CUWY3SH.B1-DEGF-4A7V-1-20-R18-Z 数据手册
2014-10-16
Micro SIDELED 3806
Datasheet
Draft Version 0.1
CUW Y3SH.B1
Micro SIDELED is a SMT LED with side emission. Due
to its low package height it is ideal for applications in
limited space environments.
Micro SIDELED ist eine SMT LED mit seitlicher
Abstrahlrichtung. Aufgrund ihrer niedrigen
Bauteilhöhe ist sie ideal für Anwendungen mit
begrenztem Raum.
Features:
Besondere Merkmale:
• Package: white SMT package, colored diffused
silicone resin
• Technology: InGaN on Sapphire
• Viewing angle at 50 % IV: 120°
• Color: Cx = 0.30, Cy = 0.29 acc. to CIE 1931
(ultra white)
• Optical efficiency (typ.): 155 lm/W (ultra white)
• Gehäusetyp: weißes SMT Gehäuse, farbiger
diffuser Silikon-Verguss
• Technologie: InGaN on Sapphire
• Abstrahlwinkel bei 50 % IV: 120°
• Farbe: Cx = 0.30, Cy = 0.29 nach CIE 1931 (ultra
weiß)
• Optischer Wirkungsgrad (typ.): 155 lm/W (ultra
weiß)
Applications
Anwendungen
• Backlighting
• LCD Backlighting
• Hinterleuchtung
• LCD Beleuchtung
2014-10-16
DRAFT – For Reference only.
Subject to change.
1
Draft Version 0.1
CUW Y3SH.B1
Ordering Information
Bestellinformation
Type:
Luminous Flux 1) page 24
Ordering Code
Typ:
Lichtstrom 1) Seite 24
Bestellnummer
IF = 20 mA
ΦV [mlm]
CUW Y3SH.B1-DEGF-4A7V-1
Note:
6500 ... 10000
Q65111A6691
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. CUW Y3SH.B1-DEGF-4A7V-1 means that only one group DE, DF, EC,
ED, EE, EF, FC, FD, FE, FF, GC, GD, GE, GF will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be
orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. CUW Y3SH.B1-DEGF-4A7V-1 means that the device will be shipped within the specified limits. In order to ensure availability, single color
chromaticity groups groups will not be orderable.
In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing
unit. E. g. CUW Y3SH.B1-DEGF-4A7V-1 means that only one forward voltage group 22,42,62,Z2 will be shippable. In order to ensure availability, single
forward voltage groups will not be orderable (see page 5).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. CUW Y3SH.B1-DEGF-4A7V-1 bedeutet, dass in einer
Verpackungseinheit nur eine der Helligkeitsgruppen DE, DF, EC, ED, EE, EF, FC, FD, FE, FF, GC, GD, GE, GF enhalten ist. Um die Liefersicherheit
zu gewährleisten, können einzelne Helligkeitsgruppen nicht bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert.
Z.B. CUW Y3SH.B1-DEGF-4A7V-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. CUW
Y3SH.B1-DEGF-4A7V-1 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten,
können einzelne Farbortgruppen nicht bestellt werden.
Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine
Durchlassspannungsgruppe geliefert. Z. B. CUW Y3SH.B1-DEGF-4A7V-1 bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer
Verpackungseinheit ist nur eine der Durchlassspannungsgruppen 22,42,62,Z2 enthalten (siehe Seite 5). Um die Liefersicherheit zu gewährleisten,
können einzelne Durchlassspannungsgruppen nicht direkt bestellt werden.
2014-10-16
Subject to change.
2
Draft Version 0.1
CUW Y3SH.B1
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 85
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 100
°C
Junction temperature
Sperrschichttemperatur
Tj
105
°C
Forward current
Durchlassstrom
(TS = 25 °C)
IF
40
mA
Surge current
Stoßstrom
(t ≤ 10 µs; D = 0.005; TS = 25 °C)
IFM
100
mA
Reverse voltage
Sperrspannung
(TS = 25 °C)
VR
not designed for reverse
operation
V
ESD withstand voltage
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM)
VESD
up to 1
kV
2014-10-16
Subject to change.
3
Draft Version 0.1
CUW Y3SH.B1
Characteristics (TS = 25 °C; IF = 20 mA)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Chromaticity coordinates acc. to CIE 1931
(typ.)
(typ.)
Cx
Cy
0.3
0.29
(typ.)
2ϕ
120
Forward voltage 3) page 24
Durchlassspannung 3) Seite 24
(min.)
(typ.)
(max.)
VF
VF
VF
2.70
2.85
3.10
V
V
V
Real thermal resistance junction / solder point
(typ.)
(max.)
Rth JS real
Rth JS real
107
132
K/W
K/W
(typ.)
(max.)
Rth JS el
Rth JS el
50
62
K/W
K/W
2) page 24
Farbkoordinaten nach CIE 1931 2) Seite 24
4) page 24
Realer Wärmewiderstand Sperrschicht / Lötpad
4) Seite 24
"Electrical" thermal resistance junction / solder
point 4) page 24
"Elektrischer" Wärmewiderstand Sperrschicht /
Lötpad 4) Seite 24
(with efficiency η e = 53 %)
Note:
Individual forward voltage groups see next page
Anm.:
Durchlassspannungsgruppen siehe nächste Seite
2014-10-16
Subject to change.
4
Draft Version 0.1
CUW Y3SH.B1
Brightness Groups
Helligkeitsgruppen
Group
Luminous Flux
Luminous Flux
Luminous Intensity
1) page 24
1) page 24
5) page 24
1) Seite 24
Lichtstrom
1) Seite 24
Lichtstärke 5) Seite 24
Gruppe
Lichtstrom
(min.) ΦV [mlm]
(max.) ΦV [mlm]
(typ.) IV [mcd]
DE
6500
6750
2190
DF
6750
7000
2270
EC
7000
7250
2350
ED
7250
7500
2430
EE
7500
7750
2520
EF
7750
8000
2600
FC
8000
8250
2680
FD
8250
8500
2760
FE
8500
8750
2850
FF
8750
9000
2930
GC
9000
9250
3010
GD
9250
9500
3090
GE
9500
9750
3180
GF
9750
10000
3260
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or
a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups
cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere
Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne
Helligkeitsgruppen sind nicht bestellbar.
Forward Voltage Groups 3) page 24
Durchlassspannungsgruppen 3) Seite 24
Group
Gruppe
(min.) VF [V]
(max.) VF [V]
Z2
2.70
2.80
22
2.80
2.90
42
2.90
3.00
62
3.00
3.10
2014-10-16
Subject to change.
5
Draft Version 0.1
CUW Y3SH.B1
Chromaticity Coordinate Groups 2) page 24
Farbortgruppen 2) Seite 24
0.90
520
Cy
7V
Cy 0.37
525
0.80
515
530
7U 6V
7T 6U 5V
540
510
0.35
0.70
7S 6T 5U
4V
7R 6S 5T
4U
550
7Q 6R 5S
4T
0.33
505
7P 6Q 5R
4S
560
0.60
7N 6P 5Q
4R
0.31
570
7M 6N 5P
4Q
500
0.50
7L 6M 5N
4P
0.29
580
7K 6L 5M
4N
590
7J 6K 5L
4M
0.27
495
0.40
7H 6J 5K
4L
600
7G 6H 5J
4K
610
7F 6G 5H
4J
490
7E 6F 5G
4H
0.23
485
7B 6C 5D
4E
0.21
7A 6B 5C
4D
480
0.10
5A 4B
Cx
0.34
0.32
0.24
0.20
0.22
0.70
0.50
0.60
0.40
0.20
0.30
4A
0.17
0.30
0.00
0.10
470
465
460
455
450
400
0.00
6A 5B 4C
0.19
475
0.26
0.20
7D 6E 5F
4G
7C 6D 5E
4F
0.28
0.30
0.25
620
630
650
700
Cx
Color Chromaticity Groups 2) page 24
Group
Gruppe
4A
5A
6A
Cx
Cy
Group
Gruppe
0.2400
0.1630
0.2700
0.2482
0.2400
0.1730
0.2700
0.2582
0.2450
0.1722
0.2750
0.2450
0.1822
0.2750
0.2400
0.1730
0.2750
0.2274
0.2400
0.1830
0.2750
0.2450
0.1822
0.2800
0.2450
0.1922
0.2800
0.2400
0.1830
0.2750
0.2374
0.2400
0.1930
0.2750
0.2474
0.2450
0.1922
0.2800
0.2450
0.2022
0.2800
7G
4H
5H
2014-10-16
Subject to change.
Cx
6
Cy
Group
Gruppe
Cx
Cy
0.3050
0.3026
0.3050
0.3126
0.2574
0.3100
0.3118
0.2674
0.3100
0.3218
0.3050
0.3126
0.2374
0.3050
0.3226
0.2366
0.3100
0.3218
0.2466
0.3100
0.3318
0.3100
0.2918
0.3100
0.3018
0.2466
0.3150
0.3010
0.2566
0.3150
0.3110
6P
7P
4Q
Draft Version 0.1
Group
Gruppe
7A
4B
5B
6B
7B
4C
5C
6C
CUW Y3SH.B1
Cx
Cy
Group
Gruppe
0.2400
0.1930
0.2750
0.2474
0.2400
0.2030
0.2750
0.2574
0.2450
0.2022
0.2800
0.2566
0.2800
0.2666
0.2750
0.2574
6H
Cx
Cy
0.2450
0.2122
0.2450
0.1722
0.2450
0.1822
0.2750
0.2500
0.1814
0.2800
0.2500
0.1914
0.2800
0.2450
0.1822
0.2800
0.2366
0.2450
0.1922
0.2800
0.2466
0.2500
0.1914
0.2850
0.2458
0.2850
0.2558
0.2800
0.2466
7H
4J
0.3100
0.3218
0.3150
0.3210
0.2766
0.3150
0.3310
0.3100
0.3218
0.3100
0.3318
0.3150
0.3310
0.2022
0.2800
0.2014
0.2850
0.2500
0.2114
0.2850
0.2450
0.2022
0.2800
0.2566
0.2450
0.2122
0.2800
0.2666
0.2500
0.2114
0.2850
0.2658
0.2850
0.2758
0.2800
0.2666
0.3410
0.3010
0.2566
0.3150
0.3110
0.2558
0.3200
0.3102
0.2658
0.3200
0.3202
0.3150
0.3110
0.3150
0.3210
0.3200
0.3202
0.2214
0.1814
0.2500
0.1914
0.2800
0.2550
0.1906
0.2850
0.2550
0.2006
0.2850
0.2500
0.1914
0.2850
0.2458
0.2500
0.2014
0.2850
0.2558
0.2550
0.2006
0.2900
0.2550
0.2900
0.2650
0.2850
0.2558
0.2500
0.2114
0.2850
0.2550
0.2106
0.2900
0.2550
0.2206
0.2900
5K
2014-10-16
Subject to change.
7
7Q
0.3150
0.2500
0.2106
6Q
0.3150
0.2500
0.2014
0.3110
0.2666
0.2500
0.2550
0.3118
0.3150
0.2674
0.2450
0.2500
0.3018
0.3100
0.3210
0.2014
4K
0.3100
0.3118
0.1922
7J
Cy
0.3150
0.2500
6J
5Q
Cx
0.3100
0.2450
5J
Group
Gruppe
4R
5R
0.3200
0.3302
0.3150
0.3210
0.2766
0.3150
0.3310
0.2758
0.3200
0.3302
0.2858
0.3200
0.3402
0.3150
0.3310
0.3150
0.3410
0.3200
0.3402
6R
7R
0.3200
0.3502
0.3200
0.3102
0.2658
0.3200
0.3202
0.2650
0.3250
0.3194
0.2750
0.3250
0.3294
4S
Draft Version 0.1
Group
Gruppe
7C
4D
5D
6D
7D
4E
5E
6E
CUW Y3SH.B1
Cx
Cy
Group
Gruppe
0.2500
0.2114
0.2850
0.2658
0.2500
0.2214
0.2850
0.2758
0.2550
0.2206
0.2900
0.2750
0.2900
0.2850
0.2850
0.2758
6K
Cx
Cy
0.2550
0.2306
0.2550
0.1906
0.2550
0.2006
0.2850
0.2600
0.1998
0.2900
0.2600
0.2098
0.2900
0.2550
0.2006
0.2900
0.2550
0.2550
0.2106
0.2900
0.2650
0.2600
0.2098
0.2950
0.2642
0.2950
0.2742
0.2900
0.2650
7K
4L
0.3200
0.3402
0.3250
0.3394
0.2950
0.3250
0.3494
0.3200
0.3402
0.3200
0.3502
0.3250
0.3494
0.2206
0.2900
0.2198
0.2950
0.2600
0.2298
0.2950
0.2550
0.2206
0.2900
0.2750
0.2550
0.2306
0.2900
0.2850
0.2600
0.2298
0.2950
0.2842
0.2950
0.2942
0.2900
0.2850
0.3594
0.3194
0.2750
0.3250
0.3294
0.2742
0.3300
0.3286
0.2842
0.3300
0.3386
0.3250
0.3294
0.3250
0.3394
0.3300
0.3386
0.2398
0.1998
0.2600
0.2098
0.2900
0.2650
0.2090
0.2950
0.2650
0.2190
0.2950
0.2600
0.2098
0.2950
0.2642
0.2600
0.2198
0.2950
0.2742
0.2650
0.2190
0.3000
0.2734
0.3000
0.2834
0.2950
0.2742
0.2600
0.2298
0.2950
0.2650
0.2290
0.3000
0.2650
0.2390
0.3000
5M
2014-10-16
Subject to change.
8
7S
0.3250
0.2600
0.2290
6S
0.3250
0.2600
0.2198
0.3294
0.2850
0.2600
0.2650
0.3302
0.3250
0.2858
0.2550
0.2600
0.3202
0.3200
0.3394
0.2198
4M
0.3200
0.3302
0.2106
7L
Cy
0.3250
0.2600
6L
5S
Cx
0.3200
0.2550
5L
Group
Gruppe
4T
5T
0.3300
0.3486
0.3250
0.3394
0.2950
0.3250
0.3494
0.2942
0.3300
0.3486
0.3042
0.3300
0.3586
0.3250
0.3494
0.3250
0.3594
0.3300
0.3586
6T
7T
0.3300
0.3686
0.3300
0.3286
0.2842
0.3300
0.3386
0.2834
0.3350
0.3378
0.2934
0.3350
0.3478
4U
Draft Version 0.1
Group
Gruppe
7E
4F
5F
6F
7F
4G
5G
6G
CUW Y3SH.B1
Cx
Cy
Group
Gruppe
0.2600
0.2298
0.2950
0.2842
0.2600
0.2398
0.2950
0.2942
0.2650
0.2390
0.3000
0.2934
0.3000
0.3034
0.2950
0.2942
6M
Cx
Cy
0.2650
0.2490
0.2650
0.2090
0.2650
0.2190
0.2950
0.2700
0.2182
0.3000
0.2700
0.2282
0.3000
0.2650
0.2190
0.3000
0.2734
0.2650
0.2290
0.3000
0.2834
0.2700
0.2282
0.3050
0.2826
0.3050
0.2926
0.3000
0.2834
7M
4N
0.3300
0.3586
0.3350
0.3578
0.3134
0.3350
0.3678
0.3300
0.3586
0.3300
0.3686
0.3350
0.3678
0.2390
0.3000
0.2382
0.3050
0.2700
0.2482
0.3050
0.2650
0.2390
0.3000
0.2934
0.2650
0.2490
0.3000
0.3034
0.2700
0.2482
0.3050
0.3026
0.3050
0.3126
0.3000
0.3034
6U
7U
0.3350
0.3778
0.3350
0.3378
0.2934
0.3350
0.3478
0.2926
0.3400
0.3470
0.3026
0.3400
0.3570
0.3350
0.3478
0.3350
0.3578
0.3400
0.3570
0.2700
0.2582
0.2700
0.2182
0.2700
0.2282
0.3000
0.2750
0.2274
0.3050
0.2750
0.2374
0.3050
0.2700
0.2282
0.3050
0.2826
0.2700
0.2382
0.3050
0.2926
0.2750
0.2374
0.3100
4V
5V
0.3400
0.3670
0.3350
0.3578
0.3134
0.3350
0.3678
0.3126
0.3400
0.3670
0.3226
0.3400
0.3770
0.3350
0.3678
0.3350
0.3778
0.2918
0.3400
0.3770
0.3100
0.3018
0.3400
0.3870
0.3050
0.2926
0.2750
0.2474
0.2700
0.2382
0.2700
0.2482
0.3050
0.3026
0.2750
0.2474
0.3100
0.3018
0.2750
0.2574
0.3100
0.3118
Subject to change.
0.3478
0.3034
0.2700
2014-10-16
0.3486
0.3350
0.3042
0.2650
5P
0.3386
0.3300
0.3578
0.2382
4P
0.3300
0.3486
0.2290
7N
Cy
0.3350
0.2700
6N
5U
Cx
0.3300
0.2650
5N
Group
Gruppe
9
6V
7V
Draft Version 0.1
CUW Y3SH.B1
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: DE-4A-Z2
Beispiel: DE-4A-Z2
Brightness
Helligkeit
Farbort
Forward Voltage
Durchlassspannung
DE
4A
Z2
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2014-10-16
Subject to change.
10
Draft Version 0.1
CUW Y3SH.B1
Relative Spectral Emission - V(λ) = Standard eye response curve 5) page 24
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 5) Seite 24
Φrel = f (λ); TS = 25 °C; IF = 20 mA
Irel
CUW Y3SH.B1
1.0
: Vλ
: ultra white
0.8
0.6
0.4
0.2
0.0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics 5) page 24
Abstrahlcharakteristik 5) Seite 24
Irel = f (ϕ); TS = 25 °C
CUW Y3SH.B1
ϕ [°]
-10°
0°
10°
20°
30°
40°
50°
60°
70°
80°
-20°
-30°
90°
1.0
: 0°
: 90°
-40°
0.8
-50°
0.6
-60°
0.4
-70°
0.2
-80°
0.0
-90°
-100°
2014-10-16
Subject to change.
11
Irel
Draft Version 0.1
CUW Y3SH.B1
Forward Current 5) page 24
Durchlassstrom 5) Seite 24
IF = f (VF); TS = 25 °C
IF [mA]
Relative Luminous Flux 5) page 24
Relativer Lichtstrom 5) Seite 24
ΦV/ΦV (20 mA) = f(IF); TS = 25 °C
ΦV
CUW Y3SH.B1
40
CUW Y3SH.B1
2.0
ΦV(20mA)
: ultra white
: ultra white
35
1.5
30
25
1.0
0.5
10
5
0.0
2
2.6
2.8
3.0
3.2
2
3.42
VF [V]
CUW Y3SH.B1
0.03
0.02
0.01
0.00
-0.01
-0.02
: ∆ Cx
: ∆ Cy
-0.03
2
5
10
15
30
35
40
IF [mA]
2014-10-16
Subject to change.
10
15
30
35
40
IF [mA]
Chromaticity Coordinate Shift 5) page 24
Farbortverschiebung 5) Seite 24
ΔCx, ΔCy = f(IF); TS = 25 °C
∆Cx
∆Cy
5
12
Draft Version 0.1
CUW Y3SH.B1
Relative Forward Voltage 5) page 24
Relative Vorwärtsspannung 5) Seite 24
ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA
∆VF [V]
ΦV/ΦV (25 °C) = f(Tj); IF = 20 mA
Φv
CUW Y3SH.B1
0.3
1.0
0.1
0.8
0.0
0.6
-0.1
0.4
-0.2
0.2
0.0
40
60
80
100
40
Tj [°C]
CUW Y3SH.B1
0.03
: Cx
: Cy
0.02
0.01
0.00
-0.01
-0.02
-0.03
40
60
80
100
Tj [°C]
2014-10-16
Subject to change.
60
80
100
Tj [°C]
ΔCx, ΔCy = f(Tj); IF = 20 mA
∆Cx
∆Cy
: ultra white
0.2
-0.3
CUW Y3SH.B1
1.2
Φv(25°C)
: ultra white
13
Draft Version 0.1
CUW Y3SH.B1
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T)
IF [mA]
CUW Y3SH.B1
45
40
35
30
25
: Ta
: Ts
10
5
Do not use below 1 mA
60
80
100
T [°C]
Permissible Pulse Handling Capability
Zulässige Impulsbelastbarkeit IF = f(tp)
D: Duty cycle
TS = 0°C ... 85°C
CUW Y3SH.B1
IF [A]
: D = 1.0
: D = 0.5
: D = 0.2
: D = 0.1
: D = 0.05
: D = 0.02
: D = 0.01
: D = 0.005
0.10
0.08
0.06
0.04
10-6
10-5
10-4
10-3
0.01
0.1
1
10
Pulse time [s]
2014-10-16
Subject to change.
14
Draft Version 0.1
CUW Y3SH.B1
Package Outline 6) page 24
Maßzeichnung 6) Seite 24
Approximate Weight:
4 mg
Gewicht:
4 mg
2014-10-16
Subject to change.
15
Draft Version 0.1
CUW Y3SH.B1
Recommended Solder Pad 6) page 24
Empfohlenes Lötpaddesign 6) Seite 24
Reflow soldering
Reflow-Löten
Note:
For superior solder joint connectivity results we
recommend soldering under standard nitrogen
atmosphere. Package not suitable for ultra
sonic cleaning.
Anm.:
Um eine verbesserte Lötstellenkontaktierung zu
erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Das Gehäuse ist
für Ultraschallreinigung nicht geeignet.
2014-10-16
Subject to change.
16
Draft Version 0.1
CUW Y3SH.B1
Reflow Soldering Profile
Reflow-Lötprofil
Preconditioning: JEDEC Level 3 acc. to JEDEC J-STD-020D.01
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
OHA04612
Profile Feature
Profil-Charakteristik
Symbol
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Ramp-up rate to preheat*)
25 °C to 150 °C
Time tS
TSmin to TSmax
tS
60
Ramp-up rate to peak*)
TSmax to TP
Recommendation
Maximum
2
3
100
120
2
3
Unit
Einheit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
s
3
6
K/s
10
Ramp-down rate*
TP to 100 °C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
2014-10-16
Subject to change.
°C
17
s
Draft Version 0.1
CUW Y3SH.B1
Taping 6) page 24
Gurtung 6) Seite 24
2014-10-16
Subject to change.
18
Draft Version 0.1
CUW Y3SH.B1
Tape and Reel
Gurtverpackung
12 mm tape with 2000 pcs. on ∅ 180 mm reel
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Tape dimensions in mm
Tape dim ensions in m m
W
P0
P1
P2
D0
E
F
12 + 0.3
4 ± 0.1
4 ± 0.1
or
8 ± 0.1
2 ± 0.05
1.5 ± 0.1
1.75 ± 0.1
5.5 ± 0.05
Reel dimensions in mm
Reel dim ensions in m m
A
W
Nmin
W1
W2max
180
12
60
12.4 + 2
18.4
2014-10-16
Subject to change.
19
Draft Version 0.1
CUW Y3SH.B1
Barcode-Product-Label (BPL)
Barcode-Produkt-Etikett (BPL)
OSRAM Opto
EX
A
RoHS Compliant
(6P) BATCH NO: 1234567890
(1T) LOT NO: 1234567890
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
MP
ML Temp ST
X XXX °C X
(9D) D/C: 1234
Pack: RXX
LE
DEMY
XXX
X_X123_1234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
Dry Packing Process and Materials
Trockenverpackung und Materialien
Moisture-sensitive label or print
Barcode label
L
VE
l
LE
k,
see
labe
code
blan
If
bar
(RH
idity
N s IVE RS
Otain
TO
SIT
UC
TIcon
SEN
U
RH
hum
0%
e
tive d
˚C/6
kag
rela are
30
_
infr pac
of
90% to ak
ns
ed (pe
or
rs
e).
ND
Hou
rs
rs
rs
Hou
and ject
ditio
cod
˚C,
72
sing
Hou
e
5
bag E
48
˚C sub
Hou
con
s UR ICO
ces
24 6
dat
40 be
time
˚C
ory
ThiISTSEM
pro
time
or
23
time
at t will ˚C).
or
l with
fact
ent
MO
Flo
time
s
TO
at
or
at
Flo
l
tica
d
tha
or
ival
ure
nth
OP
Flo
4
if: rea
w
Flo
labe
mo ices
iden
5
ced
equ
el
n
e
5a
is
el
ing,
belo
or
24
pro
6
Lev
e
dev
el
cod
e
unt whe
Lev
el
re
ow,
see
bag
Lev
l dat
re
mo
bak
bar
ned
Lev
refl
istu
10%
re
led
time
sea
for
istu
ore>
re
ope e
Mo
see
istu
k,
is
or .
sea is has k,
Mo
bef
istu
d
033
Mo
in
Flo
RH
blan
Mo
or-p blan in
bag
Car
ing,
r
TDlife
(if
If with
t.
r
lf
10%bak or
J-S
thisvapp.
Yea
_
eks rs
r
ed
icat med, C
1
Yea
tem
She
ow,
at
uire not
y
1
WeHou
unt
DE
Afte
Ind
4
uire
refl
is
red req
bod Mo
/JE
time
168
req
2b
a)
Sto ices idity
time
or
is IPC
or
time
b)
ned Flo
or
Hum ing ce
time
or
Dev 2a
e
Flo
a)
ope
or
3.
b) bakren
Flo
1
l dat
Flo
If
2
refe
time el
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
e
Lev
re
Lev
istu
Dat
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
A
C
1.
2.
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
Desiccant
OSR
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
2014-10-16
Subject to change.
Draft Version 0.1
CUW Y3SH.B1
Transportation Packing and Materials
Kartonverpackung und Materialien
Barcode label
DE
MY
8
1
T6
PL 76
R1
Q-
lti LS
TO Y
1+
POU
GR
(G)
Mu
: 01
(9D
D/C
21
00
21
99
8
4
Y:
23
LO
(X)
PR
OD
NO
11
00
(1T
QT
(Q)
H
Se
3G
H1
BA
TC
: 12
(6P
5
NO
T
14
2
O
SR
mi AM
co
nd O
uc pt
to o
rs
NO
see
labe
44
l
k,
N
O
TI
U
A
C
00
L
VE
LE
code (RH
blan
If
y
bar
idit
RH
hum
60%
e
tive d
˚C/
kag
rela are
30
E S
s
_
infr pac
OR
of
tainITIV
90% to ak
urs
CT
e).
or
urs
ted (pe
ons
con NS
Ho
g
urs
SE DU
Ho
and jec
diti
cod
˚C,
72
sin
Ho urs
e
5
bag E ON
48
˚C sub
e
Ho
con
s UR
ces
24 6
dat
e
MIC
40 be
tim
˚C
e
ThiISTSE
pro
tory
tim
or
t
with
23
tim e
at t will ˚C)
or
fac
MO
Flo
al
len
tim
s
TO
at
or
at
Flo
d
or
iva
ure
el
nth s tha
OP
ntic
Flo
4
if: rea
Flo
lab
ow
mo ice equ
ide
5
ced
el
e
5a
is
el
ingen
bel
or
24
pro
6
Lev
e
dev,
el
cod
e
unt wh
Lev
el
re
ow
see
bag
Lev
l dat
re
mo
bak
e
bar
ned
Lev
refl
istu
10%
re
tim
sea
for
istu
ore>
re
ope e
Mo
see
3
istu
is
or .
sea is has
Mo
nk,
bef
istu
nk, Flo
rd
-03
Mo
in
RH
bla
Mo
or-p bla in
bag
ingCa
r
TD
life
(if
If with
t.
r
lf
vapp.
10%baktor
J-S
this
Yea
_
eks
r
ed
ica med, C
1
urs
Yea
tem
She
ow
at
uire not
y
1
WeHo
unt
DE
Afte
Ind
1.
e
4
uire
refl
red req
2.
bod Mo
e
ity is
/JE
tim
s
168
req
e
2b
a)
Sto
tim
or
mid
is IPC
tim e
vice or
b)
ned Flo
or
Hu
tim
ing ce
or
De
e
2a
Flo
a)
ope
or
3.
b) bakren
Flo
e
1
l dat
Flo
If
2
el
refe
tim
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
te
Lev
re
Lev
istu
Da
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
P:
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Tem
2a
220
3
240 p ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
Barcode label
DE
MY
1
T6
PL 76
R1
8
lti LS
TO Y
Mu
1+
Q-
P:
PGR
(G)
44
: 01
D/C
(9D
QT
Y:
LO
(1T
NO
OD
Packing
Sealing label
Dimensions of transportation box in mm
Width
/ Breite
Length
/ Länge
Height
/ Höhe
195 ± 5
195 ± 5
30 ± 5
2014-10-16
Subject to change.
M
RA
OS
(X)
PR
5
14 2
110 0
(Q)
ico AM
nd O
uc pt
to o
rs
SR
NO
23
4
m
O
H
H1
Se
3G
TC
998
NO
: 12
BA
021
T
(6P
210
OU
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Te
2a
220 mp
3
240
ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
led
21
OHA02044
Draft Version 0.1
CUW Y3SH.B1
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Exempt group
(exposure time 10000 s). Under real circumstances
(for exposure time, eye pupils, observation
distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of
principle, however, it should be mentioned that
intense light sources have a high secondary
exposure potential due to their blinding effect. As is
also true when viewing other bright light sources
(e.g. headlights), temporary reduction in visual
acuity and afterimages can occur, leading to
irritation, annoyance, visual impairment, and even
accidents, depending on the situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Exempt group
(Expositionsdauer 10000 s). Unter realen
Umständen (für Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
Subcomponents of this LED are silverplated. Silver
is discoloring when being exposed to environments
containing high concentrations of aggressive
substances. Corroded silver may lead to a
worsening of the optical performance of the LED and
can in the worst case lead to a failure of the LED. Do
not expose this LED to aggressive atmospheres.
Note, that corrosive gases may as well be emitted
from materials close to the LED in the final product.
Einzelkomponenten dieser LED sind
silberbeschichtet. Silberoberflächen werden durch
korrosive Substanzen verändert. Korrodiertes Silber
kann zu einer Verschlechterung der optischen
Eigenschaften und im schlimmsten Fall zum Ausfall
der LED führen. Diese LED darf aggressiven
Bedingungen nicht ausgesetzt werden. Es ist zu
beachten, dass korrosive Gase auch von
Materialien emittiert werden können, die sich im
Endprodukt in unmittelbarer Umgebung der LED
befinden.
For further application related informations
please visit www.osram-os.com/appnotes
Für weitere applikationsspezifische
Informationen besuchen Sie bitte
2014-10-16
Subject to change.
22
Draft Version 0.1
CUW Y3SH.B1
Disclaimer
Disclaimer
OSRAM OS assumes no liability whatsoever for any use
of this document or its content by recipient including, but
not limited to, for any design in activities based on this
preliminary draft version. OSRAM OS may e.g. decide at
its sole discretion to stop developing and/or finalising the
underlying design at any time.
OSRAM OS übernimmt keine wie auch immer geartete
Haftung für die Nutzung dieses Dokuments und seines
Inhaltes durch den Empfänger, insbesondere nicht für
irgendwelche Design-Aktivitäten, die auf dieser
vorläufigen Entwurfsversion basieren. OSRAM OS
behält sich beispielsweise auch vor, jederzeit die
Weiter- und Fertigentwicklung des zugrundeliegenden
Designs einseitig einzustellen.
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version in
the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen Sie bitte die Ihnen bekannten Recyclingwege.
Wenn diese nicht bekannt sein sollten, wenden Sie sich
bitte an das nächstgelegene Vertriebsbüro. Wir nehmen
das Verpackungsmaterial zurück, falls dies vereinbart
wurde und das Material sortiert ist. Sie tragen die
Transportkosten. Für Verpackungsmaterial, das
unsortiert an uns zurückgeschickt wird oder das wir nicht
annehmen müssen, stellen wir Ihnen die anfallenden
Kosten in Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or the
effectiveness of that device or system.
**) Life support devices or systems are intended (a) to be
implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
2014-10-16
Subject to change.
23
Draft Version 0.1
CUW Y3SH.B1
Glossary
Glossar
1)
Brightness: Brightness groups are tested at a
current pulse duration of 25 ms and a tolerance of
± 11%.
1)
Helligkeit: Helligkeitswerte werden mit
Stromeinprägedauer von 25 ms und
Genauigkeit von ± 11% ermittelt.
2)
Chromaticity coordinate groups: Chromaticity
coordinate groups are tested at a current pulse
duration of 25 ms and a tolerance of ±0.01.
2)
Farbortgruppen: Farbortgruppen werden mit einer
Stromeinprägedauer von 25 ms und einer
Genauigkeit von ±0,01 ermittelt.
3)
Forward Voltage: Forward voltages are tested at a
current pulse duration of 1 ms and a tolerance of ±
0.1 V.
3)
Durchlassspannung: Spannungswerte werden mit
einer Stromeinprägedauer von 1 ms und einer
Genauigkeit von ± 0,1 V ermittelt.
4)
Thermal Resistance: Rth max is based on statistic
values (6σ).
4)
Wärmewiderstand: Rth
statistischen Werten (6σ).
5)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
5)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
6)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
6)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
2014-10-16
Subject to change.
24
max
basiert
einer
einer
auf
Draft Version 0.1
CUW Y3SH.B1
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2014-10-16
Subject to change.
25
