GT800X480A-C903P
GT800X480A-C903P
    NORITAKE
    7"LCDTOUCHSCREEN
GT800X480A-C903P 数据手册
TFT Module GT series GT800X480A-C903P ■ Features SIMPLIFIED DATASHEET   ■ Physical dimension A compact size 800x480xRGB dot TFTLCD with a LED back light and a projected capacitive touch panel. Unit: mm Specifications ■ Electrical Ratings Parameter Power supply voltage Symbol VCC Min. 4.75 Typ. 5.00 Max. 5.25 Unit VDC Condition ■ Electrical Characteristics Ambient temp. = 25deg. C, VCC = 5.0V Symbol Parameter Min. Typ. Max. Unit Condition Input high voltage (UART, I2C, SPI) Input low voltage (UART, I2C, SPI) Output high voltage(UART, I2C, SPI) Output low voltage(UART, I2C, SPI) GPIO High input current GPIO Low input current GPIO High input voltage GPIO Low input voltage GPIO High output voltage GPIO Low output voltage GPIO High output current par port GPIO Low output current par port GPIO High output current total GPIO Low output current total Power Supply Current 1 Power Supply Current 2 Power consumption VsIH VsIL VsOH VsOL IiIH IiIL ViIH ViIL ViOH ViOL IiOHp IiOLp IiOHt IiOLt ICC1 ICC2 Pwr 2.7 0 2.8 0 2.4 0 2.8 0 0 0 0 - 0.7 0.3 3.5 3.5 0.6 0.4 1.0 -200 3.3 0.8 0.4 -1.5 8 -8 30 0.9 0.45 4.5 ■ Optical Specifications Parameter Luminance 400 Nit (Typical) Color Back light RGB 16Bit(R5-G5-B5-I1) color LED Back light V V V V uA uA V V V V mA mA mA mA ADC ADC Watt (UART: RL = 3K ohm) IOH = -200uA IOL = 1.6mA A port is bundle of 8 GPIO. A port is bundle of 8 GPIO. Total of 26 GPIO pins. Total of 26 GPIO pins. Black screen 100%Brightness ■ Connectors CN3: Micro-AB connector CN8: Power connector through holes Pin No. Signal Pin No. Signal 1 Vcc 2 *Test (Factory use) 3 GND CN9: Serial interface and Power through holes Direction Pin No. Signal (UART/ SPI/ I2C) Function Input 1 *RESET/ *RESET/ *RESET Reset Input 2 - /SCK/ SCL Serial Clock 3 RxD/ MOSI/ SDA Data Receive Input/Output Output 4 DTR/ SBUSY/ SBUSY Display Busy Input 5 DSR/ SSEL/ Host Busy Output Data Transmit 6 TxD/ MISO/ Output 7 TRDY/ TRDY/ TRDY Target Ready 8 VCC/ VCC/ VCC Power Supply (5V) 9 GND/ GND/ GND Ground CN10, CN11: General Purpose I/O Please refer to Hardware specification for detailes. Display Power(back light) Off Condition ■Selectable Font Parameter ANK (Alphabet, Numeric, Kana) JIS Kanji +25 degrees celcius Chinise character, Korean 16x16 dot font, outline font Character code ASCII, ont byte code page, JIS X208, Big-5, GB2312-80, KSC5601-87, UTF-8 Black screen 100%Brightness ■ Environmental Specifications Parameter Condition Operating Temperature -20 +70 degrees celsius 50% brightness Storage Temperature -30 +80 degrees celsius Operating Humidity 20 80% R.H. (non-condensing) Vibration (non-operating) 10-55-10Hz, all amplitude 1mm, 30 minutes, X-Y-Z Shock (non-operating) 392m/s2 (40G) 9ms X-Y-Z, 3 times each direction ■ Physical Specifications Parameter Number of Dots 800 x RGB x 480 Display Area 152.4mm x 91.44mm(X x Y) Pixel Pitch (X x Y) 0.19 x 0.19mm (X x Y) Weight Approximately 275g ■ Interface UART, USB 2.0(High & Full speed), SPI, I2C *ANK(Alphabet, Numeric, Kana) All (6x8, 8x16, 12x24, 16x32 dot and Outline font) 16x16, 32x32 dot font, outline font ■ Functions Multi-touch Touch panel sensing. Character Display, Graphic Display, Display Action User definable font, Line, Box draw Define user windows, Vertical and Horizontal scroll I/O port Control, Jumper and memory switch to keep customized settings Macro and Program Macro function. Leaflet contents, and specifitaions and external appearance of products, may change without notice. Please confirm product details in the specification. (C)Copyright NORITAKE ITRON CORP. '16/02
GT800X480A-C903P 价格&库存
很抱歉,暂时无法提供与“GT800X480A-C903P”相匹配的价格&库存,您可以联系我们找货
