REVISION AC
FWJ-XX-XX-TX-S-XX
No OF POSITIONS
-01 THRU -23
-24 = SEE FSW-24-156
DO NOT
SCALE FROM
THIS PRINT
OPTION
-RA: RIGHT ANGLE
LEAD STYLE
SEE TABLE 1
BODY SPECIFICATION
USE FSW-24-156
PLATING SPECIFICATION
-T: MATTE IN CONTACT AND TAIL
-TM: MATTE TIN CONTACT AND TAIL
**=NOT RELEASED FOR PRODUCTION.
C1
(NO OF POSITIONS X.156 [3.96]) .010 [.25]
(No OF POS. x .156 [3.96])-.156 [3.96]
.250 6.35
REF
2 MAX SWAY
(EITHER DIRECTION)
C2
"B"
"B" (SEE NOTES 4 & 5)
"L"
.125 3.18 REF
"L"
"E"
-RA
IN-PROCESS VIEW
1. C REPRESENTS A CRITICAL DIMENSION.
2. MIN PUSHOUT FORCE: 3 LBS.
3. MAX ALLOWABLE BOW AFTER ASSEMBLY: .003 [.08] INCH/INCH
4. HEIGHT VARIATION BETWEEN PINS SHALL BE .005 [.13] MAX
5. BANDOLIER AREA TO BE POSITIONED ABOUT OR TOWARDS STANOFF SIDE OF BODY.
ENTIRE BANDOLIER AREA MUST NOT BE LOCATED IN THIS AREA ON LEADSTYLES -01, -02, -03, AND -05.
6. MAX CUT FLASH: .020 [.51]
C3
STANDOFF
"D" REF
(SEE NOTE 5)
NOTES:
"C"
90°±2°
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
1
.XXX: .005 [.13]
.XXXX: .0020 [.051]
PROPRIETARY NOTE
-RA
-02 & -04 ONLY
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
MATERIAL:
INSULATOR: PBT, UL 94 VO
COLOR: BLACK
TERMINAL: PIN STYLES -01 THRU -05: PHOS BRONZE
PIN STYLE -11: CDA 7025
F:\DWG\MISC\MKTG\FWJ-XX-XX-TX-S-XX-MKT.SLDDRW
SHEET SCALE: 1.5:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
.045 SQ POST ASSEMBLY
FWJ-XX-XX-TX-S-XX
BY: DEAN PURVIS 2-19-86
SHEET 1 OF 1
很抱歉,暂时无法提供与“FWJ-03-01-T-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.419011+0.95977
- 50+5.7735950+0.74691
- 100+4.66127100+0.60301
- 500+3.96380500+0.51278
- 1000+3.818141000+0.49394
