REVISION AA
DO NOT
SCALE FROM
THIS PRINT
IPT1-1XX-XX-XX-D-XX
OPTION
(SEE NOTE 11)
-PL: POSITION #1 REMOVED
(USE IPT1-XX-D-P)
(SEE NOTE 12)
-FL: FRICTION LOCK [POS -05 THRU -25]
(USE IPT1-XX-D-FL-X & T-1S64-XX-X)
(ONLY AVAILABLE ON -01 & -03
LEAD STYLES)
No OF POS PER ROW
-02 THRU -25
((No OF POS x .1000 [2.540]) + .0200[0.508])±.010[0.25]
.060 1.52
LEAD STYLE
SEE TABLE 1, SHEET 2
02
CL
.100 2.54 REF
.200 5.08
REF
ROW SPECIFICATION
(SEE NOTE 11)
-D: DOUBLE (USE IPT1-XX-D-XX-X)
01
PLATING SPECIFICATION
SEE NOTE 8
"A"
-S: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-SM: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-L: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
SEE TABLE 1
IPT1-50-D
(SEE NOTE 11)
.250 6.35
REF
.155 3.94
REF
.020 0.51
REF
.085 2.16 C1
"A"
.025 0.64 SQ
REF (TYP)
.100 2.54
FIG 1
SECTION "A"-"A"
(IPT1-125-01-XX-D-XXX SHOWN)
02
T-1S64-06-X
-FL: FRICTION LOCK OPTION
(IPT1-110-01-X-D-FL SHOWN)
NOTES:
19
IPT1-XX-D-P
-PL: POLARIZED OPTION
(IPT1-110-01-X-D-PL SHOWN)
2 MAX SWAY
(TYP)
1. C REPRESENTS A CRITICAL DIMENSION.
2. MAXIMUM ALLOWABLE CUT FLASH: .010[0.25].
3. MINIMUM TERMINAL PUSH OUT FORCE: 2 LBS
4. MAXIMUM VARIATION BETWEEN PIN ROWS: .005[0.13].
5. "END WALLS" AFTER CUTTING SHOULD BE .010+/-.003[0.25+/-0.08].
6. PARTS TO BE TUBE PACKAGED.
7. ALL DIMENSIONS TO BE ABOUT CENTERLINE WITHIN +/-.005[0.13].
8. PRESENCE OF VOIDS IS OPTIONAL AND PATTERN TO WHICH THEY
OCCUR IS VARIABLE.
9. -T PLATING OPTION AVAILABLE FOR EXISTING CUSTOMERS ONLY.
10. NOTE DELETED.
11. STANDARD BODIES CAN BE CUT TO POSITION.
FOR -PL & -FL OPTIONS, BODIES MUST BE MOLDED TO POSITION.
12. FOR EXISTING CUSTOMERS ONLY, -POL CAN BE SUBSTITUED FOR -PL.
13. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING
EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01[0.3]
2
.XXX: .005[0.13]
.XXXX: .0020[0.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: PHOS BRONZE, 510, 3/4 HARD
c:\enterprisevault\DWG\MISC\MKTG\IPT1-1XX-XX-XX-D-XX-MKT.SLDDRW
SHEET SCALE: 1:0.4
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.100 DOUBLE ROW SHROUDED TERMINAL ASSEMBLY
DWG. NO.
IPT1-1XX-XX-XX-D-XX
BY: DEAN P
11-05-2002
SHEET 1 OF 2
REVISION AA
PT-1-24-03-47
"B"
IPT1-XX-D-XX-X
.155 3.94
REF
"B"
(SEE TABLE 1)
HTSW-50-D-LCP
SEE TABLE1
"B"
((No OF POS x .100 [2.54])+-.005
.010
0.13
0.25
"C" C
(SEE TABLE 1)
SECTION "B"-"B"
PT-1-24-02-105
PT-1-24-08-15
PT-1-24-01-103
FIG 2
(IPT1-110-02-XX-D-XXX SHOWN)
-08
-01
-02
PT-1-24-07-51
PT-1-24-01-152
"D"
-06
"D"
PT-1-24-02-47
LEAD STYLE -02 TO -09
LEAD STYLE -01
IN-PROCESS
-03, -04, -05
FIG 3
TUBE VIEWS
-07
PROPRIETARY NOTE
-09
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPT1-1XX-XX-XX-D-XX
BY: DEAN P
11-05-2002
SHEET 2 OF 2
很抱歉,暂时无法提供与“IPT1-115-02-L-D”相匹配的价格&库存,您可以联系我们找货
