PH5-318/125-185
PH5-318/125-185
    OST
    插件,P=2.54mm
    排针 间距:2.54mm 3x6P 直插
PH5-318/125-185 数据手册
Specifications Pin Header Series: PH Features: Notched for easy separation into desired positions Side to side, end to end stackable. Ratings: Current Contact resistance Insulation resistance Operating temperature 3A 15mΩ 1,000MΩ -40°C / +105°C Material: Plastic Contact PBT Glass-filled, UL94V-0 Phospher Bronze ORDERING PROCEDURE 1 - 2 For thru-hole series: 1) Series 2) Connector side dimension 3) Solder side dimension 4) Positions 5) Plating For surface mount and 2.00mm series: 1) Series 2) Positions 3) Plating / 3 - 4 5 Plating Options: 1 = Full flash gold 5 = Tin 6 = Selective flash gold 7 = Selective 10µ gold* 8 = Selective 30µ gold* * May require minimums Please refer to following pages for ordering examples. On-Shore Technology v1917 W. Third St.Tempe, AZ 85281 vTelephone: 602-921-3000 vFax: 602-968-4444
PH5-318/125-185 价格&库存
很抱歉,暂时无法提供与“PH5-318/125-185”相匹配的价格&库存,您可以联系我们找货
