7011X1/17
7011X1/17
    VCC
    SMD
    7011X1/17
7011X1/17 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 7011X Series Bicolor SMT LEDs Description and Features 3.00 C AT HODE MAR K LE D C HIP #1 1 2 2.50 1.50 Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 2500 per reel. • RoHS Compliant 0.80 Leading Edge LED Optoelectronic Performance • Consistent high brightness. LE NS 4 3 2.00 LE D C HIP #2 1.80 Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. 0.90 • Refer to “Solder Pad Geometry 1.pdf” 1.00 0.60 0.60 MIN. 4 3 1 2 C ONT AC T S , G OLD P LAT E D (4) All dimens ions in mm. Electro-Optical Characteristics and Ratings P AR T NUMB E R Output C olor Diffused/Non-Diffused P ackage C olor P ower Dissipation (mW) P eak F orward C urrent Max. (mA) R everse V oltage (IR =100µA) (V ) Operating temperature (°C ) S torage T emperature (°C ) F orward Voltage Typ. (IF =20mA) F orward Voltage Max. (IF =20mA) C ontinuous F orward C urrent Max. (mA) Luminous Intensity Min. (IF=20mA) Luminous Intensity Max. (IF=20mA) P eak Wavelength (IF =20mA) V iewing Angle (degrees) R ated C urrent (mA) R everse C urrent Max. (VR =4V ) 7011X1/5 R ed/G reen Non-Diffused C lear 60/75 70 4 -30 to +85 -30 to +90 1.7/2.1 2.0/2.5 30 6.0/3.0 17.0/7.5 660/560 100 20 100 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
7011X1/17 价格&库存
很抱歉,暂时无法提供与“7011X1/17”相匹配的价格&库存,您可以联系我们找货
