3HDL
3HDL
    BIVAR
    T-1
    发光二极管/LED 径向
3HDL 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, GREEN, TURQUOISE, BLUE, RED, Low Ultra Ultra Super Current Current Bright Ultra Bright Bright Bright RED, Low Low Current B 3HDL-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Diffused Lens Available in Flange (F) and Shouldered (S) Lead Frame Styles 2 mA Low Operating Current Ideal for Status Indication and Display Bivar 3mm T1 Package 2 mA Low Current LED is special binned at 2 mA and is ideal for those applications where lower power budget is required such as solar panel or battery-powered portable devices. Bivar offers diffused LED lens for uniform light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number 3HDL-F 3HDL-S Material Emitted Color Peak. Wavelength λp(nm) TYP. GaAsP/GaP RED 625nm Lens Appearance Viewing Angle Red Diffused 35° Red Diffused 40° Part Number Designation 3 X X L -X LED Body, mm Emitted Color Lens Appearance Lead Frame & Body Style i.e. -F, -S Low Current ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright RED, Low Current Outline Dimensions Flanged “3XXL-F” LED Shouldered Lead “3XXL-S” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright RED, Low Current Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 10 mW Forward Current ( DC ) Peak Forward Current 7 mA 1 / mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 2 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 3HDL-F 3HDL-S / 2.0 2.6 / 2 Notes: 1. Tolerance of forward voltage : ±0.05V. Reverse Dominant Current Wavelength (nm)2 (μA) MAX / 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 2.5 / 35 / / / / 2.5 / 40 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright RED, Low Current Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Iv 0° 1.0 10° 20° 30° 40° 50° 35° 40° 0.5 60° 70° 80° λ(nm) 0.0 550 600 650 700 750 Fig. 1 Relative Luminous Intensity vs. Wavelength 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv Iv (%) 1000 50 40 100 30 20 10 10 .01 1.2 Vf (V) 1.6 2.0 2.4 2.8 3.0 1 Fig. 3 Relative Intensity (10mA) vs. Forward Voltage 400 If (mA) 1 10 100 1000 Fig. 4 Relative Luminous Intensity (%) vs. Forward Current Iv (%) 200 100 50 20 10 T (°C) -20 0 20 40 60 80 100 Fig. 5 Relative Intensity (%) vs. Temperature @ 20 mA Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright RED, Low Current Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti-Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A C 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
很抱歉,暂时无法提供与“3HDL”相匹配的价格&库存,您可以联系我们找货
