3SUYC
3SUYC
    BIVAR
    T-1
    发光二极管/LED 径向
3SUYC 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, GREEN, YELLOW, Super Ultra Bright YELLOW,Ultra UltraBright Bright B 3SUYC-X ♦ ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Water Clear Lens Available in Flange (F), Standard (Blank), and Shouldered (S) Lead Frame styles Up to 400 mcd Luminous Intensity at 20 mA Ideal for Back Lighting, Status Indication, and Display Recommended for Bivar Flexible Light Pipe assemblies Bivar 3mm T1 Package Ultra Bright LED is ideal for those applications where intensive ambient lighting exists such as Back Lighting, Signage, and Sunlight Readable applications. Bivar offers water clear LED lens for maximum light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies, the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends, and the Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. A long lead version is also available with a “-LL” suffix added to the part numbers. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. 3SUYC-F 3SUYC AIGaInP YELLOW 590nm 3SUYC-S Lens Appearance Viewing Angle Water Clear 20° Water Clear 30° Water Clear 30° Part Number Designation 3 U X X -X LED Body, mm Ultra Bright Emitted Color Lead Frame & Body Style i.e. -F, -S, Blank for Standard Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 04/09 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, GREEN, Super Bright YELLOW,Ultra UltraBright Bright Outline Dimensions Flanged “3UXX-F” LED Standard “3UXX” LED Shouldered Lead “3UXX-S” LED Standard Lead Only Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 04/09 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, GREEN, Super Bright YELLOW,Ultra UltraBright Bright Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 85 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX 3SUYC-F 3SUYC / 2.0 2.4 / 20 3SUYC-S Notes: 1. Tolerance of forward voltage : ±0.05V. / 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 400 / 20 / / / / 400 / 30 / / / / 400 / 30 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 04/09 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, GREEN, Super Bright YELLOW,Ultra UltraBright Bright Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° 20° 30° Iv 20° 30° 1.0 40° 50° 0.5 60° 70° 80° 0.0 500 90° λ(nm) 550 600 650 0.5 700 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 2.0 3.0 4.0 5.0 Vf (V) Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 If (mA) 100 1000 Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 04/09 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, GREEN, Super Bright YELLOW,Ultra UltraBright Bright Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A B 01/16/08 Revision 04/09 Page Page 4 5 of of 4 5
3SUYC 价格&库存
很抱歉,暂时无法提供与“3SUYC”相匹配的价格&库存,您可以联系我们找货
