CLD-CT876.008
PRODUCT FAMILY DATA SHEET
Cree® 5mm Round LED
C503B-WAN
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
Round LEDs offer superior light out-
• Size (mm): 5
• Torch
put for excellent readability in sun-
• Color Temperatures(K):
Cool White :
Min . (4600) / Typical (9000)
• Light Strip
light and dependable performance.
They provide extremely stable light
output over long periods of time.
These lamps are made with an
advanced optical grade epoxy
offering superior high temperature
and high moisture resistance
• Luminous Intensity (mcd)
C503B-WAN (20150-46100)
• Channel Letter
• Retail Display Lighting
• Viewing angle: 15 degree
• Lead-Free
• RoHS Compliant
performance in lighting and
WWW.CREE.COM/HB
illumination applications.
Copyright © 2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice.
the Cree logo are registered trademarks of Cree, Inc.
Cree, the Cree logo and XLamp are registered trademarks of Cree, Inc.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
www.cree.com/xlamp
Cree 5-mm Round LED
C503B-WAN
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
IF
25
mA
IFP
100
mA
Reverse Voltage
VR
5
V
Power Dissipation
PD
100
mW
Operation Temperature
Topr
-40 ~ +95
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Lead Soldering Temperature
Tsol
Forward Current
Peak Forward Current
Note
Max. 260°C for 3 sec. max.
(3 mm from the base of the epoxy bulb)
Note: Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Symbol
Condition
Unit
Forward Voltage
VF
IF = 20 mA
V
Reverse Current
IR
VR = 5 V
μA
Luminous Intensity
IV
IF = 20 mA
mcd
Chromaticity
Coordinates
x
IF = 20 mA
y
IF = 20 mA
2θ½
IF = 20 mA
50% Power Angle
Minimum
Typical
Maximum
3.2
4.0
100
20150
34000
0.2895
0.2905
deg
15
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks
Copyright
© 2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc.
of Cree, Inc.
2
Cree 5-mm Round LED
C503B-WAN
INTENSITY BIN LIMIT (IF = 20 mA)
Cool White
Bin Code
Min.
(mcd)
Max.
(mcd)
Bb
20150
23500
Ca
23500
28200
Cb
28200
32900
Da
32900
39500
Db
39500
46100
• Tolerance of measurement of luminous intensity is ±15%
VF BIN LIMIT (IF = 20 mA)
Cool White
Bin Code
Min. (V)
Max. (V)
27
2.8
3.0
28
3.0
3.2
29
3.2
3.4
2a
3.4
3.6
2b
3.6
3.8
2c
3.8
4.0
• Tolerance of measurement of VF is ±0.05V.
Copyright
of Cree, Inc.
3
Cree 5-mm Round LED
C503B-WAN
COLOR BIN LIMIT (IF = 20 mA)
Cool White
Bin
Code
Subbin
Wa
Wb
W1
Wc
Wd
We
Wf
W2
Wg
Wh
x
y
0.2545
0.2633
0.2545
0.2245
0.2450
0.2633
Bin
Code
Subbin
x
y
0.2480
0.2830
0.2410
0.2950
0.2998
0.3028
0.2290
0.2895
0.2410
0.2895
0.2720
0.2340
0.2640
0.2200
0.2545
0.2245
0.2545
0.2480
0.2640
0.2670
0.2720
0.2575
0.2633
Bin
Code
Subbin
x
y
0.3050
0.3300
0.3600
0.3210
0.3455
0.3725
0.3443
0.3535
0.2905
0.3300
0.3390
0.2905
0.3300
0.3390
0.2998
0.3028
0.3443
0.3535
0.3045
0.2865
0.3430
0.3345
0.2960
0.2760
0.3300
0.3180
0.2950
0.3210
0.3455
0.3725
0.3070
0.3370
0.3610
0.3850
0.3100
0.3150
0.3585
0.3680
0.2410
0.2998
0.3028
0.3443
0.3535
0.2633
0.2410
0.2998
0.3028
0.3443
0.3535
0.2720
0.2575
0.3100
0.3150
0.3585
0.3680
0.2800
0.2480
0.3130
0.2970
0.3560
0.3510
0.2720
0.2340
0.3045
0.2865
0.3430
0.3345
0.2640
0.2670
0.3070
0.3370
0.2735
0.2860
0.3185
0.3485
0.2808
0.2740
0.3200
0.3270
0.2720
0.2575
0.3100
0.3150
0.2720
0.2575
0.3100
0.3150
0.2808
0.2740
0.3200
0.3270
0.2880
0.2620
0.3215
0.3075
0.2800
0.2480
0.3130
0.2970
0.2735
0.2860
0.3185
0.3485
0.2830
0.3050
0.3300
0.3600
0.2895
0.2905
0.3300
0.3390
0.2808
0.2740
0.3200
0.3270
0.2808
0.2740
0.3200
0.3270
0.2895
0.2905
0.3300
0.3390
0.2960
0.2760
0.3300
0.3180
0.2880
0.2620
0.3215
0.3075
Wj
Wk
W3
Wm
Wn
Wp
Wq
W4
Wr
Ws
Wt
Wu
W5
Wv
Ww
• Tolerance of measurement of the color coordinates is ±0.01.
Copyright
of Cree, Inc.
4
Cree 5-mm Round LED
C503B-WAN
00
K
CIE CHROMATICITY DIAGRAM
00
K
50
0 .3 9 0 0
0 .1 9 0 0
0 .2 3 0 0
W
aW
c
b
W
f
3
k
W
h
2
W
n
d
1
W
e
q
s
W
W
0 .2 7 0 0
g
W
W
w
W
y
W
j
W
W
W
u
W
W
00
90
10
00
W
m
p
r W
t
4
K
K
80
00
W
W
0K
0 .3 1 0 0
0 .2 3 0 0
W
70
0 .3 5 0 0
5
00
K
W
v
W
60
W
0 .2 7 0 0
0 .3 1 0 0
0 .3 5 0 0
0 .3 9 0 0
x
Copyright
of Cree, Inc.
5
Cree 5-mm Round LED
C503B-WAN
ORDER CODE TABLE*
Color
Kit Number
Viewing Angle
Cool White
C503B-WAN-CBbDb151
Cool White
C503B-WAN-CCaDb151
Cool White
Cool White
Cool White
Color Bin Code
Package
Min.
Max.
15
20150
46100
W1,W2,W3,W4,W5
Bulk
15
23500
46100
W1,W2,W3,W4,W5
Bulk
C503B-WAN-CBbDb231
15
20150
46100
W2,W3
Bulk
C503B-WAN-CCaDb341
15
23500
46100
W3,W4
Bulk
C503B-WAN-CBbDb152
15
20150
46100
W1,W2,W3,W4,W5
Ammo
Cool White
C503B-WAN-CCaDb152
15
23500
46100
W1,W2,W3,W4,W5
Ammo
Cool White
C503B-WAN-CBbDb232
15
20150
46100
W2,W3
Ammo
Cool White
C503B-WAN-CCaDb342
15
23500
46100
W3,W4
Ammo
Notes:
1. The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one
intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin
codes will not be orderable.
2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions.
3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED
product safely.
Copyright
of Cree, Inc.
6
Cree 5-mm Round LED
C503B-WAN
GRAPHS
The above data are collected from statistical figures that do not necessarily correspond to the actual
parameters of each single LED. Hence, these data will be changed without further notice.
Copyright
of Cree, Inc.
7
Cree 5-mm Round LED
C503B-WAN
MECHANICAL DIMENSIONS
All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted.
An epoxy meniscus may extend about 1.5 mm down the leads.
Burr around bottom of epoxy may be 0.5 mm max.
NOTES
RoHS Compliance
The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/
EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as
amended through April 21, 2006.
Vision Advisory Claim
Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye.
Copyright
of Cree, Inc.
8
Cree 5-mm Round LED
C503B-WAN
KIT NUMBER SYSTEM
All dimensions in mm.Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color,
forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to
the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
Copyright
of Cree, Inc.
9
Cree 5-mm Round LED
C503B-WAN
PACKAGING
Features:
The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation.
The boxes are not water resistant, and they must be kept away from water and moisture.
The Bulk Pack types of packaging.
Max 500 pcs per bulk and Max 2500 pcs per ammo.
Bulk Pack Packaging Type:
Ammo Pack Packaging Type:
xxx xxx
R
COLOR LED LAMP
TYPE
LXXXXXXXX-XXX
LOT
JOWAXXXXX -XX-XXX
QTY
RANK
PCS
Iv
X
Vf
XX
Hue
XX
AXXXXXXXXXXX
Label
(anti-electrostatic
bag)
20 bags/carton
Copyright
of Cree, Inc.
10
