LTT67S-N2R2-25-0-10-R18-Z 数据手册
2014-04-04
TOPLED
Datasheet
Version 1.1 (not for new design)
LT T67S
TOPLED, SMT LED with integrated reflector. With our
great experience in SMT LED we are able to offer a
high quality product for all kind of applications.
TOPLED, SMT-LED mit integriertem Reflektor. Mit
unserer großen Erfahrung in SMT LED sind wir in der
Lage, ein qualitativ hochwertiges Produkt für alle Arten
von Anwendungen anzubieten.
Features:
Besondere Merkmale:
• Package: white PLCC-2 package, colorless clear
resin
• Technology: InGaN
• Viewing angle at 50 % IV: 120° (Lambertian
Emitter)
• Color: true green (528 nm)
• Corrosion Robustness: Improved corrosion
robustness
• Gehäusetyp: weisses PLCC-2 Gehäuse,
farbloser klarer Verguss
• Technologie: InGaN
• Abstrahlwinkel bei 50 % IV: 120° (Lambertscher
Strahler)
• Farbe: true green (528 nm)
• Korrosionsstabilität: Verbesserte
Applications
Anwendungen
Optical Indicator
Backlighting
Automotive Interior Lighting
Signal and Symbol Luminary
2014-04-04
1
Optischer Indikator
Hinterleuchtung
Automobilbeleuchtung innen
Signal- und Symbolleuchten
LT T67S
Ordering Information
Bestellinformation
Type:
Luminous Intensity
Ordering Code
1) page 21
Lichtstärke 1) Seite 21
Typ:
Bestellnummer
IF = 10 mA
IV [mcd]
LT T67S-N2R2-25
Note:
35.5 ... 180
Q65110A2555
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. LT T67S-N2R2-25 means that only one group N2, P1, P2, Q1, Q2, R1,
R2 will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where wavelength groups are measured and binned, single wavelength groups will be shipped on any one packing unit.
E. g. LT T67S-N2R2-25 means that only one wavelength group 2,3,4,5 will be shippable. LT T67S-N2R2-25 means that the device will be shipped
within the specified limits as stated on page 5. In order to ensure availability, single wavelength groups will not be orderable (see page 5).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LT T67S-N2R2-25 bedeutet, dass in einer Verpackungseinheit nur eine
der Helligkeitsgruppen N2, P1, P2, Q1, Q2, R1, R2 enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht
bestellt werden.
Gleiches gilt für die Farben, bei denen Wellenlängengruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine
Wellenlängengruppe geliefert. Z. B. LT T67S-N2R2-25 bedeutet, dass in einer Verpackungseinheit nur eine der Wellenlängengruppen 2,3,4,5
enthalten ist (siehe Seite 5). LT T67S-N2R2-25 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit
zu gewährleisten, können einzelne Wellenlängengruppen nicht bestellt werden.
2014-04-04
2
LT T67S
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 100
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 100
°C
Junction temperature
Sperrschichttemperatur
Tj
125
°C
Forward current
Durchlassstrom
(TS = 25 °C)
IF
15
mA
Surge current
Stoßstrom
(t ≤ 10 µs; D = 0.005; TS = 25 °C)
IFM
150
mA
Reverse voltage 2) page 21
Sperrspannung 2) Seite 21
(TS = 25 °C)
VR
5
V
ESD withstand voltage
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM)
VESD
up to 2
kV
2014-04-04
3
LT T67S
Characteristics (TS = 25 °C; IF = 10 mA)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Wavelength at peak emission
Wellenlänge d. emittierten Lichtes
(typ.)
λpeak
523
nm
Dominant Wavelength 3) page 21
Dominantwellenlänge 3) Seite 21
(min.)
(typ.)
(max.)
λdom
λdom
λdom
517
528
541
nm
nm
nm
Spectral bandwidth at 50% Irel max
Spektrale Bandbreite b. 50% Irel max
(typ.)
∆λ
33
nm
(typ.)
2ϕ
120
Forward voltage 4) page 21
Durchlassspannung 4) Seite 21
(min.)
(typ.)
(max.)
VF
VF
VF
2.60
3.20
4.00
V
V
V
Reverse current
Sperrstrom
(VR = 5 V)
(typ.)
(max.)
IR
IR
0.01
10
µA
µA
Temperature coefficient of λpeak
Temperaturkoeffizient von λpeak
(-10°C ≤ T ≤ 100°C)
(typ.)
TCλpeak
0.04
nm/K
Temperature coefficient of λdom
Temperaturkoeffizient von λdom
(-10°C ≤ T ≤ 100°C)
(typ.)
TCλdom
0.04
nm/K
Temperature coefficient of VF
Temperaturkoeffizient von VF
(-10°C ≤ T ≤ 100°C)
(typ.)
TCV
-3.60
mV/K
Real thermal resistance junction / ambient
(max.)
Rth JA real
400
K/W
(max.)
Rth JS real
180
K/W
5) page 21 , 6) page 21
Realer Wärmewiderstand Sperrschicht /
Umgebung 5) Seite 21 , 6) Seite 21
Real thermal resistance junction / solder point
6) page 21
Realer Wärmewiderstand Sperrschicht / Lötpad
6) Seite 21
2014-04-04
4
LT T67S
Brightness Groups
Helligkeitsgruppen
Group
Gruppe
Luminous Intensity
Luminous Intensity
1) page 21
1) page 21
Lichtstärke
1) Seite 21
Luminous Flux 7) page 21
Lichtstrom 7) Seite 21
(min.) Iv [mcd]
(max.) Iv [mcd]
(typ.) ΦV [mlm]
N2
35.5
45
120
P1
45
56
150
P2
56
71
190
Q1
71
90
240
Q2
90
112
300
R1
112
140
380
R2
140
180
480
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness groups
of only a few brightness groups. Individual brightness groups cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die aus
nur wenigen Helligkeitsgruppen besteht. Einzelne Helligkeitsgruppen sind nicht bestellbar.
Dominant Wavelength Groups 3) page 21
Dominant Wellenlängengruppen 3) Seite 21
Group
true green
Gruppe
(min.) λdom
[nm]
(max.) λdom
[nm]
2
517
523
3
523
529
4
529
535
5
535
541
Note:
No packing unit / tape ever contains more than one color group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Farbe enthalten.
2014-04-04
5
LT T67S
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: N2-2
Beispiel: N2-2
Brightness
Helligkeit
Wavelength
Wellenlänge
N2
2
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2014-04-04
6
LT T67S
Relative Spectral Emission - V(λ) = Standard eye response curve 7) page 21
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 7) Seite 21
Irel = f (λ); TS = 25 °C; IF = 10 mA
OHL01493
100
I rel
80
Vλ
60
true green
40
450
500
550
650
600
nm
700
λ
Radiation Characteristics 7) page 21
Abstrahlcharakteristik 7) Seite 21
Irel = f (ϕ); TS = 25 °C
40˚
30˚
20˚
10˚
0˚
ϕ
50˚
OHL01660
1.0
0.8
0.6
60˚
0.4
70˚
0.2
80˚
90˚
100˚
1.0
2014-04-04
0.8
0.6
0.4
0˚
20˚
7
40˚
60˚
80˚
100˚
120˚
LT T67S
Forward Current 7) page 21
Durchlassstrom 7) Seite 21
IF = f (VF); TS = 25 °C
Relative Luminous Intensity 7) page 21 , 8) page 21
Relative Lichtstärke 7) Seite 21 , 8) Seite 21
IV/IV(10 mA) = f(IF); TS = 25 °C
OHL01460
10 1
OHL01499
10 2
mA
IV
I V (10 mA)
IF
10 1
10 0
10 0
5
10 -1
2.0
3.0
4.0
10 -1 0
10
V 5.0
VF
OHL01532
535
533
531
529
true green
527
525
523
521
519
40 mA 50
IF
2014-04-04
10 1
mA 10 2
IF
Dominant Wavelength 7) page 21
Dominante Wellenlänge 7) Seite 21
λdom = f(IF); TS = 25 °C
539
nm
λ dom 537
5
8
LT T67S
Relative Forward Voltage 7) page 21
Relative Vorwärtsspannung 7) Seite 21
ΔVF = VF - VF(25 °C) = f(Tj); IF = 10 mA
∆VF
IV/IV(25)°C = f(Tj); IF = 10 mA
OHL02352
0.4
V
IV
I V (25 ˚C)
0.3
1.2
0.2
1.0
0.1
0.8
0.0
0.6
-0.1
0.4
-0.2
0.2
-0.3
-60 -40 -20 0
20 40 60
˚C 100
20 40 60
˚C 100
Tj
Tj
2014-04-04
OHL03870
1.4
9
LT T67S
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T)
OHL00429
I F mA
TA
15
TS
10
5
TA temp. ambient
TS temp. solder point
60
80 ˚C 100
T
Permissible Pulse Handling Capability
Zulässige Impulsbelastbarkeit IF = f(tp)
D: Duty cycle, TA = 25 °C
0.16
A
IF
D: Duty cycle, TA = 85 °C
OHL01471
t
0.16
A
tP
D = TP
IF
IF
0.10
0.08
0.06
0.04
IF
T
0.12
D=
0.10
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0.08
0.06
0.04
0.02
D=
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0.02
10-5 10-4 10-3 10-2 10-1 100 101 s 102
tp
2014-04-04
t
D = TP
T
0.12
OHL01472
tP
tp
10
LT T67S
Package Outline 9) page 21
Maßzeichnung 9) Seite 21
2.1 (0.083)
3.0 (0.118)
2.6 (0.102)
2.3 (0.091)
1.7 (0.067)
0.1 (0.004) (typ.)
0.9 (0.035)
0.7 (0.028)
3.7 (0.146)
3.3 (0.130) 4˚±1
(2.4) (0.095)
3.4 (0.134)
3.0 (0.118)
2.1 (0.083)
A
0.5 (0.020)
Cathode marking
1.1 (0.043)
C
0.18 (0.007)
0.12 (0.005)
0.6 (0.024)
0.4 (0.016)
GPLY6724
Approximate Weight:
34 mg
Gewicht:
34 mg
Mark:
bevelled edge (Cathode)
Markierung:
abgeschrägte Ecke (Kathode)
Corrosion robustness:
Test conditions: 40 °C / 90 % rh / 15 ppm H2S /
336 h
= Stricter than IEC 60068-2-43 (H 2S) [25°C / 75
% rh / 10 ppm H 2S / 21 days]
= Regarding relevant gas (H2S) stricter than EN
60068-2-60 (method 4) [25 °C / 75 % rh / 200
ppb SO2, 200 ppb NO2,10 ppb Cl2 / 21 days]
Korrosionsfestigkeit:
Test Kondition: 40°C / 90 % rh / 15 ppm H 2S /
336 h
= Besser als IEC 60068-2-43 (H2S) [25°C / 75 %
rh / 10 ppm H2S / 21 Tage]
= Bezogen auf das Gas (H 2S) besser als EN
60068-2-60 (method 4) [25°C / 75 % rh / 200ppb
SO2, 200ppb NO2,10ppb Cl2 / 21 Tage]
2014-04-04
11
LT T67S
Recommended Solder Pad 9) page 21
Empfohlenes Lötpaddesign 9) Seite 21
Reflow soldering
Reflow-Löten
4.5 (0.177)
1.5 (0.059)
1.5 (0.059)
4.5 (0.177)
2.6 (0.102)
2.6 (0.102)
Padgeometrie für
verbesserte Wärmeableitung
Lötstopplack
Solder resist
Paddesign for
improved heat dissipation
Cu-Fläche > 16 mm 2
Cu-area > 16 mm 2
OHLPY970
Reflow soldering
Reflow-Löten
Fläche darf bei Verwendung von TOPLED®
elektrisch nicht beschaltet werden.
For TOPLED® assembly do not use
this area for electrical contact
Padgeometrie für
Paddesign for
3.3 (0.130)
3.3 (0.130)
Anode
2.3 (0.091)
11.1 (0.437)
1.5 (0.059)
1.1 (0.043)
3.7 (0.146)
0.8 (0.031)
0.7 (0.028)
Kathode/
Cathode
Cu Fläche /
re
ope e
Mo
see
istu
k,
is
or .
sea is has k,
Mo
bef
istu
d
033
Mo
in
Flo
RH
blan
Mo
or-p blan in
bag
Car
ing,
r
TDlife
(if
If with
t.
r
lf
10%bak or
J-S
thisvapp.
Yea
_
eks rs
r
ed
icat med, C
1
Yea
tem
She
ow,
at
uire not
y
1
WeHou
unt
DE
Afte
Ind
4
uire
refl
is
red req
bod Mo
/JE
time
168
req
2b
a)
Sto ices idity
time
or
is IPC
or
time
b)
ned Flo
or
Hum ing ce
time
or
Dev 2a
e
Flo
a)
ope
or
3.
b) bakren
Flo
1
l dat
Flo
If
2
refe
time el
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
e
Lev
re
Lev
istu
Dat
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
A
C
1.
2.
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
Desiccant
OSR
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
Transportation Packing and Materials
Kartonverpackung und Materialien
DE
8
1
R1
Q1+
P-
GR
44
(G)
P:
Mu
lti LS
TO Y
T6
PL 76
99
8
D/C
: 01
O
00
21
(9D
(Q)
QT
AM
nd
21
co
SR
NO
23
4
mi
O
H1
Se
TC
H
BA
3G
: 12
(6P
5
NO
T
14
2
LO
11
00
NO
(X)
PR
(1T
Y:
uc pt
to o
rs
OD
see
labe
00
l
k,
N
O
TI
U
A
C
OU
Muster
L
VE
LE
code (RH
blan
If
y
bar
idit
RH
hum
60%
e
tive d
˚C/
kag
rela are
30
E S
s
_
infr pac
OR
of
tainITIV
90% to ak
urs
CT
e).
or
urs
ted (pe
ons
con NS
Ho
g
urs
SE DU
Ho
and jec
diti
cod
˚C,
72
sin
Ho urs
e
5
bag E ON
48
˚C sub
e
Ho
con
s UR
ces
24 6
dat
e
MIC
40 be
tim
˚C
e
ThiISTSE
pro
tory
tim
or
t
with
23
tim e
at t will ˚C)
or
fac
MO
Flo
al
len
tim
s
TO
at
or
at
Flo
d
or
iva
ure
el
nth s tha
OP
ntic
Flo
4
if: rea
Flo
lab
ow
mo ice equ
ide
5
ced
el
e
5a
is
el
ingen
bel
or
24
pro
6
Lev
e
dev,
el
cod
e
unt wh
Lev
el
re
ow
see
bag
Lev
l dat
re
mo
bak
e
bar
ned
Lev
refl
istu
10%
re
led
tim
sea
for
istu
ore>
re
ope e
Mo
see
3
istu
is
or .
sea is has
Mo
nk,
bef
istu
nk, Flo
rd
-03
Mo
in
RH
bla
Mo
or-p bla in
bag
ingCa
r
TD
life
(if
If with
t.
r
p.
vap
tor
10%bak
J-S
this
Yea
_
eks
r
ed
ica med, C
1
urs
Yea
tem
She
ow
at
uire not
y
1
WeHo
unt
DE
Afte
Ind
1.
e
4
uire
refl
red req
2.
bod Mo
e
ity is
/JE
tim
s
168
req
e
2b
a)
Sto
tim
or
mid
is IPC
tim e
vice or
b)
ned Flo
or
Hu
tim
ing ce
or
De
e
2a
Flo
a)
ope
or
3.
b) bakren
Flo
e
1
l dat
Flo
If
2
el
refe
tim
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
te
Lev
re
Lev
istu
Da
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
MY
Barcode label
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Tem
2a
220
3
240 p ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
Barcode label
: 01
D/C
MY
DE
8
1
R1
Q1+
PP:
GR
(G)
44
00
(9D
4
Y:
Mu
lti LS
TO Y
T6
PL 76
(1T
NO
OD
Packing
Sealing label
Dimensions of transportation box in mm (inch):
2014-04-04
M
RA
OS
(X)
PR
5
14 2
110 0
(Q)
QT
SR
23
m A
ico M
nd O
uc pt
to o
rs
NO
O
H
H1
Se
998
3G
TC
NO
: 12
BA
021
LO
T
(6P
210
OU
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Te
2a
220 mp
3
240
ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
lf
18
OHA02044
LT T67S
Width / Breite
Length / Länge
Height / Höhe
200 ± 5 (7.874 ± 0.196)
352 ± 5 (13.858 ± 0.196)
195 ± 5 (7.677 ± 0.1968)
30 ± 5 (1.181 ± 0.196)
33 ± 5 (1.299 ± 0.196)
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Exempt group
(exposure time 10000 s). Under real circumstances
(for exposure time, eye pupils, observation
distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of
principle, however, it should be mentioned that
intense light sources have a high secondary
exposure potential due to their blinding effect. As is
also true when viewing other bright light sources
(e.g. headlights), temporary reduction in visual
acuity and afterimages can occur, leading to
irritation, annoyance, visual impairment, and even
accidents, depending on the situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Exempt group
(Expositionsdauer 10000 s). Unter realen
Umständen (für Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
For further application related informations
please visit www.osram-os.com/appnotes
Für weitere applikationsspezifische
Informationen besuchen Sie bitte
2014-04-04
19
LT T67S
Disclaimer
Disclaimer
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version in
the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen Sie bitte die Ihnen bekannten Recyclingwege.
Wenn diese nicht bekannt sein sollten, wenden Sie sich
bitte an das nächstgelegene Vertriebsbüro. Wir nehmen
das Verpackungsmaterial zurück, falls dies vereinbart
wurde und das Material sortiert ist. Sie tragen die
Transportkosten. Für Verpackungsmaterial, das
unsortiert an uns zurückgeschickt wird oder das wir nicht
annehmen müssen, stellen wir Ihnen die anfallenden
Kosten in Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or the
effectiveness of that device or system.
**) Life support devices or systems are intended (a) to be
implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
2014-04-04
LT T67S
Glossary
Glossar
1)
Brightness: Brightness values are measured during
a current pulse of typically 25 ms, with an internal
reproducibility of ± 8 % and an expanded uncertainty
of ± 11 % (acc. to GUM with a coverage factor of
k = 3).
1)
Helligkeit: Helligkeitswerte werden während eines
Strompulses einer typischen Dauer von 25 ms, mit
einer internen Reproduzierbarkeit von ± 8 % und
einer erweiterten Messunsicherheit von ± 11 %
gemessen (gemäß GUM mit Erweiterungsfaktor
k = 3).
2)
Reverse Voltage: Driving the LED in reverse
direction is suitable for short term application.
2)
Sperrspannung: Die LED kann
Sperrrichtung betrieben werden.
3)
Wavelength: The wavelength is measured at a
reproducibility of ± 0.5 nm and an expanded
uncertainty of ± 1 nm (acc. to GUM with a coverage
factor of k = 3).
3)
Wellenlänge: Die Wellenläge wird während eines
einer internen Reproduzierbarkeit von ± 0,5 nm und
einer erweiterten Messunsicherheit von ± 1 nm
k = 3).
4)
Forward Voltage: The forward voltage is measured
during a current pulse of typically 8 ms, with an
internal reproducibility of ± 0.05 V and an expanded
uncertainty of ± 0.1 V (acc. to GUM with a coverage
factor of k = 3).
4)
Durchlassspannung: Vorwärtsspannungen
werden während eines Strompulses einer typischen
Dauer
von
8 ms,
mit
einer
internen
Reproduzierbarkeit von ± 0,05 V und einer
erweiterten Messunsicherheit von ± 0,1 V gemessen
(gemäß GUM mit Erweiterungsfaktor k = 3).
5)
Thermal Resistance: RthJA results from mounting
on PC board FR 4 (pad size 16mm² per pad)
5)
Wärmewiderstand: RthJA ergibt sich bei Montage
auf PC-Board FR 4 (Padgröße 16mm² je pad)
6)
Thermal Resistance: Rth max is based on statistic
values (6σ).
6)
statistischen Werten (6σ).
7)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
7)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
8)
Relative Brightness Curve: In the range where the
line of the graph is broken, you must expect higher
brightness differences between single LEDs within
one packing unit.
8)
Relative Helligkeitskurve: Im
gestrichelten
Bereich der Kennlinien muss mit erhöhten
Helligkeitsunterschieden zwischen Leuchtdioden
innerhalb einer Verpackungseinheit gerechnet
werden.
9)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
2014-04-04
21
max
kurzzeitig
basiert
in
auf
LT T67S
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2014-04-04
22
