ED1100/X (5.0 mm)
EDZ1100/X (5.08 mm)
EDZ960/X
2-16 poles, Spacing 7.62 mm
insert required no. of poles x
2-20 (16) poles, Spacing 5.0 mm or 5.08 mm
How to order see page 5
*factory wiring
400 V
12 A (T60)
2.5 mm 2
6 kV/3
0.5 Nm/M3
Ratings:
Rated Voltage
300 V
300 V
Rated Current
15A
12 A
Wire Size
AWG 22-10 AWG 22-10
Rating Impulse Voltage/Dirt Level
Rated Torque/ScrewSize
250 V
12 A (T60)
2.5 mm 2
4 kV/3
0.5 Nm/M3
Max. Rated Cross Section
Single Wire (solid)
Stranded Wire (flexible)
Stranded wire with Ferrules
2.5 mm 2
2.5 mm 2
2.5 mm 2
Single Wire (solid)
2.5 mm 2
2.5 mm 2
2.5 mm 2
Dimensions
Spacing
Stripped Length
7.62 mm
6.0 mm
Dimensions
Spacing
Stripped Length
5.0 mm (5.08 mm)
7.0 mm
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Contact
PA
UL94 V-0
-30 C/+105 C
CuZn
CuSn
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Contact
PA
UL94 V-0
-30 C/+105 C
CuZn
CuSn
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Color
Green
37
300V
15 A
AWG* 28-12
Color
Green
ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444
37
很抱歉,暂时无法提供与“ED1100/16”相匹配的价格&库存,您可以联系我们找货
