CP42S-GKS-CE0H0694
CP42S-GKS-CE0H0694
    WOLFSPEED
    DIP
    Green 527nm LED Indication - Discrete 3.6V 4-DIP (0.200", 5.08mm)
CP42S-GKS-CE0H0694 数据手册
CLD-CT1147.000 PRODUCT FAMILY DATA SHEET Cree® P4 LED CP42S-GKS PRODUCT DESCRIPTION FEATURES APPLICATIONS This revolutionary package design • Size (mm): 7.6 x 7.6 • Channel Letter • Color and Typical Dominant Wavelength: Green(527nm) • Amusement • Luminous Flux (mlm) CP42S-GKS: (1100-3300) • Lead - Free • RoHS Compliant allows the lighting designer to reduce the number of LEDs required and provide a more uniform and unique illuminated appearance than with other LED solutions. This is possible through the efficient optical-package design and highcurrent capabilities. The low-profile package can be easily coupled with reflectors or lenses to efficiently distribute light and provide the desired lit appearance. This product family employs green and blue LED materials, which allows designers to match the color of many lighting applications such as vehicle signal WWW.CREE.COM/HB lamps and amusement lighting. Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. the Cree logo are registered trademarks of Cree, Inc. Cree, the Cree logo and XLamp are registered trademarks of Cree, Inc. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 www.cree.com/xlamp Cree P4 LED CP42S-GKS ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit IF 30 mA IFP 100 mA Reverse Voltage VR 5 V Power Dissipation PD 132 mW Operation Temperature Topr -40 ~ +100 °C Storage Temperature Tstg -40 ~ +100 °C Lead Soldering Temperature Tsol Forward Current Peak Forward Current Note1 Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: 1. Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) Characteristics Symbol Condition Unit Forward Voltage VF IF = 30 mA V Reverse Current IR VR = 5 V μA Dominant Wavelength λD IF = 30 mA nm 515 527 Luminous Flux Φv IF = 30 mA mlm 1000 2000 2θ½ IF = 30 mA deg 50% Power Angle Minimum Typical Maximum 3.6 4.4 100 535 120 Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 2 Cree P4 LED CP42S-GKS FLUX BIN LIMIT (IF = 30 mA) Green Bin Code Min.(mlm) Max.(mlm) E0 1100 1650 F0 1650 2200 G0 2200 2750 H0 2750 3300 • Tolerance of measurement of luminous flux is ±15% COLOR BIN LIMIT (IF = 30 mA) Green Bin Code Min.(nm) Max.(nm) G6 515 520 G7 520 525 G8 525 530 G9 530 535 • Tolerance of measurement of dominant wavelength is ±1 nm VF BIN LIMIT (IF = 30 mA) Green Bin Code Min.(V) Max.(V) 27 2.8 3.0 28 3.0 3.2 29 3.2 3.4 2a 3.4 3.6 2b 3.6 3.8 2c 3.8 4.0 2d 4.0 4.2 2e 4.2 4.4 • Tolerance of measurement of VF is ±0.05V. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 3 Cree P4 LED CP42S-GKS ORDER CODE TABLE* Luminous Flux (mlm) Color Kit Number Viewing Angle Green CP42S-GKS-CE0H0694 120 Dominant Wavelength Min. Max. Color Bin Min. (nm) Color Bin Max. (nm) 1100 3300 G6 515 G9 535 Notes: 1. The above kit numbers represent order codes which include multiple flux-bin and color-bin codes. Only one flux-bin code and one color-bin code will be shipped on each reel. And single flux-bin code,single color bin-codes will not be orderable. 2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 4 Cree P4 LED CP42S-GKS GRAPHS                                                                                                  The above data are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 5 Cree P4 LED CP42S-GKS MECHANICAL DIMENSIONS All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max. NOTES  RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/ EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 6 Cree P4 LED CP42S-GKS KIT NUMBER SYSTEM All dimensions in mm.Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 7 Cree P4 LED CP42S-GKS PACKAGING Features: • • • • • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. The boxes are not water resistant, and they must be kept away from water and moisture. The Tube Pack type of packaging. Max 60 pcs per tube. R xxx xxx R C OL OR LED LAMP T YPE LXXXXXXXX-XXX LOT J OWAXXXXX -XX-XXX QT Y RANK P CS Iv Vf Hu e X XX XX AX XXX XXX XXX X Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 8
CP42S-GKS-CE0H0694 价格&库存
很抱歉,暂时无法提供与“CP42S-GKS-CE0H0694”相匹配的价格&库存,您可以联系我们找货
