346-050-520-802
346-050-520-802
    CARDEDGE 50POS DUAL .125 GREEN
346-050-520-802 数据手册
Contact Dimensions: 520-P.C. Tail .030x.018 (0.76x0.46) - Tail LG. =.175 (4.45) .125 (3.18) Contact Spacing x .250 (6.35) Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 3.785 96.14 3.625 92.08 .370 9.4 Card Slot Accepts .054 [1.37] to .070 [1.78] Thick P.C. Board .600 15.24 .330 8.38 Card Slot .160 4.07 Point of Contact • • • INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE 346/396 SERIES CARD EDGE CONNECTOR PART NUMBER: 346-056-520-202 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 346-ENG-MASTER DATE: APR. 22/09 N.T.S DRAWING NUMBER 346-ENG-MASTER SHEET 1 OF 2 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .120 3.05 .170 4.33 .045(1.14) to .060(1.52) Between Tails .045(1.14) to .060(1.52) Between Tails .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails Contact Code 555 • • • .210 5.33 .260 6.6 .660 16.76 .660 16.76 INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE Contact Code 556 .060 1.52 .200 5.08 Contact Code 558 1 .095 2.41 .245 6.22 .060 1.52 ORIGINAL .150 3.81 .165 4.19 .045(1.14) to .060(1.52) Between Tails .375 9.54 .125(3.18) to .210(5.33) Outside Tails Contact Code 559 Contact Code 560 346/396 SERIES CARD EDGE CONNECTOR CONTACT CODE 555,556,558,559,560 DIMENSIONS EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 346-ENG-MASTER DATE: APR. 22/09 1:1 DRAWING NUMBER 346-ENG-MASTER SHEET 2 OF 2 ISSUE 1
346-050-520-802 价格&库存
很抱歉,暂时无法提供与“346-050-520-802”相匹配的价格&库存,您可以联系我们找货
  • 1+99.111901+12.62320
  • 10+87.8352010+11.18690
  • 25+84.5116025+10.76360
  • 50+81.0948050+10.32850
  • 100+76.57010100+9.75220
  • 250+69.82970250+8.89370
  • 500+65.30500500+8.31740
  • 1000+63.847301000+8.13180
库存:37
346-050-520-802
  • 25+77.4493525+10.01027
