PNP300JR-73-39R
PNP300JR-73-39R
    YAGEO(国巨)
    AXIAL-D4.6X11.5MM
    插件电阻 - 39Ω ±5% 3W -
PNP300JR-73-39R 数据手册
DATA SHEET WIREWOUND RESISTORS High Power PNP Series ±1%, ±5% 1W to 4W Product specification – April 3, 2024 V.4 RoHS compliant & Halogen Free Through Hole Resistors Wirewound Resistors Product Specification PNP ORDERING INFORMATION Part number of the high power wirewound resistor are identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value. PART NUMBER APPLICATIONS  Power applications PNP 200 F T F 73- 10R (1) (2) (3) (4) (5) (6) (7) (1) SERIES PNP Series  Home appliance  Industry (2) POWER RATING FEATURES  Ultra miniature size  Wide resistance range  Stable performance and high reliability  Flameproof coating equivalent to UL-94V-0  RoHS compliant & halogen free 100 = 1W 300 = 3W 200 = 2W 400 = 4W (3) TOLERANCE F = ±1% J = ±5% (4) PACKAGING TYPE R = Reel Pack B= Bulk T= Box Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE F=±100ppm/°C - = Based on spec. (6) FORMING 52- = 52.4mm FFK = F-form Kink 73- = 73mm FKK = FKK Type M = M-Type Forming FT = FT Type Forming MB = M-form W/flat PN = PANAsert F = F Type AV = AVIsert FK = FK Type 52H = 52.4mm, non-painting on soldering spots 73H = 73mm, non-painting on soldering spots Note: 52.4mm and 73mm represent dimension A of the axial type, please refer to the category of AXIAL/REEL TAPE SPECIFICATION for the detail. (7) RESISTANCE VALUE E24 & E96 Series Example: 1R = 1Ω, 10R = 10Ω, 100R = 100Ω www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Product Specification Wirewound Resistors PNP DIMENSIONS Unit: mm Ultra Miniature L ψD H ψd PNP100 6.3 ± 0.5 2.5 ± 0.3 28 ± 2.0 0.55 ± 0.05 PNP200 9.0 ± 0.5 3.5 ± 0.3 26 ± 2.0 0.55 ± 0.05 PNP300 11.5 ± 1.0 4.6 ± 0.5 35 ± 2.0 0.8 ± 0.05 PNP400 15.5 ± 1.0 5.2 ± 0.5 33 ± 2.0 0.8 ± 0.05 DERATING CURVE Rated Power (%) 100 80 60 40 36 20 70 200 275 Ambient Temperature (°C) ELECTRICAL CHARACTERISTICS CHARACTERISTICS PNP100 PNP200 PNP300 PNP400 Power Rating at 70 °C 1W 2W 3W 4W Resistance Range (±1%) 0.22Ω~130Ω 0.1Ω~820Ω 0.1Ω~2.2KΩ 0.1Ω~2.8KΩ Resistance Range (±5%) 0.1Ω~130Ω 0.1Ω~820Ω 0.1Ω~2.2KΩ 0.1Ω~2.8KΩ Voltage Proof on Insulation 300V Maximum working voltage √(P X R) Operating Temp. Range - 40°C to +200°C Temperature Coefficient ±100ppm/°C, ±300ppm/°C Note: For resistance value out of above range is by request. www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 10 times rated power for 5 Sec. ±2%+0.05Ω Voltage Proof on IEC 60115-1 4.7 In V-Block for 60 sec. test voltage as No Breakdown Insulation PROCEDURE APPRAISE above table Temperature Coefficient IEC 60115-1 4.8 Between -40°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >100MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV(or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -55°C ➔ Room Temp. ➔ ±1.0%+0.05Ω +200°C➔ Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body Accidental Overload Test IEC 60115-1 4.26 4 times RCWV for 1 Min. No evidence of flaming or arcing Note: RCWV (Rated Continuous Working Voltage): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP PULSE DIAGRAMS PNP100 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time PNP200 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP PNP300 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time PNP400 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP AXIAL / REEL TAPE SPECIFICATION Unit: mm Ultra Miniature a A B1-B2 (Max.) S (spacing) PNP100 6 ± 0.5 52.4 ± 1.5 1.2 5 PNP200 6 ± 0.5 52.4 ± 1.5 1.2 5 73.0 ± 1.5 1.5 PNP300 6 ± 0.5 PNP400 5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 6 ± 0.5 T (max. deviation of spacing) 1 mm per 10 spacing, 0.5 mm per 5 spacing 10 www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP TAPE ON REEL PACKING TYPE Unit: mm/piece Ultra Miniature Across Flange(A) B Quantity Per Reel PNP100 66.5 75.5 5,000 PNP200 66.5 75.5 2,500 PNP300 87 96 2,000 PNP400 87 96 1,000 www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP TAPE ON BOX PACKING TYPE DIMENSIONS Unit: mm/piece Ultra Miniature A B C Quantity Per Box PNP100 81 104 260 5,000 PNP200 73 45 258 1,000 PNP300 81 91 260 1,000 PNP300 103 78 260 1,000 PNP400 81 91 260 1,000 PNP400 103 94 260 1,000 BULK PACKING Ultra Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag PNP100 10,000 10 1,000 PNP200 5,000 5 1,000 PNP300 2,000 4 500 PNP400 1,000 2 500 www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP FORMING M TYPE TYPE DIMENSIONS Unit: mm Ultra Miniature L ψD ψd P H PNP100 6.3 ± 0.5 2.5 ± 0.3 0.55 ± 0.05 10.0 ± 1 10.0 ± 1 PNP200 9.0 ± 0.5 3.5± 0.3 0.55 ± 0.05 12.5 ± 1 10.0 ± 1 PNP300 11.5 ± 1.0 4.6± 0.5 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 PNP400 15.5 ± 1.0 5.2 ± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 MB TYPE TYPE DIMENSIONS Unit: mm Ultra Miniature L ψD ψd P H1 H2 t PNP100 6.3 ± 0.5 2.5± 0.3 0.55 ± 0.05 10.0 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 PNP200 9.0 ± 0.5 3.5± 0.3 0.8 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 PNP300 11.5 ± 1.0 4.6 ± 0.5 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 PNP400 15.5 ± 1.0 5.2 ± 0.5 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Product Specification Wirewound Resistors PNP MHA TYPE TYPE DIMENSIONS Miniature L ψD ψd B H0 HI P P0 9.0±0.5 3.5±0.3 0.55±0.05 17.5Max 19.0±1.0 4.0±1.0 30.0±1.0 15.0±0.3 P1 P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.5 7.5±0.5 18.0±0.5 5.0Min 9.0±0.5 4.0±0.2 PNP200 Unit: mm www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Product Specification Wirewound Resistors PNP MHB TYPE TYPE DIMENSIONS ψD ψd B 15.5±1.0 5.2±0.5 0.8±0.05 P P0 30.0±1.0 15.0±0.3 Miniature L PNP400 Unit: mm H H0 HI H2 H3 21.0Max. 30Max. 18.0±1.0 5.5(Ref.) 8.0±1.5 16Max. PI P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.8 7.5±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.3 MHC TYPE TYPE DIMENSIONS Miniature L ψD ψd B H HI P P0 15.5±1.0 5.2±0.5 0.8±0.05 21.0Max. 19.0±1.0 5.25±1.0 30.0±1.0 15.0±0.3 F W W0 W1 ΨD0 10.0±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.2 PNP400 Unit: mm www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Product Specification Wirewound Resistors F TYPE PNP FK TYPE FFK TYPE TYPE DIMENSIONS Ultra Miniature L ψD ψd P h PNP200 9.0±0.5 3.5±0.3 0.55±0.05 6±1 8±1 22 PNP300 11.5±1 4.6±0.5 0.8±0.05 6±1 8±1 PNP400 15.5±1 5.2±0.5 0.8±0.05 8±1 8±1 FKK TYPE Unit: mm PN TYPE (Taping Pack) H HI E Max. Max. 5±1 18.5 3.5 3.5±1 24 5±1 20 3.5 3.5±1 28 5± 1 25 3.5 3.5±1 Max. hl AV TYPE (Taping Pack) TYPE DIMENSIONS H3 Max. Ultra Miniature H1 Max. H2 Max. H3 Max. 21.5 8.5 PNP100 11.5 20 8.5 17 25.5 8.5 PNP200 14.5 23 8.5 19 27.5 8.5 PNP300 17.5 26 8.5 TYPE DIMENSIONS Ultra Miniature H1 Max. H2 Max. PNP100 13 PNP200 PNP300 e Unit: mm Unit: mm www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP FT TYPE (Taping Pack) TYPE DIMENSIONS Unit: mm Ultra Miniature H1 Max. H2 Max. H3 Max. PNP100 10 18.5 8.5 PNP200 13 21.5 8.5 PNP300 16 24.5 8.5 www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP MARKING 5-BAND-CODE ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100KΩ 1MΩ 10MΩ TOLERANCE 0.1Ω 0.01Ω ±5 % (J) ±1 % (F) PNP Series ±1% 6-BAND-CODE www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 4 Apr.1, 2024 - - Added forming code description for part number Version 3 Nov.8, 2023 - - 52H type and 73H type are included Version 2 Sep.6, 2023 - - Updated legal disclaimer and footer versions numbers Version 1 Aug.3, 2022 - - Update the resistance value description Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Apr. 03, 2024 V.4 Through Hole Resistors Wirewound Resistors Product Specification PNP LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket , etc.), Atomic energy-related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data -processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injur y or death, or serious property damage. Particularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Apr. 03, 2024 V.4
PNP300JR-73-39R 价格&库存
很抱歉,暂时无法提供与“PNP300JR-73-39R”相匹配的价格&库存,您可以联系我们找货
PNP300JR-73-39R
  • 2000+1.052912000+0.13621
  • 4000+0.969804000+0.12546
  • 6000+0.927096000+0.11994
  • 10000+0.8787910000+0.11369
  • 14000+0.8500014000+0.10996
  • 20000+0.8218820000+0.10633
库存:326
PNP300JR-73-39R
  • 1+3.802201+0.49188
  • 10+2.4116210+0.31198
  • 25+2.0455025+0.26462
  • 50+1.8141750+0.23469
  • 100+1.61722100+0.20922
  • 250+1.40118250+0.18127
  • 500+1.26586500+0.16376
  • 1000+1.150681000+0.14886
库存:326
