342-026-541-202
342-026-541-202
    CARDEDGE 26POS DUAL .100 GREEN
342-026-541-202 数据手册
342/392 SERIES Card Edge Connector 0.100" (2.54mm) Pitch • FEATURES: • • • • • • • • .100" (2.54mm) Contact Spacing x .200" (5.08mm) Row Spacing Accepts .062" (1.57mm) Nominal Thickness P.C. Board High Profile Insulator Body, .590" (14.99mm) Contact Termination Options include P.C. Tail, Wire Wrap, 90 Degree Bends and Extender Board Bends Single or Dual Row Configurations Variety of Mounting Options, Flush or Offset Lugs Accepts between Contact and In-Contact Polarizing Keys RoHS Compliant & UL Certified Specifications: Insulator Material Contact Material Contact Plating Current Rating Contact Resistance Dielectric Withstand Voltage Insulation Resistance Operating Temperature Insertion Force Withdrawal Force Example Part Number: UL 94V-0 Thermoplastic Polyester Copper Alloy Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over 3 Amperes 10 milliohms maximum 1200 VAC rms at sea level between adjacent contacts 5000 Megaohms minimum -40°C to +105°C 16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge 1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge 342-100-541-202 Series: Insulator Color 342 392 Series Green Black Total Number of Contacts Contact Code Contact Code Contact Rows 500 520 521 523 524 540 541 542 544 555 556 558 559 560 Mounting Options Contact Rows: Description 1 2 Single Row Dual Row Total Number of Contacts: 005, 006, . . . . 059 010, 012, . . . . 116 Single Row Dual Row Mounting Options: 01 02 03 04 07 08 12 Contact Rows Description No Mounting Lug 128" (3.25mm) Wide Mounting Holes Ø.116" (Ø2.95mm) I.D. Floating Eyelets Ø.156" (Ø3.96mm) Mounting Holes M3-0.5 Metric Threaded Inserts #4-40 Unified Threaded Inserts Ø.128" (Ø3.25mm) Side Mounting Holes Description & Tail Size Wire Hole .050 x .025 (1.27 x 0.64) P.C. Tail .030 x .018 (0.76 x 0.46) P.C. Tail .025 Square (0.64 Square) P.C. Tail .025 Square (0.64 Square) P.C. Tail .018 Square (0.46 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .050 x .025 (1.27 x 0.64) EXTENDER BOARD DEND (CODE 500 CONTACTS) EXTENDER BOARD BEND (CODE 520 CONTACTS) 90 DEGREE BEND (CODE 541 CONTACTS) 90 DEGREE BEND (CODE 541 CONTACTS) EXTENDER BOARD BEND (CODE 523 CONTACTS) IN-CONTACT POLARIZING KEY P/N 345-240-328 Ordering Code Notes: 1) All connector sizes up to 58 contacts single row / 116 contacts dual row are available upon request. 2) The 500 contact code is only available in the 342 series. Green polyphenylene sulphide insulator material will be supplied. 3) For details of the extender board and 90 degree bends refer to next pages. 4) For details of the mounting options refer to page 3. www.edac.net Page 1 Tail Length "G" .270 (6.86) .185 (4.70) .160 (4.06) .400 (10.16) .185 (4.70) .570 (14.48) .760 (19.30) .655 (16.64) .760 (19.30) 342/392 SERIES Card Edge Connector 0.100" (2.54mm) Pitch SECTION THROUGH CONTACT POSITION A B SINGLE ROW DUAL ROW C .410 (10.41) CARD SLOT .370 (9.40) .240 (6.10) POINT OF CONTACT CARD SLOT ACCEPTS .054 (1.37) TO .070 (1.78) THICK P.C. BOARD LETTER"A"SIDE OF CONNECTOR SPECIFICATIONS D .590 (14.99) .135 (3.43) .270 (6.86) G .128 (3.25) DIA CONNECTOR B THROUGH HOLES DIMENSION FOR RIGHT ANGLE MTG. .030 X .080 (0.76 X 2.03) WIRE HOLE .100 (2.54) E .200 (5.08) RECOMMENDED DAUGHTER BOARD .400 (10.16) .200 PANEL MOUNT (5.08) CUT OUT .430 (10.92) .100 (2.54) .125 (3.18) PANEL MOUNT .136 (3.45) DIA REF E .042 (1.07) .080 (2.03) B CUT OUT FOR IN-CONTACT POLARIZING KEY. .042 (1.07) +.004 (0.10)/-.000 FOR ALL P.C. TAILS EXCEPT CODE 524 .031 (0.79) +.004 (0.10)/-.000 FOR CODE 524 P.C. TAIL .008 (0.20) DIA CUT OUT FOR BETWEEN CONTACT POLARIZING KEY. +.000 D MINUS .012 (0.30) -.015 (0.38) CONNECTOR MOUNTING PATTERN NUMBER OF CONTACTS Single Double 5 10 10 20 15 30 13 26 18 36 22 44 25 50 30 60 31 62 35 70 36 72 43 86 50 100 58 116 "A" Inch 1.300 1.800 2.100 2.300 2.600 3.000 3.300 3.800 3.900 4.300 4.400 5.100 5.800 6.600 "B" mm 33.02 45.72 53.34 58.42 66.04 76.20 83.82 96.52 99.06 109.22 111.76 129.54 147.32 167.64 Inch 1.022 1.522 1.822 2.022 2.322 2.722 3.022 3.522 3.622 4.022 4.122 4.822 5.522 6.322 "C" mm 25.96 38.66 46.28 51.36 58.98 69.14 76.76 89.46 92.00 102.16 104.70 122.48 140.26 160.58 www.edac.net Page 2 Inch 0.746 1.246 1.546 1.746 2.046 2.446 2.746 3.246 3.346 3.746 3.846 4.546 5.246 6.046 "D" mm 18.95 31.65 39.27 44.35 51.97 62.13 69.75 82.45 84.99 95.15 97.69 115.47 133.25 153.57 Inch 0.600 1.100 1.400 1.600 1.900 2.300 2.600 3.100 3.200 3.600 3.700 4.400 5.100 5.900 "E" mm 15.24 27.94 35.56 40.64 48.26 58.42 66.04 78.74 81.28 91.44 93.98 111.76 129.54 149.86 Inch 0.400 0.900 1.200 1.400 1.700 2.100 2.400 2.900 3.000 3.400 3.500 4.200 4.900 5.700 mm 10.16 22.86 30.48 35.56 43.18 53.34 60.96 73.66 76.20 86.36 88.90 106.68 124.46 144.78 342/392 SERIES Card Edge Connector 0.100" (2.54mm) Pitch .250 (6.35) DIA .010 (0.25) RADIAL FLOAT .348(8.84) NO MOUNTING LUGS CONNECTOR DIMENSION C B CONNECTOR DIMENSION MOUNTING OPTION CODES x02 and xO4 MOUNTING OPTION CODE x01 .005 (0.51) VERTICAL FLOAT .116 (2.95) I.D. FLOATING EYELETS DIA THROUGH HOLES A CONNECTOR DIMENSION B MOUNTING OPTION CODE x03 CODE X02 AND X04- THROUGH MTG. HOLES CODE X02 "A" DIA. .135 (3.43) 0.128(3.25)X 0.146(3.71) SLOT CODE X04 0.156(3.96) CODE X07 AND X08- THREADED INSERTS CONNECTOR B DIMENSION .128 (3.25) DIA THROUGH HOLES CODE x07 M3-0.5 METRIC CODE x08 #4-40 UNC THREADED INSERTS CONNECTOR B DIMENSION CODE X07 INSERT CODE X08 #4-40 UNC SIDE MOUNTING HOLES WITH INSERTS MOUNTING OPTION CODES x07 & xO8 FOR RIGHT ANGLE MTG. CODE X12 M3-0.5(METRIC) CODE X17 INSERT M3-0.5(METRIC) CODE X18 #4-40 UNC NUMBERED SIDE, EVEN NUMBERED SIDE OR ROW "A" SIDE OF CONNECTOR (DEPENDING UPON SERIES) .165 (4.19) .120 (3.05) .060 (1.52) A A .200 (5.08) .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .210 (5.33) OUTSIDE TAILS .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .210 (5.33) OUTSIDE TAILS CONTACT CODE 560 CONTACT CODE 555 BEND USES WIRE HOLE CONTACTS NUMBERED SIDE, EVEN NUMBERED SIDE OR ROW "A" SIDE OF CONNECTOR (DEPENDING UPON SERIES) .095 (2.41) .060 (1.52) A .150 (3.81) .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .185 (4.70) OUTSIDE TAILS CONTACT CODE 556 A B THIS CONTACT ROW IS STANDARD FOR SINGLE ROW BEND CONTACT CODE 559 www.edac.net Page 3 A B THIS CONTACT ROW IS STANDARD FOR SINGLE ROW BEND CONTACT CODE 558
342-026-541-202 价格&库存
很抱歉,暂时无法提供与“342-026-541-202”相匹配的价格&库存,您可以联系我们找货
