3SRD-201
3SRD-201
    BIVAR
    T-1
    发光二极管/LED 径向
3SRD-201 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, BLUE, YELLOW, AMBER, GREEN, Ultra 5V 12V Extended Ultra Super Low Current Bright Ultra Bright Current Bright Profile Bright SUPERLow RED, Extended Profile B 3SRX-201-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Water Clear (C) and Diffused (D) Lenses Available in a Shouldered (S) Lead Frame Style Up to 60 mcd Luminous Intensity at 20 mA Ideal for Status Indication and Display Bivar 3mm T1 Package Extended Profile LED may be used in higher ambient lighting applications and provides additional protrusion for those applications with thicker face plates. Bivar offers water clear LED lens for maximum light output and diffused LED lens for uniform light output. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number 3SRC-201-S 3SRD-201-S Material Emitted Color Peak. Wavelength λp(nm) TYP. GaAlAs/GaAs RED 645nm Lens Appearance Viewing Angle Water Clear 20° Red Diffused 35° Part Number Designation 3SX X-2 0 1 - X LED Body, mm Super Bright Lead Frame & Body Style i.e. -S, Shouldered Extended Profile Emitted Color Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, GREEN, BLUE, Ultra Extended Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Bright SUPERLow RED, Extended Profile Outline Dimensions Shouldered “3SXX-201-S” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, GREEN, BLUE, Ultra Extended Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Bright SUPERLow RED, Extended Profile Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 70 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 3SRC-201-S 3SRD-201-S / 1.7 2.4 / 20 Notes: 1. Tolerance of forward voltage : ±0.05V. Reverse Dominant Current Wavelength (nm)2 (μA) MAX / 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 60 / 20 / / / / 40 / 35 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, GREEN, BLUE, Ultra Extended Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Bright SUPERLow RED, Extended Profile Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 20° 50° 35° 0.5 60° 70° 80° 0.0 600 90° λ(nm) 700 650 0.5 750 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA If (mA) 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv 1000 4.0 100 3.0 10 2.0 1 1.0 0.1 Vf (V) 1.0 0.3 2.0 3.0 4.0 If (mA) 0.0 5.0 1 Fig. 3 Forward Current vs. Forward Voltage 10 100 1000 Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 3.0 1.2 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, GREEN, BLUE, Ultra Extended Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Bright SUPERLow RED, Extended Profile Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti-Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A B 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
3SRD-201 价格&库存
很抱歉,暂时无法提供与“3SRD-201”相匹配的价格&库存,您可以联系我们找货
3SRD-201
