CMDA7BR7A1S
CMDA7BR7A1S
    VCC
    SMD2
    发光二极管/LED SMD2
CMDA7BR7A1S 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMDA7 Series HIGH BRIGHTNESS Right Angle Surface Mount LED Description and Features Features • High brightness • Small size • Industry standard Footprint • Non-diffused optics • Right angle emitting • Compatible with IR solder profiles • Ideal for use with Light Pipes • Available in 8 mm tape on 7" diameter reel • Packaged 3,000 pieces per reel • RoHS Compliant NOTES: 1. All dimensions are in inches (mm) 2. 1 micro second @ 10% duty cycle Applications • LCD backlighting • Push button backlighting • Front panel indicator • Symbol indicator • Microdisplays • Small message panel signage CAUTION: CMDA6AG is Class 1 ESD sensitive per MILSTD-1686. Please observe appropriate precautions during handling and processing. Electro-Optical Characteristics and Ratings Part Number Diffusion Output Color Package Color Test Current (mA) Forward Voltage Typ. (V) Forward Voltage Max. Typ. (V) Luminous Intensity Min. (mcd) Luminous Intensity Typ. (mcd) Peak Wavelength (nm) Viewing Angle (Degrees) CMDA7AG7A1S Green Non-Diffused Clear 20 3.4 3.9 40 150 520 130 CMDA7DY7A1S Amber Non-Diffused Clear 20 1.9 2.4 25 95 595 130 CMDA7AR7A1S Red Non-Diffused Clear 20 1.9 2.4 25 95 637 130 Absolute Maximum Ratings to = 25°C Part Number Power Dissipation (mW) Operating Temperature (°C) Storage Temperature (°C) Peak Forward Current Max. (See note 2) (mA) Reverse Voltage (IR = 100 mA) (V) Lead Solder Time at 230°C (Seconds) AG 98 -30 to +85 -40 to +85 100 5 10 DY 75 -30 to +85 -40 to +85 100 5 10 AR 75 -30 to +85 -40 to +85 100 5 10 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMDA7BR7A1S 价格&库存
很抱歉,暂时无法提供与“CMDA7BR7A1S”相匹配的价格&库存,您可以联系我们找货
