E36D201LPN822TDB7M
E36D201LPN822TDB7M
    NCC(贵弥功)
    DIP
    8200µF 200V Aluminum Capacitors Radial, Can - Screw Terminals 2000 Hrs @ 85°C
E36D201LPN822TDB7M 数据手册
U36D SERIES Engineering Bulletin Mar 07 U36D Series  Large Can  Screw Terminals  High Ripple  Up to 550VDC Rated Voltage  Dimensions in Inches  RoHS Compliant  85C Maximum Temperature Summary of Specifications  Screw terminals: high and low post, English and Metric thread.  Capacitance range: 68µF to 2.2F.  Voltage range: 6.3 to 550VDC.  Category temperature range: 40C to 85C.  Leakage current: 0.02CV(µA) or 5mA, whichever is smaller, after 5 minutes at 25C.  Standard capacitance tolerance: 20%  Nominal case size (DL): D = 35mm (1.375”) to 89mm (3.500”); L = 41mm (1.625”) to 220mm (8.625”).  Rated lifetime: 2,000 hours at 85C with rated ripple current applied. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 1/ 13 U36D L ARGE CAN 85C The U36D series is ideal for inverter applications requiring high ripple current capabilities. With a voltage range through 550 volts, the number of capacitors in series can be reduced. The U36D capacitors offer very large capacitance of up to 2.2F and a maximum operating temperature of 85C. These capacitors are available with a variety of high current English or Metric thread terminals. Mounting options available are a three-footed clamp or bottom stud. (A special order two-footed clamp is also available for selected diameters.) All case size dimensions are based on inches. Custom designs are available upon request. Engineering Bulletin Mar 07 U36D Series U36D Specifications - Screw Terminals Item Characteristics Category Temperature Range 40 to 85C Rated Voltage Range 6.3 to 550VDC Capacitance Range 68F to 2.2F at 25C, 120Hz Capacitance Tolerance 20% ( M ) at 25C, 120Hz Leakage Current I  0.02CV (A ) or 5mA, whichever is smaller, after 5 minutes at 25C. Rated Ripple Current Multipliers Ambient Temperature (C ) Where I = Max. leakage current (A ), C = Nominal capacitance (F ) and V = Rated voltage ( V ) ≤ 55C 65C 75C 85C 2.39 2.22 1.67 1.00 50Hz 120Hz 300Hz 1kHz 3kHz 0.8 1.0 1.1 1.3 1.4 Frequency (Hz ) Endurance (Load Life) The following specifications shall be satisfied when the capacitors are restored to 25C after subjecting them to DC voltage for 2,000 hours at 85C with the rated ripple current applied. The sum of the DC voltage and peak AC voltage must not exceed the full rated voltage of the capacitors. Capacitance change: ≤ 20% from initial measurement ESR change : ≤ 300% of initial specified limit Leakage current : ≤ initial specified limit Shelf Life The following specifications shall be satisfied when the capacitors are restored to 25C after exposing them for 500 hours at 85C without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. U36D L ARGE CAN 85C Capacitance change: ≤ 20% from initial measurement ESR change : ≤ 300% of initial specified limit Leakage current : ≤ initial specified limit 2 / 13 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 U36D Series Diagram of Dimensions - Screw Terminals Unit: inches (mm) Large Can / Screw Terminals Case Dimensions ØD 0.080 (2.0) L 0.040 (1.0) F 0.010 (0.25) 1.375 (35.0) 1.625 (41) 2.125 (54) 2.625 (67) 3.125 (79) 3.625 (92) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 0.500 (12.7) 2.000 (50.8) 1.875 (48) 2.125 (54) 2.625 (67) 3.125 (79) 3.625 (92) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 0.875 (22.2) 2.500 (63.5) 3.125 (79) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 1.125 (28.6) E79 E92 EA5 EB7 ED0 EE3 EN0 3.000 (76.2) 3.125 (79) 3.625 (92) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 8.625 (220) 1.250 (31.8) FA5 FB7 FD0 FE3 3.500 (89.0) 4.125 (105) 4.625 (117) 5.125 (130) 5.625 (143) 1.250 (31.8) Case Size Code A41 A54 A67 A79 A92 AA5 AB7 AD0 AE3 Vent F C48 C54 C67 C79 C92 CA5 CB7 CD0 CE3 S T J D79 DA5 DB7 DD0 DE3 Insulating Sleeve L H Insulating End Disk D Terminal Specifications Terminal Code ØD ØD inches (mm) C-E C-E C-E C-E D-E D-F D-F D-F D-F 1.375 – 3.000 (35.0 – 76.2) 1.375 – 3.000 (35.0 – 76.2) 1.375 – 3.000 (35.0 – 76.2) 1.375 – 3.000 (35.0 – 76.2) 2.500 – 3.000 (63.5 – 76.2) 2.500 – 3.500 (63.5 – 89.0) 2.500 – 3.500 (63.5 – 89.0) 2.500 – 3.500 (63.5 – 89.0) 2.500 – 3.500 (63.5 – 89.0) Minimum Thread Depth 10 - 32 NF- 2B 10 - 32 NF- 2B M5x0.8 - 6H M5x0.8 - 6H M5x0.8 - 6H 1/4 - 28 NF- 2B 1/4 - 28 NF- 2B M6x1- 6H M6x1- 6H 0.375 (9.5) 0.219 (5.6) 0.375 (9.5) 0.219 (5.6) 0.335 (8.5) 0.344 (8.7) 0.468 (11.9) 0.344 (8.7) 0.468 (11.9) H ØS ØT J 0.020 (0.5) 0.080 (2.0) 0.010 (0.25) 0.010 (0.25) 0.250 (6.4) 0.063 (1.6) 0.250 (6.4) 0.063 (1.6) 0.200 (5.0) 0.093 (2.4) 0.250 (6.4) 0.093 (2.4) 0.250 (6.4) LJ LJ LJ LJ LJ LJ LJ LJ LJ 0.313 (8.0) 0.313 (8.0) 0.313 (8.0) 0.313 (8.0) 0.512 (13.0) 0.689 (17.5) 0.689 (17.5) 0.689 (17.5) 0.689 (17.5) 0.438 (11.1) — 0.438 (11.1) 0.438 (11.1) 0.740 (18.8) — — — — United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 3 / 13 U36D Code Thread Size L ARGE CAN 85C HP LP HL ML CD CP CH CA CS Available Case Diameter Engineering Bulletin Mar 07 U36D Series Mounting Hardware - Screw Terminals Type C: Three-Footed Clamp Unit: mm (inches) 360 3 30 455 15 D A B T J G K 5.10.5 (2 holes) (0.2010.020) R Clamp: Zinc with silver trivalent chromate post treatment. S Hardware: Screw, washer and hexagon nut included with each clamp. Type C: Clamp Dimensions G J K R S T A B 1.0 (0.040) 1.0 (0.040) 1.0 (0.040) 0.5 (0.020) 0.5 (0.020) 1.0 (0.040) 1.0 (0.040) 0.5 (0.020) Mounting Code Case ØD See Note 35.0 (1.375) — — — — — — — — C 50.8 (2.000) 31.8 (1.250) 36.5 (1.437) 13.3 (0.524) 4.5 (0.177) 7.1 (0.280) 19.1 (0.751) 9.5 (0.374) 0.8 (0.032) C 63.5 (2.500) 38.1 (1.500) 42.9 (1.689) 13.3 (0.524) 4.5 (0.177) 7.1 (0.280) 19.1 (0.751) 9.5 (0.374) 0.8 (0.032) C 76.2 (3.000) 44.5 (1.750) 49.2 (1.937) 13.3 (0.524) 4.5 (0.177) 7.1 (0.280) 19.1 (0.751) 9.5 (0.374) 1.0 (0.040) C 89.0 (3.500) 50.8 (2.000) 56.5 (2.224) 16.0 (0.630) 4.5 (0.177) 8.0 (0.313) 21.0 (0.827) 9.0 (0.354) 1.0 (0.040) Note: Type B two-footed clamp available upon request for Ø 35, Ø 50.8, Ø 63.5 and Ø 76.2. Consult UCC for specifications. U36D L ARGE CAN 85C Type S: Stud Mounting Q M N P R K T D Type S: Stud Mounting Dimensions 4 / 13 Mounting Code P 1.0 (0.040) T Thread Size M 1.0 (0.040) N 1.0 (0.040) ØK 2.0 (0.080) ØQ 1.0 (0.040) R 1.0 (0.040) S 16.0 (0.630) M12 19.0 (0.748) 18.0 (0.709) 30.0 (1.181) 22.0 (0.866) 1.40 (0.055) United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 U36D Series Part Numbering System for U36D Series When ordering, always specify complete 18-field global part number. 18 Fields 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E 3 6 D 4 0 1 H P N 1 8 2 MD 7 9 M 9 8 7 6 5 2 1 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 5 / 13 U36D 3 L ARGE CAN 85C 4 Supplement Code. Field 18. C = PET insulation with end disk. F = Coated can. M = Pb-free PVC insulation with end disk. Case Size. Fields 15, 16 and 17. The single letter diameter code is inserted in field 15. A = Ø 35mm ( Ø1.375”) C = Ø 50.8mm ( Ø 2.000”) D = Ø 63.5mm ( Ø 2.500”) E = Ø 76.2mm ( Ø 3.000”) F = Ø 89mm ( Ø 3.500”) The double character length code is inserted in fields 16 and 17. For lengths ≤ 99mm, insert the actual length rounded to nearest millimeter. For lengths of 100mm or more, insert the appropriate alpha numeric code as indicated below. 41 = 41mm (1.625”) 48 = 48mm (1.875”) 54 = 54mm (2.125”) 67 = 67mm (2.625”) 79 = 79mm (3.125”) 92 = 92mm (3.625”) A5 = 105mm (4.125”) B7 = 117mm (4.625”) D0 = 130mm (5.125”) E3 = 143mm (5.625”) N0= 220mm (8.625”) Capacitance Tolerance. Field 14. M = 20% Capacitance. Fields 11, 12 and 13. Expressed in Microfarads. The first two digits are significant figures inserted in fields 11 and 12, and the third digit inserted in field 13 indicates the number of zeros for capacitance of 10F or more. R indicates the decimal point for capacitance less than 10F (e.g. 1R8 = 1.8F; 180 = 18F; 181 = 180F; 182 = 1,800F; 183 = 18,000F ). Mounting Hardware. Field 10. N = None. B = Two-footed clamp. C = Three-footed clamp. S = Stud mount. Terminal Type. Fields 8 and 9. HP = High post 10-32 NF- 2B screw thread. LP = Low post 10-32 NF- 2B screw thread. HL = High post M5x0.8 screw thread. ML = Low post M5x0.8 screw thread. CD = UTE M5x0.8 screw thread. CP = Low post 1/4 -28 NF-2B screw thread. CH = High post 1/4 -28 NF-2B screw thread. CA = Low post M6x1 screw thread. CS = High post M6x1 screw thread. DC Rated Voltage. Fields 5, 6 and 7. Expressed in Volts. The first two digits are significant figures inserted in fields 5 and 6, and the third digit inserted in field 7 indicates the number of zeros for rated voltage of 10VDC or more. R indicates the decimal point for rated voltage less than 10VDC (e.g. 4R0 = 4.0VDC; 400 = 40VDC; 401 = 400VDC). Series Name. Fields 2, 3 and 4. Enter the 3-letter/digit series name in fields 2, 3 and 4. If the series name is only 2 letters/digits, place a dash in field 4. For a series name with more than 3 letters/digits, refer to the individual series for the appropriate 3-field series name. Capacitor Type. Field 1. Aluminum Electrolytic Capacitor (Polar). Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 6.3 Volts 8 Volts Surge 10 Volts U36D L ARGE CAN 85C 13 Volts Surge 16 Volts 20 Volts Surge Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 39,000 68,000 120,000 180,000 220,000 270,000 120,000 220,000 270,000 390,000 470,000 560,000 680,000 470,000 680,000 820,000 1,000,000 680,000 820,000 1,000,000 1,200,000 1,500,000 2,200,000 E36D6R3HPN393MA41M E36D6R3HPN683MA54M E36D6R3HPN124MA79M E36D6R3HPN184MAA5M E36D6R3HPN224MAB7M E36D6R3HPN274MAE3M E36D6R3HPN124MC54M E36D6R3HPN224MC67M E36D6R3HPN274MC79M E36D6R3HPN394MC92M E36D6R3HPN474MCB7M E36D6R3HPN564MCD0M E36D6R3HPN684MCE3M E36D6R3HPN474MD79M E36D6R3HPN684MDA5M E36D6R3HPN824MDB7M E36D6R3HPN105MDE3M E36D6R3HPN684ME79M E36D6R3HPN824ME92M E36D6R3HPN105MEA5M E36D6R3HPN125MEB7M E36D6R3HPN155MEE3M E36D6R3HPN225MEN0M 1.375  1.625 1.375  2.125 1.375  3.125 1.375  4.125 1.375  4.625 1.375  5.625 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.125 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.625 3.000  8.625 A41 A54 A79 AA5 AB7 AE3 C54 C67 C79 C92 CB7 CD0 CE3 D79 DA5 DB7 DE3 E79 E92 EA5 EB7 EE3 EN0 42.7 25.5 15.4 11.2 9.8 8.4 16.9 9.1 8.8 7.5 5.8 5.2 5.0 8.9 6.5 5.8 4.9 10.0 8.6 7.5 6.8 5.6 3.9 4.48 6.35 9.47 11.10 12.55 15.27 7.72 10.85 12.60 15.71 17.95 19.94 22.31 15.39 20.69 21.02 24.55 17.32 19.55 22.10 24.59 29.17 41.67 33,000 56,000 82,000 100,000 120,000 150,000 180,000 220,000 82,000 100,000 150,000 220,000 270,000 330,000 390,000 470,000 330,000 560,000 680,000 820,000 680,000 820,000 1,000,000 1,200,000 1,800,000 E36D100HPN333MA41M E36D100HPN563MA54M E36D100HPN823MA67M E36D100HPN104MA79M E36D100HPN124MA92M E36D100HPN154MAA5M E36D100HPN184MAB7M E36D100HPN224MAE3M E36D100HPN823MC48M E36D100HPN104MC54M E36D100HPN154MC67M E36D100HPN224MC79M E36D100HPN274MC92M E36D100HPN334MCA5M E36D100HPN394MCB7M E36D100HPN474MCE3M E36D100HPN334MD79M E36D100HPN564MDA5M E36D100HPN684MDB7M E36D100HPN824MDE3M E36D100HPN684ME92M E36D100HPN824MEA5M E36D100HPN105MED0M E36D100HPN125MEE3M E36D100HPN185MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 ED0 EE3 EN0 40.9 25.0 18.0 15.0 12.9 10.9 10.6 8.3 21.0 16.6 11.5 8.8 7.4 6.4 5.7 4.9 8.7 6.3 5.7 4.9 8.9 7.7 6.0 5.7 4.0 3.65 4.99 6.44 7.65 8.45 10.03 11.24 12.71 6.36 7.37 9.18 11.93 13.07 15.32 16.35 19.08 12.77 18.77 19.14 20.73 18.43 21.39 23.50 26.84 37.69 22,000 39,000 56,000 68,000 82,000 100,000 120,000 150,000 56,000 68,000 E36D160HPN223MA41M E36D160HPN393MA54M E36D160HPN563MA67M E36D160HPN683MA79M E36D160HPN823MA92M E36D160HPN104MAA5M E36D160HPN124MAB7M E36D160HPN154MAE3M E36D160HPN563MC48M E36D160HPN683MC54M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 44.2 26.1 19.0 15.8 13.5 11.6 10.2 8.7 21.7 17.2 3.16 4.50 5.63 6.68 7.86 9.23 10.33 12.69 5.51 6.37 Capacitance (µF ) † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 6 / 13 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 16 Volts 20 Volts Surge 25 Volts 32 Volts Surge Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 120,000 150,000 220,000 270,000 330,000 220,000 390,000 470,000 560,000 470,000 560,000 680,000 820,000 1,200,000 E36D160HPN124MC54M E36D160HPN154MC67M E36D160HPN224MC92M E36D160HPN274MCB7M E36D160HPN334MCE3M E36D160HPN224MD79M E36D160HPN394MDA5M E36D160HPN474MDB7M E36D160HPN564MDE3M E36D160HPN474ME92M E36D160HPN564MEA5M E36D160HPN684MEB7M E36D160HPN824MEE3M E36D160HPN125MEN0M 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.625 3.000  8.625 C54 C67 C92 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 EE3 EN0 12.2 9.2 6.7 5.9 5.1 8.7 6.3 5.7 4.9 8.7 7.5 6.3 5.6 3.9 9.00 10.79 13.19 15.71 19.03 12.59 18.91 20.24 24.15 19.11 22.05 22.91 25.28 34.52 15,000 27,000 39,000 47,000 56,000 68,000 82,000 100,000 39,000 47,000 82,000 100,000 150,000 180,000 220,000 180,000 270,000 330,000 390,000 330,000 390,000 470,000 560,000 820,000 E36D250HPN153MA41M E36D250HPN273MA54M E36D250HPN393MA67M E36D250HPN473MA79M E36D250HPN563MA92M E36D250HPN683MAA5M E36D250HPN823MAB7M E36D250HPN104MAE3M E36D250HPN393MC48M E36D250HPN473MC54M E36D250HPN823MC67M E36D250HPN104MC79M E36D250HPN154MCA5M E36D250HPN184MCB7M E36D250HPN224MCE3M E36D250HPN184MD79M E36D250HPN274MDA5M E36D250HPN334MDB7M E36D250HPN394MDE3M E36D250HPN334ME92M E36D250HPN394MEA5M E36D250HPN474MEB7M E36D250HPN564MEE3M E36D250HPN824MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 CA5 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 EE3 EN0 44.0 25.7 18.7 15.7 13.5 11.6 10.2 8.8 21.7 17.2 12.2 9.2 6.7 5.9 5.1 8.7 6.3 5.7 5.0 8.2 7.8 6.4 5.7 3.9 3.05 4.38 5.50 6.49 7.60 8.89 9.99 12.12 5.66 6.52 9.15 10.84 13.66 15.71 19.03 13.34 18.44 20.39 24.24 19.61 22.54 24.52 26.73 38.03 10,000 18,000 27,000 33,000 39,000 47,000 56,000 68,000 22,000 33,000 56,000 68,000 100,000 120,000 150,000 120,000 180,000 220,000 270,000 E36D350HPN103MA41M E36D350HPN103MA54M E36D350HPN103MA67M E36D350HPN103MA79M E36D350HPN103MA92M E36D350HPN103MAA5M E36D350HPN103MAB7M E36D350HPN103MAD0M E36D350HPN223MC48M E36D350HPN333MC54M E36D350HPN563MC67M E36D350HPN683MC79M E36D350HPN104MC92M E36D350HPN124MCB7M E36D350HPN154MCE3M E36D350HPN124MD79M E36D350HPN184MDA5M E36D350HPN224MDB7M E36D350HPN274MDE3M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 A41 A54 A67 A79 A92 AA5 AB7 AD0 C48 C54 C67 C79 C92 CB7 CE3 D79 DA5 DB7 DE3 47.1 27.4 19.3 16.1 13.9 12.0 10.6 10.3 22.4 17.7 12.5 9.5 8.0 6.1 5.9 9.1 6.7 5.8 5.0 2.57 3.70 4.73 5.63 6.56 7.65 8.54 9.89 4.32 5.55 7.68 9.08 11.09 12.83 15.04 11.34 15.68 18.17 22.01 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 7/ 13 U36D Nominal Case Size* DL (inches) L ARGE CAN 85C 35 Volts 44 Volts Surge Global Part Number† Capacitance (µF ) Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 35 Volts 44 Volts Surge 50 Volts U36D L ARGE CAN 85C 63 Volts Surge 63 Volts 79 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 220,000 270,000 330,000 390,000 560,000 E36D350HPN224ME92M E36D350HPN274MEA5M E36D350HPN334MED0M E36D350HPN394MEE3M E36D350HPN564MEN0M 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 E92 EA5 ED0 EE3 EN0 8.9 7.8 6.0 5.7 3.9 16.73 19.58 22.72 24.75 35.94 6,800 12,000 18,000 22,000 27,000 33,000 39,000 47,000 15,000 22,000 33,000 47,000 56,000 68,000 82,000 100,000 68,000 120,000 150,000 180,000 120,000 150,000 180,000 220,000 390,000 E36D500HPN682MA41M E36D500HPN123MA54M E36D500HPN183MA67M E36D500HPN223MA79M E36D500HPN273MA92M E36D500HPN333MAA5M E36D500HPN393MAB7M E36D500HPN473MAE3M E36D500HPN153MC48M E36D500HPN223MC54M E36D500HPN333MC67M E36D500HPN473MC79M E36D500HPN563MC92M E36D500HPN683MCA5M E36D500HPN823MCB7M E36D500HPN104MCE3M E36D500HPN683MD79M E36D500HPN124MDA5M E36D500HPN154MDB7M E36D500HPN184MDE3M E36D500HPN124ME92M E36D500HPN154MEA5M E36D500HPN184MEB7M E36D500HPN224MED0M E36D500HPN394MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 ED0 EN0 48.8 28.7 22.8 16.8 14.2 12.1 11.8 9.3 25.4 18.4 12.8 9.7 8.3 7.1 6.3 5.4 9.0 6.6 5.9 5.0 8.3 7.3 6.6 6.2 4.0 3.10 4.34 5.40 6.39 7.47 8.57 9.34 11.03 5.13 6.42 8.20 10.09 11.90 13.36 15.20 17.99 12.06 15.71 17.81 20.74 14.86 16.74 18.42 20.04 31.15 4,700 8,200 12,000 15,000 18,000 22,000 27,000 33,000 12,000 15,000 22,000 33,000 39,000 47,000 56,000 68,000 47,000 82,000 100,000 120,000 100,000 120,000 150,000 180,000 270,000 E36D630HPN472MA41M E36D630HPN472MA54M E36D630HPN472MA67M E36D630HPN472MA79M E36D630HPN472MA92M E36D630HPN472MAA5M E36D630HPN472MAD0M E36D630HPN472MAE3M E36D630HPN123MC48M E36D630HPN153MC54M E36D630HPN223MC67M E36D630HPN333MC79M E36D630HPN393MC92M E36D630HPN473MCA5M E36D630HPN563MCB7M E36D630HPN683MCE3M E36D630HPN473MD79M E36D630HPN823MDA5M E36D630HPN104MDB7M E36D630HPN124MDE3M E36D630HPN104ME92M E36D630HPN124MEA5M E36D630HPN154MED0M E36D630HPN184MEE3M E36D630HPN274MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AD0 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 ED0 EE3 EN0 52.8 31.2 22.2 18.2 15.5 13.2 11.1 9.7 25.2 19.8 13.8 11.2 8.7 7.5 6.7 5.7 9.3 6.8 6.0 5.2 9.1 7.9 6.2 5.9 4.1 2.99 4.17 5.17 6.15 7.14 8.22 9.64 10.75 5.24 6.21 7.91 9.85 11.62 13.01 14.74 17.51 11.86 15.60 17.66 20.55 14.20 16.10 19.88 21.42 31.94 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 8 / 13 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 80 Volts 100 Volts Surge 100 Volts Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 2,700 4,700 5,600 8,200 10,000 12,000 15,000 18,000 5,600 8,200 12,000 18,000 22,000 27,000 33,000 39,000 27,000 39,000 56,000 47,000 56,000 68,000 82,000 100,000 120,000 E36D800HPN272MA41M E36D800HPN472MA54M E36D800HPN562MA67M E36D800HPN822MA79M E36D800HPN103MA92M E36D800HPN123MAA5M E36D800HPN153MAD0M E36D800HPN183MAE3M E36D800HPN562MC48M E36D800HPN822MC54M E36D800HPN123MC67M E36D800HPN183MC79M E36D800HPN223MC92M E36D800HPN273MCA5M E36D800HPN333MCB7M E36D800HPN393MCE3M E36D800HPN273MD79M E36D800HPN393MDA5M E36D800HPN563MDD0M E36D800HPN473ME92M E36D800HPN563MEA5M E36D800HPN683MEB7M E36D800HPN823MED0M E36D800HPN104MEE3M E36D800HPN124MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  5.625 3.000  8.625 A41 A54 A67 A79 A92 AA5 AD0 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DD0 E92 EA5 EB7 ED0 EE3 EN0 61.9 36.4 30.0 21.7 18.2 15.6 12.9 12.8 32.5 23.2 16.1 13.0 9.8 9.8 8.0 6.3 10.1 7.4 5.9 8.7 7.5 6.7 6.2 5.5 4.1 2.77 3.87 4.44 5.65 6.60 7.56 8.93 9.99 4.62 5.59 7.32 9.22 10.95 12.39 14.12 16.65 11.34 15.07 18.51 14.52 16.51 18.28 19.88 21.42 31.53 1,800 2,700 3,900 4,700 5,600 8,200 10,000 3,900 5,600 8,200 10,000 15,000 18,000 22,000 27,000 18,000 27,000 33,000 39,000 33,000 39,000 47,000 56,000 82,000 E36D101HPN182MA41M E36D101HPN272MA54M E36D101HPN392MA67M E36D101HPN472MA79M E36D101HPN562MA92M E36D101HPN822MAB7M E36D101HPN103MAD0M E36D101HPN392MC48M E36D101HPN562MC54M E36D101HPN822MC67M E36D101HPN103MC79M E36D101HPN153MC92M E36D101HPN183MCB7M E36D101HPN223MCD0M E36D101HPN273MCE3M E36D101HPN183MD79M E36D101HPN273MDA5M E36D101HPN333MDB7M E36D101HPN393MDE3M E36D101HPN333ME92M E36D101HPN393MEA5M E36D101HPN473MEB7M E36D101HPN563MED0M E36D101HPN823MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.125 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AB7 AD0 C48 C54 C67 C79 C92 CB7 CD0 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 ED0 EN0 72.1 47.5 33.6 28.1 23.6 17.2 14.7 36.4 26.2 18.2 14.8 12.5 9.0 7.8 7.6 11.2 8.0 7.1 6.0 9.3 8.0 7.2 6.6 4.3 2.57 3.39 4.21 4.97 6.22 7.39 8.41 4.38 5.41 6.92 8.23 10.38 12.65 14.15 15.91 10.83 14.41 16.47 19.15 14.05 16.00 17.65 19.42 30.41 820 1,500 2,200 2,700 3,300 3,900 4,700 5,600 E36D161HPN821MA41M E36D161HPN152MA54M E36D161HPN222MA67M E36D161HPN272MA79M E36D161HPN332MA92M E36D161HPN392MAA5M E36D161HPN472MAB7M E36D161HPN562MAE3M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 202.0 110.0 76.9 57.4 51.1 43.6 36.7 31.0 1.95 2.83 3.57 4.26 5.05 5.83 6.55 7.85 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 9 / 13 U36D 160 Volts 200 Volts Surge Global Part Number† L ARGE CAN 85C 125 Volts Surge Capacitance (µF ) Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 160 Volts 200 Volts Surge 200 Volts U36D L ARGE CAN 85C 250 Volts Surge 250 Volts 300 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 2,200 2,700 3,900 5,600 8,200 10,000 12,000 10,000 15,000 18,000 22,000 18,000 22,000 27,000 33,000 47,000 E36D161HPN222MC48M E36D161HPN272MC54M E36D161HPN392MC67M E36D161HPN562MC79M E36D161HPN822MC92M E36D161HPN103MCB7M E36D161HPN123MCD0M E36D161HPN103MD79M E36D161HPN153MDA5M E36D161HPN183MDB7M E36D161HPN223MDE3M E36D161HPN183ME92M E36D161HPN223MEA5M E36D161HPN273MED0M E36D161HPN333MEE3M E36D161HPN473MEN0M 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.125 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 C48 C54 C67 C79 C92 CB7 CD0 D79 DA5 DB7 DE3 E92 EA5 ED0 EE3 EN0 80.9 64.7 44.7 31.8 22.4 18.4 15.9 21.5 14.9 12.5 10.6 15.2 12.9 10.3 9.2 6.7 3.86 4.49 5.73 7.37 9.53 11.71 13.46 11.23 15.52 17.82 21.54 17.74 20.73 25.17 29.02 41.98 680 1,000 1,500 1,800 2,200 2,700 3,300 3,900 1,500 2,200 3,300 3,900 5,600 8,200 10,000 6,800 10,000 12,000 15,000 12,000 15,000 18,000 22,000 33,000 E36D201HPN681MA41M E36D201HPN102MA54M E36D201HPN152MA67M E36D201HPN182MA79M E36D201HPN222MA92M E36D201HPN272MAA5M E36D201HPN332MAB7M E36D201HPN392MAD0M E36D201HPN152MC48M E36D201HPN222MC54M E36D201HPN332MC67M E36D201HPN392MC79M E36D201HPN562MC92M E36D201HPN822MCB7M E36D201HPN103MCE3M E36D201HPN682MD79M E36D201HPN103MDA5M E36D201HPN123MDB7M E36D201HPN153MDE3M E36D201HPN123ME92M E36D201HPN153MEA5M E36D201HPN183MEB7M E36D201HPN223MED0M E36D201HPN333MEN0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A41 A54 A67 A79 A92 AA5 AB7 AD0 C48 C54 C67 C79 C92 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 ED0 EN0 205.0 137.0 92.0 76.6 63.0 51.8 43.0 36.8 97.1 67.0 44.8 37.4 26.6 18.9 15.7 24.9 17.3 14.5 12.1 17.0 14.3 12.4 10.8 7.3 1.78 2.31 2.95 3.48 4.12 4.85 5.49 6.27 3.19 4.05 5.27 6.15 7.87 10.60 12.83 9.26 12.67 14.55 17.79 14.49 17.12 19.64 22.72 35.17 470 820 1,200 1,500 1,800 2,200 2,700 3,300 1,200 1,500 2,200 3,300 3,900 4,700 5,600 6,800 4,700 8,200 E36D251HPN471MA41M E36D251HPN821MA54M E36D251HPN122MA67M E36D251HPN152MA79M E36D251HPN182MA92M E36D251HPN222MAA5M E36D251HPN272MAD0M E36D251HPN332MAE3M E36D251HPN122MC48M E36D251HPN152MC54M E36D251HPN222MC67M E36D251HPN332MC79M E36D251HPN392MC92M E36D251HPN472MCA5M E36D251HPN562MCB7M E36D251HPN682MCE3M E36D251HPN472MD79M E36D251HPN822MDA5M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 A41 A54 A67 A79 A92 AA5 AD0 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 271.2 154.3 105.8 84.7 70.8 58.4 47.8 39.8 111.5 87.9 59.8 40.8 34.4 28.8 24.5 20.3 31.0 19.2 1.48 2.09 2.64 3.18 3.73 4.38 5.21 6.03 2.85 3.34 4.31 5.66 6.57 7.65 8.76 10.58 7.70 11.47 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 10 / 13 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 250 Volts 300 Volts Surge 315 Volts 365 Volts Surge Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 10,000 12,000 10,000 12,000 15,000 18,000 27,000 E36D251HPN103MDB7M E36D251HPN123MDE3M E36D251HPN103ME92M E36D251HPN123MEA5M E36D251HPN153MED0M E36D251HPN183MEE3M E36D251HPN273MEN0M 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 DB7 DE3 E92 EA5 ED0 EE3 EN0 18.4 13.6 18.8 15.9 12.6 11.2 7.7 13.28 15.91 13.22 15.31 18.76 21.43 31.82 390 560 820 1,000 1,200 1,500 560 820 1,200 1,500 2,200 2,700 3,300 3,900 2,700 3,900 4,700 5,600 4,700 5,600 6,800 8,200 15,000 E36D3B1HPN391MA54M E36D3B1HPN391MA67M E36D3B1HPN821MA79M E36D3B1HPN102MA92M E36D3B1HPN122MAB7M E36D3B1HPN152MAD0M E36D3B1HPN561MC48M E36D3B1HPN821MC54M E36D3B1HPN122MC67M E36D3B1HPN152MC79M E36D3B1HPN222MC92M E36D3B1HPN272MCB7M E36D3B1HPN332MCD0M E36D3B1HPN392MCE3M E36D3B1HPN272MD79M E36D3B1HPN392MDA5M E36D3B1HPN472MDB7M E36D3B1HPN562MDD0M E36D3B1HPN472ME92M E36D3B1HPN562MEA5M E36D3B1HPN682MEB7M E36D3B1HPN822MED0M E36D3B1HPN153MEN0M 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.625 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.625 2.000  5.125 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 A54 A67 A79 A92 AB7 AD0 C48 C54 C67 C79 C92 CB7 CD0 CE3 D79 DA5 DB7 DD0 E92 EA5 EB7 ED0 EN0 513.0 356.0 243.0 200.0 166.0 133.0 366.0 248.0 168.0 134.0 92.0 74.9 61.8 52.5 77.5 53.8 44.7 38.1 46.8 39.4 32.9 27.8 15.9 1.44 1.80 2.35 2.78 3.31 3.89 1.95 2.47 3.18 3.81 4.94 6.09 7.06 8.01 5.83 7.91 9.11 10.41 9.07 10.46 12.07 13.87 23.71 220 330 470 680 820 1,000 1,200 470 680 1,000 1,200 1,800 2,200 2,700 3,300 2,200 3,300 3,900 4,700 3,900 4,700 5,600 6,800 8,200 12,000 6,800 8,200 10,000 E36D351HPN221MA41M E36D351HPN331MA54M E36D351HPN471MA67M E36D351HPN681MA79M E36D351HPN821MA92M E36D351HPN102MAA5M E36D351HPN122MAD0M E36D351HPN471MC48M E36D351HPN681MC54M E36D351HPN102MC67M E36D351HPN122MC79M E36D351HPN182MC92M E36D351HPN222MCA5M E36D351HPN272MCB7M E36D351HPN332MCE3M E36D351HPN222MD79M E36D351HPN332MDA5M E36D351HPN392MDB7M E36D351HPN472MDD0M E36D351HPN392ME92M E36D351HPN472MEA5M E36D351HPN562MEB7M E36D351HPN682MED0M E36D351HPN822MEE3M E36D351HPN123MEN0M E36D351LLN682MFA5M E36D351LLN822MFB7M E36D351LLN103MFE3M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  5.125 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  5.625 3.000  8.625 3.500  4.125 3.500  4.625 3.500  5.625 A41 A54 A67 A79 A92 AA5 AD0 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DD0 E92 EA5 EB7 ED0 EE3 EN0 FA5 FB7 FE3 887.0 545.0 379.0 262.0 217.0 178.0 148.0 390.0 267.0 180.0 149.0 100.0 82.5 67.3 55.3 84.5 56.6 47.9 40.4 49.9 41.7 35.3 29.6 25.1 17.4 32.0 27.0 23.0 1.17 1.53 1.91 2.47 2.91 3.41 4.01 2.06 2.60 3.35 3.94 5.15 6.04 7.03 8.51 6.08 8.40 9.58 11.02 9.54 11.06 12.65 14.59 16.70 24.49 11.39 12.88 15.17 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 11/ 13 U36D Global Part Number† L ARGE CAN 85C 350 Volts 400 Volts Surge Capacitance (µF ) Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 400 Volts U36D L ARGE CAN 85C 450 Volts Surge 450 Volts 500 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL (inches) Case Size Code Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz 180 330 390 560 680 820 1,000 1,200 390 560 820 1,200 1,500 1,800 2,200 2,700 1,800 2,700 3,900 4,700 3,900 4,700 5,600 6,800 10,000 5,600 6,800 8,200 E36D401HPN181MA41M E36D401HPN331MA54M E36D401HPN391MA67M E36D401HPN561MA79M E36D401HPN681MA92M E36D401HPN821MAA5M E36D401HPN102MAB7M E36D401HPN122MAE3M E36D401HPN391MC48M E36D401HPN561MC54M E36D401HPN821MC67M E36D401HPN122MC79M E36D401HPN152MC92M E36D401HPN182MCA5M E36D401HPN222MCB7M E36D401HPN272MCE3M E36D401HPN182MD79M E36D401HPN272MDA5M E36D401HPN392MDB7M E36D401HPN472MDE3M E36D401HPN392ME92M E36D401HPN472MEA5M E36D401HPN562MED0M E36D401HPN682MEE3M E36D401HPN103MEN0M E36D401LLN562MFA5M E36D401LLN682MFB7M E36D401LLN822MFD0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 3.500  4.125 3.500  4.625 3.500  5.125 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 ED0 EE3 EN0 FA5 FB7 FD0 921.0 495.0 416.0 289.0 238.0 197.0 162.0 135.0 416.0 295.0 200.0 137.0 109.0 91.5 75.0 61.3 93.5 62.6 44.2 37.0 46.5 38.8 32.3 27.1 18.7 37.0 31.0 26.0 1.06 1.53 1.74 2.24 2.65 3.09 3.49 4.20 1.88 2.36 3.04 3.94 4.71 5.47 6.34 7.70 5.50 7.60 9.58 11.50 9.54 11.06 13.24 15.21 22.36 10.59 12.02 13.82 150 270 330 470 560 680 820 1,000 330 470 680 1,000 1,200 1,500 1,800 2,200 1,500 2,200 2,700 3,300 3,900 2,700 3,900 4,700 5,600 8,200 4,700 5,600 6,800 E36D451HPN151MA41M E36D451HPN271MA54M E36D451HPN331MA67M E36D451HPN471MA79M E36D451HPN561MA92M E36D451HPN681MAA5M E36D451HPN821MAB7M E36D451HPN102MAE3M E36D451HPN331MC48M E36D451HPN471MC54M E36D451HPN681MC67M E36D451HPN102MC79M E36D451HPN122MC92M E36D451HPN152MCA5M E36D451HPN182MCB7M E36D451HPN222MCE3M E36D451HPN152MD79M E36D451HPN222MDA5M E36D451HPN272MDB7M E36D451HPN332MDD0M E36D451HPN392MDE3M E36D451HPN272ME92M E36D451HPN392MEA5M E36D451HPN472MED0M E36D451HPN562MEE3M E36D451HPN822MEN0M E36D451LLN472MFA5M E36D451LLN562MFB7M E36D451LLN682MFD0M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.125 2.500  5.625 3.000  3.625 3.000  4.125 3.000  5.125 3.000  5.625 3.000  8.625 3.500  4.125 3.500  4.625 3.500  5.125 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DD0 DE3 E92 EA5 ED0 EE3 EN0 FA5 FB7 FD0 1,687.8 923.3 749.9 525.5 440.3 362.5 300.7 246.6 653.4 535.9 366.8 249.0 207.1 165.8 138.3 113.2 168.2 114.5 93.7 77.1 65.6 95.6 78.4 55.7 47.2 32.4 67.0 56.0 47.0 0.96 1.39 1.60 2.05 2.40 2.81 3.16 3.83 1.73 2.16 2.76 3.60 4.21 4.99 5.74 6.95 5.02 6.86 7.97 9.23 10.47 7.93 10.08 12.13 13.80 20.25 7.87 8.94 10.28 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 12 / 13 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 U36D Series Standard Voltage Ratings - Screw Terminals Rated Voltage (WVDC) 500 Volts 550 Volts Surge Case Size Code 100 180 220 330 390 470 560 680 220 330 470 680 820 1,000 1,200 1,500 1,000 1,500 2,200 2,200 2,700 3,900 5,600 3,900 4,700 5,600 6,800 E36D501HPN101MA41M E36D501HPN181MA54M E36D501HPN221MA67M E36D501HPN331MA79M E36D501HPN391MA92M E36D501HPN471MAA5M E36D501HPN561MAB7M E36D501HPN681MAE3M E36D501HPN221MC48M E36D501HPN331MC54M E36D501HPN471MC67M E36D501HPN681MC79M E36D501HPN821MC92M E36D501HPN102MCA5M E36D501HPN122MCB7M E36D501HPN152MCE3M E36D501HPN102MD79M E36D501HPN152MDA5M E36D501HPN222MDB7M E36D501HPN222ME92M E36D501HPN272MEB7M E36D501HPN392MEE3M E36D501HPN562MEN0M E36D501LLN392MFA5M E36D501LLN472MFB7M E36D501LLN562MFD0M E36D501LLN682MFE3M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.125 1.375  4.625 1.375  5.625 2.000  1.875 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 3.000  3.625 3.000  4.625 3.000  5.625 3.000  8.625 3.500  4.125 3.500  4.625 3.500  5.125 3.500  5.625 A41 A54 A67 A79 A92 AA5 AB7 AE3 C48 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 E92 EB7 EE3 EN0 FA5 FB7 FD0 FE3 3,918.0 2,141.0 1,739.0 1,155.0 975.0 808.0 677.0 557.0 1,453.0 1,177.0 817.0 563.0 465.0 381.0 317.0 253.0 320.0 213.0 212.0 175.0 142.0 99.0 69.0 131.0 109.0 92.0 76.0 0.60 0.87 1.00 1.32 1.54 1.79 2.00 2.42 1.08 1.39 1.76 2.27 2.67 3.12 3.59 4.40 3.14 4.35 5.52 5.49 6.74 8.83 12.83 5.63 6.62 7.35 8.35 68 120 150 220 270 330 390 470 220 330 470 560 680 820 1,000 680 1,000 1,200 1,500 1,200 1,500 1,800 2,200 3,900 1,800 2,200 2,700 3,300 E36D551HPN680MA41M E36D551HPN121MA54M E36D551HPN151MA67M E36D551HPN221MA79M E36D551HPN271MA92M E36D551HPN331MAB7M E36D551HPN391MAD0M E36D551HPN471MAE3M E36D551HPN221MC54M E36D551HPN331MC67M E36D551HPN471MC79M E36D551HPN561MC92M E36D551HPN681MCA5M E36D551HPN821MCB7M E36D551HPN102MCE3M E36D551HPN681MD79M E36D551HPN102MDA5M E36D551HPN122MDB7M E36D551HPN152MDE3M E36D551HPN122ME92M E36D551HPN152MEA5M E36D551HPN182MEB7M E36D551HPN222MED0M E36D551HPN392MEN0M E36D551LLN182MFA5M E36D551LLN222MFB7M E36D551LLN272MFD0M E36D551LLN332MFE3M 1.375  1.625 1.375  2.125 1.375  2.625 1.375  3.125 1.375  3.625 1.375  4.625 1.375  5.125 1.375  5.625 2.000  2.125 2.000  2.625 2.000  3.125 2.000  3.625 2.000  4.125 2.000  4.625 2.000  5.625 2.500  3.125 2.500  4.125 2.500  4.625 2.500  5.625 3.000  3.625 3.000  4.125 3.000  4.625 3.000  5.125 3.000  8.625 3.500  4.125 3.500  4.625 3.500  5.125 3.500  5.625 A41 A54 A67 A79 A92 AB7 AD0 AE3 C54 C67 C79 C92 CA5 CB7 CE3 D79 DA5 DB7 DE3 E92 EA5 EB7 ED0 EN0 FA5 FB7 FD0 FE3 3,997.0 2,227.0 1,769.0 1,202.0 977.0 797.0 674.0 559.0 1,224.0 808.0 565.0 472.0 388.0 322.0 263.0 391.0 265.0 220.0 176.0 222.0 178.0 148.0 121.0 69.0 159.0 130.0 107.0 88.0 0.50 0.71 0.83 1.08 1.28 1.54 1.75 2.01 1.13 1.48 1.89 2.21 2.58 2.97 3.59 2.59 3.89 4.56 5.46 4.06 4.79 5.50 6.36 10.71 5.11 6.06 6.81 7.76 † For terminal, mounting and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 13 / 13 U36D Nominal Case Size* DL (inches) L ARGE CAN 85C 550 Volts 600 Volts Surge Maximum ESR ( mΩ ) at 25C, 120Hz Rated Ripple Current (A rms) at 85C, 120Hz Global Part Number† Capacitance (µF )
E36D201LPN822TDB7M
物料型号:U36D系列
器件简介:U36D系列电容器适用于需要高纹波电流能力的逆变器应用。该系列提供高达550VDC的额定电压和最高85°C的最大工作温度。电容值范围从68µF至2.2F,具有大型铝或英制螺纹端子。
引脚分配:提供高柱和低柱,英制和公制螺纹的螺丝端子。
参数特性: - 电容范围:68µF至2.2F - 电压范围:6.3至550VDC - 工作温度范围:-40°C至+85°C - 漏电流:在+25°C下5分钟后,取0.02CV(µA)或5mA中较小值 - 标准电容容差:±20% - 额定寿命:在+85°C下,额定纹波电流下2000小时
功能详解:U36D系列电容器设计用于减少串联电容器的数量,适用于高纹波电流应用。它们还提供多种安装选项,包括三脚卡箍或底部螺柱安装。
应用信息:适用于逆变器等高纹波电流应用。
封装信息:提供多种尺寸,直径从35mm至89mm,长度从41mm至220mm,可根据需求定制设计。
E36D201LPN822TDB7M 价格&库存
很抱歉,暂时无法提供与“E36D201LPN822TDB7M”相匹配的价格&库存,您可以联系我们找货
