LP368PWN1-D0G
LP368PWN1-D0G
    WOLFSPEED
    DIP
    White, Cool LED Indication - Discrete 3.6V 4-DIP (0.200", 5.08mm)
LP368PWN1-D0G 数据手册
Cree® P4 LED Model # LP368PWN1-D0G Data Sheet 130-degree, 7.6 x 7.6 mm LED lamp in white color with water-transparent lens and stopper Applications • • Indicators Illuminations Absolute Maximum Ratings (TA = 25°C) Items Symbol Absolute Maximum Rating Unit IF 30 mA IFP 100 mA Reverse Voltage VR 5 V Power Dissipation PD 132 mW Operation Temperature Topr -40 ~ +95 °C Storage Temperature Tstg -40 ~ +100 °C Lead Soldering Temperature Tsol Forward Current Peak Forward Current Note Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: Pulse width ≤0.1 msec, duty ≤1/10. Typical Electrical & Optical Characteristics (TA = 25°C) Characteristics Symbol Condition Unit Forward Voltage VF IF = 30 mA V Reverse Current IR VR = 5 V μA Luminous Intensity IV IF = 30 mA mcd Luminous Flux ΦV IF = 30 mA mlm x IF = 30 mA 0.31 y IF = 30 mA 0.32 2θ½H-H IF = 30 mA Chromaticity Coordinates deg Typical Maximum 3.6 4.4 100 280 400 1100 130 D-CT123.000 Data Sheet: CL 50% Power Angle Minimum Subject to change without notice. www.cree.com/ledlamps 1 Standard Bins for LP368PWN1-D0G (IF = 30 mA) Lamps are sorted to luminous intensity (IV), VF and chromaticity coordinates (x,y) bins shown. Orders for LP368PWN1-D0G may be filled with any or all bins contained as below. All luminous intensity (IV), VF and chromaticity coordinates (x,y) values shown and specified are at IF = 30 mA. Luminous Intensity (IV) A1 A2 B1 B2 c S or above 770 mcd R 550 mcd Q 390 mcd P 280 mcd Chromaticity Coordinates (x,y) Rank Chromaticity x Coordinates y A1 A2 B1 0.245 0.264 0.280 0.264 0.264 0.283 0.296 0.280 0.283 0.307 0.313 0.296 0.229 0.267 0.248 0.220 0.267 0.305 0.276 0.248 0.305 0.337 0.297 0.276 Rank B2 Chromaticity x Coordinates y c 0.307 0.330 0.330 0.313 0.330 0.361 0.356 0.330 0.337 0.360 0.318 0.297 0.360 0.385 0.351 0.318 Forward Voltage (VF) Rank Voltage V7 V8 V9 V10 V11 V12 V13 V14 2.8-3.0 V 3.0-3.2 V 3.2-3.4 V 3.4-3.6 V 3.6-3.8 V 3.8-4.0 V 4.0-4.2 V 4.2-4.4 V Important Notes: 1. All ranks will be included per delivery; rank ratio will be based on the dice distribution. 2. Pb content
LP368PWN1-D0G 价格&库存
很抱歉,暂时无法提供与“LP368PWN1-D0G”相匹配的价格&库存,您可以联系我们找货
