 10s max Duration above 183ºC is 80s max. Duration above 217ºC is 60s pick up max SMD [13] Document No.: CREE-05-0 Rev. NO. : 16 Time within 5ºC of actual Peak Temperature = 10s max. Duration above 217ºC is 80s max. products during the process of SMT production . If handling is necessary, it should ta Only use LP6-NPP1-01-N1 careful to pick Theis following two solidification. methods areUsers necessary : • The packaging sizes of these SMD products are up verythese smallproducts. and the resin still soft after are required to handle Solder = Lowtouch Lead-free with care. Never the resin surface of SMD products. • To Average avoid damaging product’s ramp-upthe rate = 3ºC/ssurface max. and interior device, it is recommended to choose a special nozzle to pick up the SMD products the process of SMT production. If handling is necessary, take special care when picking up these products. The Preheatduring temperature = 130ºC ~170ºC following method is necessary: Preheat time = 120s max. Fig. 1a: For Small Top SMD Fig. 1b: For Mini side 0.8mm SMD • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. Ramp-down rate = 6ºC/s max. Peak temperature = 213ºC max. Time within 3ºC of actual Peak Temperature = 25s max. Duration above 200ºC is 40s max. Recommended solder pad design for heat dissipation (2-pin SMD LED):  7.0 series , it is recommended to use rubber material Nozzle to pick up SMD produ For Small Top SMD figure size for reference : 2.6 © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 a.) Circular Nozzle: inner diameter: Ø1.8mm+/-0.05mm, outer diameter: Ø2.3mm+/-0.05mm. 11 CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED PACKAGING • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. • Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. • The boxes are not water resistant, and they must be kept away from water and moisture. • The reel pack is applied in SMD LED. • Max 3000 pcs per reel. CARRIER TAPE PACKAGE MARKING 4.0 3.3 2.25 T APE FEED DIRECTION 8.0 1.75 4.0 3.5 1.5 COVER TAPE REEL(178x8mm) Label HUMIDITY INDICATOR HUMICHECK H UMIDITY IN DICA TOR DAN GE RO US DO N O T EAT DESICCANT Av oid etal Contact w ww .v itapac.com V102 Label POLYETHYLENE BAG Label A CARTON (240x220x35mm) © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1076 REV 8 12
CLM3C-MKW-CWAXB513 价格&库存
很抱歉,暂时无法提供与“CLM3C-MKW-CWAXB513”相匹配的价格&库存,您可以联系我们找货
