CLD-CT877.002
PRODUCT FAMILY DATA SHEET
Cree® 5-mm Round LED
C535A-WJN
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
Round LEDs offer superior light out-
• Size (mm): 5
• Garden Light
put for excellent readability in sun-
• Color Temperatures(K):
Cool White :
Min . (4600) / Typical (9000)
• Light Strip
output over long periods of time.
• Luminous Intensity (mcd)
C535A-WJN (770-3000)
• Retail Display Lighting
These lamps are made with an
• Viewing angle: 110 degree
light and dependable performance.
They provide extremely stable light
advanced optical grade epoxy
offering superior high temperature
and high moisture resistance
• Channel Letter
• Lead-Free
• RoHS Compliant
performance in lighting and
WWW.CREE.COM/HB
illumination applications.
Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice.
the Cree logo are registered trademarks of Cree, Inc.
Cree, the Cree logo and XLamp are registered trademarks of Cree, Inc.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
www.cree.com/xlamp
Cree 5-mm Round LED
C535A-WJN
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
IF
25
mA
IFP
100
mA
Reverse Voltage
VR
5
V
Power Dissipation
PD
100
mW
Operation Temperature
Topr
-40 ~ +95
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Lead Soldering Temperature
Tsol
Forward Current
Peak Forward Current
Note
Max. 260°C for 3 sec. max.
(3 mm from the base of the epoxy bulb)
Note: Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Symbol
Condition
Unit
Forward Voltage
VF
IF = 20 mA
V
Reverse Current
IR
VR = 5 V
μA
Luminous Intensity
IV
IF = 20 mA
mcd
Chromaticity
Coordinates
x
IF = 20 mA
y
IF = 20 mA
2θ½
IF = 20 mA
50% Power Angle
Minimum
Typical
Maximum
3.2
4.0
100
770
1400
0.2895
0.2905
deg
110
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks
Copyright
© 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc.
of Cree, Inc.
2
Cree 5-mm Round LED
C535A-WJN
INTENSITY BIN LIMIT (IF = 20 mA)
Cool White
Min.
(mcd)
Max.
(mcd)
S0
770
1100
T0
1100
1520
U0
1520
2130
V0
2130
3000
Bin Code
• Tolerance of measurement of luminous intensity is ±15%
VF BIN LIMIT (IF = 20 mA)
Cool White
Bin Code
Min. (V)
Max. (V)
27
2.8
3.0
28
3.0
3.2
29
3.2
3.4
2a
3.4
3.6
2b
3.6
3.8
2c
3.8
4.0
• Tolerance of measurement of VF is ±0.05V.
Copyright
of Cree, Inc.
3
Cree 5-mm Round LED
C535A-WJN
COLOR BIN LIMIT (IF = 20 mA)
Bin
Code
Subbin
Wa
Wb
W1
Wc
Wd
We
Wf
W2
Wg
Wh
x
y
0.2545
0.2633
0.2545
0.2245
0.2450
0.2633
Bin
Code
Subbin
x
y
0.2480
0.2830
0.2410
0.2950
0.2998
0.3028
0.2290
0.2895
0.2410
0.2895
0.2720
0.2340
0.2640
0.2200
0.2545
0.2245
0.2545
0.2480
0.2640
0.2670
0.2720
0.2575
0.2633
Bin
Code
Subbin
x
y
0.3050
0.3300
0.3600
0.3210
0.3455
0.3725
0.3443
0.3535
0.2905
0.3300
0.3390
0.2905
0.3300
0.3390
0.2998
0.3028
0.3443
0.3535
0.3045
0.2865
0.3430
0.3345
0.2960
0.2760
0.3300
0.3180
0.2950
0.3210
0.3455
0.3725
0.3070
0.3370
0.3610
0.3850
0.3100
0.3150
0.3585
0.3680
0.2410
0.2998
0.3028
0.3443
0.3535
0.2633
0.2410
0.2998
0.3028
0.3443
0.3535
0.2720
0.2575
0.3100
0.3150
0.3585
0.3680
0.2800
0.2480
0.3130
0.2970
0.3560
0.3510
0.2720
0.2340
0.3045
0.2865
0.3430
0.3345
0.2640
0.2670
0.3070
0.3370
0.2735
0.2860
0.3185
0.3485
0.2808
0.2740
0.3200
0.3270
0.2720
0.2575
0.3100
0.3150
0.2720
0.2575
0.3100
0.3150
0.2808
0.2740
0.3200
0.3270
0.2880
0.2620
0.3215
0.3075
0.2800
0.2480
0.3130
0.2970
0.2735
0.2860
0.3185
0.3485
0.2830
0.3050
0.3300
0.3600
0.2895
0.2905
0.3300
0.3390
0.2808
0.2740
0.3200
0.3270
0.2808
0.2740
0.3200
0.3270
0.2895
0.2905
0.3300
0.3390
0.2960
0.2760
0.3300
0.3180
0.2880
0.2620
0.3215
0.3075
Wj
Wk
W3
Wm
Wn
Wp
Wq
W4
Wr
Ws
Wt
Wu
W5
Wv
Ww
• Tolerance of measurement of the color coordinates is ±0.01.
Copyright
of Cree, Inc.
4
Cree 5-mm Round LED
C535A-WJN
00
K
CIE CHROMATICITY DIAGRAM
00
K
50
0 .3 9 0 0
0 .1 9 0 0
0 .2 3 0 0
W
aW
c
b
W
f
3
k
W
h
2
W
n
d
1
W
e
q
s
W
W
0 .2 7 0 0
g
W
W
w
W
y
W
j
W
W
W
u
W
W
00
90
10
00
W
m
p
r W
t
4
K
K
80
00
W
W
0K
0 .3 1 0 0
0 .2 3 0 0
W
70
0 .3 5 0 0
5
00
K
W
v
W
60
W
0 .2 7 0 0
0 .3 1 0 0
0 .3 5 0 0
0 .3 9 0 0
x
Copyright
of Cree, Inc.
5
Cree 5-mm Round LED
C535A-WJN
ORDER CODE TABLE*
Color
Kit Number
Viewing Angle
Cool White
C535A-WJN-CS0V0151
Cool White
C535A-WJN-CS0V0231
Cool White
Cool White
Min.
Max.
Color Bin Code
110
770
3000
W1,W2,W3,W4,W5
110
770
3000
W2,W3
C535A-WJN-CT0V0231
110
1100
3000
W2,W3
C535A-WJN-CU0V0231
110
1520
3000
W2,W3
Notes:
1. The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one
intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin
codes will not be orderable.
2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions.
3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED
product safely.
Copyright
of Cree, Inc.
6
Cree 5-mm Round LED
C535A-WJN
GRAPHS
The above data are collected from statistical figures that do not necessarily correspond to the actual
parameters of each single LED. Hence, these data will be changed without further notice.
Copyright
of Cree, Inc.
7
Cree 5-mm Round LED
C535A-WJN
MECHANICAL DIMENSIONS
All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted.
An epoxy meniscus may extend about 1.5 mm down the leads.
Burr around bottom of epoxy may be 0.5 mm max.
NOTES
RoHS Compliance
The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/
EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as
amended through April 21, 2006.
Vision Advisory Claim
Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye.
Copyright
of Cree, Inc.
8
Cree 5-mm Round LED
C535A-WJN
KIT NUMBER SYSTEM
All dimensions in mm.Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color,
forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to
the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
Copyright
of Cree, Inc.
9
Cree 5-mm Round LED
C535A-WJN
PACKAGING
Features:
The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation.
The boxes are not water resistant, and they must be kept away from water and moisture.
The Bulk Pack types of packaging.
Max 500 pcs per bag.
xxx xxx
R
COLOR LED LAMP
TYPE
LXXXXXXXX-XXX
LOT
JOWAXXXXX -XX-XXX
QTY
RANK
PCS
Iv
X
Vf
XX
Hue
XX
AXXXXXXXXXXX
Label
(anti-electrostatic
bag)
20 bags/carton
Copyright
of Cree, Inc.
10
