7021X15
7021X15
    VCC
    SMD
    发光二极管/LED SMD
7021X15 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 7021X Series Surface Mount LEDs Reverse Mounting Description and Features 3.20 LE D C HIP 1.40 1.60 0.10 Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 3000 per reel. Leading Edge LED Optoelectronic Performance • Consistent high brightness. 0.75 C AT HODE MAR K 1.40 P LAS T IC Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 1.pdf” S UB S T R AT E 0.80 0.30 0.50 0.50 C AT HODE P OLAR IT Y MAR K ANODE All dimensions in mm. Electro-Optical Characteristics and Ratings P AR T NUMB E R Output C olor Diffused/Non-Diffused P ackage C olor P ower Dissipation (mW) P eak F orward C urrent Max. (mA) R everse V oltage (IR =100µA) (V ) Operating temperature (°C ) S torage T emperature (°C ) F orward Voltage Typ. (IF =20mA) F orward Voltage Max. (IF =20mA) Lead S older Time @ 260°C (seconds) Luminous Intensity Min. (IF=20mA) Luminous Intensity Typ. (IF=20mA) P eak Wavelength (IF =20mA) V iewing Angle (degrees) R ated C urrent (mA) 7021X1 R ed Diffused C lear 57.5 60 4 -30 to +85 -40 to +100 1.7 2.3 5 7.6 12.7 660 75 20 7021X3 Orange Diffused C lear 70 60 4 -30 to +85 -40 to +100 2.2 2.8 5 2.2 3.7 605 70 20 7021X5 G reen Diffused C lear 70 60 4 -30 to +85 -40 to +100 2.1 2.8 5 4.1 6.9 560 70 20 7021X7 Y ellow Diffused C lear 70 60 4 -30 to +85 -40 to +100 2.2 2.8 5 2.2 3.7 580 70 20 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 7021X15 G reen Diffused C lear 70 60 4 -30 to +85 -40 to +100 2.1 2.8 5 1.6 2.7 555 70 20
7021X15 价格&库存
很抱歉,暂时无法提供与“7021X15”相匹配的价格&库存,您可以联系我们找货
