CRT18-10WH-100
CRT18-10WH-100
    DABURNELECTRONICS
    CRT18-10WH-100
CRT18-10WH-100 数据手册
CRT Corona Resistant Teflon Page 1 of 2 High Voltage Corona Resistant Teflon Wire Avoid Corona Problems: Corona Resistant Teflon construction is specifically designed to retard and prevent corona penetration. Small Size: You do not need bulky, thick insulation jacketing as used with silicone rubber and polyethylene insulation to get your Hi-Voltage requirements. Wire used is Mil-Spec QQ-W-343 and Mil-W-16878. Temperature Variations: Temperature variations from -90°C to +200°C have no life effect on the corona resistant Teflon. In addition, there is no stress or crack failure under severe, adverse conditions including mechanical strain, moisture, corona or chemical conditions. Description: Single Conductor, Stranded Silver Plated Copper, Corona Resistant Teflon Insulation. Voltage Rating: Based on insulation thickness. Minimum Life Expectancy: 10,000 hours. Operating Temperature: -90°C to 200°C. For 250°C Nickel Plated Copper is available. Available Colors: White, Black, Red, Green, Yellow, Lt. Blue, Brown, Gray, Violet, Orange. (Tracer colors and shielded constructions are available to order.) Standard Put-Ups: 250FT, 500FT, 1000FT. PART NO. AWG STR. KVAC KVDC O.D. IN. PART NO. AWG STR. KVAC KVDC O.D. IN. CRT10-2 10 37/26 2.5 10 0.158 CRT18-10 18 19/30 15 50 0.265 CRT10-2.5 10 37/26 3.75 12.5 0.168 CRT20-2 20 19/32 2.5 10 0.095 CRT12-2 12 19/25 2.5 10 0.142 CRT20-2.5 20 19/32 3.75 12.5 0.105 CRT12-2.5 12 19/25 3.75 12.5 0.152 CRT20-3 20 19/32 4.5 15 0.115 CRT12-3 12 19/25 4.5 15 0.162 CRT20-3.5 20 19/32 5.3 17.5 0.126 CRT12-3.5 12 19/25 5.3 17.5 0.172 CRT20-4 20 19/32 6 20 0.135 CRT12-4 12 19/25 6 20 0.182 CRT20-5 20 19/32 7.5 25 0.156 CRT12-5 12 19/25 7.5 25 0.202 CRT20-6.5 20 19/32 10 32.5 0.185 CRT12-6.5 12 19/25 10 32.5 0.232 CRT20-8 20 19/32 12 40 0.215 CRT12-8 12 19/25 12 40 0.262 CRT20-10 20 19/32 15 50 0.255 CRT12-10 12 19/25 15 50 0.302 CRT22-2 22 19/34 2.5 10 0.087 CRT14-2 14 19/27 2.5 10 0.124 CRT22-2.5 22 19/34 3.75 12.5 0.097 CRT14-2.5 14 19/27 3.75 12.5 0.134 CRT22-3 22 19/34 4.5 15 0.107 CRT14-3 14 19/27 4.5 15 0.144 CRT22-3.5 22 19/34 5.3 17.5 0.118 CRT14-3.5 14 19/27 5.3 17.5 0.154 CRT22-4 22 19/34 6 20 0.127 CRT14-4 14 19/27 6 20 0.164 CRT22-5 22 19/34 7.5 25 0.148 CRT14-5 14 19/27 7.5 25 0.184 CRT22-6.5 22 19/34 10 32.5 0.177 CRT14-6.5 14 19/27 10 32.5 0.214 CRT22-8 22 19/34 12 40 0.207 http://www.daburn.com/crt.html 11/15/2002 CRT Corona Resistant Teflon Page 2 of 2 CRT14-8 14 19/27 12 40 0.244 CRT22-10 22 19/34 15 50 0.247 CRT14-10 14 19/27 15 50 0.284 CRT24-2 24 19/36 2.5 10 0.081 CRT16-2 16 19/29 2.5 10 0.111 CRT24-2.5 24 19/36 3.75 12.5 0.091 CRT16-2.5 16 19/29 3.75 12.5 0.119 CRT24-3 24 19/36 4.5 15 0.101 CRT16-3 16 19/29 4.5 15 0.129 CRT24-3.5 24 19/36 5.3 17.5 0.112 CRT16-3.5 16 19/29 5.3 17.5 0.141 CRT24-4 24 19/36 6 20 0.121 CRT16-4 16 19/29 6 20 0.151 CRT24-5 24 19/36 7.5 25 0.142 CRT16-5 16 19/29 7.5 25 0.172 CRT24-6.5 24 19/36 10 32.5 0.171 CRT16-6.5 16 19/29 10 32.5 0.201 CRT24-8 24 19/36 12 40 0.201 CRT16-8 16 19/29 12 40 0.231 CRT24-10 24 19/36 15 50 0.241 CRT16-10 16 19/29 15 50 0.271 CRT26-2 26 7/34 2.5 10 0.071 CRT18-2 18 19/30 2.5 10 0.105 CRT26-2.5 26 7/34 3.75 12.5 0.081 CRT18-2.5 18 19/30 3.75 12.5 0.114 CRT26-3 26 7/34 4.5 15 0.091 CRT18-3 18 19/30 4.5 15 0.124 CRT26-3.5 26 7/34 5.3 17.5 0.101 CRT18-3.5 18 19/30 5.3 17.5 0.135 CRT26-4 26 7/34 6 20 0.111 CRT18-4 18 19/30 6 20 0.145 CRT26-5 26 7/34 7.5 25 0.131 CRT18-5 18 19/30 7.5 25 0.166 CRT26-6.5 26 7/34 10 32.5 0.161 CRT18-6.5 18 19/30 10 32.5 0.194 CRT26-8 26 7/34 12 40 0.191 CRT18-8 18 19/30 12 40 0.225 CRT26-10 26 7/34 15 50 0.231 Additional Sizes And Voltages Available. Note: Voltage ratings shown are at Sea Level. Voltage ratings at 80,000 feet are approximately 1/3 lower. Back to New Products. Back to DABURN’S Home Page. Daburn electronics & cable corp. 224 Pegasus Ave. Northvale, NJ 07647 Tel: 201-768-5400 Fax: 201-768-9642 E-Mail: daburn@daburn.com URL: http://www.daburn.com/ http://www.daburn.com/crt.html 11/15/2002
CRT18-10WH-100 价格&库存
很抱歉,暂时无法提供与“CRT18-10WH-100”相匹配的价格&库存,您可以联系我们找货
