PJM3407PSC
PJM3407PSC
    PJ(平晶)
    SOT-23
    P沟道,VDS=-30V ID=-4.6A ,PD:1.25W RDS(ON)
PJM3407PSC 数据手册
PJM3407PSC P-Channel Power MOSFET SOT-23-3 Features   VDS= -30V ID= -4.5A RDS(ON)= 60mΩ(max) @-10V  Halogen and Antimony Free 1 Applications  2 3 1. Gate Load Switch and in PWM Applications 2.Source 3.Drain Marking: P7 Schematic Diagram Drain 3 1 Gate 2 Source Absolute Maximum Ratings Ratings at TA =25℃ unless otherwise specified. Parameter Symbol Value Units Drain-Source Voltage -VDS 30 V Gate-Source Voltage VGS ±20 V Continuous Drain Current -ID 4.5 A Power Dissipation PD 1.25 W TJ, TSTG 150, -55 to 150 °C Parameter Symbol Typ. Units Maximum Junction-to-Ambient Note1 RθJA 100 °C/W Junction and Storage Temperature Range Thermal Characteristics www.pingjingsemi.com Revision:1.0 Jun-2019 1/6 PJM3407PSC P-Channel Power MOSFET Electrical Characteristics (TC=25℃ unless otherwise specified) Symbol Test Condition Min. Typ. Max. Units Drain-source breakdown voltage -V(BR)DSS VGS = 0V, ID=-250µA 30 -- -- V Drain to Source Leakage Current -IDSS VDS =-30V,VGS = 0V -- -- 1 µA Gate-body leakage current IGSS VGS =±20V, VDS = 0V -- -- ±100 nA Gate threshold voltage Note2 -VGS(th) VDS =VGS, ID =-250µA 1 1.6 3 V Drain-source on-resistance Note2 RDS(on) VGS =-10V, ID =-4.1A -- 48 60 mΩ VGS =-4.5V, ID =-3A -- 65 85 mΩ Forward transconductance Note2 gFS VDS =-5V, ID =-4A 5.5 -- -- S -- 700 -- -- 120 -- Parameter Static Characteristics Dynamic characteristics Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss -- 75 -- td(on) -- 8.6 -- -- 5 -- -- 28.2 -- VDS = -15V,VGS = 0V,f=1MHz pF Switching Characteristics Turn-on delay time Turn-on rise time Turn-off delay time tr td(off) VDS=-15V, VGS=-10V,RGEN =3Ω, RL =3.6Ω, Turn-off fall time tf -- 13.5 -- Total gate charge Qg -- 14 -- Gate-source charge Qgs -- 3.1 -- Gate-drain charge Qgd -- 3 -- -- -- 1.2 VDD =-15V,VGS =-10V,ID =-4A ns nC Source-Drain Diode characteristics Diode Forward voltage -VDS VGS =0V, IS=-4A V Notes: 1. 2. Surface mounted on FR4 board,t ≤ 10 sec. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. www.pingjingsemi.com Revision:1.0 Jun-2019 2/6 PJM3407PSC P-Channel Power MOSFET Typical Characteristic Curves Output Characteristics -20 Transfer Characteristics -5 VGS=-10、-5.0、-4.5、-4.0V Ta=25℃ Ta=25℃ Pulsed Pulsed VGS=-3.5V -4 VGS=-3.0V -10 Drain Current Drain Current ID ID (A) (A) -15 -3 -2 -5 -1 -0 -0 -1 -2 -Drain to Source Voltage RDS(ON) 4 -3 VDS -0 -5 -0 -1 -3 VGS -4 (V) RDS(ON) —— VGS ID —— -2 Gate to Source Voltage (V) 100 180 Ta=25℃ Ta=25℃ Pulsed Pulsed 150 (mΩ) (mΩ) 80 60 On-Resistance On-Resistance RDS(ON) RDS(ON) VGS=-4.5V VGS=-10V 40 120 90 ID=-4.1A 60 20 -0 -2 -4 -6 Drain Current IS —— ID -8 -10 (A) 30 -2 -4 -6 Gate to Source Voltage -8 VGS -10 (V) VSD -10 Ta=25℃ Pulsed -0.1 Source Current IS (A) -1 -0.01 -1E-3 -1E-4 -1E-5 -0.2 -0.4 -0.6 Source to Drain Voltage www.pingjingsemi.com Revision:1.0 Jun-2019 -0.8 VSD -1.0 -1.2 (V) 3/6 PJM3407PSC P-Channel Power MOSFET Package Outline SOT-23-3 Dimensions in mm 2.8 1.6 10 12 0.95 0.35 0.127± 0.03 ± 0.01 A ±0.1 ±0.05 2.92 ± 0.05 R0.15MAX `4X R0.15MAX `4X 1.26MAX 0.06 12 ± 0.05 ± 0.03 0.65 1.1 ± 0.05 10 Ordering Information Device Package Shipping PJM3407PSC SOT-23-3 3000PCS/Reel&Tape www.pingjingsemi.com Revision:1.0 Jun-2019 4/6 PJM3407PSC P-Channel Power MOSFET Conditions of Soldering And Storage Recommended condition of reflow soldering  Recommended peak temperature is over 245 ℃. If peak temperature is below 245 ℃, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 ℃  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 ℃  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:1.0 Jun-2019 5/6 PJM3407PSC P-Channel Power MOSFET Package Specifications Cover Tape 3,000 pcs per reel SOT-23-3 Carrier Tape 30,000 pcs per box 10 reels per box 240 217 0 21 43 5 120,000 pcs per carton 4 boxes per carton 455 220 2. Tape and reel data(7inch Units:mm) D A 3000 T2 T1 2900 2000 1900 1000 600 B C E PS F 1.10±0.10 Pin1 Revision:1.0 Jun-2019 N 3.2±0.10(Bo) 8 MAX 0.75 1.40±0.10(Ko) B-B Tape (8mm) www.pingjingsemi.com 0.46 0.2 8 MAX B 4.00±0.10 0.25±0.02(T) 2.45 1.55±0.05 3.50±0.05 2.00±0.05 8 ± 0 .1 0 4.00±0.10 B 1.75±0.10 Reel (7'') Symbol A B C E F D T1 T2 N G Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 3.15±0.1 1.22±0.1 6/6
PJM3407PSC 价格&库存
很抱歉,暂时无法提供与“PJM3407PSC”相匹配的价格&库存,您可以联系我们找货
PJM3407PSC
  • 10+0.37120
  • 100+0.29344
  • 300+0.25456
库存:471
