REVISION DQ
DO NOT
SCALE FROM
THIS PRINT
TSW-XXX-XX-XXX-X-XX-XXX
OPTION #2
-POLARIZING SPECIFICATION
TERMINAL SPACE SPEC.
XXX INDICATES POS. TO BE OMITTED (SEE FIG 3)
OPTION #1
(SEE ASSEMBLY INSTRUCTIONS)
-BLANK= STRAIGHT
-1=.100[2.54] FILL EVERY POSITION
-RA= RIGHT ANGLE (SEE TABLE 3 & 5, FIG 5)(-RA OPTION WITH -LL OPTION
-2= .200[5.08] FILL EVERY OTHER POS.
STARTING W/ 1ST & ENDING
EQUALS TO -LA OPTION)
W/ LAST POS. IN BODY)
-RE= EXTENDED RIGHT ANGLE (SEE TABLE 3 & 5, FIG 5)(SINGLE ROW ONLY)
-NA= RA OPTION WITH STRAIGHT OPTION BODY(-NA OPTION WITH -LL
BODY LENGTH SPEC.
OPTION IS VALID)
EXPRESSED IN # OF POS
-NE= RE OPTION WITH STRAIGHT OPTION BODY
-1: -01 THRU -50 (-S, -D, -T)
-LC= LOCKING CLIP (USE LTC-01 FOR -S ROW AND
"A" = NO. OF POS. x .100[2.54]
LTC-02 FOR -D ROW)(STYLES 08 THRU 13 & 22 ONLY) (SEE FIG 2)
-2: -02 THRU -25 (-S, -D, -T)
(N/A IN -RA OR -RE OPTION AND/OR LESS THAN 4 POSITIONS)
"A" = NO OF POS. x .200[5.08] - .100[2.54]
(N/A IN -T OR -Q)
-LA= -RA OPTION WITH -LL OPTION (SEE FIG 5)
TERMINAL SPECIFICATION
-LL= LOCKING LEAD (SEE FIG 4)
SEE TABLE 1
(N/A WITH -RE OR -NE OPTION)
(N/A IN SINGLE ROW, 1 OR 2 POSITIONS)
PLATING SPECIFICATION
ROW SPECIFICATION (SEE TABLE 2)
-G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL
-S: SINGLE
-T: MATTE TIN CONTACT AND TAIL
-D: DOUBLE
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL
-T: TRIPLE
-H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL
-Q: TRIPLE ROW, FILL OUTER ROWS ONLY
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL
-F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL
-E: 50µ" EXTRA HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL
(-07, -08, -09, -13, -14, -15, -16, -20, -21 ONLY)
-TL: TIN/LEAD (90/10 +/-5%) CONTACT AND TAIL
(AVAILABLE ONLY ON LEAD STYLES -07, -08 & -09)
-STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10 +/-5%) TAIL
(AVAILABLE ONLY ON LEAD STYLES -07, -08, -10, -15, -16, -17, -21, -23 & -24
THROUGH HOLE ONLY)
-TM: MATTE TIN CONTACT AND TAIL
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL
-LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL
-FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL
-SS: 30µ" STRIPE SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (SEE NOTE 13)
NOTES:
1. C REPRESENTS CRITICAL DIMENSION.
2. MINIMUM TERMINAL PUSHOUT: 3 LBS.
3. MAXIMUM HEIGHT VARIATION: .005[0.13] (-RA TAIL N/A).
4. ASSEMBLE GOLD PLATE END AS SHOWN.
5. STYLE -26: ROUND END TO APPEAR ON BOTTOM.
6. 'C'± .005[0.13]
.008[0.20] FOR STYLE -08, OPTION -LA & -RA ONLY.
7. TOW & SWAY SPEC. OF 2° APPLIES TO ALL
POSITIONS, POST & TAIL, IN ALL DIRECTIONS.
8. ALL DIMENSIONS TO BE ABOUT CL WITHIN ±.005[0.13].
9. MEASURE FROM THE BEND RADIUS OF THE TERMINALS .
10. TSW-50-D BODY CAN BE USED IF RTSW-50-D IS UNAVAILABLE
C 11. ORIENTATE PINS TO PREVENT BANDOLIER MARKS FROM SHOWING
IN THE POST AREA. (SEE TABLE 7)
12. MAXIMUM CUT FLASH: .020[0.50]
13. -SS OPTION ONLY AVAILABLE IN STRAIGHT LEAD STYLES -07, -08 &
-09, -RA STYLE -08 ONLY. CAN ONLY MATE WITH SSW, SSQ, SSM,
ESW, ESQ AND BCS.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01[0.3]
2
.XXX: .005[0.13]
.XXXX: .0020[0.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 3:1
BODIES: DUPONT PBT, UL 94 VO, COLOR: BLACK
TERMINALS: PHOS BRONZE
F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY
DWG. NO.
BY: KOLB
08/24/1988
SHEET 1 OF 6
REVISION DQ
C
SEE TABLE 8
(SEE CALLOUT)
-1XX=.100[2.54]
-2XX=.200[5.08]
2 MAX SWAY
(EITHER DIRECTION)
C "C"±.008[0.20]
(SEE TABLE 1, SHT 6)
(SEE NOTE 3 AND 6)
.100 2.54
.200 5.08
.200 5.08
.200 5.08
REF
.300 7.62
REF
.300 7.62
REF
-D
-T
2 MAX SWAY
(EITHER DIRECTION)
.100 2.54
"L"
(SEE TABLE 4, SHT 5)
.100 2.54
REF
.100 2.54
REF
SEE NOTE 5
2 MAX SWAY
(EITHER DIRECTION)
2 MAX SWAY
(EITHER DIRECTION)
FIG 1
(TSW-1XX-XX-XX-S SHOWN)
-S
-Q
"G" REF
.596 15.15
REF
PROPRIETARY NOTE
"F"
FIG 2
(TSW-1XX-XX-XX-S-LC SHOWN)
(SAME AS FIG 1, DIFFERENT AS SHOWN)
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
08/24/1988
SHEET 2 OF 6
REVISION DQ
50
FIG 3
-1: .100[2.54] TERMINAL SPACING
01
02
01
03
01
01
01
01
03
CL
CL
01
01
02
99
01
SINGLES
100 148
DOUBLES
25
01
150 148
02
03
150
SINGLES
01
03
04
01
DOUBLES
TRIPLES
SINGLES
01
03
EVEN POSITIONS
01
01
50
DOUBLES
SINGLES
01
04
CL
49
TRIPLES
STRAIGHT VERSION
ODD POSITIONS
02
01
DOUBLES
STRAIGHT VERSION
-Q:
(FILL OUTER ROWS ONLY)
TRIPLES
01
73
75
73
75
-Q:
TRIPLES
CL
01
01
SINGLES
DOUBLES
TRIPLES
SINGLES
TRIPLES
RIGHT ANGLE VERSION
RIGHT ANGLE VERSION
-2: .200[5.08] TERMINAL SPACING
DOUBLES
EVEN POSITIONS
ODD POSITIONS
LOCKING LEAD
= CRIMP LOCATION
TWO CENTER MOST PINS TO BE CRIMPED.
ODD POSITIONS, CRIMP CENTER POSITION AND POSITION CLOSEST TO PIN ONE.
IF CRIMP POSITION IS POLARIZED, MOVE ONE POSITION TOWARDS PIN ONE.
FIG 4
LOCKING LEAD
(NOTE: END VIEWS SHOWN)
LTC-01
LTC-02
SEE CRIMP DETAIL
.017 0.43 C
MIN
.04 1.0
SINGLE
-LC-LL
DOUBLE
-LC-LL
SINGLE STRAIGHT
-LL
DOUBLE STRAIGHT
-LL
TRIPLE STRAIGHT
-LL
.0080 0.203 C
(TYP)
CRIMP DETAIL
SCALE: 4:1
(TYP ALL CRIMPS)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
08/24/1988
SHEET 3 OF 6
FIG 5
REVISION DQ
(RIGHT ANGLE)
(-LA OPTION IS SHOWN ON ALL RIGHT ANGLES
FOR DIMENSIONAL AND LOCATION PURPOSES.)
(SEE CRIMP DETAIL VIEW, SHT 3)
PIN #3
PIN #2
PIN #2
PIN #1
PIN #1
PIN #1
.119 3.02
REF
.04 1.0
.219 5.56
REF
.04 1.0
.04 1.0
C 90°
C 90°
C 90°
.320 8.13
REF
.06 1.5
.06 1.5
C .100 2.54
(SEE NOTE 9)
"E" REF
(SEE TABLE 5)
"D"
(SEE TABLE 3)
-S
C .100 2.54
C .200 5.08
(SEE NOTE 9)
"E" REF
(SEE TABLE 5)
"E" REF
(SEE TABLE 5)
-D
-T
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
08/24/1988
SHEET 4 OF 6
REVISION DQ
POST AREA
BANDOLIER (REF)
TAIL AREA
IN PROCESS 1
-T PLATING ONLY
C (SEE NOTE 11)
(SEE TABLE 7)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
08/24/1988
SHEET 5 OF 6
REVISION DQ
.025 0.64 SQ
REF (TYP)
.018 0.46
REF (TYP)
FIG 6
(-26 LEAD STYLE)
(SAME AS FIG. 1, DIFFERENT AS SHOWN)
(1) .230[5.84] POST FOR -RA OR -RE OPTION
(2) OMIT WITH -Q ROW SPECIFICATION
(3) NOT AVAILABLE IN -RA OR -RE OPTION
(4) NOT AVAILABLE IN -RE OPTION
(5) AVAILABLE IN -LL OPTION
(6) AVAILABLE IN -LA OPTION
.005[0.13]
(7) ON STYLE -08 -LA, RA: "C" = .230[5.84]± .008[0.20]
(8) 1.220[30.99] POST FOR STRAIGHT PIN VERSION
* SQUARE END OF PIN (T-1RS7-01-XXX-2 SHOULD BE LOCATED AT "C" DIMENSION DURING FILL PROCESS.
(SEE FIG. 6)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
08/24/1988
SHEET 6 OF 6
