engineered to light up your design
www.vcclite.com
1.800.522.5546
CMD11505 Series Bright★Angle™ Right Angle Surface Mount LED
Description and Features
All dimensions
in mm.
LE D C HIP
2.10
0.60
0.10
1.70
0.10
P LAS T IC
S UB S T R AT E
1.00
0.50
0.30
0.30
• Available in Red, Orange, Yellow, Green and Pure Green.
• Right angle mounting.
• Compact size: 2.10mm x 1.00mm x 0.60mm
Surface Mount Technology
• Tape and reel packaged for high-speed autoinsertion.
• Convection and vapor-phase reflow compatible.
• Compact form enables high density placement.
• Packaged 4000 pieces per reel.
Leading Edge LED Optoelectronic Performance
• Consistent high brightness.
ANODE
C AT HODE
P IN C ONNE C T ION MAR K
Exceptional Reliability
• Stringent process controls assure quality.
• Extensive qualification testing to meet strictest requirements.
• Designed to permit easy post-reflow solder joint inspection.
• Refer to “Solder Pad Geometry 3.pdf”
Electro-Optical Characteristics and Ratings
P AR T NUMB E R
Output C olor
Diffused/Non-Diffused
P ackage C olor
P ower Dissipation (mW)
P eak F orward C urrent Max. (mA)
R everse V oltage (IR =100µA) (V )
Operating T emperature (°C )
S torage T emperature (°C )
F orward Voltage Typ. (IF =20mA)
F orward Voltage Max. (IF =20mA)
Viewing Angle (degrees)
Luminous Intensity Min. (IF=20mA)
Luminous Intensity Typ. (IF=20mA)
P eak Wavelength (IF =20mA)
R ated C urrent (mA)
Lead S older T ime @ 260°C (seconds)
C MD11505P G
G reen
Diffused
C lear
70
60
4
-30 to +85
-40 to +100
2.1
2.8
130
3.8
6.4
560
C MD11505P Y
Y ellow
Diffused
C lear
70
60
4
-30 to +85
-40 to +100
2.1
2.8
130
7.0
11.7
570
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
C MD11505UR
R ed
Diffused
C lear
57.5
60
4
-30 to +85
-40 to +100
1.7
2.3
130
7.0
11.7
660
很抱歉,暂时无法提供与“CMD11505PG”相匹配的价格&库存,您可以联系我们找货
