P585-006
P585-006
    TRIPPLITE
    P585-006
P585-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort Extension Cable, 4K @ 60 Hz, HDCP 2.2 (M/F), 6 ft. (1.83 m) MODEL NUMBER: P585-006 Highlights ● Supports video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz ● Premium foil and braid shielding ● Molded nickel-plated connectors and gold-plated contacts ● Supports DisplayPort™ v1.2a and HDCP 2.2 ● Connects to mDP, Thunderbolt™ or Thunderbolt 2 port Package Includes ● Extends your existing Mini DisplayPort (mDP) connection by 6 ft. Features Extends an Existing Mini DisplayPort Cable an Extra 6 Ft. ● Female connector attaches to current mDP cable to add length ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz ● Supports DisplayPort v1.2a and HDCP 2.2 ● Recommended for devices with mDP, Thunderbolt or Thunderbolt 2 ports First-Rate Construction for Superior Signal Transfer ● Premium foil and braid shielding for EMI/RFI noise protection ● Molded nickel-plated connectors and gold-plated contacts for optimal signal quality ● Integral strain relief for long life ● Twisted 32/32 AWG data/power lines ● Flexible PVC jacket and small footprint for easy installation in tight spaces Specifications OVERVIEW UPC Code 037332201645 Product Type Passive Cable Technology DisplayPort Cable Type Passive VIDEO 1/2 P585-006 Mini DisplayPort Extension Cable (M/F), 6 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Video Resolution 3840 x 2160 (4K) @ 60Hz PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Cable Length (cm) 182.88 Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.00 Shipping Dimensions (hwd / cm) 1.27 x 17.78 x 22.86 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 MINI DISPLAYPORT (FEMALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P585-006
1. 物料型号: - 型号:P585-006 - UPC 编码:037332201645
2. 器件简介: - 这是一款Mini DisplayPort延长线,支持4K@60Hz视频分辨率,兼容HDCP 2.2标准,长度为6英尺(1.83米)。适用于连接Mini DisplayPort、Thunderbolt或Thunderbolt 2端口。
3. 引脚分配: - 侧A - 连接器1:MINI DISPLAYPORT (MALE) - 侧B - 连接器1:MINI DISPLAYPORT (FEMALE) - 该线缆不具备锁定或抓握式连接器。
4. 参数特性: - 支持的显示端口技术:DisplayPort™ v1.2a - 支持的HDCP版本:HDCP 2.2 - 最大支持视频分辨率:3840x2160 (4K x 2K) @ 60Hz - 物理特性:黑色线缆,线长6英尺(1.83米),线径72英寸(182.88厘米)。
5. 功能详解: - 延长现有的Mini DisplayPort连接线6英尺,使连接更加灵活。 - 具有高级箔片和编织屏蔽,以提供EMI/RFI噪声保护。 - 采用模制的镀镍连接器和镀金接触点,以保证最佳的信号质量。 - 内置的应力消除设计,延长线缆的使用寿命。 - 采用扭曲的32/32 AWG数据线/电源线,以及灵活的PVC外皮和紧凑的尺寸,便于在狭小空间内安装。
6. 应用信息: - 推荐用于具有Mini DisplayPort、Thunderbolt或Thunderbolt 2端口的设备。
7. 封装信息: - 线缆颜色:黑色 - 发货尺寸:高0.50英寸x宽7.00英寸x长9.00英寸 - 发货重量:0.20磅(约0.09千克) - 产品符合RoHS标准。 - 提供全球范围内的有限终身保修。
P585-006 价格&库存
很抱歉,暂时无法提供与“P585-006”相匹配的价格&库存,您可以联系我们找货
