RNF14DTD274R
RNF14DTD274R
    SEI
    AXIAL_D2.35X6.35MM_TM
    插件电阻 - 274Ω ±0.5% 1/4W ±100ppm/℃
RNF14DTD274R 数据手册
RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Features: • • • • • • • • • • Precision metal film Superior electrical, TCR performances Flame-retardant coatings are standard Panasert available selected sizes (contact Stackpole) RNMF (mini) an ideal choice where size constraints apply RNF 5% replaces MP series Lower or higher resistance values may be possible (contact Stackpole) 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Power Maximum Maximum TCR Rating Working Overload Type / Code Mil Ref Voltage (W) Voltage (ppm/ºC) @ 70ºC (Vrms) (1) (Vrms) 0.05% ± 25 RNF18 RN 50 0.125 200 400 100 - 100K ± 50 ± 100 ± 25 RNMF14 0.25 200 400 ± 50 ± 100 ± 10 ± 25 RNF14 RN 55 0.25 250 500 100 - 100K ± 50 ± 100 ± 25 RNMF12 RL 07 0.5 350 600 ± 50 ± 100 ± 25 RNF12 RN 60 0.5 350 700 ± 50 ± 100 ± 25 RNF1 RN 65 1 350 700 ± 50 ± 100 ± 25 RNF2 2 350 800 ± 50 ± 100 (1) Lesser of √ P*R or maximum working voltage Ohmic Range (Ω) and Tolerance 0.1% 0.25% 0.5% 1% 2% 5% 30.1 - 499K 49.9 - 499K 100 - 100K 1 - 1M 10 - 1M 51.1 - 100K 1 - 10M 1 - 22M 30.1 - 499K 30.1 - 499K 100 - 100K 1 - 1M 10 - 1M 1 - 2.15M 1 - 2.2M 100 - 100K 10 - 1M 1 - 2.2M 1 - 5.11M 1.1M - 10M 1 - 10M 5.6 - 10M 1 - 10M 30.1 - 294K 49.9 - 1M 1 - 1M 30.1 - 1M 10 - 1M 1 - 10M 1 - 10M 49.9 - 499K 100 - 100K 1 - 4.99M 10 - 1M 1 - 10M 1 - 10M 10 - 470K 10 - 470K 10 - 1M 1 - 1M 1 - 1M 10 - 1M 10 - 1M 100 - 100K Mechanical Specifications Type / Code RNF18 RNMF14 RNF14 RNMF12 RNF12 A Body Length 0.130 ± 0.012 3.30 ± 0.30 0.130 ± 0.012 3.30 ± 0.30 0.250 ± 0.026 6.35 ± 0.65 0.250 ± 0.026 6.35 ± 0.65 0.344 ± 0.030 8.75 ± 0.75 Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. B Body Diameter 0.071 ± 0.012 1.80 ± 0.30 0.070 ± 0.003 1.78 ± 0.08 0.093 ± 0.010 2.35 ± 0.25 0.093 ± 0.010 2.35 ± 0.25 0.108 ± 0.039 2.75 ± 1.00 1 C Lead Length (Bulk) 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.197 28.00 ± 5.00 D Lead Diameter 0.018 ± 0.003 0.45 ± 0.07 0.017 ± 0.002 0.44 ± 0.05 0.022 ± 0.003 0.56 ± 0.08 0.022 ± 0.003 0.56 ± 0.08 0.026 ± 0.004 0.65 ± 0.10 Unit inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Mechanical Specifications (cont.) Type / Code RNF1 (< 10Ω) RNF1 (≥ 10Ω) RNF2 A Body Length 0.453 ± 0.039 11.50 ± 1.00 0.433 ± 0.039 11.00 ± 1.00 0.591 ± 0.039 15.00 ± 1.00 B Body Diameter 0.177 ± 0.020 4.50 ± 0.50 0.177 ± 0.020 4.50 ± 0.50 0.197 ± 0.020 5.00 ± 0.50 C Lead Length (Bulk) 1.378 ± 0.079 35.00 ± 2.00 1.181 ± 0.118 30.00 ± 3.00 1.339 ± 0.157 34.00 ± 4.00 D Lead Diameter 0.031 ± 0.001 0.78 ± 0.03 0.030 ± 0.002 0.75 ± 0.05 0.028 ± 0.004 0.70 ± 0.10 Unit inches mm inches mm inches mm Performance Characteristics Test Test Method Typical Results Test Limits Insulation Resistance JIS C5201-1, IEC60115-1, 4.6 ≥ 1000M Ω RNF16 / RNMF14: 300 RNF14 / RNMF12: 500 RNF12 / RNF1: 700 < ± 0.1% < ± 0.1% < ± 0.05% < ± 0.15% < ± 0.10% < ± 0.10% ≥ 1000M Ω Voltage Proof / DWV Short Time Overload JIS C5201-1, IEC60115-1, 4.13 Resistance to Solder Heat JIS C5201-1, IEC60115-1, 4.18 Rapid Change of Temperature JIS C5201-1, IEC60115-1, 4.19 Endurance at 70°C JIS C5201-1, IEC60115-1, 4.25.1 Robustness of Terminations JIS C5201-1, IEC60115-1, 4.16 Damp Heat (Steady state) JIS C5201-1, IEC60115-1, 4.24 Operating temperature range is -55ºC to +155ºC ≤ ± (0.5% + 0.05Ω) No mechanical damage ≤ ± (0.25% + 0.05Ω) ≤ ± (0.3% + 0.05Ω) ≤ ± (0.35% + 0.05Ω) ≤± (1.0% + 0.05Ω) ≤ ± (0.2% + 0.05Ω) ≤ ± (1.5% + 0.05Ω) Power Derating Curve: Surface Temperature Rise: Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Repetitive Pulse Information: If repetitive pulses are applied to resistors, pulse wave form must be less than “pulse limiting voltage”, “pulse limiting current” or “pulse limiting wattage” calculated by the formula below. Vp = K√P x R x T/t lp = K√P/R x T/t Pp = K2 x P x T/t Where: Vp: lp: Pp: P: R: T: t: K: [Vr: Note 1: Note 2: Note 3: Note 4: Note 5: Note 6: Pulse limiting voltage (V) Pulse limiting current (A) Pulse limiting wattage (W) Power rating (W) Nominal resistance (ohm) Repetitive period (sec) Pulse duration (sec) RNF / RNMF Coefficient: 0.7 Rated Voltage (V), Ir: Rated Current (A)] If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000 If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp) Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature. If ambient temperature is more than the rated temperature (70 °C), decrease power rating according to “Power Derating Curve” Assure sufficient margin for use period and conditions for “pulse limiting voltage” If the pulse waveform is not square wave, judge after transform the waveform into square wave according to the “Waveform Transformation to Square Wave”. Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Reel Packaging Specifications A max. (1) Series RNF18 RNMF14 RNF14 RNMF12 RNF12 RNF1 RNF2 B max D (2) C Tape Unit 2.756 70.00 2.756 70.00 2.756 70.00 ± ± ± ± ± ± 0.118 3.00 0.118 3.00 0.118 3.00 11.811 300.00 11.811 300.00 11.811 300.00 ± ± ± ± ± ± 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 ± ± ± ± ± ± 0.020 0.50 0.020 0.50 0.020 0.50 2.047 52.00 2.047 52.00 2.047 52.00 ± ± ± ± ± ± 0.020 0.50 0.020 0.50 0.020 0.50 0.250 6.35 0.250 6.35 0.250 6.35 inches mm inches mm inches mm 2.756 70.00 2.756 70.00 ± ± ± ± 0.118 3.00 0.118 3.00 11.811 300.00 11.811 300.00 ± ± ± ± 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 ± ± ± ± 0.020 0.50 0.020 0.50 2.047 52.00 2.047 52.00 ± ± ± ± 0.020 0.50 0.020 0.50 0.250 6.35 0.250 6.35 inches mm inches mm 2.756 70.00 2.756 70.00 ± ± ± ± 0.118 3.00 0.118 3.00 11.811 300.00 11.811 300.00 ± ± ± ± 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 ± ± ± ± 0.020 0.50 0.020 0.50 2.047 52.00 2.047 52.00 ± ± ± ± 0.020 0.50 0.020 0.50 0.250 6.35 0.250 6.35 inches mm inches mm Dimension "E": This is a non-critical dimension that does not have a tolerance in the standard. Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm). (1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component. The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component. (2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code. Ammo Packaging Specifications Type/Code Size A B C Unit inches mm inches mm RNF 16 2.756 ± 0.118 70.00 ± 3.00 RNF 14 3.937 ± 0.118 100.00 ± 3.00 RNF 12 RNF 1 2.953 ± 0.118 75.00 ± 3.00 inches mm RNMF 14 2.756 ± 0.118 70.00 ± 3.00 inches mm RNMF 12 3.937 ± 0.118 100.00 ± 3.00 inches mm 2.953 ± 0.079 75.00 ± 2.00 Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2.756 ± 0.118 70.00 ± 3.00 6 10.039 ± 0.197 255.00 ± 5.00 inches mm www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Pana-Sert Packaging Specifications Symbol Description ØD Body diameter A Body length A0 Mounting height Ød Lead diameter P Component pitch P0 Feed hole pitch P1 Feed hole center to lead P2 Feed hole center to body F Lead-lead distance Alpha Performing angle Δh Component alignment Δg Component alignment W Tape width W0 Hold down tape width W1 Hole position W2 Hold down tape position H Distance to tape center H0 Lead wire clinch height Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 PRNF14 0.102 2.60 0.276 7.00 0.492 12.50 0.020 0.52 0.500 12.70 0.500 12.70 0.152 3.85 0.250 6.35 0.200 5.08 max. max. max. max. max. max. ± 0.002 ± 0.05 ± 0.039 ± 1.00 ± 0.012 ± 0.30 ± 0.020 ± 0.50 ± 0.016 ± 0.40 +0.024 / -0.008 +0.60 / -0.20 45° max. 0.000 0.00 0.000 0.00 0.709 18.00 0.492 12.50 0.354 9.00 0.079 2.00 0.748 19.00 0.630 16.00 ± 0.079 ± 2.00 ± 0.118 ± 3.00 +0.039 / -0.031 +1.00 / -0.80 min. min. ± 0.020 ± 0.50 +0 / -0.059 +0 / -1.5 ± 0.039 ± 1.00 ± 0.020 ± 0.50 www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions Packaging Specifications – Pana-Sert (cont.) Symbol Description PRNF14 I Lead wire portrait ØD0 Feed hole diamenter i Total tape thickness L Length of shipped lead 0.039 1.00 0.157 4.00 0.028 0.70 0.433 11.00 max. max. ± 0.008 ± 0.20 max. max. max. max. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 2). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament. RoHS Compliance Status Standard Product Series RNF RNMF Description General Purpose Metal Film Leaded Resistor General Purpose Mini Metal Film Leaded Resistor Package / Termination Type Standard Series RoHS Compliant Axial YES Axial YES Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 99.3/0.7 Sn/Cu 100% Matte Sn 99.3/0.7 Sn/Cu 100% Matte Sn Apr-05 (Japan) Jan-04 (Taiwan, China) Apr-05 (Japan) Jan-04 (Taiwan, China) Lead-Free Effective Date Code (YY/WW) 05/14 04/01 05/14 04/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 www.seielect.com marketing@seielect.com RNF / RNMF Series Stackpole Electronics, Inc. General Purpose Metal Film Resistor Resistive Product Solutions How to Order 1 2 3 4 5 6 7 8 9 10 11 12 R N F 1 4 F T D 4 K 7 5 Product Series Code Description RNF Standard RNMF Mini Panasert PRNF RoHS Power Rating Code W 18 0.125 14 0.25 12 0.5 1 1 2 2 Tolerance Code Tol Value A 0.05% B 0.1% E96 C 0.25% E24 D 0.5% F 1% G 2% E24 J 5% Code T A B Packaging Size Quantity RNF18, RNF14 5000 RNMF14, RNMF12 Tape and Reel RNF12, RNF1 2500 RNF2 1000 RNF18, RNF14 5000 (*) RNMF14, RNMF12 Ammo RNF12 2000 RNF1, RNF2 1000 RNF18, RNF14, Bulk RNF12, RNF1, RNF2, 1000 RNMF12, RNMF14 Description TCR Resistance Value Code ppm Four characters with T 10 the multiplier used E 25 as the decimal C 50 holder. D 100 10 ohm = 10R0 10.2 K ohm = 10K2 1 M ohm = 1M00 (*) Precision metal film resistors with tolerances
RNF14DTD274R
物料型号: - RNF18 - RNMF14 - RNF14 - RNMF12 - RNF12 - RNF1 - RNF2
器件简介: - 这些是Stackpole Electronics, Inc.提供的通用金属膜电阻器。 - 特点包括精密金属膜、优越的电气性能和温度系数(TCR)、标准的阻燃涂层。 - RNMF系列是尺寸受限时的理想选择。 - RNF5%电阻器可替代MP系列。
引脚分配: - 引脚长度、直径和单位在机械规格表中有详细说明。
参数特性: - 包括功率额定值、最大工作电压、最大过载电压、温度系数(TCR)、欧姆范围和公差等。
功能详解: - 提供了绝缘电阻、电压证明/DWV、短时过载、焊接热抗性、快速温度变化、70°C耐久性、端子的坚固性、湿热(稳态)等性能特性的测试方法和典型结果。
应用信息: - 操作温度范围为-55ºC至+155ºC。 - 提供了功率降额曲线和表面温度升高图表。
封装信息: - 包括机械规格、重复脉冲信息、波形转换为方波、推荐的焊接配置文件、卷轴包装规格、弹药包装规格和Pana-Sert包装规格。
RNF14DTD274R 价格&库存
很抱歉,暂时无法提供与“RNF14DTD274R”相匹配的价格&库存,您可以联系我们找货
RNF14DTD274R
  • 5000+0.158745000+0.02051
