TSW-107-22-T-D-RA
TSW-107-22-T-D-RA
    SAMTEC(申泰)
    弯插,P=2.54mm
    排针 间距:2.54mm 2x7P 弯插
TSW-107-22-T-D-RA 数据手册
REVISION DQ DO NOT SCALE FROM THIS PRINT TSW-XXX-XX-XXX-X-XX-XXX OPTION #2 -POLARIZING SPECIFICATION TERMINAL SPACE SPEC. XXX INDICATES POS. TO BE OMITTED (SEE FIG 3) OPTION #1 (SEE ASSEMBLY INSTRUCTIONS) -BLANK= STRAIGHT -1=.100[2.54] FILL EVERY POSITION -RA= RIGHT ANGLE (SEE TABLE 3 & 5, FIG 5)(-RA OPTION WITH -LL OPTION -2= .200[5.08] FILL EVERY OTHER POS. STARTING W/ 1ST & ENDING EQUALS TO -LA OPTION) W/ LAST POS. IN BODY) -RE= EXTENDED RIGHT ANGLE (SEE TABLE 3 & 5, FIG 5)(SINGLE ROW ONLY) -NA= RA OPTION WITH STRAIGHT OPTION BODY(-NA OPTION WITH -LL BODY LENGTH SPEC. OPTION IS VALID) EXPRESSED IN # OF POS -NE= RE OPTION WITH STRAIGHT OPTION BODY -1: -01 THRU -50 (-S, -D, -T) -LC= LOCKING CLIP (USE LTC-01 FOR -S ROW AND "A" = NO. OF POS. x .100[2.54] LTC-02 FOR -D ROW)(STYLES 08 THRU 13 & 22 ONLY) (SEE FIG 2) -2: -02 THRU -25 (-S, -D, -T) (N/A IN -RA OR -RE OPTION AND/OR LESS THAN 4 POSITIONS) "A" = NO OF POS. x .200[5.08] - .100[2.54] (N/A IN -T OR -Q) -LA= -RA OPTION WITH -LL OPTION (SEE FIG 5) TERMINAL SPECIFICATION -LL= LOCKING LEAD (SEE FIG 4) SEE TABLE 1 (N/A WITH -RE OR -NE OPTION) (N/A IN SINGLE ROW, 1 OR 2 POSITIONS) PLATING SPECIFICATION ROW SPECIFICATION (SEE TABLE 2) -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -S: SINGLE -T: MATTE TIN CONTACT AND TAIL -D: DOUBLE -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -T: TRIPLE -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -Q: TRIPLE ROW, FILL OUTER ROWS ONLY -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -E: 50µ" EXTRA HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL (-07, -08, -09, -13, -14, -15, -16, -20, -21 ONLY) -TL: TIN/LEAD (90/10 +/-5%) CONTACT AND TAIL (AVAILABLE ONLY ON LEAD STYLES -07, -08 & -09) -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10 +/-5%) TAIL (AVAILABLE ONLY ON LEAD STYLES -07, -08, -10, -15, -16, -17, -21, -23 & -24 THROUGH HOLE ONLY) -TM: MATTE TIN CONTACT AND TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -SS: 30µ" STRIPE SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (SEE NOTE 13) NOTES: 1. C REPRESENTS CRITICAL DIMENSION. 2. MINIMUM TERMINAL PUSHOUT: 3 LBS. 3. MAXIMUM HEIGHT VARIATION: .005[0.13] (-RA TAIL N/A). 4. ASSEMBLE GOLD PLATE END AS SHOWN. 5. STYLE -26: ROUND END TO APPEAR ON BOTTOM. 6. 'C'± .005[0.13] .008[0.20] FOR STYLE -08, OPTION -LA & -RA ONLY. 7. TOW & SWAY SPEC. OF 2° APPLIES TO ALL POSITIONS, POST & TAIL, IN ALL DIRECTIONS. 8. ALL DIMENSIONS TO BE ABOUT CL WITHIN ±.005[0.13]. 9. MEASURE FROM THE BEND RADIUS OF THE TERMINALS . 10. TSW-50-D BODY CAN BE USED IF RTSW-50-D IS UNAVAILABLE C 11. ORIENTATE PINS TO PREVENT BANDOLIER MARKS FROM SHOWING IN THE POST AREA. (SEE TABLE 7) 12. MAXIMUM CUT FLASH: .020[0.50] 13. -SS OPTION ONLY AVAILABLE IN STRAIGHT LEAD STYLES -07, -08 & -09, -RA STYLE -08 ONLY. CAN ONLY MATE WITH SSW, SSQ, SSM, ESW, ESQ AND BCS. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 BODIES: DUPONT PBT, UL 94 VO, COLOR: BLACK TERMINALS: PHOS BRONZE F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 1 OF 6 REVISION DQ C SEE TABLE 8 (SEE CALLOUT) -1XX=.100[2.54] -2XX=.200[5.08] 2 MAX SWAY (EITHER DIRECTION) C "C"±.008[0.20] (SEE TABLE 1, SHT 6) (SEE NOTE 3 AND 6) .100 2.54 .200 5.08 .200 5.08 .200 5.08 REF .300 7.62 REF .300 7.62 REF -D -T 2 MAX SWAY (EITHER DIRECTION) .100 2.54 "L" (SEE TABLE 4, SHT 5) .100 2.54 REF .100 2.54 REF SEE NOTE 5 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) FIG 1 (TSW-1XX-XX-XX-S SHOWN) -S -Q "G" REF .596 15.15 REF * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. "F" DO NOT SCALE DRAWING FIG 2 (TSW-1XX-XX-XX-S-LC SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 2 OF 6 REVISION DQ 50 FIG 3 -1: .100[2.54] TERMINAL SPACING (SAME AS FIG 1, DIFFERENT AS SHOWN) 01 02 01 03 01 01 01 01 03 CL CL 01 01 02 99 01 SINGLES 100 148 DOUBLES 25 01 150 148 02 03 150 SINGLES 01 03 04 01 DOUBLES TRIPLES SINGLES 01 03 EVEN POSITIONS 01 01 50 DOUBLES SINGLES 01 04 CL 49 TRIPLES STRAIGHT VERSION ODD POSITIONS 02 01 DOUBLES STRAIGHT VERSION -Q: (FILL OUTER ROWS ONLY) TRIPLES 01 73 75 73 75 -Q: (FILL OUTER ROWS ONLY) TRIPLES CL 01 01 SINGLES DOUBLES TRIPLES SINGLES TRIPLES RIGHT ANGLE VERSION RIGHT ANGLE VERSION -2: .200[5.08] TERMINAL SPACING DOUBLES EVEN POSITIONS ODD POSITIONS LOCKING LEAD = CRIMP LOCATION TWO CENTER MOST PINS TO BE CRIMPED. ODD POSITIONS, CRIMP CENTER POSITION AND POSITION CLOSEST TO PIN ONE. IF CRIMP POSITION IS POLARIZED, MOVE ONE POSITION TOWARDS PIN ONE. FIG 4 LOCKING LEAD (NOTE: END VIEWS SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) LTC-01 LTC-02 SEE CRIMP DETAIL .017 0.43 C MIN .04 1.0 SINGLE -LC-LL DOUBLE -LC-LL SINGLE STRAIGHT -LL DOUBLE STRAIGHT -LL TRIPLE STRAIGHT -LL .0080 0.203 C (TYP) CRIMP DETAIL SCALE: 4:1 (TYP ALL CRIMPS) F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 3 OF 6 FIG 5 REVISION DQ (RIGHT ANGLE) (-LA OPTION IS SHOWN ON ALL RIGHT ANGLES FOR DIMENSIONAL AND LOCATION PURPOSES.) (SEE CRIMP DETAIL VIEW, SHT 3) (SAME AS FIG 1, DIFFERENT AS SHOWN) PIN #3 PIN #2 PIN #2 PIN #1 PIN #1 PIN #1 .119 3.02 REF .04 1.0 .219 5.56 REF .04 1.0 .04 1.0 C 90° C 90° C 90° .320 8.13 REF .06 1.5 .06 1.5 C .100 2.54 (SEE NOTE 9) "E" REF (SEE TABLE 5) "D" (SEE TABLE 3) -S C .100 2.54 C .200 5.08 (SEE NOTE 9) "E" REF (SEE TABLE 5) "E" REF (SEE TABLE 5) -D -T * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 4 OF 6 REVISION DQ POST AREA BANDOLIER (REF) TAIL AREA IN PROCESS 1 (SAME AS FIG 1, DIFFERENT AS SHOWN) -T PLATING ONLY C (SEE NOTE 11) (SEE TABLE 7) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 5 OF 6 REVISION DQ .025 0.64 SQ REF (TYP) .018 0.46 REF (TYP) FIG 6 (-26 LEAD STYLE) (SAME AS FIG. 1, DIFFERENT AS SHOWN) (1) .230[5.84] POST FOR -RA OR -RE OPTION (2) OMIT WITH -Q ROW SPECIFICATION (3) NOT AVAILABLE IN -RA OR -RE OPTION (4) NOT AVAILABLE IN -RE OPTION (5) AVAILABLE IN -LL OPTION (6) AVAILABLE IN -LA OPTION .005[0.13] (7) ON STYLE -08 -LA, RA: "C" = .230[5.84]± .008[0.20] (8) 1.220[30.99] POST FOR STRAIGHT PIN VERSION * SQUARE END OF PIN (T-1RS7-01-XXX-2 SHOULD BE LOCATED AT "C" DIMENSION DURING FILL PROCESS. (SEE FIG. 6) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 6 OF 6
TSW-107-22-T-D-RA
物料型号:TSW-XXX-XX-XXX-X-XX-XXX
器件简介:文档没有提供具体的器件简介,但提到了该器件具有多种配置选项,包括不同的行规格、引脚分配和端子规格。
引脚分配:文档提供了详细的引脚分配表,包括单行(-S)、双行(-D)和三行(-T)配置,以及不同选项下的引脚分配
参数特性:文档列出了多种参数特性,例如端子规格、镀层规格,包括金、锡、选择性金等不同材料的镀层厚度。
功能详解:文档中的功能详解部分详细描述了不同配置选项的功能,例如锁定夹(-LC)、锁定引脚(-LL)、极化规格等。
应用信息:文档没有直接提供应用信息,但从提供的规格和选项可以推断,该器件适用于需要高密度连接和多种配置选项的应用场景。
封装信息:文档提供了封装的物理尺寸和形状信息,包括端子的尺寸和形状,以及不同封装选项的尺寸差异。
TSW-107-22-T-D-RA 价格&库存
很抱歉,暂时无法提供与“TSW-107-22-T-D-RA”相匹配的价格&库存,您可以联系我们找货
