Technical Data 4341
Effective October 2015
Supersedes September 2010
FP1007
High frequency, high current power inductors
Applications
Product description
High current carrying capacity
Low core loss
Frequency range up to 2MHz
Inductance Range from 115 nH to 300nH
Current range from 32 to 94 amps
10.4 x 8.0mm footprint surface mount package
in 6.5, 7.0 or 7.5mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Servers
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
Desktop VRMs and EVRDs
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
DCR Sensing circuits
Environmental data
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature:
J-STD-020D compliant
HALOGEN
Pb HF
FREE
FP1007
Technical Data 4341
Product specifications
OCL1
(nH)±10%
FLL2
(nH) minimum
Irms3
(amps)
Isat14
(amps)
Isat25
(amps)
DCR (mΩ)
@ 20°C ±5%
K-factor8
FP1007R1-R12-R
120
86
60
81
65
0.29 ± 10%
371
FP1007R1-R14-R
140
100
60
72
56
0.29 ± 10%
371
FP1007R1-R17-R
170
122
60
58
46
0.29 ± 10%
371
FP1007R1-R22-R
215
155
60
50
36
0.29 ± 10%
371
FP1007R1-R30-R
300
216
60
32
26
0.29 ± 10%
371
FP1007R2-R12-R
120
86
51
81
65
0.48 ± 8%
368
FP1007R2-R14-R
140
100
51
72
56
0.48 ± 8%
368
FP1007R2-R17-R
170
122
51
58
46
0.48 ± 8%
368
FP1007R2-R22-R
215
155
51
50
36
0.48 ± 8%
368
FP1007R2-R30-R
300
216
51
32
26
0.48 ± 8%
368
115
83
61
94
86
0.29 ± 5%
354
Part Number7
R1 version
R2 version
R3 version
FP1007R3-R12-R
FP1007R3-R15-R
150
108
61
76
70
0.29 ± 5%
354
FP1007R3-R17-R
175
126
61
66
60
0.29 ± 5%
354
FP1007R3-R22-R
215
155
61
50
43
0.29 ± 5%
354
FP1007R3-R23-R
230
165
61
48
40
0.29 ± 5%
354
FP1007R3-R27-R
270
194
61
40
34
0.29 ± 5%
354
FP1007R3-R30-R
300
216
61
35
30
0.29 ± 5%
354
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.1Vrms, 0.0Adc, +25°C
2. Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1, +25°C
3. Irms: Irms: DC current for an approximate temperature rise of 40ºC without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other
heat generating components will affect the temperature rise. It is recommended that the
temperature of the part not exceed 125°C under worst case operating conditions verified in the
end application.
4. Isat1: Peak current for approximately 20% rolloff @ +25°C
5. Isat2: Peak current for approximately 20% rolloff @ +125°C
6. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table),
L: (Inductance in nH), ∆I (Peak-to-peak ripple current in Amps).
7. Part Number Definition: FP1007Rx-Rxx-R
FP1007R= Product code and size
x = DCR indicator
Rxx = Inductance value in μH, R= decimal point
-R suffix = RoHS compliant
Dimensions (mm)
Recommended Pad Layout
Schematic
Part marking: 1007Rx (x = DCR indicator), Rxx (xx = inductance value in
uH, R = decimal point, wwllyy = date code, R = revision level
Tolerances are ±0.25 millimeters unless stated otherwise.
PCB tolerances are ±0.1 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.1 millimeter
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
2
www.eaton.com/elx
FP1007
Technical Data 4341
Packaging information (mm)
Supplied in tape and reel packaging,
FP1007R1 700 parts per 13 ” diameter reel
FP1007R2 750 parts per 13 ” diameter reel
FP1007R3 650 parts per 13 ” diameter reel
User direction of feed
Temperature rise vs. total loss
www.eaton.com/elx
3
Technical Data 4341
Core loss vs. Bp-p
Inductance characteristics
4
www.eaton.com/elx
FP1007
FP1007
Technical Data 4341
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP1007R3-R17-R”相匹配的价格&库存,您可以联系我们找货
