LWY1SG-AFBF-EKFM-1-Z
    AMSOSRAM(艾迈斯半导体)
    2-SMD,无引线
    LEDCOOLWHITEDIFF2SMDR/A
LWY1SG-AFBF-EKFM-1-Z 数据手册
2015-06-12 Micro SIDELED 2808 Datasheet Version 2.5 LW Y1SG Micro SIDELED is a SMT LED with side emission. Due to its low package height it is ideal for applications in limited space environments. Micro SIDELED ist eine SMT LED mit seitlicher Abstrahlrichtung. Aufgrund ihrer niedrigen Bauteilhöhe ist sie ideal für Anwendungen mit begrenztem Raum. Features: • Package: white SMT package, colored diffused silicone resin • Technology: InGaN on Sapphire • Viewing angle at 50 % IV: 120° • Color: Cx = 0.30, Cy = 0.28 acc. to CIE 1931 (white); CTR = 8200 K • Optical efficiency (typ.): 45 lm/W (white) Besondere Merkmale: • Gehäusetyp: weißes SMT Gehäuse, farbiger diffuser Silikon-Verguss • Technologie: InGaN on Sapphire • Abstrahlwinkel bei 50 % IV: 120° • Farbe: Cx = 0.30, Cy = 0.28 nach CIE 1931 (weiß); CTR = 8200 K • Optischer Wirkungsgrad (typ.): 45 lm/W (weiß) Applications Backlighting • • Coupling into light guides • Signal and Symbol Luminary Anwendungen • Hinterleuchtung • Einkopplung in Lichtleiter • Signal- und Symbolleuchten 2015-06-12 1 Version 2.5 LW Y1SG Ordering Information Bestellinformation Type: Luminous Intensity 1) page 22 Ordering Code Typ: Lichtstärke 1) Seite 22 Bestellnummer IF = 20 mA IV [mcd] LW Y1SG-BFOO-EKFM-1 ≥ 1600 Q65111A8461 LW Y1SG-BFOO-GKJM-1 ≥ 1600 Q65111A8460 LW Y1SG-BFCF-EKFM-1 1600 ... 2200 Q65110A9545 LW Y1SG-BFCF-GKJM-1 1600 ... 2200 Q65110A9546 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. LW Y1SG-BFOO-GKJM-1 means that only one group BF, CE, CF, DE will be shippable for any packing unit. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. LW Y1SG-BFOO-GKJM-1 means that the device will be shipped within the specified limits. In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing unit. E. g. LW Y1SG-BFOO-GKJM-1 means that only one forward voltage group 4,5 will be shippable. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LW Y1SG-BFOO-GKJM-1 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen BF, CE, CF, DE enhalten ist. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. LW Y1SG-BFOO-GKJM-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. LW Y1SG-BFOO-GKJM-1 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Durchlassspannungsgruppe geliefert. Z. B. LW Y1SG-BFOO-GKJM-1 bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer Verpackungseinheit ist nur eine der Durchlassspannungsgruppen 4,5 enthalten (siehe Seite 5). 2015-06-12 2 Version 2.5 LW Y1SG Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 85 °C Storage temperature range Lagertemperatur Tstg -40 ... 100 °C Junction temperature Sperrschichttemperatur Tj 95 °C Forward current Durchlassstrom (TA = 25 °C) IF 30 mA Surge current Stoßstrom (t ≤ 10 µs; D = 0.005; TA = 25 °C) IFM 300 mA Reverse voltage Sperrspannung (TA = 25 °C) VR not designed for reverse operation V 2 kV VESD ESD withstand voltage ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class 2) 2015-06-12 3 Version 2.5 LW Y1SG Characteristics (TA = 25 °C; IF = 20 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Chromaticity coordinates acc. to CIE 1931 2) page 22 Farbkoordinaten nach CIE 1931 2) Seite 22 (typ.) (typ.) Cx Cy 0.3 0.28 - Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 120 ° Forward voltage 3) page 22 , 4) page 22 Durchlassspannung 3) Seite 22 , 4) Seite 22 (min.) (typ.) (max.) VF VF VF 2.90 3.30 3.60 V V V IR not designed for reverse operation Reverse current Sperrstrom Temperature coefficient of x Temperaturkoeffizient von x (typ.) TCx -0.2 10-3/K Temperature coefficient of y Temperaturkoeffizient von y (typ.) TCy -0.2 10-3/K Real thermal resistance junction / ambient 5) page 22 , (max.) Rth JA real 460 K/W (max.) Rth JS real 240 K/W 6) page 22 Realer Wärmewiderstand Sperrschicht / Umgebung 5) Seite 22 , 6) Seite 22 Real thermal resistance junction / solder point 6) page 22 Realer Wärmewiderstand Sperrschicht / Lötpad 6) Seite 22 Note: Individual forward voltage groups see next page Anm.: Durchlassspannungsgruppen siehe nächste Seite 2015-06-12 4 Version 2.5 LW Y1SG Brightness Groups Helligkeitsgruppen Group Luminous Intensity 1) page 22 Luminous Intensity 1) page 22 Luminous Flux 7) page 22 Gruppe Lichtstärke 1) Seite 22 Lichtstärke 1) Seite 22 Lichtstrom 7) Seite 22 (min.) Iv [mcd] (max.) Iv [mcd] (typ.) ΦV [mlm] AE 1000 1200 3300 AF 1200 1400 3900 BE 1400 1600 4500 BF 1600 1800 5100 CE 1800 2000 5700 CF 2000 2200 6300 DE 2200 2400 6900 DF 2400 2600 7500 EE 2600 2800 8100 Forward Voltage Groups 3) page 22 , 4) page 22 Durchlassspannungsgruppen 3) Seite 22 , 4) Seite 22 Group Gruppe (min.) VF [V] (max.) VF [V] 4 2.90 3.20 5 3.20 3.60 2015-06-12 5 Version 2.5 LW Y1SG Chromaticity Coordinate Groups 2) page 22 Farbortgruppen 2) Seite 22 0.34 + 0.33 Cy 0.32 0.9 520 JM 530 0.8 0.31 540 Cy 510 550 0.7 0.6 GM 0.5 490 0.2 0.28 590 600 610 620 630 + 0.3 E 0 0.1 0.2 0.4 FK 0.26 0.5 0.6 0.7 0.8 GK EM EL 0.25 0.3 HK FM FL 0.27 480 470 460 450 0.1 0 GL 580 0.4 JK HL 0.29 570 500 JL HM 0.30 560 EK 0.24 0.9 Cx 0.34 0.32 0.33 0.31 0.30 0.29 0.28 0.27 0.22 0.26 0.23 Cx OHA02648 Color Chromaticity Groups 2) page 22 Farbortgruppen 2) Seite 22 Group Gruppe EK EL 2015-06-12 Cx Cy 0.2800 0.2480 0.2880 Group Gruppe Cx Cy Cx Cy 0.2750 0.2810 0.2990 0.2940 0.2390 0.2820 0.2720 0.3020 0.2830 0.2880 0.2620 0.2870 0.2950 0.3090 0.3050 0.2950 0.2530 0.2910 0.2870 0.3110 0.2940 0.2720 0.2580 0.2960 0.2760 0.2960 0.3040 0.2800 0.2480 0.3010 0.2650 0.2990 0.2940 0.2820 0.2720 0.3020 0.2830 0.3070 0.3150 0.2880 0.2620 0.3050 0.2720 0.3090 0.3050 FM GK 6 Group Gruppe HL HM Version 2.5 Group Gruppe EM FK FL 2015-06-12 LW Y1SG Cx Cy 0.2720 0.2580 0.2750 Group Gruppe Cx Cy Cx Cy 0.2910 0.2870 0.3110 0.2940 0.2810 0.2960 0.2760 0.3130 0.2830 0.2820 0.2720 0.2990 0.2940 0.3210 0.3060 0.2820 0.2720 0.3020 0.2830 0.3090 0.3050 0.2880 0.2620 0.2870 0.2950 0.3110 0.2940 0.2950 0.2530 0.2910 0.2870 0.3200 0.3170 0.2960 0.2760 0.2960 0.3040 0.3210 0.3060 0.3010 0.2650 0.2990 0.2940 0.3070 0.3150 0.2820 0.2720 0.3020 0.2830 0.3090 0.3050 0.2880 0.2620 0.3050 0.2720 0.3190 0.3280 0.2910 0.2870 0.3110 0.2940 0.3200 0.3170 0.2960 0.2760 0.3130 0.2830 GL GM HK 7 Group Gruppe JK JL JM Version 2.5 LW Y1SG Group Name on Label Gruppenbezeichnung auf Etikett Example: BF-GK-4 Beispiel: BF-GK-4 Brightness Helligkeit Chromaticity Coordinate Farbort Forward Voltage Durchlassspannung BF GK 4 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2015-06-12 8 Version 2.5 LW Y1SG Relative Spectral Emission - V(λ) = Standard eye response curve 7) page 22 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 7) Seite 22 Irel = f (λ); TA = 25 °C; IF = 20 mA OHL02380 100 % I rel 80 Vλ 60 40 20 0 400 450 500 550 600 650 700 nm 750 λ 7) page 22 Radiation Characteristics Abstrahlcharakteristik 7) Seite 22 Irel = f (ϕ); TA = 25 °C 40˚ 30˚ 20˚ 10˚ 0˚ ϕ 50˚ OHL01660 1.0 0.8 0.6 60˚ 0.4 70˚ 0.2 80˚ 0 90˚ 100˚ 1.0 2015-06-12 0.8 0.6 0.4 0˚ 20˚ 9 40˚ 60˚ 80˚ 100˚ 120˚ Version 2.5 LW Y1SG Forward Current 7) page 22 , 4) page 22 Durchlassstrom 7) Seite 22 , 4) Seite 22 IF = f (VF); TA = 25 °C IF 10 2 mA Relative Luminous Intensity 7) page 22 , 4) page 22 Relative Lichtstärke 7) Seite 22 , 4) Seite 22 IV/IV(20 mA) = f(IF); TA = 25 °C OHL02743 OHL02386 10 1 IV I V (20 mA) 10 0 10 1 5 10 0 2.5 2.8 3.1 3.4 3.7 4.0 10 -1 0 10 V 4.6 VF 2015-06-12 5 10 1 mA 10 2 IF 10 Version 2.5 LW Y1SG Relative Luminous Intensity 7) page 22 Relative Lichtstärke 7) Seite 22 IV/IV(25)°C = f(Tj); IF = 20 mA Relative Forward Voltage 7) page 22 Relative Vorwärtsspannung 7) Seite 22 ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ∆VF OHL02397 0.4 V IV I V (25 ˚C) 0.3 0.2 1.0 0.1 0.8 0 0.6 -0.1 0.4 -0.2 0.2 -0.3 -60 -40 -20 0 20 40 60 0 -60 -40 -20 0 ˚C 100 20 40 60 ˚C 100 Tj Tj 2015-06-12 OHL02725 1.4 11 Version 2.5 LW Y1SG Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) IF OHL03560 35 mA 30 25 TA TS 20 15 10 5 0 TA temp. ambient TS temp. solder point 0 20 40 60 80 ˚C 100 T Permissible Pulse Handling Capability Zulässige Impulsbelastbarkeit IF = f(tp) D: Duty cycle, TA = 25 °C 0.35 IF A 0.25 0.20 0.15 0.10 Permissible Pulse Handling Capability Zulässige Impulsbelastbarkeit IF = f(tp) D: Duty cycle, TA = 85 °C OHL02563 t 0.35 IF A tP D = TP IF T t D = TP IF T 0.25 D= 0.005 0.01 0.02 0.05 0.1 0.2 0.5 1 0.20 0.15 0.10 0.05 0.05 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 D= 0.005 0.01 0.02 0.05 0.1 0.2 0.5 1 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 tp 2015-06-12 OHL02564 tP tp 12 Version 2.5 LW Y1SG Package Outline 8) page 22 Maßzeichnung 8) Seite 22 Approximate Weight: 5 mg Gewicht: 5 mg 2015-06-12 13 Version 2.5 Recommended Solder Pad 8) page 22 Empfohlenes Lötpaddesign 8) Seite 22 LW Y1SG Reflow soldering Reflow-Löten 1.4 (0.055) 1 (0.039) 0.9 (0.035) 1.4 (0.055) OHLPY944 Note: For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning. Anm.: Um eine verbesserte Lötstellenkontaktierung zu erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Das Gehäuse ist für Ultraschallreinigung nicht geeignet. 2015-06-12 14 Version 2.5 LW Y1SG Reflow Soldering Profile Reflow-Lötprofil Product complies to MSL Level 4 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Symbol Symbol Profile Feature Profil-Charakteristik Pb-Free (SnAgCu) Assembly Minimum ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2015-06-12 °C 15 s Version 2.5 LW Y1SG 2 (0.079) 0.24 (0.009) Cathode 8 (0.315) 1.5 (0.059) 3.5 (0.138) 4 (0.157) 2.9 (0.114) 1.75 (0.069) Taping 8) page 22 Gurtung 8) Seite 22 Anode 1.32 (0.052) 1.09 (0.043) 4 (0.157) OHAY2128 2015-06-12 16 Version 2.5 LW Y1SG Tape and Reel Gurtverpackung 8 mm tape with 2000 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Tape dimensions [mm] Gurtmaße [mm] Tape dim ensions in m m W P0 P1 P2 D0 E F 8 + 0.3 / -0.1 4 ± 0.1 2 ± 0.05 or 4 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 3.5 ± 0.05 Reel dimensions [mm] Rollenmaße [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 8 60 8.4 + 2 14.4 2015-06-12 17 Version 2.5 LW Y1SG Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Trockenverpackung und Materialien Moisture-sensitive label or print L VE el LE see . lab e H) nk, (R bla cod If y bar . dit RH mi % hu e /60 ve ed ag ˚C ati rar ck rel 30 s VE RS _ < inf pa % ainITI TO of to ak 90 urs d nt ). < ns (pe or urs d co NSUC Ho de , cte itio urs g SEND Ho an bje ing co ˚C 72 nd Ho urs 5 baRE CO te 48 ˚C su ss e Ho co ± ce is 24 6 da e y MI 40 be tim ˚C e ThISTU th < tor ll pro tim SE or ). 23 tim e at t wi nt˚C or l wi fac MO Flo tim s TO at or ca at re. Flo d tha ale el or nth OP nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ve % ure ba ed low ba Le mo ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk rd g -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo Barcode label N TIO U A C M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2015-06-12 18 Version 2.5 LW Y1SG Transportation Packing and Materials Kartonverpackung und Materialien Barcode label 8 Y M DE R 18 -1 Q P -1 + P: C: 99 D/ 21 00 (9 D) 21 : 20 00 : 14 2 5 (Q )Q TY O H 12 34 S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T (1 T) NO : OD PR ) (X 44 (G ) G RO UP : P -1 + Q -1 R 18 DE M Y Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 D) (9 : 20 00 D/ C: 01 Muster TY )Q : 34 : NO O PR (X ) Packing Sealing label Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 200 ± 5 195 ± 5 30 ± 5 2015-06-12 M RA OS D 5 14 2 110 0 (Q O S TC (1 T) LO T NO (6 P) : 12 BA S 8 3G em R ic AM o n O d u p ct to o H rs NO 2199 H 12 2100 01 44 el A C OU L GR E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho IC co ± is UR 24 6 da e M 40 be oc ry tim ˚C e Th STSE r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed re ty is qu JE 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT CT nt TIO co NS DU g SE U ba E ON (G ) M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 19 OHA02044 Version 2.5 LW Y1SG Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Exempt group (exposure time 10000 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Exempt group (Expositionsdauer 10000 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Autoscheinwerfer), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. Subcomponents of this LED are silverplated. Silver is discoloring when being exposed to environments containing high concentrations of aggressive substances. Corroded silver may lead to a worsening of the optical performance of the LED and can in the worst case lead to a failure of the LED. Do not expose this LED to aggressive atmospheres. Note, that corrosive gases may as well be emitted from materials close to the LED in the final product. Einzelkomponenten dieser LED sind silberbeschichtet. Silberoberflächen werden durch korrosive Substanzen verändert. Korrodiertes Silber kann zu einer Verschlechterung der optischen Eigenschaften und im schlimmsten Fall zum Ausfall der LED führen. Diese LED darf aggressiven Bedingungen nicht ausgesetzt werden. Es ist zu beachten, dass korrosive Gase auch von Materialien emittiert werden können, die sich im Endprodukt in unmittelbarer Umgebung der LED befinden. For further application related informations please visit www.osram-os.com/appnotes Für weitere applikationsspezifische Informationen besuchen Sie bitte www.osram-os.com/appnotes 2015-06-12 20 Version 2.5 LW Y1SG Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Bei abweichenden Angaben im zweisprachigen Wortlaut haben die Angaben in englischer Sprache Vorrang. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-06-12 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 21 Version 2.5 LW Y1SG Glossary Glossar 1) Brightness: Brightness groups are tested at a current pulse duration of 25 ms and a tolerance of ± 11%. 1) Helligkeit: Helligkeitswerte werden Stromeinprägedauer von 25 ms Genauigkeit von ± 11% ermittelt. 2) Chromaticity coordinate groups: Chromaticity coordinate groups are tested at a current pulse duration of 25 ms and a tolerance of ±0.01. 2) Farbortgruppen: Farbortgruppen werden mit einer Stromeinprägedauer von 25 ms und einer Genauigkeit von ±0,01 ermittelt. 3) Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of ± 0.1 V. 3) Durchlassspannung: Spannungswerte werden mit einer Stromeinprägedauer von 1 ms und einer Genauigkeit von ± 0,1 V ermittelt. 4) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 4) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 5) Thermal Resistance: RthJA results from mounting on PC board FR 4 (pad size 16mm² per pad) 5) Wärmewiderstand: RthJA ergibt sich bei Montage auf PC-Board FR 4 (Padgröße 16mm² je pad) 6) Thermal Resistance: Rth max is based on statistic values (6σ). 6) Wärmewiderstand: Rth statistischen Werten (6σ). 7) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 7) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-06-12 22 max mit und basiert einer einer auf
LWY1SG-AFBF-EKFM-1-Z 价格&库存
很抱歉,暂时无法提供与“LWY1SG-AFBF-EKFM-1-Z”相匹配的价格&库存,您可以联系我们找货
