TR Series
Stackpole Electronics, Inc.
TO-220 and TO-247 Style Power Resistor
Resistive Product Solutions
Features:
TR30/35/50/50H comes in TO-220 style power package
TR100 available in TO-247 style power package
TR30/35/50H/100 has single screw mounting to heat sink
Molded case for environmental protection
Electrically isolated case
Non-inductive package
RoHS compliant and halogen free
REACH compliant
Electrical Specifications
Type/Code
Package
Style
TR30
TO-220
TR35
TO-220
TR50
TO-220
TR50H
TO-220
TR100
TO-247
Power Rating (W)
Maximum
Power
Ohmic Range (Ω) and Tolerance
@ 25ºC
Working
TCR (ppm/ºC)
Rating (W)
(3)
(1)
@ 25ºC Voltage (V)\
0.5%
1%
5%
10%
with Heat Sink
± 50
10 - 100K
± 100
5.05 - 100K 3.01 - 100K
3.3 - 100K
± 200
10 - 100K 3.01 - 100K
3.3 - 100K
30
2.25
350
± 300
1.02 - 3.01
1.1 - 3
0.05 - 1
Unspecified(2)
± 50
10 - 10K
± 100
5.05 - 10K 3.01 - 10K
3.3 - 10K
± 200
10 - 10K
3.01 - 10K
3.3 - 10K
35
2.5
350
± 300
1.02 - 3.01
1.1 - 3
(2)
0.05 - 1
Unspecified
± 50
10 - 10K
± 100
3.3 - 10K
± 200
10 - 10K
3.01 - 10K
3.3 - 10K
50
3
350
± 300
1.02 - 3.01
1.1 - 3
(2)
0.1 - 1
Unspecified
± 50
10 - 10K
± 100
3.3 - 10K
± 200
10 - 10K
3.01 - 10K
3.3 - 10K
50
2.25
420
± 300
1.02 - 3.01
1.1 - 3
0.1 - 1
Unspecified(2)
± 50
10 - 100K
± 100
3.3 - 100K
± 200
3.3 - 100K
100
3.5
750
± 300
1.02 - 3.01
1.1 - 3
0.05 - 1
Unspecified(2)
(1) Lesser of √P*R or maximum working voltage
(2) Unspecified TCR. Contact Stackpole.
(3) The case temperature is to be used for the definition of the applied power limit. Refer to Power Derating Curve.
Thermal resistance: ((T@P0%) - (T max @P10 %))
Rev Date: 7/26/2022
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
TR Series
Mechanical Specifications
Type Code
W
H
H1
B
B1
D
D1
L
C
T
TR30/TR50H
0.409
10.40
0.640
16.25
0.125
3.18
0.512
13.00
0.122
3.10
0.050
1.27
0.030
0.76
0.125
3.18
0.200
5.08
0.125
3.18
T1
H2
P
P1
0.020
0.50
0.070
1.78
0.012
0.30
0.012
0.30
0.010
0.26
0.063
1.60
0.043
1.10
0.005
0.13
0.004
0.10
0.004
0.10
0.010
0.26
0.010
0.26
0.004
0.10
0.010
0.26
TR35
0.400
10.16
0.591
15.00
0.114
2.90
0.531
13.50
0.130
3.30
0.050
1.27
0.031
0.78
0.151
3.84
0.200
5.08
0.181
4.60
0.049
1.25
0.245
6.23
0.020
0.50
0.091
2.30
TR50
0.012
0.30
0.012
0.30
0.010
0.25
0.031
0.80
0.030
0.76
0.004
0.10
0.003
0.08
0.012
0.30
0.010
0.25
0.008
0.20
0.004
0.10
0.015
0.38
0.006
0.15
0.010
0.25
0.410
10.41
0.640
16.26
0.010
0.26
0.010
0.26
0.500
12.70
0.130
3.30
0.050
1.27
0.030
0.76
0.050
1.27
0.030
0.76
0.005
0.13
0.004
0.10
0.200
5.08
0.125
3.18
0.020
0.50
0.070
1.78
0.010
0.26
0.010
0.26
TR100
0.620
15.75
0.815
20.70
0.210
5.33
0.570
14.48
0.110
2.79
0.143
3.63
0.060
1.52
0.143
3.63
0.400
10.16
0.195
4.95
0.004
0.10
0.010
0.26
0.032
0.81
0.095
2.41
0.010
0.26
0.010
0.26
0.010
0.26
0.050
1.27
0.030
0.76
0.007
0.18
0.004
0.10
0.007
0.18
0.010
0.26
0.010
0.26
0.010
0.26
0.010
0.26
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Mounting Note:
(1) When mounting ensure entire ceramic portion of case is mounted on a clean, flat heat sink with an appropriate thermal interface,
such as thermal grease. For screw mounting use of a compression washer at a force of 150 to 300 pounds (665 to 1330 N) is
recommended without exceeding mounting torque of 8 in-lb (0.9 N-m) to avoid package damage. For clip mounting use of a round
or smooth clip in contact area is recommended to avoid a concentrated hot spot on package.
(2) TR50/100 must be mounted to heat sink using proper mounting clip for efficient heat dissipation.
Rev Date: 7/26/2022
2
www.seielect.com
TR Series
Performance Characteristics
Test
Test Specification
TR20/30/35/50/50H
TR100
Test Method
2 times rated power with applied voltage not to exceed 1.5 times
maximum continuous operating voltage for 5 seconds
Load Life
MIL-R-39009, 2000 hours at rated power
Moisture Resistance
MIL-STD-202, Method 103B
Thermal Shock
MIL-STD-202, Method 107G
Terminal Strength
MIL-STD-202, Method 211, Condition A (Pull Test) 2.4N
Vibration, High Frequency
MIL-STD-202, Method 204, Condition D
Dielectric Strength
Insulation Resistance
Operating Temperature Range: -65ºC to + 150ºC (TR20/TR30/TR50/TR50H)
-65ºC to + 175ºC (TR35/TR100)
Short Time Overload
∆R ± (0.3% + 0.001 Ω)
∆R ± (0.5% + 0.001 Ω)
∆R ± (1% + 0.001 Ω)
∆R ± (1% + 0.001 Ω)
∆R ± (0.5% + 0.001 Ω) ∆R ± (0.5% + 0.001 Ω)
∆R ± (0.3% + 0.001 Ω) ∆R ± (0.5% + 0.001 Ω)
∆R ± (0.2% + 0.001 Ω) ∆R ± (0.2% + 0.001 Ω)
∆R ± (0.2% + 0.001 Ω) ∆R ± (0.4% + 0.001 Ω)
1800 VAC
10G Ω min.
Power Derating Curve:
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Rev Date: 7/26/2022
3
Minimum
60 seconds
100°C
240°C
N/A
www.seielect.com
TR Series
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
YES(1)
100% Matte Sn
Always
Always
Radial
Leaded Resistor
Special
Note (1): RoHS Compliant by means of exemption 7c-I.
TR
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Rev Date: 7/26/2022
4
www.seielect.com
TR Series
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
T
R
3
F
B
D
1
K
Product Series
TR Standard
Power Rating
Size
W
30
30
35
35
50
50
50H
50
100
100
Tolerance
Code Tol
D
0.5%
F
1%
J
5%
K
10%
Packaging
Code Description
Size
30, 50, 50H
B
Bulk
35
100
TCR
Quantity Code
ppm
1000
X unspecified
500
C
50
105
D
100
L
200
M
300
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
"L" used as multiplier of
-3
10 for any value under
0.1 ohm.
0.05 ohm = 50L0
1.02 ohm = 1R02
100 Kohm = 100K
Resources:
Thermal Resistance Application Note
Rev Date: 7/26/2022
5
www.seielect.com
很抱歉,暂时无法提供与“TR50JBX50L0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+69.292831+8.96409
- 10+54.7351510+7.08083
- 25+51.4035025+6.64983
- 50+49.4741450+6.40024
- 100+47.93822100+6.20154
- 250+46.37659250+5.99952
- 500+45.47096500+5.88237
- 1000+44.749531000+5.78904
