3AT
3AT
    BIVAR
    T-1
    发光二极管/LED 径向
3AT 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER 3AX-X ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in Flange (F) and Shouldered (S) Lead Frame styles Ideal for Status Indication and Display Bivar 3mm T1 Package LED may be used in almost any application. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number Viewing Angle 3AC-F Water Clear 20° 3AD-F Amber Diffused 35° Amber Tinted 20° Water Clear 30° 3AD-S Amber Diffused 40° 3AT-S Amber Tinted 30° 3AC-S GaAsP/Gap Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance 3AT-F Material AMBER 605nm Part Number Designation 3 X X - X LED Body, mm Emitted Color Lead Frame & Body Style i.e. -F or -S Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 1 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 2 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 80 mW Forward Current ( DC ) 30 mA Peak Forward Current 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Dominant Current Wavelength (nm)2 (μA) MIN TYP MAX MIN TYP MAX MAX Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 40 / 20 / / / / 25 / 35 3AT-F / / / / 40 / 20 3AC-S / / / / 40 / 30 / / / / 25 / 40 / / / / 40 / 30 3AC-F 3AD-F 3AD-S / / 2.0 2.0 2.8 2.8 / / 20 20 / / 100 100 3AT-S Notes: 1. Tolerance of forward voltage : ±0.05V. 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 3 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° 20° 30° Iv 1.0 40° 20° 30° 35° 50° 40° 0.5 60° 70° 80° 0.0 550 λ(nm) 600 650 700 750 90° 0.5 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 2.0 3.0 4.0 5.0 Vf (V) 0.0 1 10 100 1000 If (mA) Fig. 4 Relative Luminous Intensity vs. Forward Fig. 3 Forward Current vs. Forward Voltage Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 4 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A C 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
很抱歉,暂时无法提供与“3AT”相匹配的价格&库存,您可以联系我们找货
