7016X13
7016X13
    VCC
    发光二极管/LED 1208
7016X13 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 7016X Series SMT LEDs 1208 Package Size Description and Features Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 2500 per reel. 3.00 1.30+0.20/-0.10 2.30 0.50 1.60 0.30 Leading Edge LED Optoelectronic Performance • Consistent high brightness. 2.00 R 0.30 TYP. Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. 1 • Refer to “Solder Pad Geometry 1.pdf” CATHODE MARK 1.70 TERMINATION 2 1.60 All dimensions in mm. Electro-Optical Characteristics and Ratings P AR T NUMB E R Output C olor Diffusion P ackage C olor T est C urrent (mA) F orward Voltage Typ. (V) F orward V oltage Max. (V ) Luminous Intensity T yp. (mcd) Luminous Intensity Max. (mcd) Luminous Intensity Min. (mcd) P eak Wavelength (nm) Viewing Angle 20 1/2 (degrees) P ower Dissipation (mW) Operating Temperature (°C ) S torage T emperature (°C ) P eak Forward C urrent Max. (1μs @ 10% duty cycle) (mA) 7016X13 Amber Non-Diffused C lear 20 2.0 2.8 2.2 6.3 1.7 610 110 75 -25 to +80 -30 to +85 75 7016X1 R ed Non-Diffused C lear 20 2.0 2.8 2.2 6.3 2.2 650 110 75 -25 to +80 -30 to +85 75 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 7016X3 Y ellow Non-Diffused C lear 20 2.1 2.8 2.2 6.3 2.1 585 110 75 -25 to +80 -30 to +85 75 7016X5 G reen Non-Diffused C lear 20 2.2 2.8 5.6 16.0 2.2 563 110 75 -25 to +80 -30 to +85 75 7016X11 R ed Non-Diffused C lear 20 1.75 2.5 5.6 16.0 2.1 660 110 75 -25 to +80 -30 to +85 75
7016X13 价格&库存
很抱歉,暂时无法提供与“7016X13”相匹配的价格&库存,您可以联系我们找货
