PRODUCT FAMILY DATA SHEET
XLamp® XHP70.2 LEDs
PRODUCT DESCRIPTION
FEATURES
TABLE OF CONTENTS
The XLamp XHP70.2 LED is the next • Available in white, configurable to 6 V
Characteristics................................................ 2
generation of Extreme High Power LEDs
Flux Characteristics, EasyWhite® Order
or 12 V by PCB layout
that delivers the lowest system cost • Available in 5-step EasyWhite bins
Codes and Bins............................................... 3
through the best lumen density, reliability
at 3000 K to 5000 K CCT, 3-step
Flux Characteristics, ANSI White Order
and color consistency. Built on Cree LED’s
EasyWhite bins at 2700 K to 5000 K
Codes and Bins............................................... 6
latest high‑power LED technology, the
and 2-step EasyWhite bins at 2700 K to
Relative Spectral Power Distribution............. 9
XHP70.2 LED improves the lumen density,
4000 K CCT
Relative Flux vs. Junction Temperature......... 9
voltage
characteristics,
reliability
and • Available in ANSI white bins at 3000 K
optical performance of the XHP70 LED in
to 7000 K CCT
Electrical Characteristics.............................. 10
Relative Flux vs. Current............................... 11
the same 7.0 mm x 7.0 mm footprint. The • Available in standard, 70-, 80-, and
Relative Chromaticity vs Current.................. 12
new XHP70.2 LED provides an easy drop‑in
Relative Chromaticity vs Temperature......... 13
90‑minimum CRI options
upgrade to achieve higher system LPW • Binned at 85 °C
Typical Spatial Distribution........................... 13
for lighting manufacturers with existing • Maximum drive current: 4800 mA (6 V),
Thermal Design............................................. 14
XHP70 designs, eliminating redesign costs.
Performance Groups - Luminous Flux......... 15
2400 mA (12 V)
Its unparalleled lumen density and longer • Low thermal resistance: 0.3 °C/W
Performance Groups - Chromaticity............ 15
lifetime at higher operating temperatures • Wide viewing angle: 125°
Standard White Chromaticity Regions
also enable new and innovative lighting • Unlimited floor life at
Plotted on the CIE 1931 Curve..................... 19
designs at lower system costs.
Standard Cool White Kits Plotted on ANSI
≤ 30 ºC/85% RH
• Reflow solderable - JEDEC J‑STD‑020C
Standard Chromaticity Regions................... 22
• RoHS and REACH compliant
Standard Warm and Neutral White Kits
• UL recognized component (E349212)
Plotted on ANSI Standard Chromaticity
Regions.......................................................... 23
Bin and Order-Code Format.......................... 24
Reflow Soldering Characteristics................. 25
Notes............................................................. 26
Mechanical Dimensions............................... 28
Electrical Configuration................................ 30
Tape and Reel................................................ 31
Packaging...................................................... 33
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2017-2022 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are
registered trademarks, and the Cree LED logo is a trademark, of Cree LED. UL® and the UL logo are registered trademarks of UL LLC.
CLD-DS170
REV 3
1
XLAMP ® XHP70.2 LED
CHARACTERISTICS
XHP70.2 LEDs are tested and binned in the 12‑V configuration. See the Mechanical Dimensions section on page 28 for pad layout
options.
Characteristics
Thermal resistance, junction to solder point
Unit
Minimum
Typical
°C/W
0.3
degrees
125
Temperature coefficient of voltage (6 V)*
mV/°C
-2.9
Temperature coefficient of voltage (12 V)
mV/°C
-5.8
Viewing angle (FWHM)
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
V
8000
DC forward current (6 V)*
mA
4800
DC forward current (12 V)
mA
2400
Reverse voltage
V
1
Forward voltage (6 V, @ 2100 mA, 85 °C)*
V
5.6
6.1
Forward voltage (12 V, @ 1050 mA, 85 °C)
V
11.2
12.2
LED junction temperature
°C
150
Note:
Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement
application note for more details.
Data for the 6‑V configuration is calculated and for reference only.
CLD-DS170
REV 3
2
XLAMP ® XHP70.2 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS
The following table provides order codes for XLamp XHP70.2 LEDs. For a complete description of how the flux and chromaticity groups
are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 24).
Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA
Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA
Nominal
CCT
CRI
Min
70
5000 K
80
90
70
4500 K
80
90
Typ
Minimum Luminous Flux
2-Step
3-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
P4
1965
2164
P2
1830
2015
N4
1710
1883
P2
1830
2015
N4
1710
1883
N2
1590
1751
XHP70B-00-00000D0HN250G
N2
1590
1751
XHP70B-00-00000D0UN250G
M4
1485
1635
M2
1380
1520
P4
1965
2164
P2
1830
2015
N4
1710
1883
N4
1710
1883
N2
1590
1751
M4
1485
1635
XHP70B-00-00000D0HM445G
N2
1590
1751
XHP70B-00-00000D0UM445G
M4
1485
1635
M2
1380
1520
Group
Order Code
Group
Order Code
5-Step
Group
Order Code
XHP70B-00-00000D0BP450E
50E
XHP70B-00-00000D0BP250E
XHP70B-00-00000D0BN450E
XHP70B-00-00000D0HP250G
50G
50G
XHP70B-00-00000D0HN450G
XHP70B-00-00000D0UM450G
XHP70B-00-00000D0UM250G
XHP70B-00-00000D0BP445E
45E
XHP70B-00-00000D0BP245E
XHP70B-00-00000D0BN445E
XHP70B-00-00000D0HN445G
45G
45G
XHP70B-00-00000D0HN245G
XHP70B-00-00000D0UM245G
XHP70B-00-00000D0UK445G
Notes
Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on
CRI measurements. See the Measurements section (page 26).
XLamp XHP70.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
Flux values @ 25 °C are calculated and for reference only.
CLD-DS170
REV 3
3
XLAMP ® XHP70.2 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - CONTINUED
Nominal
CCT
CRI
Min
70
4000 K
80
90
70
3500 K
80
90
Typ
2-Step
3-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
P4
1965
2164
P2
1830
2015
N4
1710
1883
N4
1710
1883
N2
1590
1751
M4
1485
1635
XHP70B-00-00000D0HM440H
XHP70B-00-00000D0HM440G
M4
1485
1635
XHP70B-00-00000D0UM440H
XHP70B-00-00000D0UM440G
M2
1380
1520
K4
1290
1420
P2
1830
2015
N4
1710
1883
N2
1590
1751
N4
1710
1883
N2
1590
1751
M4
1485
1635
XHP70B-00-00000D0HM435H
XHP70B-00-00000D0HM435G
M4
1485
1635
XHP70B-00-00000D0UM435H
XHP70B-00-00000D0UM435G
M2
1380
1520
K4
1290
1420
Group
Order Code
Group
Order Code
5-Step
Group
Order Code
XHP70B-00-00000D0BP440E
40E
XHP70B-00-00000D0BP240E
XHP70B-00-00000D0BN440E
XHP70B-00-00000D0HN440H
40H
40H
XHP70B-00-00000D0HN240H
XHP70B-00-00000D0UM240H
XHP70B-00-00000D0HN440G
40G
40G
XHP70B-00-00000D0UK440H
XHP70B-00-00000D0HN240G
XHP70B-00-00000D0UM240G
XHP70B-00-00000D0UK440G
XHP70B-00-00000D0BP235E
35E
XHP70B-00-00000D0BN435E
XHP70B-00-00000D0BN235E
XHP70B-00-00000D0HN435H
35H
35H
XHP70B-00-00000D0HN235H
XHP70B-00-00000D0UM235H
XHP70B-00-00000D0UK435H
XHP70B-00-00000D0HN435G
35G
35G
XHP70B-00-00000D0HN235G
XHP70B-00-00000D0UM235G
XHP70B-00-00000D0UK435G
Notes
CLD-DS170
REV 3
4
XLAMP ® XHP70.2 LED
Nominal
CCT
CRI
Min
70
3000 K
Typ
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
P2
1830
2015
N4
1710
1883
N2
1590
1751
N2
1590
1751
M4
1485
1635
XHP70B-00-00000D0HM430H
M2
1380
1520
XHP70B-00-00000D0UM230H
K4
1290
1420
K2
1200
1321
XHP70B-00-00000D0UK230H
XHP70B-00-00000D0UK230G
M4
1485
1635
XHP70B-00-00000D0HM427H
XHP70B-00-00000D0HM427G
M2
1380
1520
XHP70B-00-00000D0HM227H
K4
1290
1420
XHP70B-00-00000D0UK427H
90
K2
1200
1321
J4
1120
1233
Group
Order Code
Group
Order Code
5-Step
Group
Order Code
XHP70B-00-00000D0BP230E
30E
XHP70B-00-00000D0BN430E
XHP70B-00-00000D0BN230E
30H
80
2700 K
3-Step
Group
80
90
2-Step
30H
27H
27H
XHP70B-00-00000D0HN230H
XHP70B-00-00000D0UK430H
XHP70B-00-00000D0UK227H
XHP70B-00-00000D0UJ427H
30G
XHP70B-00-00000D0HN230G
XHP70B-00-00000D0HM430G
XHP70B-00-00000D0UM230G
30G
27G
XHP70B-00-00000D0UK430G
XHP70B-00-00000D0HM227G
XHP70B-00-00000D0UK427G
27G
XHP70B-00-00000D0UK227G
XHP70B-00-00000D0UJ427G
Notes
CLD-DS170
REV 3
5
XLAMP ® XHP70.2 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS
Nominal
CCT
CRI
Min
7000 K
0A, 0B, 0C, 0D,
0R, 0S, 0T, 0U,
1A, 1B, 1C, 1D,
1R, 1S, 1T, 1U
Typ
68
70
80
6500 K
1A, 1B, 1C, 1D
68
70
80
6000 K
1A, 1B, 1C, 1D,
1R, 1S, 1T, 1U,
2A, 2B, 2C, 2D,
2R, 2S, 2T, 2U
70
80
90
68
Group
Flux (lm) Flux (lm)
@ 85 °C @ 25 °C*
Order Code
P2
1830
2015
XHP70B-00-0000-0D00P20DT
N4
1710
1883
XHP70B-00-0000-0D00N40DT
N2
1590
1751
XHP70B-00-0000-0D00N20DT
P2
1830
2015
XHP70B-00-0000-0D0BP20DT
N4
1710
1883
XHP70B-00-0000-0D0BN40DT
N2
1590
1751
XHP70B-00-0000-0D0BN20DT
N2
1590
1751
XHP70B-00-0000-0D0HN20DT
M4
1485
1635
XHP70B-00-0000-0D0HM40DT
P2
1830
2015
XHP70B-00-0000-0D00P20E1
N4
1710
1883
XHP70B-00-0000-0D00N40E1
N2
1590
1751
XHP70B-00-0000-0D00N20E1
P2
1830
2015
XHP70B-00-0000-0D0BP20E1
N4
1710
1883
XHP70B-00-0000-0D0BN40E1
N2
1590
1751
XHP70B-00-0000-0D0BN20E1
N2
1590
1751
XHP70B-00-0000-0D0HN20E1
M4
1485
1635
XHP70B-00-0000-0D0HM40E1
P2
1830
2015
XHP70B-00-0000-0D00P20DV
N4
1710
1883
XHP70B-00-0000-0D00N40DV
P2
1830
2015
XHP70B-00-0000-0D0BP20DV
N4
1710
1883
XHP70B-00-0000-0D0BN40DV
N2
1590
1751
XHP70B-00-0000-0D0HN20DV
M4
1485
1635
XHP70B-00-0000-0D0HM40DV
M4
1485
1635
XHP70B-00-0000-0D0UM40DV
M2
1380
1520
XHP70B-00-0000-0D0UM20DV
Notes
CLD-DS170
REV 3
6
XLAMP ® XHP70.2 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - CONTINUED
Nominal
CCT
CRI
Min
Typ
68
70
5700 K
2A, 2B, 2C, 2D
80
90
70
5000 K
3A, 3B, 3C, 3D
80
90
4500 K
4A, 4B, 4C, 4D
80
90
68
Group
Flux (lm) Flux (lm)
@ 85 °C @ 25 °C*
P4
1965
2164
Order Code
XHP70B-00-0000-0D00P40E2
P2
1830
2015
XHP70B-00-0000-0D00P20E2
N4
1710
1883
XHP70B-00-0000-0D00N40E2
P4
1965
2164
XHP70B-00-0000-0D0BP40E2
P2
1830
2015
XHP70B-00-0000-0D0BP20E2
N4
1710
1883
XHP70B-00-0000-0D0BN40E2
N4
1710
1883
XHP70B-00-0000-0D0HN40E2
N2
1590
1751
XHP70B-00-0000-0D0HN20E2
M4
1485
1635
XHP70B-00-0000-0D0HM40E2
N2
1590
1751
XHP70B-00-0000-0D0UN20E2
M4
1485
1635
XHP70B-00-0000-0D0UM40E2
M2
1380
1520
XHP70B-00-0000-0D0UM20E2
P4
1965
2164
XHP70B-00-0000-0D00P40E3
P2
1830
2015
XHP70B-00-0000-0D00P20E3
N4
1710
1883
XHP70B-00-0000-0D00N40E3
P4
1965
2164
XHP70B-00-0000-0D0BP40E3
P2
1830
2015
XHP70B-00-0000-0D0BP20E3
N4
1710
1883
XHP70B-00-0000-0D0BN40E3
P2
1830
2015
XHP70B-00-0000-0D0HP20E3
N4
1710
1883
XHP70B-00-0000-0D0HN40E3
N2
1590
1751
XHP70B-00-0000-0D0HN20E3
N2
1590
1751
XHP70B-00-0000-0D0UN20E3
M4
1485
1635
XHP70B-00-0000-0D0UM40E3
M2
1380
1520
XHP70B-00-0000-0D0UM20E3
P4
1965
2164
XHP70B-00-0000-0D00P40E4
P2
1830
2015
XHP70B-00-0000-0D00P20E4
N4
1710
1883
XHP70B-00-0000-0D00N40E4
P4
1965
2164
XHP70B-00-0000-0D0BP40E4
P2
1830
2015
XHP70B-00-0000-0D0BP20E4
N4
1710
1883
XHP70B-00-0000-0D0BN40E4
N4
1710
1883
XHP70B-00-0000-0D0HN40E4
N2
1590
1751
XHP70B-00-0000-0D0HN20E4
M4
1485
1635
XHP70B-00-0000-0D0HM40E4
M4
1485
1635
XHP70B-00-0000-0D0UM40E4
M2
1380
1520
XHP70B-00-0000-0D0UM20E4
K4
1290
1420
XHP70B-00-0000-0D0UK40E4
Notes
CLD-DS170
REV 3
7
XLAMP ® XHP70.2 LED
Nominal
CCT
CRI
Min
4000 K
5A, 5B, 5C, 5D
80
90
3500 K
3000 K
6A, 6B, 6C, 6D
7A, 7B, 7C, 7D
70
70
Typ
68
Group
Flux (lm) Flux (lm)
@ 85 °C @ 25 °C*
P4
1965
2164
Order Code
XHP70B-00-0000-0D00P40E5
P2
1830
2015
XHP70B-00-0000-0D00P20E5
N4
1710
1883
XHP70B-00-0000-0D00N40E5
P4
1965
2164
XHP70B-00-0000-0D0BP40E5
P2
1830
2015
XHP70B-00-0000-0D0BP20E5
N4
1710
1883
XHP70B-00-0000-0D0BN40E5
N4
1710
1883
XHP70B-00-0000-0D0HN40E5
N2
1590
1751
XHP70B-00-0000-0D0HN20E5
M4
1485
1635
XHP70B-00-0000-0D0HM40E5
M4
1485
1635
XHP70B-00-0000-0D0UM40E5
M2
1380
1520
XHP70B-00-0000-0D0UM20E5
K4
1290
1420
XHP70B-00-0000-0D0UK40E5
P2
1830
2015
XHP70B-00-0000-0D0BP20E6
N4
1710
1883
XHP70B-00-0000-0D0BN40E6
N2
1590
1751
XHP70B-00-0000-0D0BN20E6
N4
1710
1883
XHP70B-00-0000-0D0BN40E7
N2
1590
1751
XHP70B-00-0000-0D0BN20E7
Notes
CLD-DS170
REV 3
8
XLAMP ® XHP70.2 LED
RELATIVE SPECTRAL POWER DISTRIBUTION
100%
Relative Radiant Power
80%
60%
6500 K, 68 CRI
3000 K, 80 CRI
40%
20%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
RELATIVE FLUX VS. JUNCTION TEMPERATURE
Relative Flux Output vs. Junction Temperature
Reference condition: 6 V, IF = 2100 mA; 12 V, IF = 1050 mA
120%
Relative Luminous Flux
100%
80%
60%
40%
20%
0%
25
50
75
100
125
150
Junction Temperature (ºC)
CLD-DS170
REV 3
9
XLAMP ® XHP70.2 LED
ELECTRICAL CHARACTERISTICS (TJ = 85 °C)
4800
Forward Current (mA)
4000
3200
6V
2400
1600
800
(Tj = 85°C)
5.00
5.25
5.50
5.75
6.00
Forward Voltage (V)
2400
2000
1600
1200
12 V
800
400
10.5
11.0
11.5
12.0
Forward Voltage (V)
CLD-DS170
REV 3
10
XLAMP ® XHP70.2 LED
RELATIVE FLUX VS. CURRENT (TJ = 85 °C)
200%
180%
160%
140%
120%
100%
6V
80%
60%
40%
20%
0%
1600
2400
Relative Intensity vs. Current
(Tj = 85°C)
3200
4000
4800
200%
180%
160%
140%
120%
100%
12 V
80%
60%
40%
20%
0%
800
1200
1600
2000
2400
CLD-DS170
REV 3
11
XLAMP ® XHP70.2 LED
RELATIVE CHROMATICITY VS CURRENT (WARM WHITE)
0.020
0.016
0.012
6V
0.008
0.004
ΔCCx
0.000
ΔCCy
-0.004
-0.008
-0.012
-0.016
-0.020
1600
Relative Chromaticity Vs. Current, WW
2400
3200
4000
4800
Current (mA)
0.020
0.016
0.012
12 V
0.008
0.004
ΔCCx
0.000
ΔCCy
-0.004
-0.008
-0.012
-0.016
-0.020
800
1200
1600
2000
2400
Current (mA)
CLD-DS170
REV 3
12
XLAMP ® XHP70.2 LED
RELATIVE CHROMATICITY VS TEMPERATURE (WARM WHITE)
Relative Chromaticity Vs. Temperature WW
0.020
0.016
0.012
0.008
0.004
0.000
ΔCCx
-0.004
ΔCCy
-0.008
-0.012
-0.016
-0.020
25
50
75
100
125
150
Tj (°C)
TYPICAL SPATIAL
DISTRIBUTION
Typical
Spatial Radiation
Pattern
Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA; 12 V, IF = 1050 mA
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
CLD-DS170
REV 3
13
XLAMP ® XHP70.2 LED
THERMAL DESIGN
The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end
product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life
and optical characteristics.
5000
Maximum Current (mA)
4500
6V
4000
3500
3000
2500
2000
Rj-a = 1°C/W
1500
Rj-a = 2°C/W
1000
Rj-a = 3°C/W
500
Rj-a = 4°C/W
60
80
100
120
140
160
Ambient Temperature (ºC)
Thermal Design
2500
2250
12 V
2000
1750
1500
1250
1000
Rj-a = 1°C/W
750
Rj-a = 2°C/W
500
Rj-a = 3°C/W
250
Rj-a = 4°C/W
60
80
100
120
140
160
CLD-DS170
REV 3
14
XLAMP ® XHP70.2 LED
PERFORMANCE GROUPS - LUMINOUS FLUX (TJ = 85 °C)
XLamp XHP70.2 LEDs are tested for luminous flux and placed into one of the following luminous-flux groups.
Group Code
Maximum Luminous Flux
J4
1120
1200
K2
1200
1290
K4
1290
1380
M2
1380
1485
M4
1485
1590
N2
1590
1710
N4
1710
1830
P2
1830
1965
P4
1965
2100
Q2
2100
2260
PERFORMANCE GROUPS - CHROMATICITY
XLamp XHP70.2 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
40H
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3777
0.3739
0.3797
0.3816
0.3861
0.3855
0.3838
0.3777
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
CLD-DS170
REV 3
15
XLAMP ® XHP70.2 LED
PERFORMANCE GROUPS - CHROMATICITY (CONTINUED)
EasyWhite Color Temperatures – 3-Step Ellipse
Bin Code
CCT
50G
Center Point
Major Axis
Minor Axis
Rotation Angle
x
y
a
b
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
45G
4500
0.3611
0.3658
0.00852
0.00330
61.5
40G
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
EasyWhite Color Temperatures – 5-Step Ellipse
Bin Code
CCT
50E
Center Point
Minor Axis
Rotation Angle
x
y
a
b
5000 K
0.3447
0.3553
0.01400
0.00520
65.0
45E
4500 K
0.3611
0.3658
0.01420
0.00550
61.5
40E
4000 K
0.3818
0.3797
0.01565
0.00670
53.7
35E
3500 K
0.4073
0.3917
0.01545
0.00690
54.0
30E
3000 K
0.4338
0.4030
0.01390
0.00680
53.2
ANSI White Bins
CCT
Major Axis
Bin Code
0A0
0B0
7000 K
0C0
0D0
ANSI White Bins
x
y
0.2950
0.2920
0.2984
0.3133
0.3009
0.3042
0.2920
0.2895
0.2962
0.3220
0.2984
0.3133
0.2984
0.3133
0.2962
0.3220
0.3028
0.3304
0.3048
0.3207
0.2984
0.3048
0.3068
0.3113
0.3009
0.3042
CCT
Bin Code
ANSI White Bins
x
y
0.2970
0.2980
0.3060
0.2950
0.3009
0.3042
0.3037
0.2937
0.3060
0.2895
0.3135
0.2870
0.2937
0.3312
0.2962
0.3220
0.2962
0.3220
0.2937
0.3312
0.3005
0.3415
0.3028
0.3304
0.3133
0.3037
0.3207
0.3009
0.3068
0.3113
0.3093
0.2993
0R0
0S0
7000 K
0T0
0U0
CCT
Bin Code
x
y
0.2880
0.3048
0.3207
0.2970
0.3130
0.3290
0.3144
0.3186
0.3068
0.3113
0.3135
0.3028
0.3304
0.3210
0.3115
0.3391
0.3130
0.3290
0.3048
0.3207
0.3115
0.3391
0.3205
0.3481
0.3213
0.3373
0.3130
0.3290
0.2937
0.3130
0.3290
0.3042
0.3213
0.3373
0.3221
0.3261
0.3144
0.3186
1A0
1B0
7000 K
1C0
1D0
CLD-DS170
REV 3
16
XLAMP ® XHP70.2 LED
ANSI White Bins
CCT
Bin Code
1R0
1S0
7000 K
1T0
1U0
ANSI White Bins
x
y
CCT
0.3068
0.3113
0.3144
0.3186
0.3161
0.3059
0.3093
0.3005
0.3099
0.3509
0.3115
0.3391
0.3028
0.3304
0.3099
0.3509
0.3196
0.3602
0.3205
0.3481
0.3115
0.3144
0.3221
0.3261
0.3231
0.3120
0.3161
0.3059
Bin Code
x
y
0.3215
0.3350
0.3290
0.3417
0.3290
0.3300
0.2993
0.3222
0.3415
0.3207
0.3290
0.3538
0.3290
0.3417
0.3215
0.3350
0.3290
0.3538
0.3376
0.3616
0.3371
0.3490
0.3391
0.3290
0.3186
0.3290
0.3371
0.3490
0.3366
0.3369
0.3290
0.3300
2A0
2B0
6000 K
2C0
2D0
ANSI White Bins
CCT
ANSI White Bins
Bin Code
3A0
3B0
5000 K
3C0
3D0
CCT
Bin Code
x
y
0.3222
0.3243
0.3290
0.3300
0.3290
0.3180
0.3243
0.3231
0.3120
0.3462
0.3196
0.3602
0.3290
0.3690
0.3290
0.3538
0.3207
0.3462
0.3290
0.3690
0.3381
0.3762
0.3376
0.3616
0.3417
0.3290
0.3538
0.3417
0.3290
0.3300
0.3366
0.3369
0.3361
0.3245
0.3290
0.3180
2R0
2S0
6000 K
2T0
2U0
ANSI White Bins
x
y
0.3371
0.3490
0.3451
0.3554
0.3440
0.3427
0.3366
0.3376
0.3463
0.3687
0.3451
0.3554
0.3371
0.3490
0.3463
0.3687
0.3551
0.3760
0.3533
0.3620
0.3451
0.3451
0.3533
0.3620
0.3515
0.3487
0.3440
0.3427
CCT
Bin Code
x
y
0.3530
0.3597
0.3615
0.3659
0.3512
0.3465
0.3369
0.3515
0.3487
0.3616
0.3548
0.3736
0.3641
0.3804
0.3530
0.3597
4A0
4B0
0.3533
0.362
0.3641
0.3804
0.3736
0.3874
0.3702
0.3722
0.3554
0.3615
0.3659
0.3554
0.3615
0.3659
0.3702
0.3722
0.3670
0.3578
0.3590
0.3521
4500 K
4C0
4D0
CLD-DS170
REV 3
17
XLAMP ® XHP70.2 LED
ANSI White Bins
CCT
Bin Code
5A0
5B0
4000 K
5C0
5D0
ANSI White Bins
x
y
0.3670
0.3578
0.3702
0.3722
0.3825
0.3798
0.3783
0.3702
0.3736
0.3874
0.3869
0.3958
0.3825
0.3798
0.3825
0.3798
0.3869
0.3958
0.4006
0.4044
0.3950
0.3783
0.3825
0.3798
0.3950
0.3875
0.3898
0.3716
CCT
Bin Code
ANSI White Bins
x
y
0.3889
0.3690
0.3941
0.3848
0.4080
0.3916
0.3646
0.4017
0.3722
0.3]941
0.3996
0.4015
0.4146
0.4089
0.4080
0.3916
0.4080
0.3916
0.4146
0.4089
0.4299
0.4165
0.3875
0.4221
0.3646
0.4017
0.4080
0.3916
0.4221
0.3984
0.4147
0.3814
6A0
6B0
3500 K
6C0
6D0
CCT
Bin Code
x
y
0.4147
0.3814
0.4221
0.3984
0.4342
0.4028
0.3751
0.4259
0.3853
0.3848
0.4221
0.3984
0.4299
0.4165
0.4430
0.4212
0.4342
0.4028
0.4342
0.4028
0.4430
0.4212
0.4562
0.4260
0.3984
0.4465
0.4071
0.3751
0.4259
0.3853
0.4342
0.4028
0.4465
0.4071
0.4373
0.3893
7A0
7B0
3000 K
7C0
7D0
CLD-DS170
REV 3
18
XLAMP ® XHP70.2 LED
STANDARD WHITE CHROMATICITY REGIONS PLOTTED ON THE CIE 1931 CURVE
ANSI Cool White
0.40
5000 K
0.39
5700 K
0.38
0.37
6500 K
2T
0.36
2S
CCy
8000 K
2B
1S
0.34
0T
0.33
0S
0.32
2C
1T
0.35
0B
0.31
1D
2U
2R
1A
0D
0A
0.30
2A
1B
0C
2D
1C
ANSI
C78.377A
1U
1R
0U
0R
0.29
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.28
0.28
CCx
CLD-DS170
REV 3
19
XLAMP ® XHP70.2 LED
STANDARD WHITE CHROMATICITY REGIONS PLOTTED ON THE CIE 1931 CURVE - CONTINUED
ANSI Neutral White and ANSI Warm White
0.45
0.44
2700 K
3000 K
0.43
0.42
3500 K
0.41
4000 K
6C
0.40
CCy
7C
7B
0.39
5000 K
0.38
4C
0.37
3C
3B
3D
0.35
4B
7D
7A
5C
6D
5B
5700 K
0.36
6B
4500 K
5D
6A
5A
ANSI
C78.377A
4D
4A
3A
0.34
0.50
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.33
CCx
CLD-DS170
REV 3
XLAMP ® XHP70.2 LED
0.44
ANSI C78.377 Quadrangle
0.43
EasyWhite 5-Step
EasyWhite 3-Step
0.42
3500 K
EasyWhite 2-Step
0.41
2700 K
3000 K
4000 K
0.40
4500 K
0.39
5000 K
0.38
CCy
0.37
5700 K
0.36
6500 K
0.35
0.34
8000 K
0.33
0.32
0.31
0.30
0.29
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.28
0.27
0.28
CCx
CLD-DS170
REV 3
21
XLAMP ® XHP70.2 LED
STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS
0.40
5000 K
0.39
0.38
5700 K
0.37
6500 K
2T
0.36
2S
DT
0.35
CCy
8000 K
2B
1S
0T
0.33
0C
0B
0.31
2D
1C
2A
1B
0S
0.32
2C
1T
0.34
1D
2U
1U
0D
0A
ANSI
C78.377A
2R
1A
1R
0U
0.30
0R
0.29
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.28
0.28
CCx
0.40
0.40
5000 K
0.39
0.38
DV
6500 K
0.36
0.36
2C
8000 K
0A
0R
1R
0U
CCx
0.36
0.35
0.34
0.28
0.36
0.35
0.34
0.33
0.32
0.28
0.31
0.28
0.30
ANSI
C78.377A
2R
1U
0R
0.29
0.29
2U
1A
0D
0.30
0.29
0.28
0C
0B
0.31
1R
0U
0.30
0S
0.32
1D
0.33
0A
CCy
1U
3R
2A
1B
0.32
0.31
ANSI
C78.377A
2R
1A
0D
0T
0.33
2U
3A
2D
1C
0.31
0C
0B
1D
2C
2B
1S
0.30
0S
0.32
2A
1B
3B
2S
1T
8000 K
0.34
0.29
0T
0.33
2D
1C
2T
E1
0.35
2B
1S
3S
6500 K
2T
1T
0.34
5700 K
0.37
2S
0.35
CCy
0.38
5700 K
0.37
5000 K
0.39
CCx
0.40
5000 K
0.39
0.38
5700 K
E2
0.37
6500 K
0.36
3B
2S
0.35
CCy
3S
2T
2C
1T
8000 K
0.34
0T
0.33
0S
0.32
0C
0A
3R
2A
2U
1D
ANSI
C78.377A
2R
1A
0D
2D
1C
1B
0B
0.31
3A
2B
1S
1U
1R
0U
0.30
0R
0.29
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.28
0.28
CCx
CLD-DS170
REV 3
22
XLAMP ® XHP70.2 LED
STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS
0.45
0.44
2700 K
3000 K
0.43
E7
0.42
3500 K
4000 K
CCy
0.40
0.39
5000 K
0.38
E4
4B
3C
0.36
3B
3D
0.35
7B
6C
6B
7D
7A
5C
6D
5B
4C
E3
0.37
E5
4500 K
7C
E6
0.41
6A
ANSI
C78.377A
5D
5A
4D
4A
3A
0.34
0.50
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.33
CCx
CLD-DS170
REV 3
23
XLAMP ® XHP70.2 LED
BIN AND ORDER-CODE FORMAT
Bin codes and order codes for XHP70.2 LEDs are configured in the following manner:
Order Code
Bin Code
Series
XHP70B = XHP70.2
Series
XHP70B = XHP70.2
Internal code
Chromaticity group
Minimum luminous flux group
Vf Class
D = 6-V/12-V configurable
Chromaticity group
CRI specification
0 = No minimum CRI
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
SSSSSS-BD-GGGG-HJKLMMNNN
CRI specification
0 = No minimum CRI
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
SSSSSS-E-NNN-MMM-JK-L-PP
Vf Class
Configuration
B = Internal code
D = Reel size
Internal code
Voltage performance group
Luminous flux group
Internal code
CLD-DS170
REV 3
24
XLAMP ® XHP70.2 LED
REFLOW SOLDERING CHARACTERISTICS
In testing, Cree LED has found XLamp XHP70.2 LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a
general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder
paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements.
Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment.
tP
TP
Critical Zone
TL to TP
Temperature
Ramp-up
TL
tS
Tsmax
Tsmin
Ramp-down
ts
Preheat
25
t 25˚C to Peak
Profile Feature
Average Ramp-Up Rate (Tsmax to Tp)
Time
Lead-Free Solder
1.2 °C/second
Preheat: Temperature Min (Tsmin)
120 °C
Preheat: Temperature Max (Tsmax)
170 °C
Preheat: Time (tsmin to tsmax)
65-150 seconds
Time Maintained Above: Temperature (TL)
Time Maintained Above: Time (tL)
217 °C
45-90 seconds
Peak/Classification Temperature (Tp)
235 - 245 °C
Time Within 5 °C of Actual Peak Temperature (tp)
20-40 seconds
Ramp-Down Rate
1 - 6 °C/second
Time 25 °C to Peak Temperature
4 minutes max.
Note: All temperatures refer to the topside of the package, measured on the package body surface.
CLD-DS170
REV 3
25
XLAMP ® XHP70.2 LED
NOTES
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications
only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a
number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products.
Calculated values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp
LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Cree LED did not perform Room Temperature Operating
Life (RTOL) testing on the XHP70.2 LED.
Lumen Maintenance
Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen
maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and
forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive
current affect the LED junction temperature.
Moisture Sensitivity
Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to
soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity.
Once the MBP is opened, XLamp XHP70.2 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life
in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered
LEDs in the original MBP.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
REACH Compliance
REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency
(ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED
representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67)
is also available upon request.
CLD-DS170
REV 3
26
XLAMP ® XHP70.2 LED
NOTES - CONTINUED
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
CLD-DS170
REV 3
27
XLAMP ® XHP70.2 LED
MECHANICAL DIMENSIONS
Thermal vias, if present, are not shown on these drawings.
4
3
All dimensions are ±.13 mm unless
2 otherwise indicated.
47.00
3
7.00
2
0.56
OPTICAL MODEL ORIGIN
0.56
ANODE SIDE
B
7.00
7.00
B
ANODE SIDE
CATHODE SIDE
R3.76
4.34
R3.76
CATHODE SIDE
TOP MODEL
VIEWORIGIN
OPTICAL
SIDE VIEW
Side View
Top View
6.80
5.40
4.00
TOP VIEW
4.34
SIDE VIEW
6.80
5.40
6.80
3.15
3.15
4.00
6.80
A
A
CENTER PAD IS
ELECTRICALLY ISOLATED
SOLDERMASK MAY BE PRESENT
CENTER PAD IS
BOTTOM
VIEW
ELECTRICALLY
ISOLATED
4
4
2610-
BOTTOM3VIEW
Bottom View
2
3
2
CLD-DS170
REV 3
28
XLAMP ® XHP70.2 LED
MECHANICAL DIMENSIONS - CONTINUED
4
3
6
6.80
4
0.70
3
0.70
0.70
6.80
0.70
4.00
0.70
3.15
3.15
3.15
6.80
6.80
0.70
6.80
6.80
B
2
6.80
4.00
3.15
0.70
B
2
6.80
0.70
RECOMMENDED STENCIL OPENING
V PCB FOOTPRINT
0.70
16X
4
RECOMMENDED
6V AND 12V
PCB SOLDER MASK OPENING
Recommended 6‑V & 12‑V
PCB Solder Mask Opening
3
4
0.50
0.80
28X
0.70
16X
0.80
28X
0.31
A
0.55
8X
6.80
B
6.76
0.50
0.55
3.15
8X
6.76
0.70
A
6.80
0.11
0.24
4.00
0.31
0.70
0.83
24X
6.70
6.80
0.41
4X
1
0.41
4X
2
0.83
24X
RECOMMENDED 12V PCB FOOTPRINT
RECOMMEND
Recommended 12‑V PCB Footprint
PCB SOLDER
(Thermal pad is connected to anode and
6.70
cathode and is not electrically isolated)
RECOMMENDED 6V PCB
0.24 FOOTPRINT
0.11
RECOMMENDED 6V PCB FOOTPRINT
Recommended 6‑V PCB Footprint
6.80
(Thermal pad is electrically isolated)
Stencil Openings
2610
2
3
2
A
2610-700001 XHP70B
2
1
CLD-DS170
REV 3
29
POSITIVE A
XLAMP ® XHP70.2 LED
NEGATIVE B
ELECTRICAL CONFIGURATION
12 V
6V
SOLDER PAD LINK
NEGATIVE A
POSITIVE A
NEGATIVE B
POSITIVE B
POSITIVE A
NEGATIVE B
6-V Configuration
12-V Configuration
6V
NEGATIVE A
POSITIVE A
NEGATIVE B
POSITIVE B
CLD-DS170
REV 3
30
XLAMP ® XHP70.2 LED
TAPE AND REEL
All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard.
All dimensions are ±.13 mm unless otherwise indicated.
Po
T
E
Do
Bo
R
P2
W
A
Anode side
F
A
P1
B
D1
"H"
Ko
B-B SECTION
Bo (on a place in the
bottom of the corner
radii)
Ao (on a place in the
radii)
R
"I"
Ao
Item
Dim.
ITEM
Ao
Dim.
7.40
Bo
Ao
7.40 5.40
Ko
4.60
DETAIL"H"
DETAIL"I"
A-A SECTION
Bo
Po
5.40 4.00
Ko
Po
P2
3.35
12.00
4.00
2.00
P1
T
P1
E
0.36 8.00 1.75
ITEM
F
Do
D1
W
R
Dim.
5.50
1.50
1.50
12.00
3deg
P2
F
2.00 7.50
TDo
0.36
1.50
E
D1
1.75
1.50
W
R
16.00
5°
NOTICE
1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard
2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm
2402-M022 XML3
CLD-DS170
REV 3
31
XLAMP ® XHP70.2 LED
TAPE AND REEL - CONTINUED
Feed Direction
END
START
Trailer
Loaded Pockets
Leader
Min. 160 mm empty pockets
sealed with tape
1000 Lamps
Min. 400 mm empty pockets
with min. 100 mm sealed
Feed Direction
Cover Tape
Pocket Tape
13 mm
13”
CLD-DS170
REV 3
32
XLAMP ® XHP70.2 LED
PACKAGING
CLD-DS170
REV 3
33
