RACF Series
Stackpole Electronics, Inc.
Concave Termination Chip Resistor Array
Resistive Product Solutions
Features:
Product will be discontinued - not recommended for new designs
Last time buy December 1, 2020
For more information please see our PDN here
RAVF series of convex arrays is recommended as replacement
Electrical Specifications
Type / Code /
# of Elements /
Circuit Type
Power Rating (W)
(per element)
@ 70ºC
RACF102D
0.063
25
50
RACF104D
0.063
25
50
Maximum Working Maximum Overload
Voltage (V)
Voltage (V)
RACF164D
0.063
50
RACF324D
0.125
200
RACF408M
0.063
25
RACF648N
0.063
50
RACF648R
0.063
50
Note: (1) Lesser of √ P*R or maximum working voltage.
100
400
50
100
100
TCR
(ppm/ºC)
± 650
± 250
± 400
± 200
± 200
± 200
± 200
± 200
± 200
Ohmic Range (Ω) and Tolerance
1%
2%
3 - 9.88
10 - 1M
1 - 9.88
10 - 1M
22 - 1M
5%
10 - 1M
10 - 1M
22 - 1M
22 - 1M
22 - 1M
Performance Characteristics
Test
Test Results (JIS C 5202)
Load Life in Moisture
Temperature cycle
Load Life
Resistance to Soldering heat
Terminal Adhesion
Short Time Overload
± 3%
± 1%
± 3%
± 1%
± 1%
± 2%
Operating Temperature Range:
RACF102D and RACF104D: -55ºC to 155ºC
All other types: -55ºC to 125ºC
Power Derating Curve:
Rev Date: 03/26/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
RACF Series
Schematics
Isolated Circuit - D
Bussed Circuit - M
Bussed Circuit - N
Bussed Circuit - R
Terminations
2 Resistors / 4 Terminations (D)
4 Resistors / 8 Terminations (D)
8 Resistors / 10 Terminations (N/R)
8 Resistors / 10 Terminations (M)
Mechanical Specifications
Type / Code /
# of Elements /
Circuit Type
RACF102D
RACF104D
RACF164D
RACF324D
RACF408M
RACF648N
RACF648R
L
Body Length
0.039
1.00
0.079
2.00
0.126
3.20
0.200
5.08
0.157
4.00
0.252
6.40
0.252
6.40
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
W
Body Width
0.039
1.00
0.039
1.00
0.063
1.60
0.118
3.00
0.083
2.10
0.122
3.10
0.122
3.10
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
H
Body Height
0.012
0.30
0.016
0.40
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.004
0.10
1.000
0.10
0.006
0.15
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
P
Element
Spacing
0.020
0.50
0.020
0.50
0.031
0.80
0.050
1.27
0.031
0.80
0.050
1.27
0.050
1.27
Q
Termination
Width
0.012 ± 0.004
0.30 ± 0.10
0.012 ± 0.004
0.30 ± 0.10
0.016 ± 0.008
0.40 ± 0.20
0.031 ± 0.004
0.80 ± 0.10
0.020 ± 0.008
0.50 ± 0.20
0.028 ± 0.008
0.70 ± 0.20
0.028 ± 0.008
0.70 ± 0.20
D
Bottom
Termination
0.010 ± 0.004
0.25 ± 0.10
0.010 ± 0.004
0.25 ± 0.10
0.016 ± 0.008
0.40 ± 0.20
0.020 ± 0.008
0.50 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
0.020 ± 0.008
0.50 ± 0.20
0.020 ± 0.008
0.50 ± 0.20
A
Top
Termination
0.007 ± 0.004
0.18 ± 0.10
0.006 ± 0.004
0.15 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.022 ± 0.008
0.55 ± 0.20
0.010 ± 0.008
0.25 ± 0.20
0.014 ± 0.006
0.35 ± 0.15
0.014 ± 0.006
0.35 ± 0.15
E
End
Termination
0.012 ± 0.008
0.30 ± 0.20
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Recommended Pad Layout
Type
A
B
P
Q1
Q2
Unit
RACF102D
0.020
0.50
0.079
2.00
0.020
0.50
0.011
0.28
0.009
0.22
inches
mm
2
www.seielect.com
RACF Series
Type
A
B
P
Q1
Q2
Unit
RACF104D
0.020
0.50
0.079
2.00
0.020
0.50
0.011
0.28
0.009
0.22
inches
mm
Type
A
B
P
Q1
Q2
Unit
0.031
0.80
0.087
2.20
0.102
2.60
0.165
4.20
0.031
0.80
0.050
1.27
0.020
0.50
0.028
0.70
0.012
0.30
0.022
0.57
inches
mm
inches
mm
RACF164D
RACF324D
Type
RACF408M
Type
RACF648N / 648R
A
0.039
1.00
B
0.118
3.00
A
0.031
0.80
D
0.039
1.00
B
0.122
3.10
3
E
0.134
3.40
P
0.031
0.80
P
0.050
1.27
Q1
0.020
0.50
Q1
0.028
0.70
Unit
inches
mm
Unit
inches
mm
www.seielect.com
RACF Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Package /
Standard
Termination Series RoHS
Type
Compliant
Description
Thick Film Surface Mount Chip Resistor Array
Concave Terminations
Note (1): RoHS Compliant by means of exemption 7c-I.
RACF
SMD
YES(1)
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
100% Matte Sn over Ni
Jan-04
04/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
R
A
C
F
1
6
4
D
J
T
1
K
Product Series
Concave
RACF
RoHS
Power Rating
Code
W
102D
0.063
104D
0.063
164D
0.063
324D
0.125
408M
0.063
648N
0.063
648R
0.063
Tolerance
Code
Tol
Value
F
1%
E24, E96
G
2%
E24
J
5%
Z
jumper
Code
T
Packaging
Description
Size
102D, 104D
Reel - Paper Tape
164D
324D, 408M
Reel - Plastic Tape
648N, 648R
Quantity
10000
5000
4000
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
1 ohm = 1R00
100 Kohm = 100K
1 Mohm = 1M00
Zero ohm jumper = 0R00
D = Isolated
M, N, R = Bussed
4
www.seielect.com
很抱歉,暂时无法提供与“RACF164DGT100R”相匹配的价格&库存,您可以联系我们找货
