5BC
5BC
    BIVAR
    径向
    LED GRN/RED DIFF 5MM ROUND T/H
5BC 数据手册
5mm 3mm (T1 Package Package Discrete Discrete LED LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED RED/GREEN, RED/GREEN, Bi-Color Bi-Color 5BC-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 5mm (T1 ¾) Package RoHS Compliant White Diffused Lens Available in Flange (F) and Standard (Blank) Lead Frame styles 2-Lead Bi-Color LED Ideal for Status Indication and Display Bivar 5mm T1 ¾ Package Bi-Color LED is ideal for those applications where dual signals need to be displayed at the same location such as standby-on indication for server or computer peripherals. Bivar offers white diffused LED lens for uniform light output and the 2-lead package simplifies the circuitry design where a reverse voltage is available. Bivar offers white diffused LED lens for uniform light output. The Flange LED is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends. Part Number 5BC-F 5BC Material Emitted Color Peak. Wavelength λp(nm) TYP. GaAsP/GaP RED 625nm GaP/GaP GREEN 568nm GaAsP/GaP RED 625nm GaP/GaP GREEN 568nm Lens Appearance Viewing Angle White Diffused 45° Part Number Designation 5 B C -X LED Body, mm Lead Frame & Body Style i.e. -F, Blank for Standard Red/Green Bi-Color ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 1 of 6 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER YELLOW/GREEN, RED/GREEN, Bi-Color RED/GREEN, Bi-Color Bi-Color Outline Dimensions Flanged “5BC-F” LED Standard “5BC” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 2 of 6 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER YELLOW/GREEN, RED/GREEN, Bi-Color RED/GREEN, Bi-Color Bi-Color Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 80 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Emitted Color Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 5BC-F 5BC Red / 2.0 2.8 Green / 2.1 2.8 Red / 2.0 2.8 Green / 2.1 2.8 Reverse Dominant Current Wavelength (nm)2 (μA) MAX / 20 / 100 / 20 / 100 Notes: 1. Tolerance of forward voltage : ±0.05V. MIN Viewing Angle 2Ө½ (deg) Luminous Intensity Iv (mcd) TYP MAX MIN TYP MAX / / / / 8 / / / / / 8 / / / / / 6 / / / / / 8 / TYP 45 45 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 3 of 6 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER YELLOW/GREEN, RED/GREEN, Bi-Color RED/GREEN, Bi-Color Bi-Color Typical Electrical / Optical Characteristics - Red TA = 25°C unless otherwise noted 0° Iv 20° 10° 30° 1.0 40° 45° 50° 0.5 60° 70° 80° λ(nm) 0.0 550 600 650 700 750 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA Iv 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv (%) 1000 50 40 100 30 20 10 10 .01 1.2 Vf (V) 1.6 2.0 2.4 2.8 3.0 1 Fig. 3 Relative Intensity (10mA) vs. Forward Voltage 50 If (mA) 1 10 100 1000 Fig. 4 Relative Luminous Intensity (%) vs. Forward Current If(mA) 400 Iv (%) 200 40 100 30 20 50 10 20 T (°C) 0 0 20 40 60 80 100 Fig. 5 Forward Current vs. Temperature 10 T (°C) -20 0 20 40 60 80 100 Fig. 6 Relative Intensity (%) vs. Temperature @ 20 mA Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 4 of 6 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER YELLOW/GREEN, RED/GREEN, Bi-Color RED/GREEN, Bi-Color Bi-Color Typical Electrical / Optical Characteristics - Green TA = 25°C unless otherwise noted 0° 10° 20° 30° Iv 1.0 40° 45° 50° 60° 0.5 70° 80° 0.0 500 λ(nm) 550 600 650 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 Vf (V) 2.0 3.0 4.0 5.0 Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 100 1000 If (mA) Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 3.0 1.2 1.1 2.0 1.0 1.0 0.9 0.8 T (°C) -40 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 5 of 6 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER YELLOW/GREEN, RED/GREEN, Bi-Color RED/GREEN, Bi-Color Bi-Color Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A B 01/16/08 Revision 03/09 Page Page 4 6 of of 4 6
很抱歉,暂时无法提供与“5BC”相匹配的价格&库存,您可以联系我们找货
