CRT Corona Resistant Teflon
Page 1 of 2
High Voltage
Corona Resistant Teflon Wire
Avoid Corona Problems: Corona Resistant Teflon construction is specifically designed to retard and prevent corona
penetration.
Small Size: You do not need bulky, thick insulation jacketing as used with silicone rubber and polyethylene insulation to get
your Hi-Voltage requirements. Wire used is Mil-Spec QQ-W-343 and Mil-W-16878.
Temperature Variations: Temperature variations from -90°C to +200°C have no life effect on the corona resistant Teflon.
In addition, there is no stress or crack failure under severe, adverse conditions including mechanical strain, moisture, corona
or chemical conditions.
Description: Single Conductor, Stranded Silver Plated Copper, Corona Resistant Teflon Insulation.
Voltage Rating: Based on insulation thickness.
Minimum Life Expectancy: 10,000 hours.
Operating Temperature: -90°C to 200°C. For 250°C Nickel Plated Copper is available.
Available Colors: White, Black, Red, Green, Yellow, Lt. Blue, Brown, Gray, Violet, Orange. (Tracer colors and shielded
constructions are available to order.)
Standard Put-Ups: 250FT, 500FT, 1000FT.
PART NO. AWG STR. KVAC KVDC O.D. IN. PART NO. AWG STR. KVAC KVDC O.D. IN.
CRT10-2
10
37/26
2.5
10
0.158
CRT18-10
18
19/30
15
50
0.265
CRT10-2.5
10
37/26
3.75
12.5
0.168
CRT20-2
2.5
10
0.095
CRT12-2
12
19/25
2.5
10
0.142
CRT20-2.5
3.75
12.5
0.105
CRT12-2.5
12
19/25
3.75
12.5
0.152
CRT20-3
4.5
15
0.115
CRT12-3
12
19/25
4.5
15
0.162
CRT20-3.5
5.3
17.5
0.126
CRT12-3.5
12
19/25
5.3
17.5
0.172
CRT20-4
6
CRT12-4
12
19/25
6
CRT20-5
7.5
25
0.156
CRT12-5
12
19/25
7.5
25
0.202
CRT20-6.5
10
32.5
0.185
CRT12-6.5
12
19/25
10
32.5
0.232
CRT20-8
12
40
0.215
CRT12-8
12
19/25
12
40
0.262
CRT20-10
15
50
0.255
CRT12-10
12
19/25
15
50
0.302
CRT22-2
22
19/34
2.5
10
0.087
CRT14-2
14
19/27
2.5
10
0.124
CRT22-2.5
22
19/34
3.75
12.5
0.097
CRT14-2.5
14
19/27
3.75
12.5
0.134
CRT22-3
22
19/34
4.5
15
0.107
CRT14-3
14
19/27
4.5
15
0.144
CRT22-3.5
22
19/34
5.3
17.5
0.118
CRT14-3.5
14
19/27
5.3
17.5
0.154
CRT22-4
22
19/34
6
CRT14-4
14
19/27
6
CRT22-5
22
19/34
7.5
25
0.148
CRT14-5
14
19/27
7.5
25
0.184
CRT22-6.5
22
19/34
10
32.5
0.177
CRT14-6.5
14
19/27
10
32.5
0.214
CRT22-8
22
19/34
12
40
0.207
http://www.daburn.com/crt.html
11/15/2002
Page 2 of 2
CRT14-8
14
19/27
12
40
0.244
CRT22-10
22
19/34
15
50
0.247
CRT14-10
14
19/27
15
50
0.284
CRT24-2
24
19/36
2.5
10
0.081
CRT16-2
16
19/29
2.5
10
0.111
CRT24-2.5
24
19/36
3.75
12.5
0.091
CRT16-2.5
16
19/29
3.75
12.5
0.119
CRT24-3
24
19/36
4.5
15
0.101
CRT16-3
16
19/29
4.5
15
0.129
CRT24-3.5
24
19/36
5.3
17.5
0.112
CRT16-3.5
16
19/29
5.3
17.5
0.141
CRT24-4
24
19/36
6
CRT16-4
16
19/29
6
CRT24-5
24
19/36
7.5
25
0.142
CRT16-5
16
19/29
7.5
25
0.172
CRT24-6.5
24
19/36
10
32.5
0.171
CRT16-6.5
16
19/29
10
32.5
0.201
CRT24-8
24
19/36
12
40
0.201
CRT16-8
16
19/29
12
40
0.231
CRT24-10
24
19/36
15
50
0.241
CRT16-10
16
19/29
15
50
0.271
CRT26-2
26
7/34
2.5
10
0.071
CRT18-2
18
19/30
2.5
10
0.105
CRT26-2.5
26
7/34
3.75
12.5
0.081
CRT18-2.5
18
19/30
3.75
12.5
0.114
CRT26-3
26
7/34
4.5
15
0.091
CRT18-3
18
19/30
4.5
15
0.124
CRT26-3.5
26
7/34
5.3
17.5
0.101
CRT18-3.5
18
19/30
5.3
17.5
0.135
CRT26-4
26
7/34
6
CRT18-4
18
19/30
6
CRT26-5
26
7/34
7.5
25
0.131
CRT18-5
18
19/30
7.5
25
0.166
CRT26-6.5
26
7/34
10
32.5
0.161
CRT18-6.5
18
19/30
10
32.5
0.194
CRT26-8
26
7/34
12
40
0.191
CRT18-8
18
19/30
12
40
0.225
CRT26-10
26
7/34
15
50
0.231
Additional Sizes And Voltages Available.
Note: Voltage ratings shown are at Sea Level. Voltage ratings at 80,000 feet are approximately 1/3 lower.
Back to New Products.
Back to DABURN’S Home Page.
Daburn electronics & cable corp.
224 Pegasus Ave.
Northvale, NJ 07647
Tel: 201-768-5400
Fax: 201-768-9642
E-Mail: daburn@daburn.com
URL: http://www.daburn.com/
11/15/2002
很抱歉,暂时无法提供与“CRT22-6.5RD-100”相匹配的价格&库存,您可以联系我们找货
