REVISION AY
FTR-1XX-XX-XX-D-XX-XX
PATENT NUMBERS
5713755 / 5961339
DO NOT
SCALE FROM
THIS PRINT
No OF POSITIONS
-02 THRU -50
(PER ROW)
LEAD STYLE
SEE TABLE 1
(No OF POS x .050 [1.27]) +.002/-.010
[+.05/-.25]
02
100
.196 4.98
REF
SEE NOTE 4
.100 2.54
REF
01
99
HTMS-50-D
3 MAX SWAY
(EITHER DIRECTION)
.050 1.27 REF
OPTION
-P: PICK & PLACE PAD
(USE PPP-22)
(SEE FIG 3, SHT 2)
[5 POS MIN]
-TR: TAPE AND REEL PACKAGING
(POSITIONS -02 THROUGH -50)
PLATING SPECIFICATION
-G: 10µ" GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-T: MATTE TIN CONTACT AND TAIL
(LEAD STYLES -01, -02, -03, -51, -52 ONLY)
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-TM: MATTE TIN CONTACT AND TAIL
-FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-H: 30µ" HEAVY GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
OPTION
-A: ALIGNMENT PIN (5 POS MIN)
( SEE FIG 2, SHT 2)
SAMTEC DISCRETION ON WHICH
-A PIN USED.
-LC: STAKED LOCKING CLIP (USE LC-05-TM)
(SEE FIG 4, SHT 2 & NOTE 10)
-XX: POLARIZING SPECIFICATION
XX INDICATES POS TO BE OMMITED
BODY SPECIFICATION
-D: DOUBLE (USE HTMS-50-D)
T-1M6-XX-XX-2
.018 0.46 SQ
REF
2 MAX SWAY
(EITHER DIRECTION)
2 MAX SWAY
(EITHER DIRECTION)
CONTACT
AREA
.050 1.27 (TYP)
(SEE NOTE 5)
C
"B"
+4°
90° - 2° (TYP)
C
.100 2.54
REF
C
.004 [.10]
NOTES:
1.
REPRESENTS A CRITICAL DIMENSION.
2. MAXIMUM CUT FLASH: .010[.25].
3. MINIMUM PUSHOUT FORCE: 2 LB.
4. MAXIMUM PIN ROTATION IN BODY: 2°.
5. SHEAR TAILS TO DIMENSION SHOWN.
6. MAXIMUM BURR ALLOWANCE: .003[.08]
7. MEASURED AT BEND RADIUS.
8. TUBE POSITIONS -05 AND GREATER; LAYER
PACKAGE POSITIONS -02 THRU -04.
9. -P OPTION: TUBE POSITIONS -07 THRU -50;
ALL OTHERS, TAPE & REEL ONLY.
10. DUE TO HIGH AMOUNT OF INSERTION FORCE
NEEDED, THE -LC OPTION IS NOT COMPATIBLE
WITH AUTO PLACEMENT. SAMTEC RECOMENDS
MANUAL PLACEMENT FOR ALL ASSEMBLIES
WITH THE -LC OPTION.
C
FIG 1
.05 1.3
(SEE NOTE 7)
.2960 7.518 REF
FTR-1XX-XX-D SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.X: .1 [2.5]
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
TERMINAL: PHOS BRONZE
F:\DWG\MISC\MKTG\FTR-1XX-XX-XX-D-XX-XX-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
HI-TEMP TERMINAL MICRO-STRIP (DOUBLE ROW)
DWG. NO.
BY: DEAN P
12/12/2000
SHEET 1 OF 3
REVISION AY
HTMS-50-D-XX
.040 1.02
REF
C
C
.090 2.29
(No OF POS - 2) x .0500[1.270]
.0430 1.092 REF
STAKED
(5 POSITIONS MINIMUM)
SMA-8H
.090 2.29
REF
.040 1.02
REF
.0430 1.092
REF
(No OF POS -2) x .0500[1.270] REF
MOLDED
FIG 2
-A OPTION: ALIGNMENT PIN
(DIFFERENT AS SHOWN, OTHERWISE SEE FIG 1)
"N"
C
"Q"
.390 9.91 REF
.375 9.53 REF
PPP-22
.230 5.84
REF
C
.105 2.67
.056 1.42 REF
LC-05-TM
CL
"N" = USE MEASURED DIM
"Q" = {("N" - .375) / 2} .020
FIG 3
-P PICK & PLACE
(5 POSITIONS MINIMUM, SEE NOTE 9)
PROPRIETARY NOTE
FIG 4
-LC OPTION: STAKED LOCKING CLIP
(6 POSITIONS MINIMUM)
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: DEAN P
12/12/2000
SHEET 2 OF 3
REVISION AY
PT-1-24-02-44 & TP-03
-01, -02, -03, -51 & -52 LEAD STYLES
-01-P, -02-P, -03-P,
-51-P & -52-P LEAD STYLES
PT-1-24-09-29 & TP-03
PT-1-24-01-29 & TP-03
-53 & -54 LEAD STYLES
-55, -56 & -57 LEAD STYLES
PT-1-24-05-44 & TP-03
PT-1-24-03-44 & TP-03
-53-P LEAD STYLE
-54-P, -55-P, -56-P & -57-P LEAD STYLES
PACKAGING VIEWS
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: DEAN P
12/12/2000
SHEET 3 OF 3
